Message: Layer cannot be edited
This message is displayed in the Editing Status dialog box.
Cause
The layer or table cannot be edited for one of the following reasons:
The layer or table is currently being edited or accessed by another application.
The layer or table is read-only, or you don't have the necessary permissions to edit it.
Solution
Solutions include the following:
Confirm that you or other team members are not editing this data in another session.
Use File Explorer to grant yourself permission to write to the folder containing your data and to the files you want to edit—for example, the geodatabase, the files that comprise a shapefile, and so on. Generally, this occurs if the data was copied from other storage media such as a DVD or CD-ROM.
If you are editing data from an enterprise geodatabase, ensure that the data is registered as versioned and you have write access to the version.
