Geometric constraints
The geometric constraint commands constrain the orientation of a segment parallel or perpendicular to other features, or to the vertical axis in 3D scenes. They are available when you draw line or polygon feature geometry.
Constraint |
Description |
Constrain the current segment parallel to an another feature. |
Constrain the current segment perpendicular to an another feature. |
Constrain the current z-aware segment to the vertical axis in a 3D scene. Note:This command is only available with 3D scenes. |
