Data performance tips
Available with Location Referencing license.
Database tuning and the implementation of attribute and spatial indexes during the data loading operation can enhance the performance of any application. This is especially true for data intensive applications such as ArcGIS Roads and Highways.
For optimal performance in Roads and Highways, ensure that your database has the appropriate indexes created. You can use the Add Attribute Index tool to create indexes.
Table name
Multicolumn attribute index fields
LRS Network feature class
  • RouteID (the concatenated routeID in the network feature class)
  • From Date
  • To Date
  • Route Name (if configured)
Calibration Point feature class
  • Route ID
  • Network ID
  • From Date
  • To Date
Centerline feature class
  • Centerline ID
Centerline Sequence table
  • Route ID
  • Network ID
  • From Date
  • To Date
  • Centerline ID
Lookup table
Key Field (if the lookup table is configured with this field)
Event feature class
  • Event ID
  • Route ID
  • To Route ID (if configured)
  • From Date, To Date
Intersection feature class
  • Route ID
  • From Date
  • To Date
Since the centerline, calibration point, network, and event feature classes are stored in a geodatabase, spatial indexes are automatically created and maintained. In some circumstances, recalculating a spatial index can improve performance.
