Mosaic Dataset Analyzer: Warning 71130
Available with Standard or Advanced license.
Warning
The image file associated with the cached raster function present in the mosaic dataset item has not been generated.
Raster item cache has been defined on the mosaic dataset item, but the cache image is missing.
Solution
Use the Synchronize Mosaic Dataset tool on your mosaic dataset.
Also, you can use the Repair Mosaic Dataset window to repair the mosaic dataset paths.
