Editing template warnings and errors
The Create Features pane displays warnings and errors for editing templates that create nonvisible features or are unable to create features. Additionally, it hides templates if they create features for layers that are not visible or editable.
Warnings and errors
Hover over a warning or error icon to view information about the cause and a possible remedy described in the following tables.
The Warning icon appears next to the name of an active template if it creates features that are not visible in the active view.
Warning
Possible cause
Possible remedy
Missing symbol
The attribute value for the symbol is missing or the symbology has changed. Symbology must be of single-symbol type, or unique symbols.
Add the missing value to the feature template, change the layer symbology to single symbol or unique symbols, or create a new feature template.
Layer is not visible
The scale range for the layer is outside the current map scale.
Zoom in or out to display the layer.
Failed definition query
An attribute value required by the definition query is missing.
Add the missing values to the feature template or modify the definition query for the layer.
Layer is time enabled
One or more attribute values that specify time are outside the expected range.
Change the appropriate template attribute values or disable the Layer Time property.
Layer is range enabled
One or more attribute values that specify range are outside the expected extent.
Change the appropriate template attribute values or disable the Layer Range property.
Domain Not Satisfied
The template attribute values are outside the defined domain.
Change the appropriate template attribute values to a valid domain value.
Optional Contingent Values
The template attribute values do not satisfy the optional contingent attribute values.
Change the appropriate template attribute values.
The Error icon appears next to the name of an active template if it is unable to create features in the active view.
Error
Possible cause
Possible remedy
Change the appropriate template attribute values to a valid domain value or turn off the Enforce Attribute Validation application editing option.
Required Contingent Values
The template attribute values do not satisfy the required contingent attribute values.
Change the appropriate template attribute values to a valid domain value or change the field group to optional.
Hidden templates
Editing templates are not shown for layers that are either not visible or not editable. To view them in the template notification view, click Click here to see templates not listed .
Hidden templates
In the Missing Feature Template Notification view, click and expand a layer name to view information about why its templates are hidden To close the view, click the Back arrow .
The table below describes possible causes for hidden templates.
Notification
Possible cause
Possible remedy
Layer is not marked editable
The layer check box is unchecked in the Contents pane, on the Editing page .
Check the layer check box to enable editing.
The layer check box is unchecked in the Contents pane, on the Drawing Order page .
Check the layer check box to enable visibility and display the layer.
Layer has no templates
No templates exist for this layer.
Create a feature template for this layer.
