View centerline sequence table properties
Available with the Linear Referencing license.
You can view the properties of a centerline sequence table as either a stand-alone table or a geodatabase table.
Centerline sequence table properties
The following sections describe the centerline sequence table properties.
Name
The Name property appears at the top of the Linear Referencing tab.
| Property | Description |
| Name | The name of the centerline sequence table. |
Fields
You can view the following Fields properties for the centerline sequence table:
| Centerline ID | The unique ID of the centerline. |
| Route ID | The unique ID of the route associated with the centerline. |
| From Date | The date the centerline became active. |
| To Date | The date the centerline became inactive. This can be null. |
| Network ID | The unique ID of the network associated with the centerline. |
View the properties of a centerline sequence table as a stand-alone table
To view the properties of a stand-alone centerline sequence table from the Contents pane, complete the following steps:
Open the Contents pane in ArcGIS Pro.
Right-click the stand-alone centerline sequence table, and click Properties.
The Standalone Table Properties dialog box appears with the table name in the title bar.
The tabs on the dialog box are specific to the selected layer type.
Click the Linear Referencing tab.
Scroll down if the tab isn't visible in the list.
The Linear Referencing tab displays general properties for the selected table at the top, with additional nodes below.
Click the arrow for a node to expand or collapse its properties.
If the value or field name is longer than the field, hover over the property to view its details, or resize the dialog box to view additional details.
Tip:
You can copy the read-only properties to the clipboard.
Click OK to close the Standalone Table Properties dialog box.
View the properties of a centerline sequence table as a geodatabase table
To view the properties of a centerline sequence table from the Catalog pane, complete the following steps:
Open the Catalog pane in ArcGIS Pro.
Expand the geodatabase connection to browse to the centerline sequence table.
Right-click the centerline sequence table in the Catalog pane, and click Properties.
The Table Properties dialog box appears with the table name in the title bar.
Tip:
Click OK to close the Table Properties dialog box.
