View calibration point properties
Available with the Linear Referencing license.
You can view the properties of a calibration point as either a map layer or a feature class.
Calibration point properties
The following sections describe the calibration point properties.
Name
The Calibration Point Name property appears at the top of the Linear Referencing tab.
Property Description
Calibration Point Name The name of the calibration point feature class.
Fields
You can view the following Fields properties for the calibration point feature class:
Measure The field that represents the calibration point measure.
From Date The date the calibration point became active.
To Date The date the calibration point became inactive.
Route ID The unique ID of the route with which the calibration point is associated.
Network ID The unique ID of the network in which the calibration point (and route) are placed.
View calibration point properties by map layer
To view the properties of a calibration point map layer from the Contents pane, complete the following steps:
  1. Open the Contents pane in ArcGIS Pro.
  2. Right-click the calibration point layer, and click Properties.
    The Layer Properties dialog box appears with the selected calibration point layer name in the title bar.
    The tabs on the dialog box are specific to the selected layer type.
  3. Click the Linear Referencing tab.
    Scroll down if the tab isn't visible in the list.
    The Linear Referencing tab displays general properties for the selected layer at the top, with additional nodes below.
  4. Click the arrow for a node to expand or collapse its properties.
    If the value or field name is longer than the field, hover over the property to view its details, or resize the dialog box to view additional details.
    Tip:
    You can copy the read-only properties to the clipboard.
  5. Click OK to close the Layer Properties dialog box.
View calibration point properties by feature class
To view the properties of a calibration point feature class from the Catalog pane, complete the following steps:
  1. Open the Catalog pane in ArcGIS Pro.
  2. Expand the geodatabase connection and the feature dataset to browse to the feature class.
  3. Right-click the calibration point feature class, and click Properties.
    The Feature Class Properties dialog box appears with the selected feature class name in the title bar.
  4. Click the Linear Referencing tab.
    The Linear Referencing tab displays general properties for the selected feature class at the top, with additional nodes below.
  5. Click the arrow for a node to expand or collapse its properties.
    Tip:
  6. Click OK to close the Feature Class Properties dialog box.
