Mosaic Dataset Analyzer: Warning 71144
Available with Standard or Advanced license.
Warning
The data source referenced by this item is broken. The item could not be built by its corresponding raster type.
The source files referenced by the mosaic dataset item are missing or cannot be loaded.
Solution
You can use the Repair Mosaic Dataset window to repair the broken mosaic dataset paths.
If you no longer want the broken items in the mosaic dataset, you can use the Remove Rasters from Mosaic Dataset tool or the Synchronize Mosaic Dataset tool to remove the broken paths.
