Introduction to ArcGIS Roads and Highways
Available with Location Referencing license.
ArcGIS Roads and Highways is a linear referencing system (LRS) solution for departments of transportation that extends the ArcGIS technology. The capabilities supported by the Roads and Highways LRS platform include the following:
In ArcGIS Pro 3.8, the tools on the Location Referencing tab will be moved to the Linear Referencing tab.
LRS Network management
LRS Network management allows you to visualize and maintain your roadway LRS Networks and associated event data, as well as edit and maintain LRS Networks. You can also provide rule-based location management that allows you to define how event measures and route associations will react to changes in the LRS, keeping your event data aligned with roadway LRS Network changes.
Event location management
Roads and Highways supports updating event measures and route associations based on changes to the LRS Network. For events modeled in the geodatabase and registered with Roads and Highways, you can update event measures and route associations directly.
Roads and Highways supports the following measure behavior rules:
Stay Put—The x,y location of the event is preserved, but the m-values can change.
Move—The m-values are preserved, but the x,y location can change.
Retire—Both the m- and x,y-values are preserved, but the event record only displays if the event layer is rolled back to a time before the event's retire date.
Snap—The location along the route is preserved, but in retired portions of a route, the event can change ownership to a concurrent route in that location; m-values and route references are subject to change.
Cover—Both measure and geographic location can change to ensure the event covers an entire edited section of a route.
Support for multiple linear referencing methods
Roads and Highways supports multiple linear referencing methods (LRM). The data model supports combining event data from different linear referencing methods. It also supports translating event data from one LRM to another.
Platform for reporting
Roads and Highways spatially enables event data from non-GIS systems and integrates it through the LRS. Roads and Highways, in concert with ArcGIS, can be used to generate data products and maps that support safety analysis, traffic congestion analysis, infrastructure maintenance planning, and other roadway data analyses. These reports and data products can provide government and public entities transparency into many facets of highway-based data, such as highway assets, incidents, and roadway characteristics.
LRS web services
Roads and Highways extends the ArcGIS Server map service to provide linear referencing capability to your data as REST services. These capabilities include the following:
Event editing
Translating coordinates to measures
Translating measures to coordinates
Translating between measure systems
Dynamically segmenting event layers
Detecting gaps, overlaps, and invalid measures on events
For more information about services and developing for services, refer to the following:
Quality control
Roads and Highways provides quality control checks for LRS Networks and event data. In addition, Roads and Highways includes ArcGIS Data Reviewer, a feature set that extends the ArcGIS software for checking data and managing data errors.
Learn more about ArcGIS Data Reviewer
Workflow management
Roads and Highways includes access to standard ArcGIS Workflow Manager capabilities, which can be used to manage workflows across business units and to develop a standardized and repeatable process for LRS data management in your organization.
