Select related parcel features
Use the Parcel Features command in the Selection group on the Parcel Record Workflows tab to select the related points and lines of a selection of parcels.
This command is useful for selecting parcel points and parcel lines for editing operations and for geoprocessing tool inputs.
To select the related points and lines of parcels, first use the Select tool to select the parcels. Parcels are selected by selecting the parcel polygons. Click the Parcel Features command to select the related points and lines. The parcel polygons remain selected.
The number of selected parcels must be 1000 or less. To select more parcels, use the Select Parcel Features geoprocessing tool.
Points
Only points related to the parcel will be selected. Related points are points that are on the endpoints of lines that define the parcel. If the parcel has a polyline boundary, points at inflections in the polyline will be selected. If a point sits on a related parcel line but is an endpoint of an unrelated parcel line, the point will not be selected.
Historic parcels
If historic parcel polygons are selected the Parcel Features command will select related historic lines and points. Current parcel lines and points that bound the parcel will be selected if no historic bounding lines and points are found.
