Release locks through the LRS Locks table
Available with Location Referencing license.
The LRS Locks table allows you to review and release line, route, and event locks.
Tip:
You can also release locks with the Release Locks tool.
You can differentiate between the lock types by looking at the contents of the Event column. If a cell in the Event column contains a value, the lock is an event lock. If a cell in the Event column is blank, the lock is a route or line lock.
The following is an example of event and route locks in the LRS Locks table:
LRS Locks table, Event column
You can identify lock types in the LRS Locks table by user.
Item
Lock type
Route or Line
Event
Tools available in the LRS Locks table
The following table describes the tools available in the LRS Locks table:
Tool
Tool name
Tool description
Selection
Select All
Select All
Selects all the records in the LRS Locks table and shows the selection on the map.
Zoom To Selection
Zoom To Selection
Zooms to the routes associated with the highlighted locks on the map.
Switch Selection
Switch Selection
Switches the selected rows.
Clear Selection
Clear Selection
Clears any selected rows in the table.
Copy
Copy Selection
Copies the selected rows.
Release locks
Release selected locks
Releases the locks from the selected rows. This tool is enabled only when all the selected rows have their releasable status values set to Yes.
Learn more about releasing locks
Release all
Release all releasable locks
Releases all the locks whose releasable status value is Yes. There is no need to select rows.
Release highlighted locks
Releases the locks from the highlighted rows. This tool is available only in Show Selected Records mode. This tool is enabled only when all the highlighted rows have their releasable status values set to Yes.
Highlighted (available in Show Selected Records mode)
Unselect Highlighted
Removes the highlighted rows from the current selection set.
Reselect Highlighted
Updates the current selection set to highlighted rows (only).
Switch Highlighted
Switch Highlighted
Switches the highlighted rows.
Clear Highlighted
Clear Highlighted
Deselects the currently highlighted rows.
Tools available when right-clicking a row
Flash
Flash
Flashes the route on the map.
Zoom To Selection
Zoom To Selection
Zooms to the route on the map.
Pan To Selection
Pan To Selection
Pans (center) to the route on the map.
Select/Unselect
Select/Unselect
Selects or unselects the row in the table and on the map.
Highlight/Unhighlight
Highlights or unhighlights the row in the table and on the map. This tool is available only in Show Selected Records mode.
Pop-up
Pop-up
Shows the attributes for the route on the map.
Impact of the user and version on releasable status
The releasable status reported in the LRS Locks table is dependent on the signed-in user and the version being edited.
The following is an example of the LRS Locks table with user22 signed in using Version2:
The numbers in the image above correspond to the numbers in the following table:
The locks were acquired by user22 using Version2, and their edits were saved, resulting in a releasable status value of On Post.
The locks were acquired by user22 using Version2, and they didn't save any edits, resulting in a releasable status value of Yes.
The locks were acquired by user11 using Version1, and the signed-in user (user22) didn't acquire the locks, resulting in a releasable status value of No.
The following is an example of the LRS Locks table with user11 signed in using Version1:
The lock was acquired by user11 using Version1, and they didn't save any edits, resulting in a releasable status value of Yes.
The locks were acquired by user22 using Version2, and the signed-in user (user11) didn't acquire the locks, resulting in a releasable status value of No.
Release locks
You can release locks in the LRS Locks table if the Releasable column value is Yes.
The following table describes the releasable status values:
Releasable status
Reason
Yes
The lock is owned by the user who is signed in (in any version), and the route or event has not been edited.
On Post
The lock is owned by the user who is signed in (in any version), and the route or event has been edited.
No
The lock is owned by another user.
To release locks through the LRS Locks table, complete the following steps:
  1. Start ArcGIS Pro and open a project with an LRS Network from a conflict prevention-enabled LRS.
  2. On the Location Referencing tab, in the Conflict Prevention group, click LRS Locks to open the table.
  3. Optionally, filter the locks in the LRS Locks table using the available filters for the Network, User, Version, Event, and Line columns.
    The filters can be used individually or in combination to show only the locks that meet these conditions.
  4. To release locks, do one of the following:
    • To release one lock, select a row with the releasable status value of Yes, and click Release Selected .
    • To release all locks with the releasable status value of Yes without selecting any rows, click Release All .
