View redline properties
Available with Location Referencing license.
You can view the properties of a redline as either a map layer or a feature class.
Redline properties
The following tables describe the redline properties:
Name
The Redline Name property appears at the top of the Location Referencing tab.
Property |
Description |
Redline Name |
The name of the redline feature class. |
Fields
You can view the following Fields properties for the redline feature class:
Property |
Description |
From Measure |
The Start Measure field of the redline feature class. |
To Measure |
The End Measure field of the redline feature class. |
Route ID |
The unique ID of the route with which the redline is associated. |
Route Name |
The unique name of the route with which the redline is associated. |
Effective Date |
The effective date of the redline feature. |
Activity Type |
The edit activity type of the redline feature, such as create route, extend route, and so on. |
Network ID |
The unique ID of the network with which the redline is associated. |
View redline properties by map layer
You can view the properties of a redline map layer from the Contents pane:
Open the Contents pane in ArcGIS Pro.
Right-click the redline layer, and click Properties.
The Layer Properties dialog box appears with the selected network layer name in the title bar.
The tabs on the dialog box are specific to the selected layer type.
Click the Location Referencing tab.
Scroll down if the tab isn't visible in the list.
The Location Referencing tab displays general properties for the selection at the top, with additional nodes below.
Click the arrow for a node to expand or collapse its properties.
If the value or field name is longer than the field, hover over the property to view its details, or resize the dialog box to view additional details.
Tip:
You can copy the read-only properties to the clipboard.
Click OK to close the Layer Properties dialog box.
View redline properties by feature class
You can view the properties of a redline feature class from the Catalog pane:
Open the Catalog pane in ArcGIS Pro.
Expand the geodatabase connection and the feature dataset to browse to the feature class.
Right-click the redline feature class, and click Properties.
The Feature Class Properties dialog box appears with the selected feature class name in the title bar.
Tip:
Click OK to close the Feature Class Properties dialog box.
