View LRS intersection properties
Available with Location Referencing license.
You can view the properties of an LRS intersection as either a map layer or a feature class.
To modify existing LRS intersection properties, use the Modify LRS Intersection geoprocessing tool.
Learn more about creating and modifying LRS intersections
The following tables describe the intersection properties:
Name and feature class
The intersection name and parent network properties appear at the top of the Location Referencing tab.
Property
Intersection Name
The name of the selected intersection.
Parent Network
The LRS Network in which the event is located.
Tolerance and resolution
You can view the following Tolerance and Resolution properties:
Learn more about tolerance and resolution settings for the LRS
Property
XY Tolerance
The x,y tolerance set for the network feature class.
M Tolerance
The m-tolerance set for the network feature class.
Z Tolerance
The z-tolerance set for the network feature class.
XY Resolution
The x,y resolution set for the network feature class.
M Resolution
The m-resolution set for the network feature class.
Z Resolution
The z-resolution set for the events feature class.
Fields
You can view the following Fields properties for the intersection feature class:
Property
Network Description
The field used to describe intersections with other layers. The name separator and description field of the intersection layer are concatenated when events are recorded.
Intersecting ID
The name of the intersection ID field.
Intersection Name
The name of the intersection.
Route ID
The unique ID of the route.
Feature ID
The unique ID of the intersecting feature.
Feature Class Name
The name of the intersection point feature class.
From Date
The date the network became active.
To Date
The date the network was retired.
Measure
The measure on the dominant route where the intersection is located.
Intersecting layers
You can view the following Intersecting Layers properties:
Property
Intersecting Feature
The feature class that intersects the LRS Network.
Intersecting ID
The field in the intersecting layer used to uniquely identify the feature that intersects the network.
Description Field
The field that provides the description, such as town or county name, of the intersecting feature.
Name Separator
The name separator for the intersection, such as AND, INTERSECT, +, or |.
View intersection properties by map layer
You can view the properties of an LRS intersection map layer from the Contents pane:
  1. Open the Contents pane in ArcGIS Pro.
  2. Right-click the intersection layer, and click Properties.
    The Layer Properties dialog box appears with the selected network layer name in the title bar.
    The tabs on the dialog box are specific to the selected layer type.
  3. Click the Location Referencing tab.
    Scroll down if the tab isn't visible in the list.
    The Location Referencing tab displays general properties for the selection at the top, with additional nodes below.
  4. Click the arrow for a node to expand or collapse its properties.
    If the value or field name is longer than the field, hover over the property to view its details, or resize the dialog box to view additional details.
    Tip:
    You can copy the read-only properties to the clipboard.
  5. Click OK to close the Layer Properties dialog box.
View intersection properties by feature class
You can view the properties of an LRS intersection feature class from the Catalog pane:
  1. Open the Catalog pane in ArcGIS Pro.
  2. Expand the geodatabase connection and the feature dataset to browse to the feature class.
  3. Right-click the intersection feature class, and click Properties.
    The Feature Class Properties dialog box appears with the selected feature class name in the title bar.
  4. Click the Location Referencing tab.
  5. Click the arrow for a node to expand or collapse its properties.
    Tip:
  6. Click OK to close the Feature Class Properties dialog box.
