Mosaic Dataset Analyzer: Warning 71107
Available with Standard or Advanced license.
Warning
The maximum number of records allowed for transmission is high.
The maximum number of records that are allowed for transmission is set fairly high. This may impact your performance over a network. This property is used to prevent a server from processing too many records when viewing the mosaic dataset as a published image service.
Solution
In the mosaic dataset properties, change the Maximum Number of Records Returned per Request to less than 1000.
