Mosaic Dataset Analyzer: Error 70121
Available with Standard or Advanced license.
Error
The SHAPE field of the mosaic dataset item contains invalid geometry. Incorrect ring ordering: the polygon is topologically simple, but its rings may not be oriented correctly (outer rings: clockwise; inner rings: counter-clockwise).
The rings should be oriented in the same direction. The geometry needs to be updated to have correct ring ordering.
Solution
Use the Build Footprints tool to rebuild the footprints.
