Modify postprocessing effect settings
Once you apply postprocessing effects to a scene, you can make adjustments to them before creating a final image or video output.
To adjust postprocessing effects, click the View tab. In the Scene group, click the Postprocessing Effects drop-down arrow and click Postprocessing Effect Settings. The Postprocessing Effects Settings dialog box appears, where you can activate or deactivate effects or change their properties. All changes are immediately applied in the active view. Click Reset to default to return a setting to the default values.
Postprocessing effect settings
The following table lists the customizable properties of each postprocessing effect type:
Postprocessing effect |
Description |
Bloom |
Add a glow to color values brighter than a given threshold to produce bright light in the scene.
Vignette |
Apply darkening around the edges and corners of the scene compared to the center.
Grain |
Apply a gradient noise or texture in the view by visualizing the scene as small particles.
Color Grading |
Enhance colors in the scene by altering or correcting color and luminance.
