Mosaic Dataset Analyzer: Warning 71110
Available with Standard or Advanced license.
Warning
The maximum allowed mosaic request size is high.
The maximum allowed request size is set fairly high. This may impact the performance of your mosaic dataset by increasing the time it takes to process the mosaicked image.
Solution
In the mosaic dataset default properties, edit the Maximum Size of Request to be less than 20000 rows by 20000 columns.
Generally, your users will be viewing the mosaic dataset on a reasonably sized computer monitor or mobile device; therefore, the default values are acceptable. Large request sizes are generally only needed if the user is printing very large, high-resolution plots. However, by making these numbers too small, no image may display. For example, if you changed the numbers to 10, then the display window could only be 10 pixels in dimension or smaller to display an image.
