Point at end of line
The Point at end of line builder generates a point feature at a specified distance from the last vertex and an offset from a line feature you create in a map.
This builder is available to feature templates that create point features when a group template is configured with the following settings:
  • The primary template creates point or line features.
  • The group template toolset on the Tools side tab is set to Line tools or Radial tools.
This builder is also available to primary templates that create point features when the toolset is set to Radial tools, .
Parameters
Parameter
Explanation
Setting type
Position along the line
The distance from the last vertex of the primary line at which the new point feature is created
  • None—Distance is equal to zero. This is the default setting.
  • Distance—Distance is specified in units selected from a drop-down list.
  • Proportional—Distance is specified as a ratio of the segment length; for example, 50 equals 50 percent and interpreted as the midpoint.
Optional
Offset to the side of the line
The distance from the left or right side of the primary line at which the new point feature is created
  • None—Offset is equal to zero. This is the default setting.
  • Left—Offset is measured from the left of the segment.
  • Right—Offset is measured from the right of the segment.
Optional
Parameters for Point at end of line
