Introduction to ArcGIS StreetMap Premium
ArcGIS StreetMap Premium allows you to display, geocode, route, and deploy commercial street data on-premises, behind your firewall. ArcGIS StreetMap Premium data is available in two formats: mobile map package (.mmpk) and file geodatabase (.gdb). The mobile map package includes a vector tile package (.vtpk) for mapping, a network dataset for routing, and locators for geocoding and place finding for use in ArcGIS Pro, ArcGIS Enterprise, ArcGIS Navigator, or ArcGIS Maps SDKs for Native Apps. The mobile map package is available in either GCS_WGS_1984 uncompressed or WGS84 Web Mercator (Auxiliary Sphere) compressed formats.
The GCS_WGS_1984 uncompressed format is optimized for routing in ArcGIS Pro and routing services in ArcGIS Enterprise. The network dataset is uncompressed for users who require more performant network analysis; the trade-off is a larger dataset due to the data not being compressed. ArcGIS Navigator and ArcGIS Maps SDKs for Native Apps users should use the WGS84 Web Mercator (Auxiliary Sphere) compressed format.
In addition, there are file geodatabases (.gdb) containing the mapping layers and network dataset for routing. There is also a separate, orderable ArcGIS StreetMap Premium Custom Roads product that allows organizations to combine their own street data with the StreetMap Premium streets for a single continuous, routable transportation network. A StreetMap Premium subscription includes regular data updates to ensure the most accurate visualization, geocoding, and routing possible.
ArcGIS StreetMap Premium is a subscription data product that requires annual renewal. You cannot use the product or services created from the product after the time-out date. See the license expiration FAQ for more information.
ArcGIS StreetMap Premium provides an enriched street dataset that works with ArcGIS Pro to provide a high-quality, high-performance map display and support for geocoding and routing. StreetMap Premium is a ready-to-use solution, helps you achieve optimal geocoding match rates, and generates the best possible routes and driving directions using the included historical traffic information or an optional live traffic feed. For details about the data quality and geographic coverage available, see the mobile map package coverage map or file geodatabase coverage map on the ArcGIS StreetMap Premium website.
StreetMap Premium map data
For information about technical restrictions for ArcGIS StreetMap Premium data, see Technical restrictions for ArcGIS StreetMap Premium on the ArcGIS StreetMap Premium website. For licensing requirements, see StreetMap Premium Licensing Requirements on the ArcGIS StreetMap Premium website.
