Set the layer display field
The display field layer property uses a designated field in the feature layer to identify a selected layer in editing tools and the selection chip. You can change the display field on the Layer Properties dialog box or write a custom display expression for easier identification.
The display field property is also used by MapTips, Pop-ups, published map services, and other areas of ArcGIS Pro that identify a feature layer.
To change the display field, complete the following steps:
  1. On the ribbon, click the View tab. In the Windows group, click Contents .
    The Contents pane appears.
  2. Right-click the layer and click Properties .
    The Layer Properties dialog box appears.
  3. Click the Display tab.
  4. Click the Display Field drop-down arrow and choose a field.
    By default, it is set to the first available string field in the feature layer containing the word name in the field name.
    Display field
    Tip:
    To create a custom display expression, click Set an expression .
    On the Expression Builder dialog box, use the Arcade language to concatenate your own text to the text supplied by the designated field, for example, "Street Name: " + $feature.NAME. Custom display expressions use the Feature Display Tile Arcade profile.
    Expression Builder
  5. Click OK.
