Buffer (Polygon)
The Buffer builder
generates a polygon feature at a specified distance around a sketched primary polygon feature.
This builder is available to feature templates that create polygon features when a group template is configured with the following settings:
The primary template creates polygon features.
The group template toolset on the Tools side tab is set to Polygon tools.
Parameters
Parameter |
Explanation |
Setting type |
Distance |
The distance around the primary polygon feature at which the boundary for the new polygon is created. Null geometry is generated when you specify a distance of zero.
Optional |
