Point at every vertex except start and end
The Point at every vertex except start and end builder generates point features at every vertex at a specified offset except the first and last vertex of a line feature you create in a map.
This builder is available to feature templates that create polygon features when a group template is configured with the following settings:
  • The primary template creates point or line features.
  • The group template toolset on the Tools side tab is set to Line tools.
Parameters
Parameter
Explanation
Setting type
Offset
The distance from the left or right side of the primary line at which the new point features are created
  • Left—Offset is measured from the left of the segment.
  • Right—Offset is measured from the right of the segment.
Optional
Parameters for Point at every vertex except start and end
