Mosaic Dataset Analyzer: Error 70122
Available with Standard or Advanced license.
Error
The SHAPE field of the mosaic dataset item contains invalid geometry. Incorrect segment orientation: individual segments are not consistently oriented. The "to" point of seg i should coincide with the "from" point of seg i+1.
Each segment on a line should have a consistent direction, which is dictated by the to and from attributes. The geometry needs to be updated to ensure correct segment orientation.
Solution
Use the Build Footprints tool to rebuild the footprints.
