View centerline sequence table properties
Available with Location Referencing license.
You can view centerline sequence table properties as either stand-alone table properties or as database-level properties.
Centerline sequence table properties
The following tables describe the centerline sequence table properties:
Name
The Name property appears at the top of the Location Referencing tab.
Property
Name
The name of the centerline sequence table.
Fields
You can view the following Fields properties for the centerline sequence table:
Property
Centerline ID
The unique ID of the centerline.
Route ID
The unique ID of the route associated with the centerline.
From Date
The date the centerline became active.
To Date
The date the centerline became inactive. This can be null.
Network ID
The unique ID of the network associated with the centerline.
View standalone centerline sequence table properties
You can view the properties of a stand-alone centerline sequence table from the Contents pane:
  1. Open the Contents pane in ArcGIS Pro.
  2. Expand the geodatabase connection to browse to the Centerline_Sequence table.
  3. Right-click the stand-alone Centerline_Sequence table in the Contents pane, and click Properties.
    The Standalone Table Properties dialog box appears with the table name in the title bar.
    The tabs on the dialog box are specific to the selected layer type.
  4. Click the Location Referencing tab.
    Scroll down if the tab isn't visible in the list.
    The Location Referencing tab displays general properties for the selection at the top, with additional nodes below.
  5. Click the arrow for a node to expand or collapse its properties.
    If the value or field name is longer than the field, hover over the property to view its details, or resize the dialog box to view additional details.
    Tip:
    You can copy the read-only properties to the clipboard.
  6. Click OK to close the Standalone Table Properties dialog box.
You can view the database-level properties of a centerline sequence table from the Catalog pane:
  1. Open the Catalog pane in ArcGIS Pro.
  3. Right-click the stand-alone Centerline_Sequence table in the Catalog pane, and click Properties.
    The Table Properties dialog box appears with the table name in the title bar.
    Tip:
  6. Click OK to close the Table Properties dialog box.
