Multiple single part lines (Line)
The Multiple single part lines builder generates a line feature at a specified offset from the left or right side of a line feature you create in a map.
This builder is available to feature templates that create line features when a group template is configured with the following settings:
  • The primary template creates line features.
  • The group template toolset on the Tools side tab is set to Line tools.
Parameters
Parameter
Explanation
Setting type
Offset
The distance from the left or right side of the primary line feature at which the new line is created
  • Left—Offset is measured from the left of the segment.
  • Right—Offset is measured from the right of the segment.
Optional
Parameters for Point at every vertex except start
