Override SCAMIN
Available with ArcGIS Maritime license.
The SCAMIN_STEP property is a coded value domain at the feature level used to override SCAMIN values calculated on export. The following are the values that you can set for this property:
SCAMIN_STEP values
SCAMIN_STEP |
Description |
NULL |
When |
0 |
By setting |
1, 2, 3, or 4 |
When |
999—Fixed SCAMIN |
A fixed SCAMIN value of 999 is set on the feature. |
Additional fixed values are present in the domain, and the domain can be extended to include more values if needed.
Complete the following steps to override the SCAMIN value:
Start ArcGIS Pro.
Open a new or existing project.
Add data from a maritime S-57 geodatabase to the map if necessary.
The Maritime S-57 tab appears.
Select a feature on the map.
On the Maritime S-57 tab, in the Selection group, click the Attributes button
.The Attributes pane appears.
In the Maritime Attributes section, locate the SCAMIN attribute.
The SCAMIN attribute is in the S-57 Attributes group.
Change the attribute value.
Click Apply.
Save the changes.
