Copy editing templates
The Copy Templates command copies editing templates from a source map to a destination map. This command is available when you right-click a map in the Manage Templates pane.
When you copy editing templates, consider the following:
  • You can choose to replace or skip existing templates in the destination map that have matching names.
  • Editing templates with unique names in the source map are copied to matching layers and group layers in the destination map.
  • Editing templates with broken data sources are not copied.
Tip:
To copy templates between layers in the Contents pane, consider using the Copy and Paste Properties commands on the ribbon Edit tab. This method deletes existing templates in the target layer and replaces them with templates from the source layer.
To learn more, see Copy and paste properties between layers or tables.
To copy editing templates, complete the following steps:
  1. On the ribbon Edit tab, click Manage Templates in the Manage Edits group.
    The Manage Templates pane appears.
  2. In the layers view, right-click the map containing the source templates and click Copy Templates .
    The Copy Templates dialog box appears.
  3. Click the Choose the target map drop-down arrow and choose the destination map.
    The source editing templates to be copied appear in the Layer Matching view.
  4. If duplicate template names exist between the source and destination maps, choose one of the following options in the Handle duplicate templates section.
    • Skip—Copy editing templates with unique names to the destination map, and do not replace templates with matching names.
    • Overwrite in Target—Copy editing templates with unique names to the destination map, and replace templates with matching names.
    These options are not available if duplicate template names don't exist.
  5. Review the editing templates to be copied in the Layer Matching view.
    Layers in the source map that do not have editing templates do not appear in this view.
  6. Click Copy to copy the editing templates from the source map to the destination map.
    Caution:
    If you click Cancel, also click Undo on the Quick Access Toolbar immediately following cancelling this command to ensure that all changes are undone.
