Clear trace components
Components of a trace include starting points, barriers, and trace results. On the Utility Network tab, in the Tools group, the Trace command provides additional options that include the Clear All command
. This command can be used to clear all trace locations placed interactively using the Trace pane as well as the currently selected named trace configuration on the Named Configuration tab. Where applicable, any values configured for the aggregated geometry result type of a named trace configuration on the tab will also be cleared. Use the Clear tool to remove trace results from the map.
Clear starting points
To clear starting points, complete the following steps:
On the Utility Network tab, in the Tools group, click the Trace command to open the Trace pane.
In the Trace pane, ensure that the Start tab is active.
In the list of starting points, click the delete button
next to the starting point you want to remove.Click Apply.
To clear all starting points, click Clear All
under the list of starting points.
The specified starting points are removed from the active map.
Clear barriers
To clear barriers, complete the following steps:
In the Trace pane, ensure that the Barriers tab is active.
In the list of barriers, click the delete button
next to the barrier you want to remove.Click Apply.
To clear all barriers, click Clear All
under the list of barriers.
The specified barriers are removed from the active map.
Clear the results of a trace
Trace results can be displayed as selections in a map view.
To clear trace result selections, complete the following steps:
Select the map view to activate the Map tab.
In the Selection group of the Map tab, click Clear
All trace selection results are removed from the active map.
