00001: Data frame does not have layers
A data frame in the document you are importing is empty. It does not contain any layers.
Solutions
Do nothing. Accept the empty map.
Open the
.mxdfile in ArcMap and add layers to the empty data frame. Reimport the map document.Open the
.mxdfile in ArcMap and remove the data frame. This option is only available when more than one data frame exists in the map, as ArcMap documents must always have one data frame. Reimport the map document.
More information
The data frame in ArcMap and the equivalent map in ArcGIS Pro provide the principal display of geographic information as a set of map layers. Within the data frame and map, you display geographic datasets as layers, where each layer represents a particular dataset overlaid in the map.
See Adding layers to a map in ArcMap for more information.
