Linear referencing sample applications
Most applications that use linear features can benefit from linear referencing. Example applications are outlined in the sections below.
Highways and streets
Agencies that manage highways and streets use linear referencing in a variety of ways in their day-to-day operations. For example, linear referencing is useful for the following:
Assess pavement conditions.
Maintain, manage, and value assets (such as traffic signs and signals, guard rails, toll booths, and loop detectors).
Organize bridge management information.
Review and coordinate construction projects.
Linear referencing can also be used for creating a common database that traffic planners, traffic engineers, and public works analysts can use for cross-disciplinary decision support.
Transit
Linear referencing is a key component in transit applications such as the following:
Route planning and analysis
Automatic vehicle location and tracking
Bus stop and facility inventory
Rail system facility management
Track, power, communications, and signal maintenance
Accident reporting and analysis
Demographic analysis and route restructuring
Ridership analysis and reporting
Transportation planning and modeling
Railways
Railways use linear referencing to manage information for rail operations, maintenance, asset management, and decision support systems. Linear referencing makes it possible, for example, to select a line and track and identify milepost locations for bridges and other obstructions that would prevent various types of freight movement along the route. Linear referencing can also be used to display track characteristics or view digital images of bridges and obstructions.
Oil and gas exploration
The petroleum industry manages tremendous volumes of data used in geophysical exploration. Seismic surveys, or shotpoint data, are used to help understand the underlying geology in an area. Seismic data must be represented as both a linear object (the seismic line) and a collection of point objects (the shotpoints). Both the seismic line and the individual shotpoints have attributes that must be maintained simultaneously and are used in modeling applications. Linear referencing helps with all of this.
Pipelines
In the pipeline industry, linear referencing is often referred to as stationing. Stationing allows any point along a pipeline to be uniquely identified. Stationing is useful for the following:
Collecting and storing information regarding pipeline facilities
Inline and physical inspection histories
Regulatory compliance information
Risk assessment studies
Work history events
Geographic information, such as environmentally sensitive areas, political boundaries (for example, state and county), right-of-way boundaries, and various types of crossings
Water resources
In hydrology applications, linear referencing is often called river addressing. River addressing allows objects such as field monitoring stations—which collect information about water quality analysis, toxic release inventories, drinking water supplies, flow, and so on—to be located along a river or stream system. The measurement scheme used in river addressing allows the measurement of flow distance between any two points on a flow path.
