Mosaic Dataset Analyzer: Warning 71127
Available with Standard or Advanced license.
Warning
The default resampling method is incompatible with the data type defined for the mosaic dataset.
When your Data Type is thematic, the default resampling method should be nearest neighbor. Your data may not render as expected if you keep this as your resampling Data Type method.
Solution
On the Mosaic Dataset Properties Defaults tab, edit Default Resampling Method to be nearest neighbor.
