Mosaic Dataset Analyzer: Error 70117
Available with Standard or Advanced license.
Error
The SHAPE field of the mosaic dataset item contains invalid geometry. Mismatched attributes: the Z or M coordinate of a line segment's endpoint does not match the Z or M coordinate of the coincident endpoint on the next segment.
The Z and M coordinates for a line segment must be the same within an entire line. The Z or M coordinates need to match.
Solution
Use the Build Footprints tool to rebuild the footprints.
