Work with export presets
Use export presets to save export settings for reuse. Export presets are files with an .xprt file extension. They are available in the Export gallery. Use them to open the Export pane with the same file type and settings each time. You can create custom preset files to add to the gallery or to share. Export presets are available for both map and layout exports.
Use export presets
To use an export preset, complete the following steps:
On the Share tab, click the lower half of the Export Map
or Export Layout button
to open the preset gallery.Select a preset from the gallery to open the Export pane with the preset settings applied or click the Open preset button
to browse to a preset using a file path.
Create export presets
To create an export preset, complete the following steps:
On the Share tab, click the upper half of the Export Map
to open the Export pane.In the Export pane, select a file type from the File Type drop-down list.
Adjust the settings of the selected file type for the preset.
Click the Save Preset button to open the Save Preset dialog box.
On the Save Preset dialog box, provide a name for the preset in the Name text box.
By default, the Location option is set to the folder for the preset gallery.
Optionally, use the Browse button
to choose a different location to save the preset file.If a new location is chosen, the preset does not appear in the preset gallery.
Security and map series settings are not included in presets, even if those options are available for the export type.
Default exports
The following default export presets are available for layouts:
Layout exports
Name |
Description |
Example Use Case |
Default AIX |
Basic settings for creating an |
Give the layout to a graphic designer to further refine it with the ArcGIS Maps for Adobe Creative Cloud extension. |
Flattened PDF |
Settings for a PDF document in which all vector data is rasterized, reducing the file size. Vector-specific capabilities for the PDF document, such as turning on and off layers, aren't available. |
Email the layout to a coworker or customer to open and view. This is preset usually produces the smallest size PDF. |
GeoReferenced PDF |
Settings for a PDF document in which the final output is georeferenced, meaning the map coordinates are available in the PDF document. |
Share the layout with someone so they can access the coordinates while viewing the PDF. |
GeoTIFF |
Settings for a TIFF image in which the final output is georeferenced, meaning the map coordinates are available. If there are multiple maps on the layout, select which map will be used for georeferencing, as |
Give the layout to someone to use as a raster layer in another project. |
Vector PDF |
Settings for a PDF document that includes vector capabilities such as turning on and off layers and is georeferenced. |
Provide the layout to someone to view different combinations of layers in the PDF. This also contains coordinates for them to reference. |
Web JPEG |
Settings for a simple JPEG image that can be uploaded to the web or otherwise shared. |
Upload the layout to a website. |
The following default export presets are available for maps:
Map exports
Name |
Description |
Example Use Case |
Default AIX - Map |
Give the map to a graphic designer to further refine it with the ArcGIS Maps for Adobe Creative Cloud extension. |
Flattened PDF - Map |
Email the map to a coworker or customer to open and view. This is preset usually produces the smallest size PDF. |
GeoTIFF - Map |
Settings for a TIFF image in which the final output is georeferenced, meaning the map coordinates are available. This allows you to use the TIFF image as raster data in other maps. |
Give the map to someone to use it as a raster layer in another project. |
Vector PDF - Map |
Provide the map to someone to view different combinations of layers in the PDF. This also contains coordinates for them to reference. |
Manage the export gallery
To view the export presets default folder, click the Project tab, click Options, and click the Share and Download tab. Additionally, you can set the gallery to reference a different folder containing export presets. Updating the folder location is useful for organizations in which many users need to access the same export preset files.
