Set annotation editing options
Application options for annotation include default settings for tools that create or modify annotation features such as the Annotation editing tool
and the Follow Feature construction tool
Rotate and resize options
In the Annotation Editing section, the rotate and resize options customize the default settings for the Rotate and Resize toggle buttons available with the Annotation tool
in the Modify Features pane.
To change the default settings, complete the following steps:
Click the ribbon Edit tab and click the Options dialog box launcher
in the Manage Edits group.The Options dialog box appears.
Click the Editing side tab and expand Annotation.
In the Annotation Editing section, check or uncheck the Enable rotate and Enable resize check boxes.
Checked
Activate and show the enabled cursor command when hovering near a control point or selection boundary.
Unchecked
Don’t show or activate the cursor command.
To reset Annotation Editing options to the default settings, click Reset
.Click OK.
Your settings are saved and the dialog box closes.
Follow feature options
In the Follow Feature section, follow feature options customize the default settings for tools that create or modify follow feature annotation such as the Annotation editing tool
in the Manage Edits group.Tip:
When you create annotation features with the Follow Feature construction tool
, or modify annotation with the Annotation editing tool
, you can right-click the map and choose Follow Feature Options
or press O to change these settings.The Options dialog box appears.
In the Feature Linked Annotation section, check one or more of the following check boxes to automatically follow linked features and use placement properties defined by the annotation feature class.
Automatically follow linked line features
Feature-linked annotation automatically follows the contours of its related line features. This is turned on by default.
Automatically follow linked polygon features
Feature-linked annotation automatically follows the contours of its related polygon features.
Use placement properties defined in the annotation class
To see which relationship class is associated with an annotation feature class, right-click the feature class in the Catalog pane, click Properties
, and click Relationships.In the Make Annotation section, choose how annotation is aligned.
Parallel
Create straight annotation that is aligned parallel to the feature. As you create new annotation, you can switch this to perpendicular on the toolbar.
Perpendicular
Create straight annotation that is aligned perpendicular to the feature.
Curved
Create curved annotation that follows the contours of the feature.
This setting disables Parallel/Perpendicular
, which appears on the toolbar.In the Constrain Placement section, choose how annotation is constrained by the feature it is following.
Side cursor is on
Dynamically constrain annotation to follow the pointer as you hover to either side of a segment.
This setting disables Left/Right
, which appears on the toolbar.Left
Constrain annotation to the left side of the feature, based on the direction of the segment.
Right
Constrain annotation to the right side of the feature, based on the direction of the segment.
On Line
Constrain annotation centered on the feature segment.
, which appears on the toolbar.To reset Follow Feature options to the default settings, click Reset
.Click OK.
