Turn snapping on or off by layer
The List By Snapping tab
in the Contents pane includes check boxes that turn snapping on or off by layer. When you add a layer to a map or scene, it is automatically enabled as snappable. Layers with snapping disabled remain visible but undetectable by your active snap agents.
Layer snapping by layer operates independent of the pointer snap settings. If the scale or complexity of your feature data is causing unwanted snapping, turning off snapping by layer can be an effective part of your overall snapping strategy in addition to adjusting the snapping tolerance and configuring snap agents.
To turn snapping on or off by layer, complete the following steps:
On the ribbon, click the View tab. In the Windows group, click Contents
.Click the List By Snapping tab
in the Contents pane.
To enable or disable snapping for one or more layers, choose from the following methods:
Method
Check a layer check box.
Enable snapping for the selected layer.
Uncheck a layer check box.
Disable snapping for the layer.
Press Ctrl+Shift and click a layer check box.
Enable or disable snapping for all layers.
Right-click a layer and click Make this the only snappable layer
Enable snapping for the selected layer and disable snapping for all other layers.
