Mosaic Dataset Analyzer: Warning 71128
Warning
The default compression method is incompatible with the data type defined for the mosaic dataset.
When your Data Type is thematic, your compression method should not be JPEG, since a lossy compression may lose some pixel values.
Solution
Open the Mosaic Dataset Properties. On the Defaults tab, edit the default method for Allowed Compression Methods to be LZW or NONE.
