Mosaic Dataset Analyzer: Warning 71112
Available with the Standard or Advanced license.
Warning
The default compression quality is set too low.
The default compression type is JPEG with a quality value less than 30. This is a fairly low compression quality, and the imagery may not display well because of compression artifacts.
Solution
In the mosaic dataset default properties, edit the Default Compression Quality to be greater than 30.
