Direction, distance, and elevation commands
Direction, distance, and elevation commands specify x-, y-, and z-coordinate values for the current feature segment you are actively sketching. They are available as individual commands that operate with the active construction tool.
Command |
Description |
Constrains the current segment to the specified direction value. Pitch in the z-direction can be specified when the feature is z-aware. To complete the segment, specify a distance. Note:This tool is Ground to Grid and COGO aware. |
Constrains the current segment to the specified distance. To complete the segment, specify a direction. |
Creates a vertex at the specified horizontal direction and distance measured from the last vertex. Pitch in the z-direction can be specified when the feature is z-aware. Note:This tool is Ground to Grid and COGO aware. |
Constrains the current segment to the specified angle measured from the last segment. To complete the segment, specify a distance. |
Constrains the current segment to a specified angle measured from an existing right-clicked feature segment. |
Creates a vertex or a point feature at the specified x- and y-coordinate location. A z-value can be specified when the feature is z-aware. |
Creates a vertex at the specified x- and y-coordinate location measured from the last vertex. A z-value can be specified when the feature is z-aware. |
Constant |
Specifies a constant z-value when sketching z-aware features. In a 3D scene, click the active view to autofill this value. |
Specifies a z-value from a clicked elevation surface in the map. This is available only with maps containing one or more elevation surfaces. |
