Mosaic Dataset Analyzer: Error 70119
Available with Standard or Advanced license.
Error
The SHAPE field of the mosaic dataset item contains invalid geometry. Empty Z values: the geometry has one or more vertex with an empty Z value (for example, NaN).
The Z value for one or more vertices is empty. The Z values needs to be set to a valid value.
Solution
Use the Build Footprints tool to rebuild the footprints.
