Edit the data contributing to a LAS dataset
Available with 3D Analyst license.
You can add or remove data contributing to a LAS dataset. Any number of LAS format files (*.las, *.zlas, and *.laz) and surface constraints can be added or removed from an existing LAS dataset. Adding or removing data provides the ability to update LAS dataset surface data, which is important to make accurate and current surface information available for conducting analysis.
There are two methods for adding or removing LAS related files or surface constraints from a LAS dataset: use either geoprocessing tools or the LAS Dataset Properties dialog box from the Catalog pane.
LAS dataset surface updates can come in different forms:
  • Adding ancillary data (for example, breaklines)
  • Removing or replacing bad lidar data
  • Increasing extent with additional data
  • Using newer or more accurate data
  • Inserting design/modeled data to perform what-if analyses
The following geoprocessing tools are available to add or remove LAS related files or surface constraints. These tools can be found on the Data tab, in the Management group.
Geoprocessing tools
Add Files To LAS Dataset tool
Adds lidar LAS files and/or surface constraint features to an existing LAS dataset
Remove Files From LAS Dataset tool
Removes reference of one or more lidar LAS files and/or surface constraints from an LAS dataset
The Catalog pane provides access to the LAS Dataset Properties dialog box to add or remove LAS related files or surface constraints interactively. Click either the LAS Files or Surface Constraints tab on the LAS Dataset Properties dialog box to add or remove data.
