Time in spatial data
Time is supported in spatial data in a variety of ways. Time information can be stored as an attribute (feature classes, stand-alone tables, and mosaic datasets), or it can be stored internally (such as in netCDF data). The following sections describe data that can be visualized through time.
Feature layers
With feature layers, features can be visualized over time in two ways:
  • The shape and location of each feature are constant, but attribute values can change over time.
  • The shape and location of each feature change over time.
Features that change in shape or location over time must be stored as separate features. For example, for hurricane tracks that are visualized over time, the point feature representing the location of a hurricane at a particular time must be stored as a separate feature.
Features that do not change in shape or location can also be represented in the table as separate features, for example, for population values per city. Each city can be represented by multiple features. Each feature representing the same city has the same location with a different population value for each date.
However, in cases where you have many time stamps for the same static feature, you can use a one-to-many join where the spatial information is stored in the base table, and the duplicate information is stored in a separate table.
Learn more about storing temporal data in separate tables
Stand-alone tables
Nongeographic changes over time can be visualized using stand-alone tables. When the table properties have time defined on a date field, the table automatically filters its records to only show the records that fall within the current time slider extent. For example, a table showing monthly employee sales data updates with each monthly time slider step as it plays through the year.
Mosaic datasets
Mosaic datasets can be used to store rasters representing a change over time. For example, a mosaic dataset can contain aerial images representing land-use change over time, which can be visualized over time. As with feature layers, you must have a date field in your mosaic dataset's attribute table to indicate the valid time for each raster.
NetCDF layers
With netCDF layers, you can choose a dimension for visualizing the data. Time values are stored as one dimension of the netCDF layer. For netCDF feature layers, you can specify the layer time using a time dimension or the attribute fields (start time and end time fields) containing the time values. For netCDF raster layers, however, you can only specify layer time using the time dimension that allows you to step through the data over time.
