Create segments by tracing other features
In the Create Features pane, the Trace tool
creates continuous segments that follow the geometry of other features on layers with snapping turned on. This tool is available with line and polygon feature templates, and on the construction toolbar when you create line segments.
When you create z-enabled polyline or polygon features, vertices are assigned z-values based on the current z-coordinate elevation setting. For steps to specify z-values, see Specify an elevation for 3D features.
Trace
In the Catalog pane, do one of the following to add the layer to your map:
Expand Databases
, expand the database containing your data, and drag the feature class onto the map.Right-click the default database and create a new polyline or polygon feature class.
Dragging or creating a feature class adds the layer to the current map and creates a feature template with default settings.
Turn snapping off by layer for the features you do not want to trace. This can improve draw performance significantly.
On the View tab, in the Windows group, click Contents
.Click List by Snapping
.Uncheck the check box next to the layer name to disable snapping, or right-click and click Make this the only snappable layer
On the Edit tab, in the Snapping group, enable your snapping preferences.
Tip:
As you sketch the feature, you can press and hold the Spacebar to temporarily turn off snapping.
On the Edit tab, in the Features group, click Create
.The Create Features pane appears.
In the pane, click a polyline feature template.
The construction toolbar appears at the bottom of the map.
Next to the tool palette, click the Active template button
.The tool palette and the feature attribute table for the template appear in the pane.
In the attribute table, type the values you want to apply to the new feature.
- For group templates, click a template icon to display its attribute table.
Click Trace
.Click the feature you want to trace and create the first vertex.
The first vertex is created and a dashed line appears along the feature as you drag the pointer.
Tip:
Press the T key to show the vertices of the feature you are tracing.
Drag the pointer along the feature or features you want to trace.
- To temporarily turn snapping off as you create the polygon, press the Spacebar.
To complete the trace, click the map.
To finish the feature, right-click and click Finish
or press the F2 key.
Keyboard shortcuts
Keyboard shortcut |
Action |
Comment |
O |
View the options. |
Open the Options dialog box. |
Tab |
Set a negative offset. |
Switch the side of the offset and trace the other side of an edge. |
Ctrl and drag |
Trace selected features. |
Trace only selected features. If Trace selected features is turned on, you can trace selected features and unselect features. |
Trace with an offset
Use the Trace with an offset option to create segments at a specified offset. For example, you can click a water main feature template, set an offset of 7 meters, and trace along a parcel boundary to create water mains that run parallel to the parcel boundary at a constant offset.
Click Trace
.Right-click the map, and click Trace Options.
The Trace Options dialog box appears.
Check the Trace with an offset check box.
Click the Units drop-down arrow, set the format, and type the offset distance in the text box.
Click OK.
Your settings are saved and the dialog box closes.
Trace the existing feature or features.
Tip:
Press the Tab key to toggle the offset to the opposite side of the feature.
Corners
Use the Corners option to control the shape of corners.
Click Trace
Click one of the following settings:
Mitered
Beveled
Rounded
Click OK.
Trace the features.
Remove self-intersecting loops
Use the Remove self-intersecting loops option to prevent self-intersecting loops from occurring when Trace with an offset is set to a large offset distance.
Click Trace
Check the Remove self-intersecting loops check box.
Click OK.
Trace the new feature.
Limit trace length
Use the Limit trace length option to limit the length of traced segments to a distance you specify.
Click Trace
Check the Limit trace length check box.
Type the distance and set the Units format.
Click OK.
Trace the features.
Trace selected features only
Use the Trace selected features only option to limit tracing to only the features you select in the map.
On the Edits tab, in the Selection group, click a selection tool and select the features you want to trace.
Click Trace
Check the Trace selected features only check box.
Click OK.
Trace the selected features.
