Reverse routes
Available with Location Referencing license.
During the lifespan of a pipeline, the direction of calibration of a route may need to be reversed as a result of calibration in the wrong direction or in preparation for a realignment that requires route calibration to be reversed.
When this occurs, you can reverse the route direction using the Reverse Route tool. Then, you can reapply event behaviors to the reversed route.
Reversing a route is an editing activity that allows you to reverse the direction of calibration on a route or routes in an LRS Network. The Reverse Route tool updates calibration points located along the reversed route and reverses the route direction.
Beta:
You can use the ArcGIS Pro Assistant (Beta) to perform route reversal and to guide you through the workflow.
Route reversal scenarios
Route reversal scenarios are described below.
Route reversal with intermediate calibration points at equidistance
In the following example, Route1 has a start measure of 0 and an end measure of 10 with intermediate calibration points at 2.5, 5, and 7.5:
After reversing the route, the start and end measures are reversed, and intermediate calibration measures are updated, but the location of calibration points remains unchanged.
Route reversal with disproportionate intermediate calibration points
In the following example, Route1 has a start measure of 0 and an end measure of 10 with a disproportionate intermediate calibration point (8):
The start and end measures are reversed, and the intermediate calibration measure is updated from 8 to 2, but the location of the calibration point remains unchanged.
Route reversal on a line in a line network
Before route reversal, Route1 has start and end measures of 0 and 10, Route2 has start and end measures of 15 and 25, and Route3 has start and end measures of 30 and 40. The line order for the routes is 100, 200, and 300, respectively.
In the following example, three routes that are present on a line (LineA) in a line network are reversed:
After the reversal, the start and end measures are updated, but the location of the calibration points remains unchanged.
After the reversal, each of the routes has the same start and end measures but in the opposite direction. The line order remains the same before and after the route reversal.
Route reversal workflow
To reverse a route, complete the following steps:
Add the network feature class to a map.
Alternatively, open a map in which the network feature class is present.
Branch versioned networks, including any network configured with a user-generated route ID, must be edited through a feature service.
Zoom in to the location of the route you want to reverse.
On the Location Referencing tab, in the Routes group, click Reverse
The Reverse Route pane appears.
Choose the network in which you want to reverse the route.
If the network is a nonline network, the Route Name parameter appears in the pane.
If the network is a line network, the From Route Name and To Route Name parameters appear in the pane.
To edit using feature services, the LRS Network must be published with the Linear Referencing and Version Management capabilities.
Provide an effective date for the route reversal by doing one of the following:
Double-click in the Effective Date text box to use today's date.
Provide the date in the Effective Date text box.
Click the Calendar button
and choose a date.
Choose a route to reverse using the Choose route from map button
.If the network is a line network, click the Choose route from map button
, and select the ending route on the map to populate the To Route Name parameter.If the From Route Name and To Route Name values in a line network are not the same, the routes spanned by the map selection are reversed.
Click Run.
The selected routes are reversed.
