Dynamic text tags
Dynamic text works through the use of tags, similar to HTML. This allows you to combine both dynamic and static text in a single text element. Once dynamic text has been added to your layout, you can modify the text to change the information that is displayed and how it is shown. Along with dynamic text tags that provide the information displayed, you can use formatting tags to modify the formatting for portions of the text. This allows you to create mixed-format text where, for example, one word in a sentence is underlined.
Text elements using dynamic text tags can be as simple or complex as needed. In some cases, you may just need a single, stand-alone tag, but other cases may require several tags along with static text. The following is an example for keeping track of the last person to work on a project:
Last updated on <ITA><dyn type="project" property="dateSaved" format="long"/></ITA> by <ITA><dyn type="user"/></ITA>.
This example uses static text, two dynamic text tags, a modifier on the first tag to specify the date format, and two formatting tags to italicize the date and the user name. The output looks similar to the following: Last updated on Monday, June 9, 2014 by userName.
Text formatting tags are applied only if the current typeface includes that style.
Tables of dynamic text tags, formatting information for dynamic text, and examples of how to use these tags are provided below. For lists and examples of formatting tags, see Text formatting tags.
Numeric values
You can modify the number of decimal places used by tags that return numeric values using the decimalPlaces attribute, for example, <dyn type="mapFrame" name="MapFrameName" property="lowerMid" units="ddm" decimalPlaces="0"/> appears as -95 13 32 58, and <dyn type="mapFrame" name="Map Map Frame" property="lowerMid" units="ddm" decimalPlaces="2"/> appears as -95 13.29 32 57.68.
Empty strings
If a text element contains nothing but a dynamic text tag that currently parses to nothing, an empty bounding box appears on the layout when the element is selected.
If a text element contains additional static text, or an additional dynamic text tag that does parse to a value, that text appears. For example, if you have the following text on a layout that has never been exported: Last exported: <dyn type="layout" name="Layout" property="dateExported"/>, it appears as Last exported: on the page until the page has been exported.
However, if you want certain text to display when a tag parses to null, you can add emptyStr="<text>" to the dynamic text tag. For example, consider the following tag:
Credits: <dyn type="mapFrame" name="Map Frame" property="credits"/>
If the map contains no credit information, the result on the layout is Credits:. Using the empty attribute, you can set default text when there is no information available, for example:
Credits: <dyn type="mapFrame" name="<Map Frame Name>" property="credits" emptyStr="Credits for this map were unavailable."/>
The result on the layout is Credits: Credits for this map were unavailable.
Pre and post strings
Pre and post string attributes can be used to add text before or after a tag. The advantage of using these attributes over static text is that they only appear on the layout if the dynamic text tag has a value. For example, consider the following tag:
Date Exported: <dyn type="layout" name="Layout" property="dateExported" format="short"/>
If the layout has never been exported, the result on the layout is Date Exported:. Instead of adding an empty string attribute to explain that it has not been exported, you can remove the static text and add pre and post string attributes instead, so Date Exported: does not appear on the page.
<dyn type="layout" name="Layout" property="dateExported" format="short" preStr="Last exported on " postStr="."/>
This way, the text on the page is blank until the layout is exported. Once the layout has been exported, the text looks similar to the following:
Last exported on 2/11/2015.
New lines
To start a new line with a dynamic text tag, add the new line attribute. The tag looks similar to the following:
Date Saved <dyn type="project" property="dateSaved" format="short|short" newLine="true"/>
The result on the layout is:
Date Saved
1/27/2015 11:20 AM
System tags
The following table lists the available tags for system information:
System
Example syntax
Example output
Computer Name
<dyn type="computer"/>
MYLAPTOP
Current Date
<dyn type="date" format=""/>
4/4/2019
Current Time
<dyn type="time" format=""/>
10:20 AM
User Name
<dyn type="user"/>
User
Selecting Current Time from the Dynamic Text gallery on the Insert tab inserts text with both the current date and current time tags. The result in the Format Text pane is Current Time <dyn type="mapFrame" name="{0}" property="time" format="short|short"/>.
Learn more about formatting dates and time
Project tags
The following tags are available for project information, including information about the active portal and user:
Project
Example syntax
Example output
Name
<dyn type="project" property="name"/>
CityMaps
Path
<dyn type="project" property="path"/>
C:\Users\UserName\Documents\ArcGIS\Projects\CityMaps\CityMaps.aprx
Folder
<dyn type="project" property="folder"/>
Date Saved
<dyn type="project" property="dateSaved" format="short|short"/>
4/4/2019 11:20 AM
Default Folder
<dyn type="project" property="defaultFolder"/>
Default Geodatabase
<dyn type="project" property="defaultGeodatabase"/>
C:\Users\UserName\Documents\ArcGIS\Projects\CityMaps\CityMaps.gdb
Default Toolbox
<dyn type="project" property="defaultToolbox"/>
C:\Users\UserName\Documents\ArcGIS\Projects\CityMaps\CityMaps.tbx
Default Distance Units
<dyn type="project" property="distUnits"/>
Meters
Default Angular Units
<dyn type="project" property="angularUnits"/>
Decimal Degrees
Default Area Units
<dyn type="project" property="areaUnits"/>
Square Kilometer
Default Page Units
<dyn type="project" property="pageUnits"/>
Centimeter
Username
<dyn type="project" property="portal" attribute="username" portalUri="https://www.arcgis.com/"/>
esriUser1
First Name
<dyn type="project" property="portal" attribute="firstname" portalUri="https://www.arcgis.com/"/>
Jane
Last Name
<dyn type="project" property="portal" attribute="lastname" portalUri="https://www.arcgis.com/"/>
Smith
Full Name
<dyn type="project" property="portal" attribute="fullname" portalUri="https://www.arcgis.com/"/>
Jane Smith
Organization Name
<dyn type="project" property="portal" attribute="orgname" portalUri="https://www.arcgis.com/"/>
City Group
Default Distance Units, Default Angular Units, Default Area Units, and Default Page Units can be changed by updating the unit options.
Project metadata
Example syntax
Example output
Project Title
<dyn type="project" property="metadata" attribute="title"/>
City Project
Project Summary
<dyn type="project" property="metadata" attribute="summary" />
Data and maps for the city
Project Description
<dyn type="project" property="metadata" attribute="description"/>
All data and maps for the city from 2019.
Project Tags
<dyn type="project" property="metadata" attribute="tags"/>
City, boundaries, utilities, parks, streets
Project Credits
<dyn type="project" property="metadata" attribute="credits" />
City GIS Office
Project Use Limitations
<dyn type="project" property="metadata" attribute="use"/>
For display purposes only.
Layout tags
The following tags are available for layouts:
Layout
Example syntax
Example output
Date Exported
<dyn type="layout" name="LayoutName" property="dateExported" format= "short|short"/>
4/4/2019 11:00 AM
Date Printed
<dyn type="layout" name="LayoutName" property="datePrinted" format= "short|short"/>
4/4/2019 11:05 AM
Metadata
When you select this option from the menu, a text element containing a set of metadata tags is inserted. See the layout metadata table for a breakdown.
Name
<dyn type="layout" name="LayoutName" property="name"/>
City Layout
Service Layer Credits
<dyn type="layout" name="LayoutName" property="serviceLayerCredits"/>
Sources: Esri, HERE, Garmin, FAO, NOAA, USGS, © OpenStreetMap contributors, and the GIS User Community
Page Width
<dyn type="layout" name="LayoutName" property="pageSize" attribute="width"/>
297
Page Height
<dyn type="layout" name="LayoutName" property="pageSize" attribute="height"/>
210
Page Unit
<dyn type="layout" name="LayoutName" property="pageSize" attribute="unit"/>
Millimeter
Page Size Name
<dyn type="layout" name="LayoutName" property="pageSize" attribute="page size name"/>
A4
The Service Layer Credits tag displays the credits for all the map frames on the page.
Layout metadata
Example syntax
Example output
Title
<dyn type="layout" property="metadata" attribute="title"/>
Minimal A3 Landscape
Tags
<dyn type="layout" property="metadata" attribute="tags"/>
minimal, tabloid, landscape, layout, title, credits, template
Summary
<dyn type="layout" property="metadata" attribute="summary"/>
A simple, A3-size landscape layout without any margins. It includes a map title and service layer credits.
<dyn type="layout" property="metadata" attribute="description"/>
A landscape layout ideal for showing countries, cities, and states.
Credits
<dyn type="layout" property="metadata" attribute="credits"/>
Designed in 2019 by a cartographer.
Use Limit
<dyn type="layout" property="metadata" attribute="uselimit"/>
Map frame tags
Map frame tags display information about map frames and the maps they contain.
When you create a dynamic text tag for a specified map frame, the map frame is referenced by the name it has when the tag is created. For example, if the current default map frame is named My Map and you insert a dynamic text element for the scale, the tag is: <dyn type="mapFrame" name="My Map" property="scale"/>. If you later rename the map frame, the tag remembers the map frame it references, but the tag does not update to reflect the map frame's new name.
The following map frame tags are available:
Map frame
Example syntax
Example output
Camera
When you select this option from the gallery, you can choose which camera tags to include. See the map frame camera table for a list of tags.
Credits
<dyn type="mapframe" name="MapFrameName" property="credits"/>
Created in 2019.
<dyn type="mapframe" name="MapFrameName" property="description"/>
Map showing the population of cities in 1970.
Layer Metadata
When you select this option from the gallery, you can choose which layer to reference, and which layer metadata tags to include. See the layer metadata table for a list of tags.
Map Units
<dyn type="mapFrame" name="MapFrameName" property="mapUnits"/>
Meter
Metadata
When you select this option from the gallery, you can choose which map metadata tags to include. See the map frame metadata table for a list of tags.
Name
<dyn type="mapFrame" name="MapFrameName" property="name"/>
Map Frame
Name of Map
<dyn type="mapFrame" name="MapFrameName" property="mapName"/>
Iceland map
Reference Scale
<dyn type="mapFrame" name="MapFrameName" property="referenceScale"/>
Relative Scale
1 centimeter equals <dyn type="mapFrame" name="Map Map Frame" property="scale" pageUnits="cm" mapUnits="km" pageValue="1" decimalPlaces="2"/> kilometers
This tag modifies the map's scale to be relative to the page. The attribute pageUnits is used to set the desired units in page space, such as inches or centimeters, and pageValue is used to set the number of these units used. The attribute mapUnits is used to set units for the map's scale.
1 centimeter equals 0.08 kilometers
Rotation
<dyn type="mapFrame" name="MapFrameName" property="rotation"/>
90
Scale
<dyn type="mapFrame" name="MapFrameName" property="scale" preStr="1:"/>
1:8,000
Center Scale
<dyn type="mapFrame" name="MapFrameName" property="centerscale" preStr="1:"/>
This tag computes the scale at the center latitude and longitude of the associated map frame.
1:6,854
Spatial Reference
When you select this option from the gallery, you can choose which spatial reference tags to include. See the spatial reference table for a list of tags.
North
Example syntax
Example output
True North
<dyn type="mapFrame" name="MapFrameName" property="trueNorth" units="dd" decimalPlaces="1" showDirections="false"/>
0.2°
Magnetic North
<dyn type="mapFrame" name="MapFrameName" property="magneticNorth" units="dd" decimalPlaces="0" showDirections="false"/>
-10°
Map North
<dyn type="mapFrame" name="MapFrameName" property="gridNorth" units="dd" decimalPlaces="0" showDirections="false"/>
0°
Magnetic Declination
<dyn type="mapFrame" name="MapFrameName" property="magneticDeclination" units="dd" decimalPlaces="2" showDirections="false"/>
Magnetic declination is the angle between true north and magnetic north.
-9.67°
Convergence
<dyn type="mapFrame" name="MapFrameName" property="convergence" units="dd" decimalPlaces="2" showDirections="false"/>
Convergence is the angle between true north and grid north.
0.22°
G-M Angle
<dyn type="mapFrame" name="MapFrameName" property="gmAngle" units="dd" decimalPlaces="2" showDirections="false"/>
G-M angle is the angle between grid north and magnetic north.
-9.89°
Layer metadata
Example syntax
Example output
Title
<dyn type="mapframe" property="metadata" attribute="title" name="Map Frame" layerUri="CIMPATH=map/streets.xml" preStr="Title: " newLine="true" emptyStr=""/>
Road center lines
Tags
<dyn type="mapframe" property="metadata" attribute="tags" name="Map Frame" layerUri="CIMPATH=map/streets.xml" preStr="Tags: " newLine="true" emptyStr=""/>
survey, 2018, roads, highways,
Summary
<dyn type="mapframe" property="metadata" attribute="summary" name="Map Frame" layerUri="CIMPATH=map/streets.xml" preStr="Summary: " newLine="true" emptyStr=""/>
Road data from the 2018 survey.
<dyn type="mapframe" property="metadata" attribute="description" name="Map Frame" layerUri="CIMPATH=map/streets.xml" preStr="Description: " newLine="true" emptyStr=""/>
Road center lines. Includes road name, road type, and road cover.
Credits
<dyn type="mapframe" property="metadata" attribute="credits" name="Map Frame" layerUri="CIMPATH=map/streets.xml" preStr="Credits: " newLine="true" emptyStr=""/>
Created in 2018.
Use Limit
<dyn type="mapframe" property="metadata" attribute="useLimit" name="Map Frame" layerUri="CIMPATH=map/streets.xml" preStr="Use Limit: " newLine="true" emptyStr=""/>
For display and analysis. Accurate as of December 2018.
Layer metadata dynamic text tags require the layer URI. It is recommended to add this dynamic text from Dynamic Text button instead of typing the tags.
Map frame camera
Example syntax
Example output
X
<dyn type="mapFrame" name="MapFrameName" property="camera.x" units="dms" decimalPlaces="0"/>
46°8'3"E
Y
<dyn type="mapFrame" name="MapFrameName" property="camera.y" units="dms" decimalPlaces="0"/>
13°4'18"S
Z
<dyn type="mapFrame" name="MapFrameName" property="camera.z"/>
2,601,586.4995
Scale
<dyn type="mapFrame" name="MapFrameName" property="camera.scale" preStr="Scale: 1:"/>
Scale: 1:12,487,512
Rotation
<dyn type="mapFrame" name="MapFrameName" property="camera.rotation"/>
5.03
Pitch
<dyn type="mapFrame" name="MapFrameName" property="camera.pitch"/>
-90
Roll
<dyn type="mapFrame" name="MapFrameName" property="camera.roll"/>
-90
Map frame metadata
Example syntax
Example output
Title
<dyn type="mapframe" name="mapFrameName" property="metadata" attribute="title"/>
The World in 1970
Tags
<dyn type="mapframe" name="mapFrameName" property="metadata" attribute="tags"/>
population, map, 1970, world, historic map
Summary
<dyn type="mapframe" name="mapFrameName" property="metadata" attribute="summary"/>
World population map.
<dyn type="mapframe" name="mapFrameName" property="metadata" attribute="description"/>
Map showing the population of cities worldwide in 1970.
Credits
<dyn type="mapframe" name="mapFrameName" property="metadata" attribute="credits"/>
Created in 2019.
Use Limit
<dyn type="mapframe" name="mapFrameName" property="metadata" attribute="uselimit"/>
For educational purposes only.
If your map frame contains time-enabled data, you can display time information using dynamic text.
Map frame—Time
Example syntax
Example output
Start Time
<dyn type="mapFrame" name="MapFrameName" property="startTime" format="short|short"/>
1/1/2001 12:00 AM
Current Time
<dyn type="mapFrame" name="MapFrameName" property="time" format="short|short"/>
1/1/2004 12:00 AM to 1/1/2006 12:00 AM
End Time
<dyn type="mapFrame" name="MapFrameName" property="endTime" format="short|short"/>
1/1/2010 12:00 AM
Times are displayed according to the time zone set for the map.
Spatial reference tags
Example syntax
Example output
Name
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="name"/>
WGS 1984 UTM Zone 12N
Projected Coordinate System
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="pcs"/>
Geographic Coordinate System
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="gcs"/>
GCS WGS 1984
Datum
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="datum"/>
WGS 1984
Projection
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="projection"/>
Transverse Mercator
Remarks
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="remarks"/>
User Defined Geographic Coordinate System based on OSGB1936
Central Meridian
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="central meridian"/>
-111.0000
Latitude of Origin
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="latitude of origin"/>
0.0000
Longitude of Origin
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="longitude of origin"/>
0.0000
Latitude of Center
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="latitude of center"/>
0.0000
Longitude of Center
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="longitude of center"/>
0.0000
Latitude of 1st
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="latitude of 1st"/>
0.0000
Latitude of 2nd
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="latitude of 2nd"/>
0.0000
Longitude of 1st
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="longitude of 1st"/>
0.0000
Longitude of 2nd
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="longitude of 2nd"/>
0.0000
False Easting
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="false easting"/>
500,000.0000
False Northing
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="false northing"/>
0.0000
Standard Parallel 1
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="standard parallel 1"/>
0.0000
Standard Parallel 2
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="standard parallel 2"/>
0.0000
Scale Factor
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="scale factor"/>
0.9996
Azimuth
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="azimuth"/>
0.0000
Units
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="units"/>
Meter
Authority
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="authority"/>
EPSG
WKID
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="wkid"/>
3857
Map frame—Coordinates
Example syntax
Example output
Center
<dyn type="mapFrame" name="MapFrameName" property="center" units="dms" decimalPlaces="0"/>
80°41'25"W 44°36'4"N
X
<dyn type="mapFrame" name="MapFrameName" property="center.x" units="dms" decimalPlaces="0"/>
80°41'25"W
Y
<dyn type="mapFrame" name="MapFrameName" property="center.y" units="dms" decimalPlaces="0"/>
44°36'4"N
Lower Left
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft" units="dms" decimalPlaces="0"/>
80°44'54"W 44°34'33"N
Lower Middle
<dyn type="mapFrame" name="MapFrameName" property="lowerMid" units="dms" decimalPlaces="0"/>
80°41'25"W 44°34'32"N
Lower Right
<dyn type="mapFrame" name="MapFrameName" property="lowerRight" units="dms" decimalPlaces="0"/>
80°37'57"W 44°34'32"N
Middle Left
<dyn type="mapFrame" name="MapFrameName" property="midLeft" units="dms" decimalPlaces="0"/>
80°44'53"W 44°36'5"N
Middle Right
<dyn type="mapFrame" name="MapFrameName" property="midRight" units="dms" decimalPlaces="0"/>
80°37'57"W 44°36'3"N
Upper Left
<dyn type="mapFrame" name="MapFrameName" property="upperLeft" units="dms" decimalPlaces="0"/>
80°44'53"W 44°37'36"N
Upper Middle
<dyn type="mapFrame" name="MapFrameName" property="upperMid" units="dms" decimalPlaces="0"/>
80°41'25"W 44°37'36"N
Upper Right
<dyn type="mapFrame" name="MapFrameName" property="upperRight" units="dms" decimalPlaces="0"/>
80°37'56"W 44°37'35"N
Coordinate Formatting
To break the coordinate down into parts, append .x or .y to the property you specified. You can format how coordinate values display using the format tags below.
Coordinate formatting
Tag
Example syntax
Example output
units
Specify the format for the coordinate.
  • dd for decimal degrees
  • dms for degrees minutes seconds
  • ddm for decimal minutes
  • mgrs for Military Grid Reference System coordinates
  • usng for United States National Grid coordinates
<dyn type="mapFrame" name="Map Frame" property="center" units="dms"/>
117°15'26.257"W
showSymbol
Show the degree, minute, and second symbols.
The default is True.
<dyn type="mapFrame" name="Map Frame" property="center" units="dms" showSymbol="False"/>
117 15 26.257 W
decimalPlaces
Set the number of decimal places displayed.
<dyn type="mapFrame" name="Map Frame" property="center" units="dd" decimalPlaces = "1"/>
100.1°W
padDecimal or zeroPad
Show decimals with the value of 0. This is usually used in conjunction with the decimalPlaces tag.
The default is False.
<dyn type="mapFrame" name="Map Frame" property="center" units="dd" decimalPlaces = "3" padDecimal = "True"/>
100.100°W
showZeroMinutes
Show the minute value if it is equal to zero.
<dyn type="mapFrame" name="Map Frame" property="center" units="dms" showZeroMinutes="True"/>
100°0'W
showZeroSeconds
Show the second value if it is equal to zero.
<dyn type="mapFrame" name="Map Frame" property="center" units="dms" showZeroSeconds="True"/>
100°0'0"W
showSpaces
Include spaces between coordinate parts for MGRS or USNG coordinates.
<dyn type="mapFrame" name="Map Frame" property="center" units="mgrs" showSpaces = "True" />
08V MN
padDegrees
Show two digits in degree values for latitudes and three digits in degree values for longitudes. Pad the value with 0 if the value isn't long enough.
<dyn type="mapFrame" name="Map Frame" property="center" units="dms" padDegrees="True"/>
009°18'E
padMinutes
Show two digits for all minute values.
<dyn type="mapFrame" name="Map Frame" property="center" units="dms" padMinutes="True"/>
9°04'48"E
padSeconds
Show two digits for all second values.
<dyn type="mapFrame" name="Map Frame" property="center" units="dms" padSeconds="True"/>
9°1'02"E
padGridZone
Show two digit values for all MGRS or USNG grid zones.
<dyn type="mapFrame" name="Map Frame" property="center" units="mgrs" padGridZone="false"/>
8VMN
showDirections
Show the cardinal point associated with the coordinate.
True shows the cardinal point after the coordinate, False does not show the cardinal point but shows a negative sign if applicable, and None does not show the cardinal point or a negative sign.
<dyn type="mapFrame" name="Map Frame" property="center" units="dms" showDirections = "False"/>
-97°9'25.1"
directionSeparator
Separate coordinate value and direction. This tag is ignored if showDirections="False" or showDirections="None".
<dyn type="mapFrame" name="Map Frame" property="center" units="dms" directionSeparator=" "/>
10° S
showPlusSign
Show a plus sign or negative sign in front of the coordinates. This requires that showDirections is set to None or False.
<dyn type="mapFrame" name="Map Frame" property="center" units="dms" showDirections="False" showPlusSign ="True"/>
+14°
Decimal degree parts
Format
Example syntax
Example output
dd
Decimal Degrees
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft.x" units="dd" decimalPlaces="2" showDirections="True"/>
122.31W
dd.deg
Degrees
Does not include direction
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft.x" units="dd.deg" decimalPlaces="2" showDirections="True"/>
122.31
dd.deg.int
Degree Integer
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft.x" units="dd.deg.int" decimalPlaces="2" showDirections="True"/>
122
dd.deg.sym
Degree Symbol
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft.x" units="dd.deg.sym" decimalPlaces="2" showDirections="True"/>
dd.dec
Decimal
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft.x" units="dd.dec" decimalPlaces="2" showDirections="True"/>
31
dd.dir
Direction
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft.x" units="dd.dir" decimalPlaces="2" showDirections="True"/>
W
Degree minute second parts
Format
Example syntax
Example output
dms
Degrees Minutes Seconds
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft.x" units="dms" decimalPlaces="2" showDirections="False"/>
-122°18'37.82"
dms.deg
Degrees
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft.x" units="dms.deg" decimalPlaces="2" showDirections="True"/>
122
dms.deg.sym
Degree Symbol
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft.x" units="dms.deg.sym" decimalPlaces="2" showDirections="True"/>
dms.min
Minutes
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft" units="dms.min" decimalPlaces="2" showDirections="True"/>
18
dms.min.sym
Minutes Symbol
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft.x" units="dms.min.sym" decimalPlaces="2" showDirections="True"/>
dms.sec
Seconds
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft.x" units="dms.sec" decimalPlaces="2" showDirections="True"/>
37.82
dms.sec.sym
Seconds Symbol
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft.x" units="dms.sec.sym" decimalPlaces="2" showDirections="True"/>
dms.sec.int
Seconds Integer
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft" units="dms.sec.int" decimalPlaces="2" showDirections="True"/>
37
dms.sec.dec
Seconds Decimal
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft.x" units="dms.sec.dec" decimalPlaces="2" showDirections="True"/>
82
dms.dir
Direction
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft.x" units="dms.dir" showDirections="True"/>
W
Decimal minute parts
Format
Example syntax
Example output
ddm
Decimal Minutes
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft.x" units="ddm" decimalPlaces="2" showDirections="True"/>
122°18.63 W
ddm.deg
Degrees
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft.x" units="ddm.deg" decimalPlaces="2" showDirections="True"/>
122
ddm.min
Minutes
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft.x" units="ddm.min" decimalPlaces="2" showDirections="True"/>
18.63
ddm.min.int
Minutes Integer
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft" units="ddm.min.int" decimalPlaces="2" showDirections="True"/>
18
ddm.min.dec
Minutes Decimal
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft" units="ddm.min.dec" decimalPlaces="2" showDirections="True"/>
63
ddm.deg.sym
Degree Symbol
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft" units="ddm.deg.sym" decimalPlaces="2" showDirections="True"/>
ddm.dir
Direction
<dyn type="mapFrame" name="MapFrameName" property="lowerLeft" units="ddm.dir" decimalPlaces="2" showDirections="True"/>
W
MGRS parts
Format
Example syntax
Example output
mgrs
<dyn type="mapFrame" name="Map Frame" property="center" units="mgrs"/>
08VMN
mgrs.gzd
Grid zone designator
<dyn type="mapFrame" name="Map Frame" property="center" units="mgrs.gzd"/>
08V
mgrs.100km
100,000-meter square
<dyn type="mapFrame" name="Map Frame" property="center" units="mgrs.100km" showSpaces="true"/>
08V MN
mgrs.10km
10,000-meter square
<dyn type="mapFrame" name="Map Frame" property="center" units="mgrs.10km" showSpaces="true"/>
08V MN 9 3
mgrs.1km
1,000-meter square
<dyn type="mapFrame" name="Map Frame" property="center" units="mgrs.1km" showSpaces="true"/>
08V MN 97 31
mgrs.100m
100-meter square
<dyn type="mapFrame" name="Map Frame" property="center" units="mgrs.100m" showSpaces="true"/>
08V MN 975 311
mgrs.10m
10-meter square
<dyn type="mapFrame" name="Map Frame" property="center" units="mgrs.10m" showSpaces="true"/>
08V MN 9751 3115
mgrs.1m
1-meter square
<dyn type="mapFrame" name="Map Frame" property="center" units="mgrs.1m" showSpaces="true"/>
08V MN 97516 31154
USNG parts
Format
Example syntax
Example output
usng
<dyn type="mapFrame" name="Map Frame" property="center" units="usng"/>
11TPF
usng.gzd
<dyn type="mapFrame" name="Map Frame" property="center" units="usng.gzd"/>
11T
usng.100km
<dyn type="mapFrame" name="Map Frame" property="center" units="usng.100km showSpaces="true"/>
11T PF
usng.10km
10,000-meter square
<dyn type="mapFrame" name="Map Frame" property="center" units="usng.10km showSpaces="true"/>
11T PF 4 2
usng.1km
1,000-meter square
<dyn type="mapFrame" name="Map Frame" property="center" units="usng.1km showSpaces="true"/>
11T PF 45 23
usng.100m
100-meter square
<dyn type="mapFrame" name="Map Frame" property="center" units="usng.100m showSpaces="true"/>
11T PF 458 239
usng.10m
10-meter square
<dyn type="mapFrame" name="Map Frame" property="center" units="usng.10m showSpaces="true"/>
11T PF 4584 2397
usng.1m
1-meter square
<dyn type="mapFrame" name="Map Frame" property="center" units="usng.1m showSpaces="true"/>
11T PF 45841 23976
