Load routes into an existing LRS Network
Available with the Linear Referencing license.
Use the Append Routes tool to load routes from an input polyline into an existing LRS Network. Use the Generate Routes tool to regenerate route shapes and apply calibration changes.
Append routes to an LRS Network
Use the Append Routes tool to load routes into an LRS Network.
The Append Routes tool creates centerline features in the centerline feature class and routes in the target LRS Network.
Generate routes in an LRS Network
Use the Generate Routes tool to regenerate shapes and apply calibration changes for route features.
To generate derived network routes, run the Generate Routes tool using the line network as the Input Route Features parameter value.
If a derived network is configured, running the Generate Routes tool on the line network also updates the derived network.
The Generate Routes tool also determines route calibration changes so event behaviors can be processed. Calibration changes can occur when you add, edit, or delete calibration points outside the Linear Referencing tools in ArcGIS Pro.
