Buffer (Line)
The Buffer builder generates a polygon feature at a specified distance around a sketched line feature.
This builder is available to feature templates that create polygon features when a group template is configured with the following settings:
  • The primary template creates line features.
  • The group template toolset on the Tools side tab is set to Line tools.
Parameters
Parameter
Explanation
Setting type
Distance
The distance around the primary line feature at which the boundary for the new polygon is created. Null geometry is generated when you specify a distance of zero.
  • Distance—Distance is specified in units selected from a drop-down list.
Optional
Parameters for Buffer
