Event behavior for route reversal
Available with Location Referencing license.
When one or more routes are reversed, events are impacted depending on the configured event behavior for the event layer.
Events are not updated until the Apply Event Behaviors tool is run after route edits. If you are using conflict prevention on branch versioned data, you are prompted to run Apply Event Behaviors before posting to the default version.
When Recalibrate route downstream is chosen for an LRS route edit, the configured calibrate event behavior is applied to downstream sections. You can review configured event behaviors by viewing LRS event properties.
The route reversal and corresponding event behaviors are described below.
Route reversal scenario
Single or multiple adjoining routes that belong to the same line can be reversed in one edit.
In the following scenario, Route 1 is active from 1/1/2000. The reversal is set to occur to reverse the entire route on 1/1/2005. The graphics and tables below demonstrate the route information before and after the reversal.
Before route reversal
The following image shows the route before the reversal:
Route 1 before reversal
The following table provides details about the route before the reversal:
Route Name
From Date
To Date
From Measure
To Measure
Route1
1/1/2000
<Null>
After route reversal
The following image shows the route after the reversal:
Route 1 after reversal
The following table provides details about the route after the reversal:
Route Name
From Date
To Date
From Measure
To Measure
Route1
1/1/2000
1/1/2005
Route1
1/1/2005
<Null>
Events before route reversal
There are two events on Route 1 that have a start date (From Date) of 1/1/2000. The following image shows the route and events before the reversal.
Route 1 and associated events before route reversal
The following table provides details about the events before the reversal:
Event
Route Name
From Date
To Date
From Measure
To Measure
Event1
Route1
1/1/2000
<Null>
12
Event2
Route1
1/1/2000
<Null>
12
20
The following sections detail how event behavior rules are enforced after running the Apply Event Behaviors tool under this route reversal scenario.
Stay Put event behavior
Although the geographic location of the event is maintained, the measures can change.
The route reversal described above has the following effects:
  • Event 1 is retired on the date of reversal because it is within the edit section. A new event is created with the reversal date being the start date (From Date). The start measure (From Measure) value changes to 8 and the end measure (To Measure) value changes to 15 to accommodate the reversed measures of Route 1.
  • Event 2 is retired on the date of reversal because it is within the edit section. A new event is created with the reversal date being the start date. The start measure value changes to 0 and the end measure value changes to 8 to accommodate the reversed measures of Route 1.
The following image shows the route and events after the reversal:
The retired event is not drawn in the following image.
Route 1 and associated events after reversal when Stay Put is the configured event behavior
The following table provides details about the events after the reversal when Stay Put is the configured event behavior:
Event
Route Name
From Date
To Date
From Measure
To Measure
Location Error
Event1
Route1
1/1/2000
1/1/2005
12
No Error
Event1
Route1
1/1/2005
<Null>
8
15
No Error
Event2
Route1
1/1/2000
1/1/2005
12
20
No Error
Event2
Route1
1/1/2005
<Null>
No Error
Move event behavior
Although the measures of the event are maintained, the geographic location can change.
  • Event 1 is retired on the date of reversal because it is within the edit section. A new event is created with the reversal date being the start date. Because the measures do not change for the Move behavior, the event maintains its original start measure of 5 and the end measure of 12.
  • Event 2 is retired on the date of reversal because it is within the edit section. A new event is created with the reversal date being the start date. Because the measures do not change for the Move behavior, the event maintains its original start measure of12 and end measure of 20.
Route 1 and associated events after reversal when Move is the configured event behavior
The following table provides details about the events after the reversal when Move is the configured event behavior:
Event
Route Name
From Date
To Date
From Measure
To Measure
Location Error
Event1
Route1
1/1/2000
1/1/2005
12
No Error
Event1
Route1
1/1/2005
<Null>
12
No Error
Event2
Route1
1/1/2000
1/1/2005
12
20
No Error
Event2
Route1
1/1/2005
<Null>
12
20
No Error
Retire event behavior
Events intersecting the reversal region are retired.
  • Event 1 retires on the date of reversal because it is completely inside the edit section.
  • Event 2 retires on the date of reversal because it is completely inside the edit section.
Route 1 and associated events after reversal when Retire is the configured event behavior
The following table details the events after the reversal when Retire is the configured event behavior:
Event
Route Name
From Date
To Date
From Measure
To Measure
Event1
Route1
1/1/2000
1/1/2005
12
Event2
Route1
1/1/2000
1/1/2005
12
20
Detailed route reversal behavior on routes in a line network with events that span routes
In this example, there are three routes on the same line and the routes are active from 1/1/2000. The reversal is set to occur on 1/1/2005, where all three routes are reversed. The following graphics and tables demonstrate the route information before and after the reversal.
The following image shows the routes before reversal:
The three routes on Line A before reversal
The following table provides details about the routes before the reversal:
Route Name
Line Name
Line Order
From Date
To Date
From Measure
To Measure
Route1
LineA
100
1/1/2000
<Null>
Route2
LineA
200
1/1/2000
<Null>
15
25
Route3
LineA
300
1/1/2000
<Null>
30
40
The following image shows the routes after the reversal:
The three routes on Line A after reversal
The following table provides details about the routes after the reversal:
Route Name
Line Name
Line Order
From Date
To Date
From Measure
To Measure
Route1
LineA
100
1/1/2000
1/1/2005
Route1
LineA
100
1/1/2005
<Null>
Route2
LineA
200
1/1/2000
1/1/2005
15
25
Route2
LineA
200
1/1/2005
<Null>
15
25
Route3
LineA
300
1/1/2000
1/1/2005
30
40
Route3
LineA
300
1/1/2005
<Null>
30
40
Events before reversal
There are two spanning events on routes on Line A. The following image shows the routes and events before the reversal:
The three routes and associated events before reversal
Event ID
From Date
To Date
From Route Name
From Measure
To Route Name
To Measure
Event1
1/1/2000
<Null>
Route1
7
Route2
18
Event2
1/1/2000
<Null>
Route2
18
Route3
35
The following sections describe how event behavior rules are enforced when routes on a line in a line network are reversed.
  • Event 1 is retired on the date of reversal because it is within the edit section. A new event is created with the reversal date being the start date (From Date). The start measure (From Measure) value changes to 22 on Route 22 and the end measure (To Measure) value changes to 3 on Route 1 to accommodate the new measure of the reversed routes.
  • Event 2 is retired on the date of reversal because it is within the edit section. A new event is created with the reversal date being the From Date. The From and To Measures are changed from measure 35 on Route 3 to measure 22 on Route 2 to accommodate the new measure of the reversed routes.
The following image shows the routes and events after the reversal:
The three routes and associated events after the reversal when Stay Put is the configured event behavior
Event ID
From Date
To Date
From Route Name
From Measure
To Route Name
To Measure
Location Error
Event1
1/1/2000
1/1/2005
Route1
7
Route2
18
No Error
Event1
1/1/2005
<Null>
Route2
22
Route1
No Error
Event2
1/1/2000
1/1/2005
Route2
18
Route3
35
No Error
Event2
1/1/2005
<Null>
Route3
35
Route2
22
No Error
Move event behavior
  • Event 1 is retired on the date of reversal because it is within the edit section. A new event is created with the reversal date being the start date. Because the measures do not change for the Move behavior, the event maintains its original start measure value of 18 on Route 2 and end measure value of 7 on Route 1. Note that the route start and end locations also switch to accommodate the event direction after route reversal.
  • Event 2 is retired on the date of reversal because it is within the edit section. A new event is created with the reversal date being the start date. Because the measures do not change for the Move behavior, the event maintains its original start measure value of 35 on Route 3 and end measure value of 18 on Route 2. Note that the route start and end locations also switch to accommodate the event direction after route reversal.
The three routes and associated events after the reversal when Move is the configured event behavior
Event ID
From Date
To Date
From Route Name
From Measure
To Route Name
To Measure
Location Error
Event1
1/1/2000
1/1/2005
Route1
7
Route2
18
No Error
Event1
1/1/2005
<Null>
Route2
18
Route1
7
No Error
Event2
1/1/2000
1/1/2005
Route2
18
Route3
35
No Error
Event2
1/1/2005
<Null>
Route3
35
Route2
18
No Error
The three routes and associated events after reversal when Retire is the configured event behavior
The following table provides details about the events after reversal when Retire is the configured event behavior:
Event ID
From Date
To Date
From Route Name
From Measure
To Route Name
To Measure
Event1
1/1/2000
1/1/2005
Route1
Route2
20
Event2
1/1/2000
1/1/2005
Route2
20
Route3
35
