Mosaic Dataset Analyzer: Error 70131
Available with the Standard or Advanced license.
Error
The mosaic dataset has an invalid compression method.
The Allowed Compression Methods property of the mosaic dataset is empty. Setting this property will enable you to transmit the compressed mosaicked image when served as an image service.
Solution
Open the Mosaic Dataset Properties window and add a valid compression method for the mosaic dataset.
