DAML ID Reference ADMapping.daml
Language: C#
Subject: Framework
Contributor: ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization: Esri, https://www.esri.com
Date: 4/30/2026
ArcGIS Pro: 3.7
Visual Studio: 2022
Click this link to view ADMapping.daml.
- controls
- categories
- conditions
- dockpanes
- galleries
- groups
- insertsheet
- menus
- minitoolbars
- modules
- palettes
- panes
- propertysheets
- splitbuttons
- subgroups
- tabgroups
- tabs
- toolbars
controls
button
![]() | Name: Add to Current Map ID: esri_aiassistant_addQueryToCurrentMapButton Condition: esri_mapping_mapPane |
![]() | ID: esri_aiassistant_addQueryToNewMapButton |
![]() | Name: Edit Query ID: esri_aiassistant_editQueryButton |
![]() | Name: Calculation Rule ID: esri_attributeRulesView_AddCalculationRuleButton Condition: esri_mapping_attributeRulesView_editable |
![]() | Name: Constraint Rule ID: esri_attributeRulesView_AddConstraintRuleButton Condition: esri_mapping_attributeRulesView_editable |
![]() | Name: Validation Rule ID: esri_attributeRulesView_AddValidationRuleButton Condition: esri_mapping_attributeRulesView_editable |
![]() | Name: Contingent Values ID: esri_attributeRulesView_contingentValuesButton Condition: esri_mapping_attributeRulesPane |
![]() | Name: Delete Check ID: esri_attributeRulesView_deleteAttributeRulesCompositeRulesButton Condition: esri_mapping_attributeRulesView_compositeItemRuleSelected |
![]() | Name: Delete ID: esri_attributeRulesView_deleteRuleButton Condition: esri_mapping_attributeRulesView_rulesSelected_notCompositeRule |
![]() | Name: Disable ID: esri_attributeRulesView_disableRuleButton Condition: esri_mapping_attributeRulesView_disabled |
![]() | Name: Domains ID: esri_attributeRulesView_domainsButton Condition: esri_mapping_attributeRulesPane |
![]() | Name: Enable ID: esri_attributeRulesView_enableRuleButton Condition: esri_mapping_attributeRulesView_enabled |
![]() | Name: Export Rules ID: esri_attributeRulesView_exportRuleButton Condition: esri_mapping_attributeRulesView_canExport |
![]() | Name: Field Groups ID: esri_attributeRulesView_fieldGroupsButton Condition: esri_mapping_attributeRulesPane |
![]() | Name: Fields ID: esri_attributeRulesView_fieldsButton Condition: esri_mapping_attributeRulesPane |
![]() | Name: Browse... ID: esri_attributeRulesView_importBrowseRuleButton Condition: esri_mapping_attributeRulesView_editable |
![]() | Name: Parcel Fabric ID: esri_attributeRulesView_importParcelRuleButton Condition: esri_mapping_parcelAttributeRulesView_editable |
![]() | Name: Import Rules ID: esri_attributeRulesView_importRuleButton Condition: esri_mapping_attributeRulesView_editable |
![]() | Name: Save ID: esri_attributeRulesView_saveRulesButton Condition: esri_mapping_attributeRules_hasEditsCondition |
![]() | Name: Subtypes ID: esri_attributeRulesView_subtypesButton Condition: esri_mapping_attributeRulesPane |
![]() | Name: Refresh From Source ID: esri_bimCloudItemRefreshFromSourceMenuButton Condition: esri_mapping_openProjectState |
![]() | Name: Refresh From Source ID: esri_bimCloudItemRefreshFromSourceRibbonButton Condition: esri_mapping_openProjectState |
![]() | Name: Upload Support Files ID: esri_bimCloudItemUploadSupportFilesMenuButton Condition: esri_mapping_openProjectState |
![]() | Name: Attribute Rules ID: esri_contingentvaluesview_attributeRulesButton Condition: esri_mapping_designview_canOpenAttributeRules |
![]() | Name: Save ID: esri_contingentValuesView_commitButton Condition: esri_mapping_contingentValues_hasEditsCondition |
![]() | Name: Delete ID: esri_contingentValuesView_deleteCavButton Condition: esri_mapping_contingentValues_canAddContingentValuesCondition |
![]() | Name: Domains ID: esri_contingentvaluesview_domainsButton Condition: esri_mapping_contingentValuesPane |
![]() | Name: Export ID: esri_contingentValuesView_exportContingentValueButton Condition: esri_mapping_contingentValues_hasFieldGroupsCondition |
![]() | Name: Field Groups ID: esri_contingentvaluesview_fieldGroupsButton Condition: esri_mapping_contingentValuesPane |
![]() | Name: Fields ID: esri_contingentvaluesview_fieldsButton Condition: esri_mapping_contingentValuesPane |
![]() | Name: Generate ID: esri_contingentValuesView_generateContingentValuesButton Condition: esri_mapping_contingentValues_canGenerateContingentValuesCondition |
![]() | Name: Import ID: esri_contingentValuesView_importContingentValueButton Condition: esri_mapping_contingentValues_canImportContingentValues |
![]() | Name: New ID: esri_contingentValuesView_newContingentValueButton Condition: esri_mapping_contingentValues_canAddContingentValuesCondition |
![]() | Name: Retire Value ID: esri_contingentValuesView_retireContingentValue Condition: esri_mapping_contingentValues_canRetireValuesCondition |
![]() | Name: Subtypes ID: esri_contingentvaluesview_subtypesButton Condition: esri_mapping_contingentValuesView_canOpenSubtypesCondition |
![]() | Name: Toggle Code/Description ID: esri_contingentValuesView_toggleCodeDescription Condition: esri_mapping_contingentValues_hasFieldGroupsCondition |
![]() | Name: Toggle Value IDs ID: esri_contingentValuesView_toggleIDs Condition: esri_mapping_contingentValues_hasFieldGroupsCondition |
![]() | Name: Batch Calculation ID: esri_designview_batchCalculationButton Condition: esri_mapping_attributeRulesView_editable |
![]() | Name: Immediate Calculation ID: esri_designview_immediateCalculationButton Condition: esri_mapping_attributeRulesView_editable |
| Name: Calculate Geometry Fields ID: esri_designview_templatesCalculateGeometryFieldsButton Condition: esri_mapping_attributeRulesView_calculateGeometryFieldsCondition | |
| Name: Generate ID ID: esri_designview_templatesGenerateIdButton Condition: esri_mapping_attributeRulesView_editable | |
| Name: Generate Spatial Join ID: esri_designview_templatesSpatialJoinButton Condition: esri_mapping_attributeRulesView_spatialJoinCondition | |
| Name: Generate Symbol Rotation ID: esri_designview_templatesSymbolRotationButton Condition: esri_mapping_attributeRulesView_symbolRotationCondition | |
| Name: Generate Update Related ID: esri_designview_templatesUpdateRelatedButton Condition: esri_mapping_attributeRulesView_editable | |
![]() | Name: Save ID: esri_domainview_commitButton Condition: esri_mapping_domainsView_hasEditsCondition |
![]() | Name: New ID: esri_domainview_createnewdomainButton Condition: esri_mapping_domainsView_canEditDomainsCondition |
![]() | Name: Domain Usage ID: esri_domainview_currentdomainsinuseButton |
![]() | Name: Delete ID: esri_domainview_deletedomainButton Condition: esri_mapping_domainsView_canDelete |
![]() | Name: Select All In Layer ID: esri_editing_selectAllInLayer Condition: esri_mapping_mapPane |
![]() | Name: Save ID: esri_fieldsview_commitButton Condition: esri_mapping_fieldsView_hasEditsCondition |
![]() | Name: New ID: esri_fieldsview_createnewfieldButton Condition: esri_mapping_fieldsView_canAdd |
![]() | Name: Delete ID: esri_fieldsview_deletefieldButton Condition: esri_mapping_fieldsView_canDelete |
![]() | Name: Data Engineering ID: esri_fieldsview_openDataEngineering |
![]() | Name: Reset ID: esri_fieldsview_resetFieldOrderButton |
![]() | Name: Sort Ascending ID: esri_fieldsview_sortAscendingButton |
![]() | Name: Sort Descending ID: esri_fieldsview_sortDescendingButton |
![]() | Name: Attribute Rules ID: esri_fieldview_attributeRulesButton Condition: esri_mapping_designview_canOpenAttributeRules |
![]() | Name: Contingent Values ID: esri_fieldview_contingentvaluesButton Condition: esri_mapping_fieldsView_canOpenContingentValues |
![]() | Name: Domains ID: esri_fieldview_domainsButton Condition: esri_mapping_fieldsView_canOpenDomains |
![]() | Name: Field Groups ID: esri_fieldview_fieldGroupsButton Condition: esri_mapping_fieldsView_canFieldGroups |
![]() | Name: Subtypes ID: esri_fieldview_subtypesButton Condition: esri_mapping_fieldsView_canOpenSubtypes |
![]() | Name: Achromatopsia (full-color-blind) ID: esri_mapping_achromatopsiaContextButton |
![]() | Name: Create ID: esri_mapping_activateProfileViewTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Add Archive ID: esri_mapping_addArchiveTableButton Condition: esri_mapping_mapMemberSelectedIsArchiveEnabledCondition |
![]() | Name: Add To Selection ID: esri_mapping_addCandidateToSelection |
![]() | Name: Add System Style ID: esri_mapping_addCoreStyleButton |
| Name: Add custom... ID: esri_mapping_addCustomRasterProcessingTemplateButton | |
![]() | Name: Add Style ID: esri_mapping_addCustomStyleButton |
![]() | Name: Add Data ID: esri_mapping_addDataButton Condition: esri_mapping_mapPaneOrLayoutPaneOrLinkChart |
![]() | Name: Browse... ID: esri_mapping_addDataFromBrowseButton Condition: esri_mapping_mapPaneOrLayoutPaneOrLinkChart |
![]() | Name: From Path... ID: esri_mapping_addDataFromPathButton Condition: esri_mapping_mapPaneOrLinkChart |
![]() | Name: Add Data From Path ID: esri_mapping_addDataFromPathRibbonButton Condition: esri_mapping_mapPaneOrLinkChart |
![]() | Name: Add Data ID: esri_mapping_addDataToBuildingDisciplineLayerButton Condition: esri_mapping_onlyBimCompositeLayerSelectedCondition |
![]() | Name: Add Data ID: esri_mapping_addDataToGroupLayerButton Condition: esri_mapping_singleGroupLayerSelectedCondition |
![]() | Name: From File ID: esri_mapping_addFromFileButton Condition: esri_mapping_openProjectCondition |
![]() | Name: Add Error Layers ID: esri_mapping_addGDBErrorTablesButton Condition: esri_mapping_mapMemberSelectedSupportsGdbValidationCondition |
![]() | Name: Add Graphic ID: esri_mapping_addGraphicToMap |
![]() | Name: Make Layer from Catalog Dataset Item ID: esri_mapping_addSelectedCTSLayersButton |
![]() | Name: Add To Map ID: esri_mapping_addSelectedRastersToViewButton |
![]() | Name: Add to Favorites ID: esri_mapping_addToFavoritesButton |
![]() | Name: Add To Feature Class ID: esri_mapping_addToFeatureClassButton |
![]() | Name: Adjustable ID: esri_mapping_adjustableAppendTransitionButton Condition: esri_mapping_mapPaneOrLayoutPane |
| Name: Append Keyframe (Ctrl+Click) ID: esri_mapping_animationAppendKeyframeButton Condition: esri_mapping_mapPaneOrLayoutPane | |
| Name: Add Control Point ID: esri_mapping_animationControlPointAtClickButton Condition: esri_mapping_mapPaneOrLayoutPane | |
| Name: Delete Keyframe ID: esri_mapping_animationDeleteKeyframeButton Condition: esri_mapping_mapPaneOrLayoutPane | |
![]() | Name: Movie ID: esri_mapping_animationExportButton Condition: esri_mapping_mapPaneOrLayoutPane |
| Name: Insert Keyframe After ID: esri_mapping_animationInsertAfterButton Condition: esri_mapping_mapPaneOrLayoutPane | |
| Name: Insert Keyframe Before ID: esri_mapping_animationInsertBeforeButton Condition: esri_mapping_mapPaneOrLayoutPane | |
![]() | Name: Lock View Size ID: esri_mapping_animationLockViewSizeButton Condition: esri_mapping_mapPaneOrLayoutPane |
| Name: Set Keyframe Target Point (Shift+Click) ID: esri_mapping_animationLookAtClickPointButton Condition: esri_mapping_mapPaneOrLayoutPane | |
| Name: Look At Next Keyframe ID: esri_mapping_animationLookAtNextKeyframeButton Condition: esri_mapping_mapPaneOrLayoutPane | |
![]() | Name: Overlay Properties ID: esri_mapping_animationOverlayPropertiesButton |
| Name: Prepend Keyframe (Ctrl+Shift+Click) ID: esri_mapping_animationPrependKeyframeButton Condition: esri_mapping_mapPaneOrLayoutPane | |
![]() | Name: Preview ID: esri_mapping_animationPreviewButton Condition: esri_mapping_mapPaneOrLayoutPane |
| Name: Remove Control Point ID: esri_mapping_animationRemoveControlPointButton Condition: esri_mapping_mapPaneOrLayoutPane | |
| Name: Remove Look At Point ID: esri_mapping_animationRemoveLookAtPointButton Condition: esri_mapping_mapPaneOrLayoutPane | |
![]() | Name: Remove ID: esri_mapping_animationRemoveTrack Condition: esri_mapping_mapPaneOrLayoutPane |
| Name: Reset Control Points ID: esri_mapping_animationResetControlPointsButton Condition: esri_mapping_mapPaneOrLayoutPane | |
![]() | Name: Settings ID: esri_mapping_animationSettingsButton |
![]() | Name: Timeline ID: esri_mapping_animationTimelineButton Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Annotate Selected Features ID: esri_mapping_annotateSelectedButton Condition: esri_mapping_singleFeatureLayerSelectedCondition |
| Name: Append ID: esri_mapping_appendTransitionButton Condition: esri_mapping_mapPaneOrLayoutPane | |
![]() | Name: Attach to Camera ID: esri_mapping_attachSlicePlaneToCameraButton |
| Name: Auto-complete ID: esri_mapping_autoCompleteProfileButton | |
![]() | Name: Computation Settings ID: esri_mapping_binningComputationSettingsButton Condition: esri_mapping_singleBinningLayerSelectedCondition |
![]() | Name: Summary Statistics ID: esri_mapping_binningStatsButton Condition: esri_mapping_singleBinningLayerSelectedCondition |
![]() | Name: Bring Forward ID: esri_mapping_bringForwardButton |
![]() | Name: Bring To Front ID: esri_mapping_bringToFrontButton |
![]() | Name: Import ID: esri_mapping_browseThumbnailButton |
![]() | Name: Camera Effect Settings ID: esri_mapping_cameraEffectSettingsButton |
![]() | Name: Camera ID: esri_mapping_cameraEffectToggleButton Condition: esri_mapping_CameraEffectCondition |
![]() | Name: Camera ID: esri_mapping_cameraPropertiesControl |
![]() | Name: Cancel ID: esri_mapping_cancelExistingFillCacheRequestsButton Condition: esri_mapping_fillCacheInProgressCondition |
![]() | Name: Cast Shadow ID: esri_mapping_castShadowButton |
![]() | Name: Change Moment ID: esri_mapping_changeTimeButton Condition: esri_mapping_dataSourceSelectedIsValidForChangeMomentCondition |
![]() | Name: Change To Default ID: esri_mapping_changeToDefaultVersionButton Condition: esri_mapping_dataSourceSelectedIsValidForChangeVersionToDefaultCondition |
![]() | Name: Change Version ID: esri_mapping_changeVersionButton Condition: esri_mapping_dataSourceSelectedIsValidForChangeVersionCondition |
![]() | Name: Clear All ID: esri_mapping_clearInteractiveAnalysisButton Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Clear Selection ID: esri_mapping_clearLayerSelectionButton Condition: esri_mapping_selectionSupportedLayersSelectedCondition |
![]() | Name: Clear Reference Scale ID: esri_mapping_ClearMapReferenceScale |
![]() | Name: Clear ID: esri_mapping_clearSelectionButton Condition: esri_mapping_mapPane |
![]() | Name: Clear ID: esri_mapping_clearSelectionLasPointsButton Condition: esri_mapping_mapPane |
![]() | Name: Clear Selection ID: esri_mapping_clearStandaloneTableSelectionButton |
![]() | Name: Clear ID: esri_mapping_clearTableRecordSelection Condition: esri_mapping_allOidTablesSelectedCondition |
![]() | Name: Summary Statistics ID: esri_mapping_clusteringStatsButton Condition: esri_mapping_singleClusteringLayerSelectedCondition |
![]() | Name: Color Vision Simulator ID: esri_mapping_colorVisionSimulatorButton Condition: esri_mapping_ColorVisionCondition |
![]() | Name: To Basemap ID: esri_mapping_convertToBasemapButton Condition: esri_mapping_MapConvertCondition |
![]() | Name: Checkbox ID: esri_mapping_convertToCheckboxGroupLayerButton Condition: esri_mapping_singleGroupLayerSelectedCondition |
![]() | Name: To Global Scene ID: esri_mapping_convertToGlobalSceneButton Condition: esri_mapping_MapConvertCondition |
![]() | Name: To Local Scene ID: esri_mapping_convertToLocalSceneButton Condition: esri_mapping_MapConvertCondition |
![]() | Name: To Map ID: esri_mapping_convertToMapButton Condition: esri_mapping_MapConvertCondition |
![]() | Name: Radio ID: esri_mapping_convertToRadioGroupLayerButton Condition: esri_mapping_singleGroupLayerSelectedCondition |
![]() | Name: Copy Coordinates ID: esri_mapping_copyCoordinates Condition: esri_mapping_mapPane |
![]() | Name: DD ID: esri_mapping_copyDDButton Condition: esri_mapping_mapPane |
![]() | Name: DDM ID: esri_mapping_copyDDMButton Condition: esri_mapping_mapPane |
![]() | Name: DMS ID: esri_mapping_copyDMSButton Condition: esri_mapping_mapPane |
![]() | Name: MGRS ID: esri_mapping_copyMGRSButton Condition: esri_mapping_mapPane |
![]() | Name: Copy Records ID: esri_mapping_copyRecordsButton Condition: esri_mapping_singleFeatureLayerSelectedCondition |
![]() | Name: Copy ID: esri_mapping_copySelectedCTSLayersButton |
![]() | Name: Copy ID: esri_mapping_copySelectedElevationSourceLayerButton Condition: esri_mapping_ElevationSourceLayerSelectedCondition |
![]() | Name: Copy ID: esri_mapping_copySelectedElevationSurfaceLayerButton Condition: esri_mapping_IsGroundSurfaceLayerSelectedCondition |
![]() | Name: Copy ID: esri_mapping_copySelectedLayersButton Condition: esri_mapping_canCopySelectedLayersCondition |
![]() | Name: Copy ID: esri_mapping_copyStyleItemButton |
![]() | Name: USNG ID: esri_mapping_copyUSNGButton Condition: esri_mapping_mapPane |
![]() | Name: UTM ID: esri_mapping_copyUTMButton Condition: esri_mapping_mapPane |
![]() | Name: New Bookmark... ID: esri_mapping_createBookmark |
| Name: New Mosaic ID: esri_mapping_createMosaicDatasetButton | |
![]() | Name: New Version ID: esri_mapping_createNewVersionButton Condition: esri_mapping_itemSelectedIsVersionableAndNoEditsAndNotBranchClientServerCondition |
![]() | Name: New Filter ID: esri_mapping_createObject3DRenderingFilter |
| Name: Along a Line ID: esri_mapping_createProfileAlongCreatedLineButton | |
| Name: Along Selected Lines ID: esri_mapping_createProfileAlongSelectedLineButton | |
| Name: Cross Section ID: esri_mapping_createProfileCrossSectionButton | |
![]() | Name: Make Layer From Selected Features ID: esri_mapping_createSelectionLayerButton Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Layer From Selection ID: esri_mapping_createSelectionLayerButton_Ribbon Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Create Surface Layers From Sources ID: esri_mapping_createSurfaceLayersFromSelectedSourcesButton |
![]() | Name: Create Surface Layers From Sources ID: esri_mapping_createSurfaceLayersFromSourcesButton |
| Name: Create Thumbnail ID: esri_mapping_createThumbnail | |
| Name: Create ID: esri_mapping_createThumbnailButton | |
| Name: Custom ID: esri_mapping_customBandCombinationButton | |
![]() | Name: Delete Cut And Fill ID: esri_mapping_CutFillDeleteButton |
![]() | Name: Move Cut And Fill ID: esri_mapping_CutFillMoveButton |
![]() | Name: Cut And Fill Properties ID: esri_mapping_cutFillPropertiesButton |
![]() | Name: Tilt Cut And Fill ID: esri_mapping_CutFillRotateButton |
![]() | Name: Cut ID: esri_mapping_cutSelectedElevationSourceLayerButton Condition: esri_mapping_ElevationSourceLayerSelectedCondition |
![]() | Name: Cut ID: esri_mapping_cutSelectedElevationSurfaceLayerButton Condition: esri_mapping_IsGroundSurfaceLayerSelectedCondition |
![]() | Name: Cut ID: esri_mapping_cutStyleItemButton |
![]() | Name: Apply ID: esri_mapping_dataSources_ApplyButton |
![]() | Name: Discard ID: esri_mapping_dataSources_DiscardButton |
![]() | Name: Data Sources ID: esri_mapping_dataSources_editDataSourcesButton |
![]() | Name: Update Data Sources ID: esri_mapping_dataSources_editDataSourcesContextMenuButton |
![]() | Name: Filter ID: esri_mapping_dataSources_FilterButton |
![]() | Name: Find and Replace ID: esri_mapping_dataSources_FindAndReplaceButton |
![]() | Name: Repair ID: esri_mapping_dataSources_RepairButton |
![]() | Name: Save As ID: esri_mapping_dataSources_SaveAsButton |
![]() | Name: Close ID: esri_mapping_dataSources_stopDataSourcesEditingButton |
![]() | Name: Validate and Apply ID: esri_mapping_dataSources_ValidateApplyButton |
![]() | Name: Validate ID: esri_mapping_dataSources_ValidateButton |
![]() | Name: Item ID: esri_mapping_dataSources_ViewItemButton |
![]() | Name: Workspace ID: esri_mapping_dataSources_ViewWorkspaceButton |
![]() | Name: Delete All Inactive Filters ID: esri_mapping_deleteAllObject3DRenderingFilters |
![]() | Name: Delete ID: esri_mapping_deleteInteractiveAnalysisButton |
![]() | Name: Delete ID: esri_mapping_deleteStyleItemButton |
![]() | Name: Depth Priority ID: esri_mapping_depthPriorityButton |
![]() | Name: Configure Pop-ups ID: esri_mapping_designPopupsButton Condition: esri_mapping_isPopDesignEnabledCondition |
![]() | Name: Deuteranopia (green-blind) ID: esri_mapping_deuteranopiaContextButton |
![]() | Name: Enable Location ID: esri_mapping_deviceLocation_enableMyLocationButton Condition: esri_mapping_enableMyLocationEnabledCondition |
![]() | Name: Location Details ID: esri_mapping_deviceLocation_locationInfoButton Condition: esri_mapping_showLocationInfoEnabledCondition |
![]() | Name: Disable Masking ID: esri_mapping_disableMaskingButton Condition: esri_mapping_canDisableMaskings |
![]() | Name: Disable Modifications ID: esri_mapping_disableModificationsButton Condition: esri_mapping_canDisableIntegratedMeshModification |
![]() | Name: Disable Pop-ups ID: esri_mapping_disablePopupsButton |
| Name: Display Bookmark Label ID: esri_mapping_displayBookmarkLabelInView Condition: esri_mapping_mapPaneOrEquivalent | |
![]() | Name: Display Route Events... ID: esri_mapping_displayRouteEventsButton Condition: esri_mapping_standaloneTableSelectedCondition |
![]() | Name: Save ID: esri_mapping_domainsview_commitButton Condition: esri_mapping_domainsView_hasSavableEditsCondition |
![]() | Name: Discard ID: esri_mapping_domainsview_discardButton Condition: esri_mapping_domainsView_hasEditsCondition |
![]() | Name: Refresh ID: esri_mapping_domainsview_refreshButton Condition: esri_mapping_domainsView_hasNoEditsCondition |
![]() | Name: Duplicate in Ground ID: esri_mapping_duplicateInGroundButton |
![]() | Name: Duplicate From Here ID: esri_mapping_duplicateSimulationFromCurrentButton |
![]() | Name: Edge Snapping ID: esri_mapping_edgeSnappingButton Condition: esri_mapping_mapPane |
![]() | Name: Edit ID: esri_mapping_editBandCombinationButton |
![]() | Name: Edit Query ID: esri_mapping_editQueryButton Condition: esri_mapping_singleSqlQuerySelectedCondition |
![]() | Name: Properties ID: esri_mapping_ElevationSourceLayerPropertiesButton Condition: esri_mapping_ElevationSourceLayerSelectedCondition |
![]() | Name: Add ID: esri_mapping_enableAnimationButton Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Binning ID: esri_mapping_enableBinningButton Condition: esri_mapping_singleBinningLayerSelectedCondition |
![]() | Name: Clusters ID: esri_mapping_enableClusteringButton Condition: esri_mapping_single2DClusteringLayerSelectedCondition |
![]() | Name: Eye-Dome Lighting ID: esri_mapping_enableEyeDomeLightingButton Condition: esri_mapping_EDLEnabledCondition |
![]() | Name: Enable Lighting ID: esri_mapping_enableLightingButton |
![]() | Name: Locked Ranges ID: esri_mapping_enableLockedRangesButton |
![]() | Name: Enable Masking ID: esri_mapping_enableMaskingButton Condition: esri_mapping_canEnableMaskings |
![]() | Name: Enable Modifications ID: esri_mapping_enableModificationsButton Condition: esri_mapping_canEnableIntegratedMeshModification |
![]() | Name: Enable Pop-ups ID: esri_mapping_enablePopupsButton |
![]() | Name: Active Range ID: esri_mapping_enableRangeButton Condition: esri_mapping_rangeEnabledCondition |
![]() | Name: Time ID: esri_mapping_enableTimeButton Condition: esri_mapping_timeEnabledCondition |
![]() | Name: End Snapping ID: esri_mapping_endSnappingButton Condition: esri_mapping_mapPane |
![]() | Name: Exit Swipe Mode ID: esri_mapping_exitSwipeButton |
![]() | Name: Explore ID: esri_mapping_exploreContext Condition: esri_mapping_mapPane |
![]() | Name: Export Bookmarks... ID: esri_mapping_exportBookmarksToFile Condition: esri_mapping_activeMapHasBookmarksCondition |
![]() | Name: Extract Locations ID: esri_mapping_extractLocationsButton Condition: esri_mapping_mapPaneOrLinkChart |
![]() | Name: Extruded Path and Keyframes ID: esri_mapping_extrudedPathFeedbackButton Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Face Snapping ID: esri_mapping_faceSnappingButton Condition: esri_mapping_mapPane |
![]() | Name: Save ID: esri_mapping_fieldsview_commitButton Condition: esri_mapping_fieldsView_hasEditsCondition |
![]() | Name: Discard ID: esri_mapping_fieldsview_discardButton Condition: esri_mapping_fieldsView_hasEditsCondition |
![]() | Name: Refresh ID: esri_mapping_fieldsview_refreshButton Condition: esri_mapping_fieldsView_hasNoEditsCondition |
![]() | Name: Variables ID: esri_mapping_filterByVariablesButton |
| Name: First-Person Navigation ID: esri_mapping_firstPersonModeButton Condition: esri_mapping_ViewingMode3DCondition | |
![]() | Name: Fixed ID: esri_mapping_fixedAppendTransitionButton Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Fixed Zoom In ID: esri_mapping_fixedZoomInButton |
![]() | Name: Fixed Zoom Out ID: esri_mapping_fixedZoomOutButton |
![]() | Name: Flash ID: esri_mapping_flashCandidateGraphic |
![]() | Name: Flash placemark ID: esri_mapping_flashSelectedKMLPlacemarks |
![]() | Name: Create Barrier ID: esri_mapping_floodSimCreateBarrierButton Condition: esri_mapping_mapPane |
![]() | Name: Create Channel ID: esri_mapping_floodSimCreateChannelButton Condition: esri_mapping_mapPane |
![]() | Name: Create Sink Area ID: esri_mapping_floodSimCreateWaterSinkAreaButton Condition: esri_mapping_mapPane |
![]() | Name: Create Water Area ID: esri_mapping_floodSimCreateWaterSourceAreaButton Condition: esri_mapping_mapPane |
![]() | Name: Create Water Source ID: esri_mapping_floodSimCreateWaterSourceButton Condition: esri_mapping_mapPane |
![]() | Name: Add Mask ID: esri_mapping_FSL_addMaskButton Condition: esri_mapping_canAddMaskingLayer |
![]() | Name: Exclude ID: esri_mapping_FSL_Exclude_MaskButton Condition: esri_mapping_canRemoveMaskingLayer |
![]() | Name: Include ID: esri_mapping_FSL_Include_MaskButton Condition: esri_mapping_canRemoveMaskingLayer |
| ID: esri_mapping_FSL_Masking_EnabledStateButtonRibbon | |
![]() | Name: Remove Mask ID: esri_mapping_FSL_removeMaskButton Condition: esri_mapping_canRemoveMaskingLayer |
![]() | Name: Geocode Table ID: esri_mapping_generalGeocodeTableButton |
![]() | Name: Generate Definition Query from Selection ID: esri_mapping_GenerateDefQuerySelectionButton |
![]() | Name: Refresh Filter Values ID: esri_mapping_generateSummaryStatisticsButton |
![]() | Name: Geocode Table... ID: esri_mapping_geocodeTableButton Condition: esri_mapping_mapPaneOrLinkChart |
![]() | Name: Close Georeference ID: esri_mapping_georeference_CloseSessionButton Condition: esri_mapping_GeoreferenceCondition |
![]() | Name: Elevate To Ground ID: esri_mapping_georeference_ElevateToGroundButton Condition: esri_mapping_GeoreferenceCondition |
![]() | Name: Move Input ID: esri_mapping_georeference_MoveButtonInput Condition: esri_mapping_GeoreferenceCondition |
![]() | Name: Move To Display ID: esri_mapping_georeference_MoveToDisplayButton Condition: esri_mapping_GeoreferenceCondition |
![]() | Name: Reset ID: esri_mapping_georeference_ResetButton Condition: esri_mapping_GeoreferenceCondition |
![]() | Name: Rotate Input ID: esri_mapping_georeference_RotateButtonInput Condition: esri_mapping_GeoreferenceCondition |
![]() | Name: Save As New ID: esri_mapping_georeference_SaveAsButton Condition: esri_mapping_GeoreferenceCondition |
![]() | Name: Save ID: esri_mapping_georeference_SaveButton Condition: esri_mapping_GeoreferenceCondition |
![]() | Name: Save To Workspace ID: esri_mapping_georeference_SaveToWorkspaceButton Condition: esri_mapping_GeoreferenceCondition |
![]() | Name: Scale Input ID: esri_mapping_georeference_ScaleButtonInput Condition: esri_mapping_GeoreferenceCondition |
![]() | Name: Transform ID: esri_mapping_georeferenceing_ModifyModelToWorldButton |
![]() | Name: Georeference ID: esri_mapping_georeferenceing_StartSessionButton |
![]() | Name: GIS Server ID: esri_mapping_GISServerButton Condition: esri_mapping_openProjectCondition |
![]() | Name: Global ID: esri_mapping_globe3DViewButton Condition: esri_mapping_mapPane |
![]() | Name: Go To XY ID: esri_mapping_gotoXYControl |
![]() | Name: Extract LAS ID: esri_mapping_GP3DAnalyst_ExtractLasButton |
![]() | Name: Extract Mesh Features ID: esri_mapping_GP3DAnalyst_ExtractMeshFeaturesUsingPointCloudButton |
![]() | Name: Extract Multipatch From Mesh ID: esri_mapping_GP3DAnalyst_ExtractMultipatchFromMeshButton |
![]() | Name: Extract Objects ID: esri_mapping_GP3DAnalyst_ExtractObjectsFromPointCloudButton |
![]() | Name: Extract Power Lines ID: esri_mapping_GP3DAnalyst_ExtractPowerLinesFromPointCloudButton |
![]() | Name: Extract Rails ID: esri_mapping_GP3DAnalyst_ExtractRailsFromPointCloudButton |
![]() | Name: Intervisibility ID: esri_mapping_GP3DAnalyst_IntervisibilityButton |
![]() | Name: Clip ID: esri_mapping_GPAnalysis_ClipButton |
![]() | Name: Mesh To LAS ID: esri_mapping_GPConversion_MeshToLASButton |
![]() | Name: Generate Level Of Detail ID: esri_mapping_GPManagement_GenerateLevelOfDetailButton |
![]() | Name: Project ID: esri_mapping_GPManagement_ProjectButton |
![]() | Name: Upgrade Scene Layer ID: esri_mapping_GPManagement_UpgradeSceneLayerButton |
![]() | Name: Export Isosurface ID: esri_mapping_GPMD_ExportIsosurfaceButton |
![]() | Name: Group ID: esri_mapping_groupSelectedLayersButton Condition: esri_mapping_CanGroupSelectedMapMembersCondition |
![]() | Name: Group ID: esri_mapping_groupSelectedTablesButton Condition: esri_mapping_CanGroupSelectedMapMembersCondition |
![]() | Name: Hide Selection ID: esri_mapping_hideSelectedFeaturesButton |
![]() | Name: Historical Moments ID: esri_mapping_historicalViewButton Condition: esri_mapping_dataSourceSelectedIsValidForChangeMomentCondition |
![]() | Name: Hop ID: esri_mapping_hopAppendTransitionButton Condition: esri_mapping_mapPaneOrLayoutPane |
| Name: Ignore Range ID: esri_mapping_ignoreBookmarkRange | |
| Name: Ignore Time ID: esri_mapping_ignoreBookmarkTime | |
![]() | Name: Illumination ID: esri_mapping_illuminationTimeButton Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Add Modification ID: esri_mapping_IM_Layer_addModificationButton Condition: esri_mapping_canAddIntegratedMeshModification |
![]() | Name: Add ID: esri_mapping_IM_Layer_addModificationButtonRibbon Condition: esri_mapping_canAddIntegratedMeshModification |
![]() | Name: Clip ID: esri_mapping_IM_Layer_ClipButton Condition: esri_mapping_canRemoveIntegratedMeshModification |
![]() | Name: Mask ID: esri_mapping_IM_Layer_MaskButton Condition: esri_mapping_canRemoveIntegratedMeshModification |
| ID: esri_mapping_IM_Layer_modificationEnabledStateButtonRibbon | |
![]() | Name: Remove Modification ID: esri_mapping_IM_Layer_removeModificationButton Condition: esri_mapping_canRemoveIntegratedMeshModification |
![]() | Name: Remove ID: esri_mapping_IM_Layer_removeModificationButtonRibbon Condition: esri_mapping_canRemoveIntegratedMeshModification |
![]() | Name: Replace ID: esri_mapping_IM_Layer_ReplaceButton Condition: esri_mapping_canRemoveIntegratedMeshModification |
![]() | Name: Import Bookmarks... ID: esri_mapping_importBookmarksFromFile |
![]() | Name: Import ID: esri_mapping_importFileStyleButton |
![]() | Name: Add Style ID: esri_mapping_importFileStylxButton |
![]() | Name: Add Style ID: esri_mapping_importPortalStylxButton |
![]() | Name: Import ID: esri_mapping_importStyleButton |
![]() | Name: Import Style ID: esri_mapping_importStyleRibbonButton |
![]() | Name: Import Thumbnail ID: esri_mapping_importThumbnail |
| Name: Visible Layers ID: esri_mapping_infoAllLayersButton Condition: esri_mapping_mapPaneOrEquivalent | |
![]() | Name: Configure Infographics ID: esri_mapping_infographicSettingsButton Condition: esri_mapping_infographic_signedIn_condition |
| Name: No Pop-ups ID: esri_mapping_infoNoneButton Condition: esri_mapping_mapPaneOrEquivalent | |
| Name: Selectable Layers ID: esri_mapping_infoSelectableLayersButton Condition: esri_mapping_mapPaneOrEquivalent | |
| Name: Selected in Contents ID: esri_mapping_infoSelectedTOCButton Condition: esri_mapping_mapPaneOrEquivalent | |
| Name: Topmost Layer ID: esri_mapping_infoTopmostLayerButton Condition: esri_mapping_mapPaneOrEquivalent | |
![]() | Name: Intersection Snapping ID: esri_mapping_intersectionSnappingButton Condition: esri_mapping_mapPane |
![]() | Name: Keep at Center ID: esri_mapping_keepLocationAtCenterButton |
![]() | Name: Keep within View ID: esri_mapping_keepLocationWithinViewButton |
![]() | Name: Keyframes ID: esri_mapping_keyFeedbackButton Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Path and Keyframes ID: esri_mapping_keyPathFeedbackButton Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Abbreviation Dictionaries... ID: esri_mapping_labelAbbreviationDictionariesButton Condition: esri_mapping_mapViewingMode2DCondition |
![]() | Name: Clear Limits ID: esri_mapping_labelClassClearScalesButton Condition: esri_mapping_labeledLayerSelectedCondition |
![]() | Name: Copy ID: esri_mapping_labelClassCopyButton Condition: esri_mapping_singleLabelClassSelectedCondition |
![]() | Name: Create Label Class... ID: esri_mapping_labelClassCreateButton Condition: esri_mapping_singleFeatureLayerSelectedCondition |
![]() | Name: Create Label Classes From Symbology... ID: esri_mapping_labelClassCreateFromSymbologyButton Condition: esri_mapping_singleFeatureLayerSelectedCondition |
| Name: Create... ID: esri_mapping_labelClassCreateSelectedButton Condition: esri_mapping_singleFeatureLayerSelectedCondition | |
![]() | Name: Duplicate ID: esri_mapping_labelClassDuplicateSelectedButton Condition: esri_mapping_singleFeatureLayerSelectedCondition |
![]() | Name: Expression ID: esri_mapping_labelClassExpressionButton Condition: esri_mapping_labeledLayerSelectedCondition |
![]() | Name: Expression ID: esri_mapping_labelClassPasteExpressionButton |
![]() | Name: All Properties ID: esri_mapping_labelClassPasteLabelClassButton |
![]() | Name: Placement Properties ID: esri_mapping_labelClassPasteLabelingPropsButton |
![]() | Name: SQL Query ID: esri_mapping_labelClassPasteSQLQueryButton |
![]() | Name: Text Symbol Properties ID: esri_mapping_labelClassPasteTextSymbolButton |
![]() | Name: Visibility Range ID: esri_mapping_labelClassPasteVisibilityRangeButton |
![]() | Name: Labeling Properties... ID: esri_mapping_labelClassPropertiesButton Condition: esri_mapping_singleFeatureLayerSelectedCondition |
![]() | Name: Remove All But This ID: esri_mapping_labelClassRemoveAllButThisButton Condition: esri_mapping_singleLabelClassSelectedCondition |
![]() | Name: Remove ID: esri_mapping_labelClassRemoveSelectedButton Condition: esri_mapping_singleFeatureLayerSelectedCondition |
![]() | Name: SQL Query ID: esri_mapping_labelClassSQLQueryButton Condition: esri_mapping_labeledLayerSelectedCondition |
![]() | Name: Convert Labels To Annotation... ID: esri_mapping_labelConvertLabelsToAnnoMenuButton Condition: esri_mapping_mapViewingMode2DCondition |
![]() | Name: Convert Labels To Graphics... ID: esri_mapping_labelConvertLabelsToGraphicsMenuButton Condition: esri_mapping_mapViewingMode2DCondition |
![]() | Name: Convert Labels To Annotation... ID: esri_mapping_labelConvertLayerLabelsToAnnoMenuButton Condition: esri_mapping_singleFeatureLayerSelectedCondition |
![]() | Name: Convert Labels To Graphics... ID: esri_mapping_labelConvertLayerLabelsToGraphicsMenuButton Condition: esri_mapping_singleFeatureLayerSelectedCondition |
| Name: Use Maplex Label Engine ID: esri_mapping_labelEngineButton Condition: esri_mapping_mapViewingMode2DCondition | |
| Name: Draft Quality ID: esri_mapping_labelEngineQualityButton Condition: esri_mapping_mapViewingMode2DCondition | |
![]() | Name: Label ID: esri_mapping_labelFeatureLayerEnableButton Condition: esri_mapping_labeledLayerSelectedCondition |
![]() | ID: esri_mapping_labelingOptionsButton Condition: esri_mapping_mapPane |
![]() | Name: Key Numbering... ID: esri_mapping_labelKeyNumberingButton Condition: esri_mapping_mapViewingMode2DCondition |
![]() | Name: Label ID: esri_mapping_labelKMLLayerEnableButton Condition: esri_mapping_labeledLayerSelectedCondition |
![]() | Name: Lock ID: esri_mapping_labelLockButton Condition: esri_mapping_mapViewingMode2DCondition |
![]() | Name: Label ID: esri_mapping_labelMapImageSubLayerEnableButton Condition: esri_mapping_mapServiceSubLayerSelectedCondition |
![]() | Name: Pause ID: esri_mapping_labelPauseButton Condition: esri_mapping_mapViewingMode2DCondition |
![]() | Name: Priorities... ID: esri_mapping_labelPriorityRankingButton Condition: esri_mapping_mapViewingMode2DCondition |
![]() | Name: Label ID: esri_mapping_labelSceneLayerEnableButton Condition: esri_mapping_labeledSceneLayerSelectedCondition |
![]() | Name: Summary... ID: esri_mapping_labelSummaryRankingButton Condition: esri_mapping_mapViewingMode2DCondition |
![]() | Name: Decrease Font Size ID: esri_mapping_labelTextSymbolDecreaseSizeButton Condition: esri_mapping_labeledLayerSelectedCondition |
![]() | Name: Increase Font Size ID: esri_mapping_labelTextSymbolIncreaseSizeButton Condition: esri_mapping_labeledLayerSelectedCondition |
![]() | Name: Labels to Annotation ID: esri_mapping_labelToAnnotationButton Condition: esri_mapping_singleFeatureLayerSelectedCondition |
![]() | Name: View Unplaced ID: esri_mapping_labelViewUnplacedButton Condition: esri_mapping_mapViewingMode2DCondition |
![]() | Name: Weights... ID: esri_mapping_labelWeightRankingButton Condition: esri_mapping_mapViewingMode2DCondition |
![]() | Name: Clear Limits ID: esri_mapping_layerClearScalesButton |
![]() | Name: Display Filters ID: esri_mapping_layerDisplayFilters Condition: esri_mapping_FeatureLayerIn2DMapCondition |
![]() | Name: Flicker ID: esri_mapping_layerFlickerButton |
![]() | Name: Scale Range ID: esri_mapping_layerScaleRangeToggleButton |
![]() | Name: Linear ID: esri_mapping_linearAppendTransitionButton Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Find Routes ID: esri_mapping_linearReferencing_findRoutes |
![]() | Name: Hatches ID: esri_mapping_linearReferencing_hatches Condition: esri_mapping_EnableDrawingCondition |
![]() | Name: Line of Sight Properties ID: esri_mapping_lineOfSightPropertiesButton |
![]() | Name: Link Cursors ID: esri_mapping_linkCursorsButton |
![]() | Name: Clear Feature Cache ID: esri_mapping_localFeatureCacheClearCache Condition: esri_mapping_allOidTablesSelectedCondition |
![]() | Name: Cache Features ID: esri_mapping_localFeatureCacheFillCache Condition: esri_mapping_allOidTablesSelectedCondition |
![]() | Name: What's here? ID: esri_mapping_locateReverseGeocode Condition: esri_mapping_locateProvidersReadyToUseWithMap |
![]() | Name: Pan to Location ID: esri_mapping_location_panToLocationButton |
![]() | Name: Track-up Mode ID: esri_mapping_location_trackUpOrientationButton |
![]() | Name: Zoom to Location ID: esri_mapping_location_zoomToLocationButton |
![]() | Name: Lock To Selection ID: esri_mapping_lockToSelectedRastersButton |
![]() | Name: Magnifier ID: esri_mapping_magnifierControl Condition: esri_mapping_mapPane |
![]() | Name: Elevation Source Layer... ID: esri_mapping_makeElevationSourceLayerButton Condition: esri_mapping_mapPaneOrLinkChart |
![]() | Name: Make Feature Layer From Sublayer ID: esri_mapping_makeFeatureLayerFromENCSublayerButton |
![]() | Name: Hyperspectral Data... ID: esri_mapping_makeHyperspectralRasterLayerButton Condition: esri_mapping_mapPaneOrLinkChart |
![]() | Name: Multidimensional Data... ID: esri_mapping_makeMultidimensionalRasterLayerButton Condition: esri_mapping_mapPaneOrLinkChart |
![]() | Name: Multidimensional Voxel Layer... ID: esri_mapping_makeMultidimensionalVoxelLayerButton Condition: esri_mapping_mapPaneOrLinkChart |
![]() | Name: Make this the only selectable layer ID: esri_mapping_makeOnlySelectableLayerButton Condition: esri_mapping_singleBasicFeatureLayerSelectedCondition |
![]() | Name: Make this the only snappable layer ID: esri_mapping_makeOnlySnappableLayerButton Condition: esri_mapping_singleSnappableLayerSelectedCondition |
![]() | Name: Query Layer... ID: esri_mapping_makeQueryLayerButton Condition: esri_mapping_mapPaneOrLinkChart |
![]() | Name: Make Route Event Layer ID: esri_mapping_makeRouteEventLayerButton Condition: esri_mapping_mapPaneOrLinkChart |
![]() | Name: Space Time Cube Layer... ID: esri_mapping_makeSpaceTimeCubeLayerButton Condition: esri_mapping_mapPaneOrLinkChart |
![]() | Name: Make Standalone Table From Subtable ID: esri_mapping_makeStandaloneTableFromENCSubtableButton |
![]() | Name: Subtype Group Layer... ID: esri_mapping_makeSubtypeGroupLayerButton Condition: esri_mapping_mapPaneOrLinkChart |
![]() | Name: Trajectory Data... ID: esri_mapping_makeTrajectoryLayerButton Condition: esri_mapping_mapPaneOrLinkChart |
![]() | Name: Make XY Event Layer ID: esri_mapping_makeXYEventLayerButton Condition: esri_mapping_mapPaneOrLinkChart |
![]() | Name: Manage Style ID: esri_mapping_ManageStyleButton |
![]() | Name: Empty ID: esri_mapping_manualClearCacheButton Condition: esri_mapping_featureCachingEnabledWithActiveMapCondition |
![]() | Name: Fill ID: esri_mapping_manualFillCacheButton Condition: esri_mapping_fillCacheNotInProgressCondition |
![]() | Name: Map ID: esri_mapping_map2DViewButton Condition: esri_mapping_mapPane |
![]() | Name: Open ID: esri_mapping_mapContextMenuContainmentViewButton |
![]() | Name: To Map ID: esri_mapping_mapContextMenuConvertStereoMapTo2DMapButton |
![]() | Name: To Local Scene ID: esri_mapping_mapContextMenuConvertStereoMapTo3DLocalSceneButton |
![]() | Name: To Global Scene ID: esri_mapping_mapContextMenuConvertStereoMapTo3DSceneButton |
![]() | Name: To Map ID: esri_mapping_mapContextMenuConvertTo2DButton |
![]() | Name: To Global Scene ID: esri_mapping_mapContextMenuConvertTo3DButton |
![]() | Name: To Basemap ID: esri_mapping_mapContextMenuConvertToBasemapButton |
![]() | Name: To Local Scene ID: esri_mapping_mapContextMenuConvertToLocalSceneButton |
![]() | Name: To Map ID: esri_mapping_mapContextMenuConvertToMapButton |
![]() | Name: Open Global View ID: esri_mapping_mapContextMenuGlobe3DViewButton |
![]() | Name: Open ID: esri_mapping_mapContextMenuMap2DViewButton |
![]() | Name: Open ID: esri_mapping_mapContextMenuNetworkDiagramViewButton |
![]() | Name: Delete ID: esri_mapping_mapContextMenuRemoveButton |
![]() | Name: Open Local View ID: esri_mapping_mapContextMenuScene3DViewButton |
![]() | Name: Open ID: esri_mapping_mapContextMenuStereoMapViewButton |
![]() | Name: Geocode Table ID: esri_mapping_mapMemberGeocodeTableButton |
![]() | Name: Properties ID: esri_mapping_mapPropertiesButton Condition: esri_mapping_mapSelectedCondition |
![]() | Name: Measure ID: esri_mapping_measureCurrentTool Condition: esri_mapping_mapPane |
| Name: Ground Area ID: esri_mapping_measurement_default_groundArea Condition: esri_mapping_imageLoadedInOrientedImageryViewerCondition | |
| Name: Ground Distance ID: esri_mapping_measurement_default_groundDistance Condition: esri_mapping_imageLoadedInOrientedImageryViewerCondition | |
| Name: Height Above Ground ID: esri_mapping_measurement_default_heightAboveGround Condition: esri_mapping_imageLoadedInOrientedImageryViewerCondition | |
| Name: Surface Location ID: esri_mapping_measurement_default_surfaceLocation Condition: esri_mapping_imageLoadedInOrientedImageryViewerCondition | |
| Name: Area ID: esri_mapping_measurement_triangulated_area Condition: esri_mapping_imageLoadedInOrientedImageryViewerCondition | |
| Name: Distance ID: esri_mapping_measurement_triangulated_distance Condition: esri_mapping_imageLoadedInOrientedImageryViewerCondition | |
| Name: Location ID: esri_mapping_measurement_triangulated_location Condition: esri_mapping_imageLoadedInOrientedImageryViewerCondition | |
![]() | Name: Midpoint Snapping ID: esri_mapping_midpointSnappingButton Condition: esri_mapping_mapPane |
![]() | Name: Zoom To ID: esri_mapping_moveCameraToInteractiveAnalysisButton |
![]() | Name: Move to... ID: esri_mapping_moveToInteractiveAnalysisButton |
![]() | Name: Go to camera position ID: esri_mapping_moveToKMLNode |
![]() | Name: Navigator ID: esri_mapping_navigationControl |
![]() | Name: Navigation Options ID: esri_mapping_navigationOptionsButton |
![]() | Name: New Group Layer ID: esri_mapping_new2DGroupLayerButton |
![]() | Name: New Group Layer ID: esri_mapping_new3DGroupLayerButton |
![]() | Name: New Basemap ID: esri_mapping_newBasemapButton Condition: esri_mapping_openProjectCondition |
![]() | Name: Color ID: esri_mapping_newColor |
![]() | Name: Color Scheme ID: esri_mapping_newColorScheme |
![]() | Name: Dimension Style ID: esri_mapping_newDimensionStyle |
![]() | Name: Add Elevation Source Layer ID: esri_mapping_newElevationSourceLayerButton Condition: esri_mapping_ElevationSurfaceLayerSelectedCondition |
![]() | Name: Add Elevation Surface Layer ID: esri_mapping_newElevationSurfaceLayerButton |
![]() | Name: Add Graphics Layer ID: esri_mapping_newGraphicsLayerButton Condition: esri_mapping_addGraphicsLayersCondition |
![]() | Name: New Group Layer ID: esri_mapping_newGroupLayerButton Condition: esri_mapping_CanAddGroupLayerCondition |
![]() | Name: Line Symbol ID: esri_mapping_newLineSymbol |
![]() | Name: New Local Scene ID: esri_mapping_newLocalSceneButton Condition: esri_mapping_openProjectCondition |
![]() | Name: New Map ID: esri_mapping_newMapButton Condition: esri_mapping_openProjectCondition |
![]() | Name: Maplex Label Placement ID: esri_mapping_newMaplexLabelPlacement |
![]() | Name: Mesh Symbol ID: esri_mapping_newMeshSymbol |
![]() | Name: New Mobile Style ID: esri_mapping_newMobileStyleButton |
![]() | Name: Point Symbol ID: esri_mapping_newPointSymbol |
![]() | Name: Polygon Symbol ID: esri_mapping_newPolygonSymbol |
![]() | Name: New Global Scene ID: esri_mapping_newSceneButton Condition: esri_mapping_openProjectCondition |
![]() | Name: Standard Label Placement ID: esri_mapping_newStandardLabelPlacement |
![]() | Name: New Stereo Map ID: esri_mapping_newStereoMapButton Condition: esri_mapping_openProjectAndHasIAELicCondition |
![]() | Name: New Style ID: esri_mapping_newStyleButton |
| Name: New ID: esri_mapping_newStyleItemInCurrentClass | |
![]() | Name: Text Symbol ID: esri_mapping_newTextSymbol |
![]() | Name: Next Extent ID: esri_mapping_nextExtentButton |
![]() | Name: Remove ID: esri_mapping_offlineRemoveButton Condition: esri_mapping_mapHasAtLeastOneSyncableLayerCondition |
![]() | Name: Sync ID: esri_mapping_offlineSyncButton Condition: esri_mapping_syncCondition |
| Name: Attribute Rules Options ID: esri_mapping_openAttributeRulesOptionsButton | |
![]() | Name: Build Definition Query ID: esri_mapping_openDefQueryButton Condition: esri_mapping_queryDefSupportedSingleLayerSelectedCondition |
| Name: Elevation ID: esri_mapping_openLayerElevationPropertyPageButton Condition: esri_mapping_singleVoxelLayerSelectedInLocalSceneCondition | |
| Name: Share and Download Options ID: esri_mapping_openLocationOptionsButton | |
| Name: Range ID: esri_mapping_openRangeDefinitionPageButton Condition: esri_mapping_imageServiceAndMosaicLayerSelectedCondition | |
| ID: esri_mapping_openRasterMosaicRulePageButton Condition: esri_mapping_dynamicImageServiceLayerWithTableSelectedCondition | |
| ID: esri_mapping_openRasterProcessingTemplatesPageButton Condition: esri_mapping_renderingRulesSupportedCondition | |
| Name: Selection Options ID: esri_mapping_openSelectionOptionsButton | |
![]() | Name: Configuration ID: esri_mapping_openSimulationConfigurationButton |
![]() | Name: Add Web Map ID: esri_mapping_openWebMapFromFileButton Condition: esri_mapping_openProjectCondition |
![]() | Name: Overlay Cameras ID: esri_mapping_orientedImageryLayerCameraLocationOverlays Condition: esri_mapping_imageLoadedInOrientedImageryViewerCondition |
![]() | Name: Camera Locations ID: esri_mapping_orientedImageryLayerCameraLocations |
![]() | Name: Current Footprint ID: esri_mapping_orientedImageryLayerCurrentFootprint |
![]() | Name: Measure In Image ID: esri_mapping_orientedImageryLayerCurrentMeasureOIToolButton Condition: esri_mapping_imageLoadedInOrientedImageryViewerCondition |
![]() | Name: Footprints ID: esri_mapping_orientedImageryLayerFootprints |
![]() | Name: Overlay Features ID: esri_mapping_orientedImageryLayerOverlaysFeatureLayerButton Condition: esri_mapping_imageLoadedInOrientedImageryViewerCondition |
![]() | Name: Reset ID: esri_mapping_orientedImageryLayerReset |
![]() | Name: Page Down ID: esri_mapping_pageZoomDownButton Condition: esri_mapping_mapPane |
![]() | Name: Page Left ID: esri_mapping_pageZoomLeftButton Condition: esri_mapping_mapPane |
![]() | Name: Page Right ID: esri_mapping_pageZoomRightButton Condition: esri_mapping_mapPane |
![]() | Name: Page Up ID: esri_mapping_pageZoomUpButton Condition: esri_mapping_mapPane |
![]() | Name: Pan To ID: esri_mapping_panToCandidateLocation |
![]() | Name: Pan To Selection ID: esri_mapping_panToLayerSelectionButton Condition: esri_mapping_selectionSupportedLayersSelectedCondition |
![]() | Name: Pan to node ID: esri_mapping_panToSelectedKMLFeatures |
![]() | Name: Pan To Selection ID: esri_mapping_panToSelectionButton |
![]() | Name: All Properties ID: esri_mapping_pasteAllMapMemberPropertiesButton Condition: esri_mapping_singleTOCItemSelectedCondition |
![]() | Name: Paste ID: esri_mapping_pasteElevationSourceLayersButton Condition: esri_mapping_PasteElevationSourceLayerSelectedCondition |
![]() | Name: Paste ID: esri_mapping_PasteElevationSurfaceLayerButton Condition: esri_mapping_PasteElevationSurfaceLayerSelectedCondition |
![]() | Name: Display Filters ID: esri_mapping_pasteLayerDisplayFiltersButton Condition: esri_mapping_singleLayerSelectedCondition |
![]() | Name: Labeling ID: esri_mapping_pasteLayerLabelingButton Condition: esri_mapping_singleLayerSelectedCondition |
![]() | Name: Mosaic rule ID: esri_mapping_pasteLayerMosaicRuleButton Condition: esri_mapping_singleTOCItemSelectedCondition |
![]() | Name: Paste ID: esri_mapping_pasteLayersIntoGroupButton Condition: esri_mapping_pasteLayersIntoGroupCondition |
![]() | Name: Paste ID: esri_mapping_pasteLayersIntoMapButton Condition: esri_mapping_pasteLayersIntoMapCondition |
![]() | Name: Symbology ID: esri_mapping_pasteLayerSymbologyButton Condition: esri_mapping_singleLayerSelectedCondition |
![]() | Name: Visibility Range ID: esri_mapping_pasteLayerVisibilityRangeButton Condition: esri_mapping_singleSubtypeValueLayerSelectedCondition |
![]() | Name: Charts ID: esri_mapping_pasteMapMemberChartsButton Condition: esri_mapping_singleTOCItemSelectedCondition |
![]() | Name: Definition Queries ID: esri_mapping_pasteMapMemberDefQueryButton Condition: esri_mapping_singleTOCItemSelectedCondition |
![]() | Name: Display Expression ID: esri_mapping_pasteMapMemberDisplayExpressionButton Condition: esri_mapping_singleSubtypeValueMemberSelectedCondition |
![]() | Name: Field Properties ID: esri_mapping_pasteMapMemberFieldPropertiesButton Condition: esri_mapping_singleTOCItemSelectedCondition |
![]() | Name: Pop-ups ID: esri_mapping_pasteMapMemberPopupsButton Condition: esri_mapping_singleTOCItemSelectedCondition |
![]() | Name: Paste Properties ID: esri_mapping_pasteMapMemberPropertiesButton Condition: esri_mapping_singleTOCItemSelectedCondition |
![]() | Name: Processing template ID: esri_mapping_pasteRasterProcessingTemplateButton Condition: esri_mapping_singleTOCItemSelectedCondition |
![]() | Name: Paste ID: esri_mapping_pasteStyleItemButton |
![]() | Name: Path ID: esri_mapping_pathFeedbackButton Condition: esri_mapping_mapPaneOrLayoutPane |
| Name: Label Placement Properties ID: esri_mapping_placementPropertiesButton | |
![]() | Name: Create Plume Source Area ID: esri_mapping_plumeSimCreateSourceAreaButton Condition: esri_mapping_mapPane |
![]() | Name: Create Plume Source Line ID: esri_mapping_plumeSimCreateSourceLineButton Condition: esri_mapping_mapPane |
![]() | Name: Create Plume Source Point ID: esri_mapping_plumeSimCreateSourcePointButton Condition: esri_mapping_mapPane |
![]() | Name: Point Snapping ID: esri_mapping_pointSnappingButton Condition: esri_mapping_mapPane |
![]() | Name: Add to Map ID: esri_mapping_popupAddToMapButton |
| Name: Copy Record ID: esri_mapping_popupCopyRecordsButton | |
| Name: Flash ID: esri_mapping_popupFlashButton | |
| Name: Flash Route Location ID: esri_mapping_popupFlashRouteLocationButton | |
| Name: Layer Properties ID: esri_mapping_popupLayerPropertiesButton | |
| Name: Mark Location with Callout ID: esri_mapping_popupMarkLocationCalloutButton | |
| Name: Mark and Label Location ID: esri_mapping_popupMarkLocationLabeledPushpinButton | |
| Name: Mark Location ID: esri_mapping_popupMarkLocationPushpinButton | |
| Name: Pan To ID: esri_mapping_popupPanToButton | |
| Name: Move to Pinned Pop-up ID: esri_mapping_popupPinButton | |
| Name: Promote To Top ID: esri_mapping_popupPromoteToTopButton | |
| Name: Copy Record ID: esri_mapping_popupRelateCopyRecordsButton | |
| Name: Select ID: esri_mapping_popupRelateSelectButton | |
| Name: Sort Ascending ID: esri_mapping_popupRelateSortAscendingButton | |
| Name: Sort by Data ID: esri_mapping_popupRelateSortByIdButton | |
| Name: Sort Descending ID: esri_mapping_popupRelateSortDescendingButton | |
| Name: Unselect ID: esri_mapping_popupRelateUnselectButton | |
| Name: Remove From List ID: esri_mapping_popupRemoveFromListButton | |
| Name: Select ID: esri_mapping_popupSelectButton | |
| Name: Select Layer in Contents Pane ID: esri_mapping_popupSelectInContentsButton | |
| Name: Sort Ascending ID: esri_mapping_popupSortAscendingButton | |
| Name: Sort by Data ID: esri_mapping_popupSortByIdButton | |
| Name: Sort Descending ID: esri_mapping_popupSortDescendingButton | |
| Name: Move to Pop-up Pane ID: esri_mapping_popupUnpinButton | |
| Name: Unselect ID: esri_mapping_popupUnselectButton | |
| Name: Zoom To ID: esri_mapping_popupZoomToButton | |
![]() | Name: Postprocessing Effects Settings ID: esri_mapping_postprocessingEffectSettingsButton Condition: esri_mapping_EffectCondition |
![]() | Name: Postprocessing ID: esri_mapping_postprocessingEffectToggleButton |
![]() | Name: Previous Extent ID: esri_mapping_prevExtentButton |
![]() | Name: Remove Profile Path ID: esri_mapping_ProfileCancelButton |
![]() | Name: Finish Profile ID: esri_mapping_ProfileFinishButton |
![]() | Name: Move Forward ID: esri_mapping_ProfileMoveAwayButton |
![]() | Name: Move and Rotate Profile ID: esri_mapping_ProfileMoveRotateButton |
![]() | Name: Move Backward ID: esri_mapping_ProfileMoveTowardsButton |
![]() | Name: Reverse Direction ID: esri_mapping_ProfileReverseDirection |
![]() | Name: Scale Profile ID: esri_mapping_ProfileScaleButton |
![]() | Name: Settings ID: esri_mapping_projectSettingsButton Condition: esri_mapping_openProjectCondition |
![]() | Name: Protanopia (red-blind) ID: esri_mapping_protanopiaContextButton |
| Name: Background ID: esri_mapping_rasterBackground | |
![]() | Name: Clear ID: esri_mapping_rasterClearLayerSelectionButton Condition: esri_mapping_selectionSupportedLayersSelectedCondition |
![]() | Name: Stretch Type ID: esri_mapping_rasterLayerHistogramButton |
![]() | Name: Symbology ID: esri_mapping_rasterLayerSymbologyButton Condition: esri_mapping_allRasterLayersSelectedCondition |
![]() | Name: Zoom To Source Resolution ID: esri_mapping_rasterMnuViewOneToOne |
![]() | Name: All ID: esri_mapping_rasterSelectAllLayerSelectionButton Condition: esri_mapping_selectionSupportedLayersSelectedCondition |
![]() | Name: Refresh ID: esri_mapping_refreshKMLLayerButton |
![]() | Name: Remove ID: esri_mapping_removeBandCombinationButton |
![]() | Name: Remove ID: esri_mapping_RemoveElevationSourceLayerButton Condition: esri_mapping_ElevationSourceLayerSelectedCondition |
![]() | Name: Remove ID: esri_mapping_RemoveElevationSurfaceLayerButton Condition: esri_mapping_CanRemoveSurfaceLayerCondition |
![]() | Name: Remove Empty Layers ID: esri_mapping_removeEmptySubLayersButton |
![]() | Name: Remove Pop-up Source ID: esri_mapping_removePopupSourceButton |
![]() | Name: Remove ID: esri_mapping_removeSelectedDataSourceButton Condition: esri_mapping_canRemoveSelectedLayersCondition |
![]() | Name: Remove ID: esri_mapping_removeSelectedFeatureDatasetButton Condition: esri_mapping_canRemoveSelectedLayersCondition |
![]() | Name: Remove ID: esri_mapping_removeSelectedLayersButton Condition: esri_mapping_canRemoveSelectedLayersCondition |
![]() | Name: Delete ID: esri_mapping_removeSelectedLinkChartLinkSetsButton |
![]() | Name: Delete ID: esri_mapping_removeSelectedLinkChartNodeSetsButton |
![]() | Name: Delete ID: esri_mapping_removeSelectedLinkChartsButton |
![]() | Name: Remove ID: esri_mapping_removeSelectedMapMembersButton Condition: esri_mapping_canRemoveSelectedMapMembersCondition |
![]() | Name: Remove ID: esri_mapping_removeSelectedStandaloneTablesButton Condition: esri_mapping_SelectedStandaloneTableInEditableContainerCondition |
![]() | Name: Remove ID: esri_mapping_removeSelectedStandaloneVideosButton |
![]() | Name: Remove Category ID: esri_mapping_removeSelectedTimelineLayersButton |
![]() | Name: Delete ID: esri_mapping_removeSelectedTimelinesButton |
![]() | Name: Delete ID: esri_mapping_removeSelectedTimelineSwimlanesButton |
![]() | Name: By Name ID: esri_mapping_reorderLayersByNameMenuButton Condition: esri_mapping_mapPaneOrLinkChart |
![]() | Name: By Type ID: esri_mapping_reorderLayersByTypeMenuButton Condition: esri_mapping_mapPaneOrLinkChart |
![]() | Name: Deselect overviews ID: esri_mapping_reselectPrimaryButton |
![]() | Name: Rotate to... ID: esri_mapping_rotateToInteractiveAnalysisButton |
![]() | Name: Style Items ID: esri_mapping_SaveItemsToStyleBtn |
![]() | Name: Save to Style ID: esri_mapping_saveToStyleButton |
![]() | Name: Local ID: esri_mapping_scene3DViewButton Condition: esri_mapping_mapPane |
| Name: Planar Navigation ID: esri_mapping_screenPlanePanButton Condition: esri_mapping_ViewingMode3DCondition | |
![]() | Name: Select All ID: esri_mapping_selectAllLayerSelectionButton Condition: esri_mapping_selectionSupportedLayersSelectedCondition |
![]() | Name: Select All ID: esri_mapping_selectAllSceneLayerSelectionButton Condition: esri_mapping_selectionSupportedSceneLayersSelectedCondition |
![]() | Name: Select All ID: esri_mapping_selectAllStandaloneTableSelectionButton Condition: esri_mapping_standaloneTableSelectedCondition |
![]() | Name: All ID: esri_mapping_selectAllTableRecordsButton Condition: esri_mapping_allOidTablesSelectedCondition |
![]() | Name: Select Features ID: esri_mapping_selectContext Condition: esri_mapping_mapPane |
![]() | Name: Properties ID: esri_mapping_selectedAnnotationSubLayerPropertiesButton Condition: esri_mapping_onlyAnnotationSubLayersSelectedCondition |
![]() | Name: Properties ID: esri_mapping_selectedBinningLayerPropertiesButton Condition: esri_mapping_singleBinningLayerSelectedCondition |
![]() | Name: Properties ID: esri_mapping_selectedClusteringLayerPropertiesButton Condition: esri_mapping_singleClusteringLayerSelectedCondition |
![]() | Name: Attribute Rules ID: esri_mapping_selectedLayerAttributeRulesViewButton Condition: esri_mapping_selectionSupportsAttributeRulesView |
![]() | Name: Contingent Values ID: esri_mapping_selectedLayerContingentValuesViewButton Condition: esri_mapping_selectionSupportsContingentValues |
![]() | Name: Domains ID: esri_mapping_selectedLayerDomainsViewButton Condition: esri_mapping_selectionSupportsDesignViewDomains |
![]() | Name: Field Groups ID: esri_mapping_selectedLayerFieldsGroupDialogButton Condition: esri_mapping_selectionSupportsDesignViewDomains |
![]() | Name: Fields ID: esri_mapping_selectedLayerFieldsViewButton Condition: esri_mapping_selectionSupportsDesignView |
![]() | Name: Properties ID: esri_mapping_selectedLayerPropertiesButton Condition: esri_mapping_layerSelectedCondition |
![]() | Name: Subtypes ID: esri_mapping_selectedLayerSubtypesViewButton Condition: esri_mapping_selectionSupportsDesignViewSubtypes |
![]() | Name: Symbology ID: esri_mapping_selectedLayerSymbologyButton Condition: esri_mapping_LayersWithSymbologySelectedCondition |
![]() | Name: Properties ID: esri_mapping_selectedLinkChartLinkSetPropertiesButton |
![]() | Name: Properties ID: esri_mapping_selectedLinkChartNodeSetPropertiesButton |
![]() | Name: Properties ID: esri_mapping_selectedLinkChartPropertiesButton |
![]() | Name: Properties ID: esri_mapping_selectedTablePropertiesButton Condition: esri_mapping_standaloneTableSelectedCondition |
![]() | Name: Properties ID: esri_mapping_selectedTimelineLayerPropertiesButton Condition: esri_mapping_timelineSelectedCondition |
![]() | Name: Properties ID: esri_mapping_selectedTimelinePropertiesButton Condition: esri_mapping_timelineSelectedCondition |
![]() | Name: Properties ID: esri_mapping_selectedTimelineSwimlanePropertiesButton Condition: esri_mapping_timelineSelectedCondition |
![]() | Name: Properties ID: esri_mapping_selectedVideoPropertiesButton Condition: esri_mapping_standaloneVideoSelectedCondition |
![]() | Name: Select Features ID: esri_mapping_selectLasPointsContext Condition: esri_mapping_mapPane |
![]() | Name: Select Map Coordinate System ID: esri_mapping_selectOGCMapCoordinateSystemButton Condition: esri_mapping_layerSelectedCondition |
![]() | Name: Select Visible Features ID: esri_mapping_selectVisibleLayerSelectionButton Condition: esri_mapping_selectionSupportedLayersSelectedCondition |
![]() | Name: Visible ID: esri_mapping_selectVisibleRastersButton |
![]() | Name: Send Backward ID: esri_mapping_sendBackwardButton |
![]() | Name: Send To Back ID: esri_mapping_sendToBackButton |
![]() | Name: Set Data Source ID: esri_mapping_SetDataSourceContextMenuItem Condition: esri_mapping_singleMapMemberWhoseDataSourceCanChangeSelectedCondition |
![]() | Name: Set Reference Scale ID: esri_mapping_SetMapReferenceScale |
![]() | Name: Set Pop-up Source ID: esri_mapping_setPopupSourceButton |
| Name: Show Descriptions ID: esri_mapping_showBookmarkDescription | |
![]() | Name: Manage Bookmarks ID: esri_mapping_showBookmarksWindow |
![]() | Name: Show Details ID: esri_mapping_showCandidateDetails |
![]() | Name: Show Related Footprint Pop-up ID: esri_mapping_showCTSRelatedFootprintPopupButton |
![]() | Name: Show Hidden ID: esri_mapping_showHiddenFeaturesButton |
![]() | Name: Show Pop-up ID: esri_mapping_showKMLPopup |
![]() | Name: Symbology ID: esri_mapping_showLayerBinsSymbologyDockPane Condition: esri_mapping_EnableDrawingCondition |
![]() | Name: Symbology ID: esri_mapping_showLayerClustersSymbologyDockPane Condition: esri_mapping_EnableDrawingCondition |
![]() | Name: Symbology ID: esri_mapping_showLayerSymbologyDockPane Condition: esri_mapping_EnableDrawingCondition |
![]() | Name: Locate ID: esri_mapping_showLocateDockPane Condition: esri_mapping_locateProvidersReadyToUseWithMap |
![]() | Name: Symbology ID: esri_mapping_showPointCloudLayerSymbologyDockPane |
![]() | Name: Project ID: esri_mapping_showProjectDockPane Condition: esri_mapping_openProjectCondition |
![]() | Name: Properties ID: esri_mapping_showSelectedCTSLayerPropertiesButton |
![]() | Name: Copy All ID: esri_mapping_simCopyAllObjectsButton Condition: esri_mapping_mapPane |
![]() | Name: Copy ID: esri_mapping_simCopySelectedObjectButton Condition: esri_mapping_mapPane |
![]() | Name: Duplicate ID: esri_mapping_simDuplicateSelectedObjectButton |
![]() | Name: Modify ID: esri_mapping_simEditSelectedObjectButton |
![]() | Name: Paste ID: esri_mapping_simPasteObjectsButton Condition: esri_mapping_mapPane |
![]() | Name: Remove All ID: esri_mapping_simRemoveAllObjectsButton Condition: esri_mapping_mapPane |
![]() | Name: Remove ID: esri_mapping_simRemoveSelectedObjectButton |
![]() | Name: Simulate Overprint ID: esri_mapping_simulateOverprint |
![]() | Name: Clear ID: esri_mapping_simulationClearButton Condition: esri_mapping_mapPane |
![]() | Name: Copy All ID: esri_mapping_simulationCopyAllLayersButton Condition: esri_mapping_mapPane |
![]() | Name: Analysis Results ID: esri_mapping_simulationExportButton Condition: esri_mapping_mapPane |
![]() | Name: Modify ID: esri_mapping_simulationModifySelectedAreaButton Condition: esri_mapping_mapPane |
![]() | Name: Remove All ID: esri_mapping_simulationRemoveAllLayersButton Condition: esri_mapping_mapPane |
![]() | Name: Run ID: esri_mapping_simulationRunButton Condition: esri_mapping_mapPane |
![]() | Name: Zoom To ID: esri_mapping_simZoomToSelectedObjectButton |
![]() | Name: Properties ID: esri_mapping_singleSelectedLayerPropertiesButton Condition: esri_mapping_singleLayerSelectedCondition |
![]() | Name: Slice Properties ID: esri_mapping_sliceBoxPropertiesButton |
![]() | Name: Slice Properties ID: esri_mapping_sliceCylinderPropertiesButton |
![]() | Name: Delete Slice ID: esri_mapping_SliceDeleteButton |
![]() | Name: Move Slice ID: esri_mapping_SliceMoveButton |
![]() | Name: Move and Rotate Slice ID: esri_mapping_SliceMoveRotateButton |
![]() | Name: Accept Slice ID: esri_mapping_SliceOkButton |
![]() | Name: Slice Properties ID: esri_mapping_sliceRectPropertiesButton |
![]() | Name: Rotate Slice ID: esri_mapping_SliceRotateButton |
![]() | Name: Scale Slice ID: esri_mapping_SliceScaleButton |
![]() | Name: Slice Properties ID: esri_mapping_sliceSpherePropertiesButton |
![]() | Name: Enable Snap Chip ID: esri_mapping_snapChipToggleButton Condition: esri_mapping_mapPane |
![]() | Name: Snapping ID: esri_mapping_snappingToggleButton |
![]() | Name: Exploratory 3D Analysis ID: esri_mapping_startInteractiveAnalysisButton Condition: esri_mapping_mapPaneOrLayoutPaneNotLinkChart |
![]() | Name: Stepped ID: esri_mapping_steppedAppendTransitionButton Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Discard Observations ID: esri_mapping_streamingDataDiscardObservationsButton Condition: esri_mapping_singleFeatureLayerSelectedCondition |
| ID: esri_mapping_streamingDataPropertiesButton Condition: esri_mapping_streamLayerSelectedCondition | |
![]() | Name: Start Stream ID: esri_mapping_streamingDataStartStreamButton Condition: esri_mapping_singleFeatureLayerSelectedCondition |
![]() | Name: Stop Stream ID: esri_mapping_streamingDataStopStreamButton Condition: esri_mapping_singleFeatureLayerSelectedCondition |
![]() | Name: By Category ID: esri_mapping_styleSortByCategory |
![]() | Name: By ID ID: esri_mapping_styleSortByID |
![]() | Name: By Name ID: esri_mapping_styleSortByName |
![]() | Name: Remove From Project ID: esri_mapping_StyleUnreferenceButton |
![]() | Name: Switch Selection ID: esri_mapping_switchLayerSelectionButton Condition: esri_mapping_selectionSupportedLayersSelectedCondition |
![]() | Name: Switch Selection ID: esri_mapping_switchStandaloneTableSelectionButton Condition: esri_mapping_standaloneTableSelectedCondition |
![]() | Name: Switch ID: esri_mapping_switchTableRecordSelection Condition: esri_mapping_allOidTablesSelectedCondition |
| Name: Symbol Layers ID: esri_mapping_symbolLayersButton Condition: esri_mapping_only2DFeatureLayersSelectedCondition | |
![]() | Name: Center And Scale ID: esri_mapping_syncCenterAndScaleButton |
![]() | Name: Center ID: esri_mapping_syncCenterButton |
![]() | Name: None ID: esri_mapping_syncNoCenterButton |
| Name: Sync ID: esri_mapping_SyncStyleButton | |
![]() | Name: Time ID: esri_mapping_syncTimeButton |
![]() | Name: Tangent Snapping ID: esri_mapping_tangentSnappingButton Condition: esri_mapping_mapPane |
| Name: Text Symbol ID: esri_mapping_textSymbolButton | |
![]() | Name: More ... ID: esri_mapping_textSymbolMoreButton |
| Name: Use Service Cache ID: esri_mapping_toggleImageServiceViewMode | |
![]() | Name: Masking ID: esri_mapping_toggleMaskingButton |
![]() | Name: Drawing Performance Overlay ID: esri_mapping_toggleStatsOverlay |
![]() | Name: Export Points ID: esri_mapping_trajectoryLayerExportPoints |
![]() | Name: Tritanopia (blue-blind) ID: esri_mapping_tritanopiaContextButton |
![]() | Name: Ungroup ID: esri_mapping_ungroupSelectedLayerButton Condition: esri_mapping_canUngroupLayerSelectedCondition |
![]() | Name: Upgrade ID: esri_mapping_UpgradeStyleButton |
![]() | Name: Manage Versions ID: esri_mapping_versionViewButton Condition: esri_mapping_itemSelectedIsVersionManagerAvailableCondition |
![]() | Name: Vertex Snapping ID: esri_mapping_vertexSnappingButton Condition: esri_mapping_mapPane |
![]() | Name: View Dome Properties ID: esri_mapping_viewDomePropertiesButton |
![]() | Name: Viewshed Properties ID: esri_mapping_viewshedPropertiesButton |
![]() | Name: Turn Off ID: esri_mapping_visibilityOffSelectedLayersButton Condition: esri_mapping_CanTurnOffLayerVisibility |
![]() | Name: Turn On ID: esri_mapping_visibilityOnSelectedLayersButton Condition: esri_mapping_CanTurnOnLayerVisibility |
![]() | Name: Visual Effect Settings ID: esri_mapping_visualEffectSettingsButton |
![]() | Name: Visual ID: esri_mapping_visualEffectToggleButton |
![]() | Name: Delete ID: esri_mapping_voxelDeleteSliceOrDynamicSectionButton |
![]() | Name: Horizontal Section ID: esri_mapping_voxelDynamicSection_CreateHorizontalButton |
![]() | Name: Vertical Section ID: esri_mapping_voxelDynamicSection_CreateVerticalButton |
![]() | Name: Duplicate Section ID: esri_mapping_voxelDynamicSection_duplicateButton Condition: esri_mapping_singleVoxelLayerSelectedInLocalSceneCondition |
![]() | Name: Edit ID: esri_mapping_voxelDynamicSection_editButton Condition: esri_mapping_singleVoxelLayerSelectedInLocalSceneCondition |
![]() | Name: Lock Section ID: esri_mapping_voxelDynamicSection_lockButton Condition: esri_mapping_singleVoxelLayerSelectedInLocalSceneCondition |
![]() | Name: Remove ID: esri_mapping_voxelDynamicSection_removeButton Condition: esri_mapping_singleVoxelLayerSelectedCondition |
![]() | Name: Edit ID: esri_mapping_voxelIsosurface_editButton Condition: esri_mapping_singleVoxelLayerSelectedInLocalSceneCondition |
![]() | Name: Lock Color ID: esri_mapping_voxelIsosurface_lockColorButton Condition: esri_mapping_singleVoxelLayerSelectedInLocalSceneCondition |
![]() | Name: Remove ID: esri_mapping_voxelIsosurface_removeButton Condition: esri_mapping_singleVoxelLayerSelectedCondition |
![]() | Name: Remove All Isosurfaces ID: esri_mapping_voxelIsosurfaceContainer_removeAllButton Condition: esri_mapping_singleVoxelLayerSelectedCondition |
![]() | Name: Create Isosurface ID: esri_mapping_voxelLayer_createIsosurfaceButton Condition: esri_mapping_singleVoxelLayerSelectedInLocalSceneCondition |
![]() | Name: Slice and Section ID: esri_mapping_voxelLayer_exploreButton Condition: esri_mapping_singleVoxelLayerSelectedInLocalSceneCondition |
![]() | Name: Create Section ID: esri_mapping_voxelSectionsContainer_createButton Condition: esri_mapping_singleVoxelLayerSelectedInLocalSceneCondition |
![]() | Name: Remove All Sections ID: esri_mapping_voxelSectionsContainer_removeAllButton Condition: esri_mapping_singleVoxelLayerSelectedCondition |
![]() | Name: Create Slice ID: esri_mapping_voxelSlice_createButton Condition: esri_mapping_singleVoxelLayerSelectedInLocalSceneCondition |
![]() | Name: Horizontal Slice ID: esri_mapping_voxelSlice_CreateHorizontalButton |
![]() | Name: Vertical Slice ID: esri_mapping_voxelSlice_CreateVerticalButton |
![]() | Name: Edit ID: esri_mapping_voxelSlice_editButton Condition: esri_mapping_singleVoxelLayerSelectedInLocalSceneCondition |
![]() | Name: Flip ID: esri_mapping_voxelSlice_FlipButton |
![]() | Name: Push or Pull ID: esri_mapping_voxelSlice_MoveButton |
![]() | Name: Orient ID: esri_mapping_voxelSlice_OrientButton |
![]() | Name: Remove ID: esri_mapping_voxelSlice_removeButton Condition: esri_mapping_singleVoxelLayerSelectedCondition |
![]() | Name: Tilt ID: esri_mapping_voxelSlice_TiltButton |
![]() | Name: Remove All Slices ID: esri_mapping_voxelSliceContainer_removeAllButton Condition: esri_mapping_singleVoxelLayerSelectedCondition |
![]() | Name: Duplicate Section ID: esri_mapping_voxelStaticSection_duplicateButton Condition: esri_mapping_singleVoxelLayerSelectedInLocalSceneCondition |
![]() | Name: Remove ID: esri_mapping_voxelStaticSection_removeButton Condition: esri_mapping_singleVoxelLayerSelectedCondition |
![]() | Name: Unlock Section ID: esri_mapping_voxelStaticSection_unlockButton Condition: esri_mapping_singleVoxelLayerSelectedInLocalSceneCondition |
![]() | Name: Zoom To Locked Section ID: esri_mapping_voxelStaticSection_ZoomToButton Condition: esri_mapping_singleVoxelLayerSelectedInLocalSceneConditionEx |
![]() | Name: Remove All Sections ID: esri_mapping_voxelStaticSectionContainer_removeAllButton Condition: esri_mapping_singleVoxelLayerSelectedCondition |
![]() | Name: Weather ID: esri_mapping_weatherEffectButton Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: XY Table To Point ID: esri_mapping_xyTableToPointButton Condition: esri_mapping_mapPaneOrLinkChart |
![]() | Name: Zoom Full Extent ID: esri_mapping_zoomFullButton |
![]() | Name: Zoom To Reference Scale ID: esri_mapping_ZoomMapReferenceScale |
![]() | Name: Zoom To ID: esri_mapping_zoomToCandidateLocation |
![]() | Name: Zoom To Selection ID: esri_mapping_zoomToLayerSelectionButton Condition: esri_mapping_selectionSupportedLayersSelectedCondition |
![]() | Name: Zoom To Make Visible ID: esri_mapping_zoomToMakeCTSLayerVisibleButton |
![]() | Name: Zoom To Make Visible ID: esri_mapping_zoomToMakeVisibleButton |
![]() | Name: Zoom To Layer ID: esri_mapping_zoomToSelectedCTSLayersButton |
![]() | Name: Zoom To ID: esri_mapping_zoomToSelectedElevationLayersButton |
![]() | Name: Zoom to node ID: esri_mapping_zoomToSelectedKMLFeatures |
![]() | Name: Zoom To Layer ID: esri_mapping_zoomToSelectedLayersButton Condition: esri_mapping_inValidGroupLayerSelectedCondition |
![]() | Name: Zoom To ID: esri_mapping_zoomToSelectionButton |
![]() | Name: Add To Current Map ID: esri_onlineItemAddToActiveMapButton Condition: esri_mapping_canAddToCurrentMapCondition |
![]() | Name: Add To Current Map ID: esri_projectItemAddToActiveMapButton Condition: esri_mapping_canAddToCurrentMapCondition |
![]() | Name: Local Scene ID: esri_projectItemAddToNewLocalSceneButton Condition: esri_mapping_openProjectState |
![]() | Name: Map ID: esri_projectItemAddToNewMapButton Condition: esri_mapping_openProjectState |
![]() | Name: Global Scene ID: esri_projectItemAddToNewSceneButton Condition: esri_mapping_openProjectState |
![]() | Name: Stereo Map ID: esri_projectItemAddToNewStereoMapButton Condition: esri_mapping_openProjectState |
![]() | Name: Save ID: esri_subtypesview_commitButton Condition: esri_mapping_subtypesView_hasEditsCondition |
![]() | Name: Attribute Rules ID: esri_subtypeview_attributeRulesButton Condition: esri_mapping_designview_canOpenAttributeRules |
![]() | Name: Contingent Values ID: esri_subtypeview_contingentValuesButton Condition: esri_mapping_subtypesPane |
![]() | Name: Create/Manage ID: esri_subtypeview_designButton Condition: esri_subtypes_canManageCondition |
![]() | Name: Domains ID: esri_subtypeview_domainsButton Condition: esri_mapping_subtypesPane |
![]() | Name: Redo ID: esri_subtypeview_editRedo Condition: esri_mapping_subtypesView_redoCondition |
![]() | Name: Undo ID: esri_subtypeview_editUndo Condition: esri_mapping_subtypesView_undoCondition |
![]() | Name: Field Groups ID: esri_subtypeview_fieldGroupsButton Condition: esri_mapping_subtypesPane |
![]() | Name: Fields ID: esri_subtypeview_fieldsButton Condition: esri_mapping_subtypesPane |
![]() | Name: Change to Selected Version ID: esri_versionview_ChangeToSelectedVersionButton |
![]() | Name: Save ID: esri_versionview_commitButton Condition: esri_mapping_versionsView_hasEditsCondition |
![]() | Name: Delete ID: esri_versionview_deleteVersionButton Condition: esri_mapping_versionsView_canDeleteCondition |
![]() | Name: New ID: esri_versionview_newVersionButton Condition: esri_mapping_versionsView_canAddNewCondition |
![]() | Name: Reconcile/Post ID: esri_versionview_reconcileVersionButton Condition: esri_mapping_versionsView_canReconcileAndPostCondition |
![]() | Name: Refresh Versions ID: esri_versionview_refreshVersionButton Condition: esri_mapping_versionsView_readOnlyCondition |
![]() | Name: Restore ID: esri_versionview_restoreVersionButton Condition: esri_mapping_versionsView_canRestoreCondition |
![]() | Name: Sync ID: RGDBProjectItemSyncButton |
comboBox
| Name: Target layer ID: esri_mapping_graphicsTargetLayerComboBox Condition: esri_mapping_addMapGraphicsCondition |
| Name: Expression ID: esri_mapping_labelClassExpressionComboBox Condition: esri_mapping_singleLabeledLayerSelectedCondition |
| Name: Font Size ID: esri_mapping_labelTextSymbolFontSizeComboBox Condition: esri_mapping_labeledLayerSelectedCondition |
| Name: Font Style ID: esri_mapping_labelTextSymbolFontStyleComboBox Condition: esri_mapping_labeledLayerSelectedCondition |
| Name: Layer Definition Query ID: esri_mapping_layerDefQueryComboBox Condition: esri_mapping_queryDefSupportedLayersSelectedCondition |
| Name: Layer Name ID: esri_mapping_linearReferencingLayerComboBox Condition: esri_mapping_MapContainsRouteFeatureClass |
| Name: Route Id Field ID: esri_mapping_linearReferencingRouteIdFieldComboBox Condition: esri_mapping_SingleRouteLayerSelected |
| Name: Mode ID: esri_mapping_nearPlaneClippingMode Condition: esri_mapping_ViewingMode3DCondition |
| Name: Alias Source ID: esri_mapping_rangeAliasLayerSourceComboBox |
| Name: Active Range ID: esri_mapping_rangeNamesComboBox |
| Name: Renderer: ID: esri_mapping_rasterLayerRenderer |
| Name: Show: ID: esri_mapping_StyleClassCombobox |
| Name: Variable ID: esri_mapping_voxelLayerVariableComboBox Condition: esri_mapping_singleVoxelLayerSelectedInLocalSceneCondition |
| Name: Owner: ID: esri_versionview_versionOwnerComboBox |
checkBox
| Name: Auto Cache ID: esri_mapping_autoFillCacheButton Condition: esri_mapping_featureCachingEnabledWithActiveMapCondition | |
| Name: Label Features In This Class ID: esri_mapping_labelClassEnableCheckBox Condition: esri_mapping_labeledLayerSelectedCondition | |
![]() | Name: Show Location ID: esri_mapping_location_displayLocationButton |
![]() | Name: Accuracy Buffer ID: esri_mapping_location_toggleAccuracyBufferButton |
| Name: Only Show Entities in Map ID: esri_mapping_popupToggleOnlyShowEntitiesInMapCheckBox | |
| Name: Single Value ID: esri_mapping_rangeSingleValueCheckBox | |
| Name: Show Previous Observations ID: esri_mapping_streamLayerShowPreviousObservationsCheckBox Condition: esri_mapping_singleFeatureLayerSelectedCondition | |
| Name: Show Track Lines ID: esri_mapping_streamLayerShowTrackLinesCheckBox Condition: esri_mapping_singleStreamLayerSupportTrackLinesSelectedCondition |
customControl
![]() | Name: Embeddings ID: esri_geoai_workflowsDropdown Condition: esri_mapping_mapTypeLinkChartState_false |
![]() | ID: esri_mapping_animationKeyframeControl |
![]() | ID: esri_mapping_animationListControl |
![]() | ID: esri_mapping_animationMoveControl |
![]() | ID: esri_mapping_animationOverlayControl |
![]() | ID: esri_mapping_animationPlaybackControl |
| ID: esri_mapping_basicFeatureLayerBlendModeComboBox | |
![]() | ID: esri_mapping_binningAppearanceCustomControl Condition: esri_mapping_singleBinningLayerSelectedCondition |
![]() | ID: esri_mapping_binningLockLevelCustomControl Condition: esri_mapping_singleBinningLayerSelectedCondition |
![]() | Name: Change binning level of detail ID: esri_mapping_binningSizeTweaker |
![]() | ID: esri_mapping_binningThresholdControl Condition: esri_mapping_singleBinningLayerSelectedCondition |
| Name: Layer Limit ID: esri_mapping_catalogLayerMaxLayersComboBox | |
| Name: Scale Threshold ID: esri_mapping_clusteringThresholdControl Condition: esri_mapping_singleClusteringLayerSelectedCondition | |
![]() | Name: Clustering Radius ID: esri_mapping_clusterRadiusSlider Condition: esri_mapping_singleClusteringLayerSelectedCondition |
![]() | ID: esri_mapping_currentRangeControl |
![]() | ID: esri_mapping_currentTimeControl |
| ID: esri_mapping_dataSourceSelectionComboBox | |
![]() | Name: Download Map ID: esri_mapping_downloadMap Condition: esri_mapping_mapHasAtLeastOneSyncEnabledLayerCondition |
![]() | Name: Exclude From Integrated Mesh ID: esri_mapping_elevationSurface_ExcludeFromDraping |
| Name: Drawing ID: esri_mapping_elevationSurfaceLayerDrawing | |
| Name: Surface Layer ID: esri_mapping_elevationSurfaceLayerRibbon | |
| Name: Eye-Dome lighting ID: esri_mapping_EyeDomeLightingSliderControl Condition: esri_mapping_EDLEnabledCondition | |
![]() | ID: esri_mapping_fullRangeControl |
![]() | ID: esri_mapping_fullTimeControl |
| ID: esri_mapping_illuminationTimeControl Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Font ID: esri_mapping_labelClassFontControl Condition: esri_mapping_labeledLayerSelectedCondition | |
![]() | Name: Maximum Scale ID: esri_mapping_labelClassInBeyondComboBox2D Condition: esri_mapping_labeledLayerSelectedCondition |
![]() | Name: Closest Distance ID: esri_mapping_labelClassInBeyondComboBox3D Condition: esri_mapping_labeledLayerSelectedCondition |
| Name: Label Class ID: esri_mapping_labelClassNameComboBox Condition: esri_mapping_singleFeatureLayerSelectedCondition | |
![]() | Name: Minimum Scale ID: esri_mapping_labelClassOutBeyondComboBox2D Condition: esri_mapping_labeledLayerSelectedCondition |
![]() | Name: Farthest Distance ID: esri_mapping_labelClassOutBeyondComboBox3D Condition: esri_mapping_labeledLayerSelectedCondition |
| Name: Set color for current label class ID: esri_mapping_labelTextSymbolColorPicker Condition: esri_mapping_labeledLayerSelectedCondition | |
| Name: Variable Font Settings ID: esri_mapping_labelTextSymbolVariableFontSettings Condition: esri_mapping_labeledLayerSelectedCondition | |
| ID: esri_mapping_layerBlendModeComboBox | |
| Name: Brightness ID: esri_mapping_layerBrightness Condition: esri_mapping_allRasterLayersSelectedCondition | |
| Name: Contrast ID: esri_mapping_layerContrast Condition: esri_mapping_allRasterLayersSelectedCondition | |
| Name: Layer Extrusion ID: esri_mapping_layerExtrusionFieldAndUnit | |
| Name: Gamma ID: esri_mapping_layerGamma Condition: esri_mapping_rasterLayerStretchTypeApplicableCondition | |
![]() | Name: Maximum Scale ID: esri_mapping_layerInBeyondComboBox |
![]() | Name: Masking ID: esri_mapping_layerMasking Condition: esri_mapping_subtypeValueLayerAndStreamServiceNotSelectedCondition |
![]() | Name: Minimum Scale ID: esri_mapping_layerOutBeyondComboBox |
![]() | Name: Reference Scale ID: esri_mapping_layerReferenceScaleComboBox |
![]() | Name: Reference Scale ID: esri_mapping_layerReferenceScaleComboBoxNoNone |
| Name: Transparency ID: esri_mapping_layerTransparency Condition: esri_mapping_disableTransparency | |
| ID: esri_mapping_measureToolsMenu Condition: esri_mapping_mapPane | |
| Name: Feature Layer overlay ID: esri_mapping_orientedImageryLayerOverlaysFeatureLayerMenu Condition: esri_mapping_imageLoadedInOrientedImageryViewerCondition | |
| Name: Point Display Controls ID: esri_mapping_PointCloudRibbonThinning_CustomControl Condition: esri_mapping_singlePointCloudLayerSelectedCondition | |
![]() | ID: esri_mapping_profileViewControl Condition: esri_mapping_ViewingMode3DCondition |
![]() | ID: esri_mapping_rangePlaybackSpeedControl |
![]() | ID: esri_mapping_rangeStepControl |
| Name: Compression ID: esri_mapping_rasterLayerCompression Condition: esri_mapping_imageServiceAndMosaicLayerSelectedCondition | |
| ID: esri_mapping_rasterStretchDRA | |
![]() | ID: esri_mapping_simulationActiveControl |
![]() | ID: esri_mapping_simulationConfigControl |
![]() | ID: esri_mapping_simulationPlaybackControl |
![]() | ID: esri_mapping_simulationResolutionControl |
| ID: esri_mapping_snappingOpenTrayButton | |
| ID: esri_mapping_streamingDataCustomControl Condition: esri_mapping_singleFeatureLayerSelectedCondition | |
![]() | ID: esri_mapping_TimePlaybackSpeedControl |
![]() | ID: esri_mapping_timeSnappingControl |
![]() | ID: esri_mapping_TimeStepControl |
![]() | ID: esri_mapping_timeZoneControl |
| Name: Elevation ID: esri_mapping_voxelLayerElevation | |
| Name: Lighting ID: esri_mapping_voxelLayerLighting | |
| ID: esri_mapping_weatherEffectControl Condition: esri_mapping_ViewingMode3DCondition |
dynamicMenu
| ID: esri_mapping_addCalculationRuleDynamicMenu | |
| ID: esri_mapping_addDataDynamicMenu | |
| Name: Color Vision Simulator ID: esri_mapping_colorVisionDynamicMenu | |
| Name: Update Data Sources ID: esri_mapping_dataSources_editDataSourcesContextMenu | |
| Name: Enable Pop-ups ID: esri_mapping_enablePopupsMenu Condition: esri_mapping_NoIntegratedMeshLayersSelectedConditionEx | |
| Name: Enable Masking ID: esri_mapping_FSL_maskingEnabledMenu | |
| Name: Enable Modifications ID: esri_mapping_IM_Layer_modificationEnabledMenu | |
| Name: Depth Priority ID: esri_mapping_layerDepthPriorityDynamicMenu | |
| Name: Layer Visibility ID: esri_mapping_layerVisibilityDynamicMenu | |
| Name: BA ext ID: esri_mapping_locate_dynamic | |
| ID: esri_mapping_pastePropertiesDynamicMenu | |
| ID: esri_mapping_popupFeatureContextMenuItems | |
| ID: esri_mapping_popupLayerContextMenuItems | |
| ID: esri_mapping_popupLinkChartFeatureContextMenuItems | |
| ID: esri_mapping_popupRelateContextMenuItems | |
| Name: Selectable Layers ID: esri_mapping_selectableLayersMenu | |
| ID: esri_mapping_selectOGCMapCoordinateSystemMenu | |
| Name: Change Basemap Layer Type ID: esri_mapping_setBasemapLayerTypeMenu | |
![]() | Name: Update ID: esri_mapping_updateBookmarksMenu |
| Name: Add To Map ID: esri_projectItemAddToMapDynamicMenu |
editBox
| Name: Filter Text: ID: esri_domainview_filterEditBox Condition: esri_mapping_domainsPane |
| Name: Filter Domain: ID: esri_fieldsview_filterDomainEditBox Condition: esri_mapping_fieldsPane |
| Name: Filter Name: ID: esri_fieldsview_filterNameEditBox Condition: esri_mapping_fieldsPane |
| Name: Name: ID: esri_versionview_versionNameEditBox Condition: esri_mapping_VersionsPane |
labelControl
| Name: ID: esri_emptyLabel1 |
| Name: ID: esri_emptyLabel2 |
| Name: Target layer: ID: esri_mapping_graphicsTargetLayerLabel |
| Name: Field ID: esri_mapping_labelClassFieldLabel Condition: esri_mapping_singleFeatureLayerSelectedCondition |
| Name: Class ID: esri_mapping_labelClassNameLabel Condition: esri_mapping_singleFeatureLayerSelectedCondition |
| Name: Size ID: esri_mapping_layerSymbolSizeLabel |
| Name: Alias: ID: esri_mapping_rangeAliasLayerSourceLabel |
| Name: Name: ID: esri_mapping_rangeNameLabel |
| Name: Variable ID: esri_mapping_voxelLayerVariableLabel Condition: esri_mapping_singleVoxelLayerSelectedInLocalSceneCondition |
spinner
| Name: Flicker ID: esri_mapping_layerFlickerSpinner |
| Name: Angle: ID: esri_mapping_rasterRotateAngleSpinner |
| Name: Distance ID: esri_mapping_spinner_nearPlaneClippingDistance Condition: esri_mapping_ViewingMode3DCondition |
tool
| Name: Address Inspector ID: esri_mapping_addressInspectorTool Condition: esri_mapping_addressInspectorCondition | |
![]() | Name: Create ID: esri_mapping_createProfileViewAlongLineTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Create ID: esri_mapping_createProfileViewTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Cut and Fill ID: esri_mapping_cutFillTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Elevation Profile ID: esri_mapping_elevationProfileTool Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Swipe ID: esri_mapping_elevationSurfaceSwipeTool Condition: esri_mapping_EnableSwipeCondition |
![]() | Name: Exploratory Analysis ID: esri_mapping_exploratoryAnalysisInteractionTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Exploratory Analysis ID: esri_mapping_exploratoryAnalysisTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Explore ID: esri_mapping_exploreTool Condition: esri_mapping_mapPaneOrEquivalent |
![]() | Name: Eyedropper ID: esri_mapping_eyedropperTool |
![]() | Name: Flicker ID: esri_mapping_FlickerTool |
![]() | Name: Focus Distance ID: esri_mapping_focusDistanceTool |
![]() | Name: Move ID: esri_mapping_georeference_MoveButton Condition: esri_mapping_GeoreferenceCondition |
![]() | Name: Rotate ID: esri_mapping_georeference_RotateButton Condition: esri_mapping_GeoreferenceCondition |
![]() | Name: Scale ID: esri_mapping_georeference_ScaleButton Condition: esri_mapping_GeoreferenceCondition |
![]() | Name: Infographics ID: esri_mapping_infographicTool Condition: esri_mapping_infographic_signedIn_condition |
![]() | Name: Swipe ID: esri_mapping_layerSwipeTool Condition: esri_mapping_EnableSwipeCondition |
![]() | Name: Line of Sight ID: esri_mapping_lineOfSightTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Measure Area ID: esri_mapping_measureAreaTool Condition: esri_mapping_mapPane |
![]() | Name: Measure Distance ID: esri_mapping_measureDistanceTool Condition: esri_mapping_mapPane |
![]() | Name: Measure Features ID: esri_mapping_measureFeaturesTool Condition: esri_mapping_mapPane |
![]() | Name: Measure Terrain Distance ID: esri_mapping_measureTerrainDistanceTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Measure Vertical ID: esri_mapping_measureVerticalTool Condition: esri_mapping_ViewingMode3DOrStereoCondition |
![]() | Name: Object Detection ID: esri_mapping_objectDetectionTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Measure Area ID: esri_mapping_oldMeasureAreaTool Condition: esri_mapping_mapPane |
![]() | Name: Measure Distance ID: esri_mapping_oldMeasureDistanceTool Condition: esri_mapping_mapPane |
![]() | Name: Measure Features ID: esri_mapping_oldMeasureFeaturesTool Condition: esri_mapping_mapPane |
![]() | Name: Measure Terrain Distance ID: esri_mapping_oldMeasureTerrainDistanceTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Measure Vertical ID: esri_mapping_oldMeasureVerticalTool Condition: esri_mapping_ViewingMode3DOrStereoCondition |
![]() | Name: Display Image ID: esri_mapping_orientedImageryDisplayImage |
![]() | Name: 2D ID: esri_mapping_orientedImageryExploreIn2D |
![]() | Name: 3D ID: esri_mapping_orientedImageryExploreIn3D Condition: esri_mapping_orientedImageryExploreIn3DCondition |
![]() | Name: Explore Images ID: esri_mapping_orientedImageryLayerExploreImagesTool |
![]() | Name: Map-Image Location ID: esri_mapping_orientedImageryLayerMapImageConversionTool Condition: esri_mapping_imageLoadedInOrientedImageryViewerCondition |
![]() | Name: Rotate ID: esri_mapping_rasterViewRotate Condition: esri_mapping_featureLayerSelectedCondition |
![]() | Name: Rectangle Zoom In ID: esri_mapping_rectangleZoom Condition: esri_mapping_mapPane |
![]() | Name: Rectangle Zoom Out ID: esri_mapping_rectangleZoomOut Condition: esri_mapping_mapPane |
![]() | Name: Box ID: esri_mapping_selectByBoxTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Circle ID: esri_mapping_selectByCircleTool Condition: esri_mapping_mapPane |
![]() | Name: Cylinder ID: esri_mapping_selectByCylinderTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Lasso ID: esri_mapping_selectByLassoTool Condition: esri_mapping_mapPane |
![]() | Name: Line ID: esri_mapping_selectByLineTool Condition: esri_mapping_mapPane |
![]() | Name: Polygon ID: esri_mapping_selectByPolygonTool Condition: esri_mapping_mapPane |
![]() | Name: Rectangle ID: esri_mapping_selectByRectangleTool Condition: esri_mapping_mapPane |
![]() | Name: Sphere ID: esri_mapping_selectBySphereTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Trace ID: esri_mapping_selectByTraceTool Condition: esri_mapping_traceToolCondition |
![]() | Name: Box ID: esri_mapping_selectLasPointsByBoxTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Power Line ID: esri_mapping_selectLasPointsByCatenaryCurve Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Circle ID: esri_mapping_selectLasPointsByCircleTool Condition: esri_analyst3D_las2DFullResolutionCondition |
![]() | Name: Cylinder ID: esri_mapping_selectLasPointsByCylinderTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Lasso ID: esri_mapping_selectLasPointsByLassoTool Condition: esri_analyst3D_las2DFullResolutionCondition |
![]() | Name: Line ID: esri_mapping_selectLasPointsByLineTool Condition: esri_analyst3D_las2DFullResolutionCondition |
![]() | Name: Polygon ID: esri_mapping_selectLasPointsByPolygonTool Condition: esri_analyst3D_las2DFullResolutionCondition |
![]() | Name: Rectangle ID: esri_mapping_selectLasPointsByRectangleTool Condition: esri_analyst3D_las2DFullResolutionCondition |
![]() | Name: Sphere ID: esri_mapping_selectLasPointsBySphereTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Cluster ID: esri_mapping_selectLasPointsClusterTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Rail ID: esri_mapping_selectLasPointsOnRailTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Plane ID: esri_mapping_selectLasPointsPlaneTool Condition: esri_mapping_ViewingMode3DCondition |
| Name: Add Barrier ID: esri_mapping_simAddBarrierTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Add Channel ID: esri_mapping_simAddChannelTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Add Plume Source Area ID: esri_mapping_simAddPlumeSourceAreaTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Add Plume Source Line ID: esri_mapping_simAddPlumeSourceLineTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Add Plume Source Point ID: esri_mapping_simAddPlumeSourcePointTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Add Water Sink ID: esri_mapping_simAddWaterSinkAreaTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Add Water Area ID: esri_mapping_simAddWaterSourceAreaTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Add Water Source ID: esri_mapping_simAddWaterSourceTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Edit Barrier ID: esri_mapping_simEditBarrierTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Edit Channel ID: esri_mapping_simEditChannelTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Edit Plume Source Area ID: esri_mapping_simEditPlumeSourceAreaTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Edit Plume Source Line ID: esri_mapping_simEditPlumeSourceLineTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Edit Plume Source Point ID: esri_mapping_simEditPlumeSourcePointTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Edit Water Sink ID: esri_mapping_simEditWaterSinkAreaTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Edit Water Area ID: esri_mapping_simEditWaterSourceAreaTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Edit Water Source ID: esri_mapping_simEditWaterSourceTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Add Barrier ID: esri_mapping_simSelectedAddBarrierTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Add Channel ID: esri_mapping_simSelectedAddChannelTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Add Plume Source Area ID: esri_mapping_simSelectedAddPlumeSourceAreaTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Add Plume Source Line ID: esri_mapping_simSelectedAddPlumeSourceLineTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Add Plume Source Point ID: esri_mapping_simSelectedAddPlumeSourcePointTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Add Water Sink ID: esri_mapping_simSelectedAddWaterSinkAreaTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Add Water Area ID: esri_mapping_simSelectedAddWaterSourceAreaTool Condition: esri_mapping_ViewingMode3DCondition | |
| Name: Add Water Source ID: esri_mapping_simSelectedAddWaterSourceTool Condition: esri_mapping_ViewingMode3DCondition | |
![]() | Name: Slice Box ID: esri_mapping_sliceBoxTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Slice Cylinder ID: esri_mapping_sliceCylinderTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Slice Rectangle ID: esri_mapping_sliceRectTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Slice Sphere ID: esri_mapping_sliceSphereTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Steepest Path ID: esri_mapping_steepestPathTool Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Threat Dome ID: esri_mapping_threatDomeTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Viewshed ID: esri_mapping_viewshedTool Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Slice and Section ID: esri_mapping_voxelLayer_sliceTool Condition: esri_mapping_singleVoxelLayerSelectedInLocalSceneCondition |
categories
conditions
| Name: License is advanced ID: esri_license_AdvancedLicenseCondition |
| Name: Business Analyust license is active ID: esri_license_hasBusinessAnalystLicenseAndOpenMapProjectCondition |
| Name: License is standard and versions view has edits ID: esri_license_hasStandardLicenseAndVersionsHaveEditsCondition |
| Name: License is standard ID: esri_license_hasStandardLicenseCondition |
| Name: License is standard or datasource is file geodatabase ID: esri_license_hasStandardLicenseOrDatasourceIsFileGDBCondition |
| Name: MapHasBookmarks ID: esri_mapping_activeMapHasBookmarksCondition |
| Name: The active map view has selected features. ID: esri_mapping_activeMapView_hasFeatureSelectionCondition |
| Name: All the layers and standalone tables selected have oid ID: esri_mapping_allOidTablesSelectedCondition |
| Name: A raster layer is selected ID: esri_mapping_allRasterLayersSelectedCondition |
| Name: The active map view has animation enabled. ID: esri_mapping_animationEnabledCondition |
| Name: The active map view has animation enabled and animation shortcuts are available. ID: esri_mapping_animationShortcutsEnabledCondition |
| Name: A feature layer is selected ID: esri_mapping_annotationLayerSelectedCondition |
| Name: Attribute rules has valid edits ID: esri_mapping_attributeRules_hasEditsCondition |
| Name: Enable map-basemap converter ID: esri_mapping_BasemapConvertCondition |
| Name: Enable Basemap Gallery ID: esri_mapping_BasemapGalleryCondition |
| Name: Camera Effect Condition ID: esri_mapping_CameraEffectCondition |
| Name: A map or a single group layer is selected ID: esri_mapping_CanAddGroupLayerCondition |
| Name: Current map is available ID: esri_mapping_canAddToCurrentMapCondition |
| Name: The selected layer is eligible for aggregation. ID: esri_mapping_CanAggregateSelectedLayersCondition |
| Name: The selected layers can be copied ID: esri_mapping_canCopySelectedLayersCondition |
| Name: The selected map members can be grouped ID: esri_mapping_CanGroupSelectedMapMembersCondition |
| Name: The selected layers can be removed ID: esri_mapping_canRemoveSelectedLayersCondition |
| Name: The selected map members can be removed ID: esri_mapping_canRemoveSelectedMapMembersCondition |
| Name: The ground surface layer can be removed ID: esri_mapping_CanRemoveSurfaceLayerCondition |
| Name: Multiple layers are selected and at least one of them is turned on ID: esri_mapping_CanTurnOffLayerVisibility |
| Name: Multiple layers are selected and at least one of them is turned off ID: esri_mapping_CanTurnOnLayerVisibility |
| Name: A single group layer, with children, is selected ID: esri_mapping_canUngroupLayerSelectedCondition |
| Name: A map member with data sources selected ID: esri_mapping_catalogViewEditingDataSourcesCondition |
| Name: Color Coded Layer is selected ID: esri_mapping_colorCodedLayerSelectedCondition |
| Name: Color Vision Condition ID: esri_mapping_ColorVisionCondition |
| Name: No composite sublayer and feature layer using stream service is selected ID: esri_mapping_compositeSublayerAndStreamServiceNotSelectedCondition |
| Name: No composite sublayer is selected ID: esri_mapping_compositeSublayerNotSelectedCondition |
| Name: Can add contingent value ID: esri_mapping_contingentValues_canAddContingentValuesCondition |
| Name: Can delete contingent value ID: esri_mapping_contingentValues_canDeleteContingentValuesCondition |
| Name: Can add contingent value ID: esri_mapping_contingentValues_canGenerateContingentValuesCondition |
| Name: Retire contingent value ID: esri_mapping_contingentValues_canRetireValuesCondition |
| Name: Contingent values have valid edits ID: esri_mapping_contingentValues_hasEditsCondition |
| Name: Has field groups ID: esri_mapping_contingentValues_hasFieldGroupsCondition |
| Name: Data source supports viewing subtypes ID: esri_mapping_contingentValuesView_canOpenSubtypesCondition |
| Name: A Layer that support custom request parameters is selected ID: esri_mapping_customParameterLayerSelectedCondition |
| Name: A Standalone table that support custom request parameters is selected ID: esri_mapping_customParameterStandaloneTableSelectedCondition |
| Name: A data layer is selected ID: esri_mapping_dataLayerSelectedCondition |
| Name: A data source is versionable and selected ID: esri_mapping_dataSourceSelectedIsValidForChangeMomentCondition |
| Name: A data source is versionable and selected ID: esri_mapping_dataSourceSelectedIsValidForChangeVersionCondition |
| Name: A data source is versionable and selected and not already on default ID: esri_mapping_dataSourceSelectedIsValidForChangeVersionToDefaultCondition |
| Name: A data source is versionable and selected ID: esri_mapping_dataSourceSelectedIsVersionableAndNotFeatureServiceCondition |
| Name: A data source is versionable and selected ID: esri_mapping_dataSourceSelectedIsVersionableCondition |
| Name: Data source supports viewing attribute rules ID: esri_mapping_designview_canOpenAttributeRules |
| Name: A network diagram layer is selected ID: esri_mapping_diagramLayerSelectedCondition |
| Name: Data source supports deleting selected domains ID: esri_mapping_domainsView_canDelete |
| Name: License is standard or datasource is file geodatabase and domains are editable. ID: esri_mapping_domainsView_canEditDomainsCondition |
| Name: Domains are selected in the fields view for paste. ID: esri_mapping_domainsView_copiedCondition |
| Name: Domains are selected in the fields view for cut. ID: esri_mapping_domainsView_cutCondition |
| Name: Domains are selected in the fields view for delete. ID: esri_mapping_domainsView_deleteCondition |
| Name: Domains have been modified or deleted in the domains view. ID: esri_mapping_domainsView_hasEditsCondition |
| Name: Domains have not been modified or deleted in the domains view. ID: esri_mapping_domainsView_hasNoEditsCondition |
| Name: Domains have been modified or deleted in the domains view. ID: esri_mapping_domainsView_hasSavableEditsCondition |
| Name: Domains are selected in the domains view for copy. ID: esri_mapping_domainsView_selectedCondition |
| Name: An image service layer with table is selected ID: esri_mapping_dynamicImageServiceLayerWithTableSelectedCondition |
| Name: Edge Snapping ID: esri_mapping_EdgeSnapping |
| Name: Datasources currently being edited ID: esri_mapping_editingDataSourcesCondition |
| Name: 3D Scene or Globe ID: esri_mapping_EffectCondition |
| Name: An elevation source layer is selected ID: esri_mapping_ElevationSourceLayerSelectedCondition |
| Name: An elevation surface layer is selected ID: esri_mapping_ElevationSurfaceLayerSelectedCondition |
| Name: End Snapping ID: esri_mapping_EndSnapping |
| Name: The active map view has an EAT item selected and EAT shortcuts are available. ID: esri_mapping_exploratoryAnalysisShortcutsEnabledCondition |
| Name: Face Snapping ID: esri_mapping_FaceSnapping |
| Name: A feature layer is selected ID: esri_mapping_featureLayerSelectedCondition |
| Name: A feature layer is selected and is versionable ID: esri_mapping_featureLayerSelectedIsVersionableState |
| Name: A feature layer is selected and is versioned ID: esri_mapping_featureLayerSelectedIsVersionedState |
| Name: Data source supports adding new fields ID: esri_mapping_fieldsView_canAdd |
| Name: Data source supports deleting selected fields ID: esri_mapping_fieldsView_canDelete |
| Name: Data source supports adding field groups ID: esri_mapping_fieldsView_canFieldGroups |
| Name: Data source supports viewing contingent values ID: esri_mapping_fieldsView_canOpenContingentValues |
| Name: Data source supports viewing domains ID: esri_mapping_fieldsView_canOpenDomains |
| Name: Data source supports viewing subtypes ID: esri_mapping_fieldsView_canOpenSubtypes |
| Name: Fields are selected in the fields view for paste. ID: esri_mapping_fieldsView_copiedCondition |
| Name: Fields are selected in the fields view for cut. ID: esri_mapping_fieldsView_cutCondition |
| Name: Fields are selected in the fields view for delete. ID: esri_mapping_fieldsView_deleteCondition |
| Name: Fields have been modified or deleted in the fields view. ID: esri_mapping_fieldsView_hasEditsCondition |
| Name: Fields have not been modified or deleted in the fields view. ID: esri_mapping_fieldsView_hasNoEditsCondition |
| Name: Fields are selected in the fields view for Undo. ID: esri_mapping_fieldsView_redoCondition |
| Name: Fields are selected in the fields view for copy. ID: esri_mapping_fieldsView_selectedCondition |
| Name: Fields are selected in the fields view for Undo. ID: esri_mapping_fieldsView_undoCondition |
| Name: The active map view has floor filtering enabled. ID: esri_mapping_floorEnabledCondition |
| Name: Selected map has an active georeferencing edit session. ID: esri_mapping_GeoreferenceCondition |
| Name: Group layer is selected ID: esri_mapping_groupLayerSelectedCondition |
| Name: An image service layer or a mosaic layer is selected ID: esri_mapping_imageServiceAndMosaicLayerSelectedCondition |
| Name: An image service layer is selected ID: esri_mapping_imageServiceLayerSelectedCondition |
| Name: An image service layer with table is selected ID: esri_mapping_imageServiceLayerWithTableSelectedCondition |
| Name: Indoor Map ID: esri_mapping_indoorLicenseCondition |
| Name: The user is signed in to the AGOL portal. ID: esri_mapping_infographic_signedIn_condition |
| Name: Intersection Snapping ID: esri_mapping_IntersectionSnapping |
| Name: A valid group layer is selected ID: esri_mapping_inValidGroupLayerSelectedCondition |
| Name: IPS Map ID: esri_mapping_ipsLicenseCondition |
| Name: Feature Class is selected ID: esri_mapping_isFeatureClassSelectedCondition |
| Name: The ground surface layer is selected ID: esri_mapping_IsGroundSurfaceLayerSelectedCondition |
| Name: Popup design is enabled ID: esri_mapping_isPopDesignEnabledCondition |
| Name: Non query subtype stream feature layer is selected ID: esri_mapping_isSelectedFeatureLayerValidForIndexesCondition |
| Name: The layer floor property page can be shown. ID: esri_mapping_isSelectedLayerValidForFloorCondition |
| Name: Non shapefile query table is selected ID: esri_mapping_isSelectedTableValidForIndexesCondition |
| Name: ShapeField is selected ID: esri_mapping_isShapeFileSelectedCondition |
| ID: esri_mapping_itemSelectedIsVersionableAndNoEditsAndNotBranchClientServerCondition |
| Name: Selected Layer is not a Subtype layer, not a StreamLayer and not a Subtype value table. ID: esri_mapping_JoinsEnabledCondition |
| Name: Show the labeling pane ID: esri_mapping_LabelingPaneVisibleCondition |
| Name: A layer is selected ID: esri_mapping_layerSelectedCondition |
| Name: A layer legend class is selected ID: esri_mapping_legendClassSelectedCondition |
| Name: The map contains an m-aware layer ID: esri_mapping_LinearReferencingCondition |
| Name: No feature layer using stream service is selected ID: esri_mapping_LinkChartCompositeSubLayerStreamServiceNotSelectedCondition |
| Name: A link chart entity is selected ID: esri_mapping_linkChartEntitySelectedCondition |
| Name: A link chart relationship is selected ID: esri_mapping_linkChartRelationshipSelectedCondition |
| Name: A link chart is selected ID: esri_mapping_linkChartSelectedCondition |
| Name: Map Pane View is a 2D map ID: esri_mapping_MapCondition |
| Name: The map contains a Route Line Feature Class ID: esri_mapping_MapContainsRouteFeatureClass |
| Name: Enable 2D-3D map converter ID: esri_mapping_MapConvertCondition |
| Name: Map image layer is selected ID: esri_mapping_MapImageLayerSelectedCondition |
| Name: A feature layer is selected and is archive enabled ID: esri_mapping_mapMemberSelectedIsArchiveEnabledCondition |
| Name: A feature layer is selected and its parent datasource supports GDB validation ID: esri_mapping_mapMemberSelectedSupportsGdbValidationCondition |
| Name: The current map is not a BaseMap ID: esri_mapping_mapNotBaseMapCondition |
| Name: A project has a map project item ID: esri_mapping_mapProjectItemCondition |
| Name: A map is selected ID: esri_mapping_mapSelectedCondition |
| Name: Map service sublayer is selected ID: esri_mapping_mapServiceSubLayerSelectedCondition |
| Name: Active pane is not a Link Chart ID: esri_mapping_mapTypeLinkChartState_false |
| Name: 2D Map ID: esri_mapping_mapViewingMode2DCondition |
| Name: 3D Globe ID: esri_mapping_mapViewingMode3DGlobeCondition |
| Name: 3D Scene ID: esri_mapping_mapViewingMode3DPerspectiveCondition |
| Name: Midpoint Snapping ID: esri_mapping_MidpointSnapping |
| Name: A mosaic image sub layer is selected ID: esri_mapping_mosaicImageSubLayerSelectedCondition |
| Name: Multiple layers are selected ID: esri_mapping_multipleLayersSelectedCondition |
| Name: A network analyst layer is selected ID: esri_mapping_NALayerOrSublayerSelectedCondition |
| Name: A network analyst layer is selected ID: esri_mapping_NALayerSelectedCondition |
| Name: Selected raster layer uses a netcdf or multidimensional raster data source ID: esri_mapping_netcdfOrMdimRasterDataSourceSelectedCondition |
| Name: Selected feature layer uses a netcdf data source ID: esri_mapping_netcdfStandardDataSourceSelectedCondition |
| Name: Datasources currently being edited ID: esri_mapping_notEditingDataSourcesCondition |
| Name: A OGCAPI Layer is selected ID: esri_mapping_OgcAPILayerSelectedCondition |
| Name: Only knowledge graph tables selected. ID: esri_mapping_onlyKnowledgeGraphTableLayersSelectedCondition |
| Name: Only point cloud layers are selected ID: esri_mapping_onlyPointCloudLayersSelectedCondition |
| Name: All Selected Layers are Subtype layers ID: esri_mapping_onlySubtypeGroupLayersSelectedCondition |
| Name: Only standalone tables or feature layers selected. ID: esri_mapping_onlyTableLayersSelectedCondition |
| Name: A project is open and Image Analyst license is available. ID: esri_mapping_openProjectAndHasIAELicCondition |
| Name: A project is opened ID: esri_mapping_openProjectCondition |
| Name: An elevation source layer has been copied to the clipboard ID: esri_mapping_PasteElevationSourceLayerSelectedCondition |
| Name: An elevation surface layer has been copied to the clipboard ID: esri_mapping_PasteElevationSurfaceLayerSelectedCondition |
| Name: Point Snapping ID: esri_mapping_PointSnapping |
| Name: Enable Basemap Gallery for Preview ID: esri_mapping_PreviewBasemapGalleryCondition |
| Name: Selected raster layer uses a query data source ID: esri_mapping_queryDataSourceSelectedCondition |
| Name: The active map view has range enabled. ID: esri_mapping_rangeEnabledCondition |
| Name: The active map view has range enabled and range shortcuts are available. ID: esri_mapping_rangeShortcutsEnabledCondition |
| Name: Show the symbology pane ID: esri_mapping_RasterSymbologyPaneVisibleCondition |
| Name: Selected Layer is not a StreamLayer. ID: esri_mapping_RelatesEnabledCondition |
| Name: Multiple Layers and Tables selected in a TOC for Save as Layer File button ID: esri_mapping_SaveLayerFileCondition |
| Name: Selected map has an active georeferencing edit session. ID: esri_mapping_SceneGeoreferenceCondition |
| Name: Map Pane View is a 3D map ID: esri_mapping_SceneMapCondition |
| Name: A standalone table is selected but not a sub-table of a layer ID: esri_mapping_SelectedStandaloneTableInEditableContainerCondition |
| Name: The layer elevation property page can be shown. ID: esri_mapping_showLayerElevationCondition |
| Name: The voxel display property page can be shown. ID: esri_mapping_showVoxelLayerDisplayPropertyPageCondition |
| Name: A single 2D layer with point clustering is selected ID: esri_mapping_single2DClusteringLayerSelectedCondition |
| Name: A single binning layer is selected ID: esri_mapping_singleBinningLayerSelectedCondition |
| Name: A single layer with point clustering is selected ID: esri_mapping_singleClusteringLayerSelectedCondition |
| Name: A single group layer is selected ID: esri_mapping_singleGroupLayerSelectedCondition |
| Name: A single layer is selected ID: esri_mapping_singleLayerSelectedCondition |
| Name: A single link chart entity is selected ID: esri_mapping_singleLinkChartEntitySelectedCondition |
| Name: A single link chart relationship is selected ID: esri_mapping_singleLinkChartRelationshipSelectedCondition |
| Name: A single link chart is selected ID: esri_mapping_singleLinkChartSelectedCondition |
| Name: A single map member is selected ID: esri_mapping_singleMapMemberSelectedCondition |
| Name: A single map member whose data source can be changed is selected ID: esri_mapping_singleMapMemberWhoseDataSourceCanChangeSelectedCondition |
| Name: Exactly one point cloud layer is selected ID: esri_mapping_singlePointCloudLayerSelectedCondition |
| Name: A single Route Layer is selected ID: esri_mapping_SingleRouteLayerSelected |
| Name: A single sql query is selected ID: esri_mapping_singleSqlQuerySelectedCondition |
| Name: A single standalone table is selected ID: esri_mapping_singleStandaloneTableSelectedCondition |
| Name: A single standalone table is selected ID: esri_mapping_singleStandaloneVideoSelectedCondition |
| Name: A single subtype value layer is selected ID: esri_mapping_singleSubtypeValueLayerSelectedCondition |
| Name: A single subtype value layer or table is selected ID: esri_mapping_singleSubtypeValueMemberSelectedCondition |
| Name: A single TOC item is selected ID: esri_mapping_singleTOCItemSelectedCondition |
| Name: A standalone table is selected ID: esri_mapping_standaloneSubTableSelectedCondition |
| Name: A standalone table is selected ID: esri_mapping_standaloneTableSelectedCondition |
| Name: A standalone video is selected ID: esri_mapping_standaloneVideoSelectedCondition |
| Name: Feature layer using a stream service data connection is not selected ID: esri_mapping_StreamServiceNotSelectedCondition |
| Name: No subtype layer or subtype value layer is selected ID: esri_mapping_subtypeGroupLayerParentAndChildNotSelectedCondition |
| Name: A Subtype layer is selected ID: esri_mapping_subtypeGroupLayerSelectedCondition |
| Name: Subtype group tables selected. ID: esri_mapping_subtypeGroupTableSelectedCondition |
| Name: Subtypes are selected in the fields view for paste. ID: esri_mapping_subtypesView_copiedCondition |
| Name: Subtypes are selected in the fields view for cut. ID: esri_mapping_subtypesView_cutCondition |
| Name: Subtypes are selected in the fields view for delete. ID: esri_mapping_subtypesView_deleteCondition |
| Name: Subtypes have been modified or deleted in the subtypes view. ID: esri_mapping_subtypesView_hasEditsCondition |
| Name: Subtypes are selected in the fields view for Undo. ID: esri_mapping_subtypesView_redoCondition |
| Name: Subtypes are selected in the fields view for copy. ID: esri_mapping_subtypesView_selectedCondition |
| Name: Subtypes are selected in the fields view for Undo. ID: esri_mapping_subtypesView_undoCondition |
| Name: No subtype value layer and feature layer using stream service is selected ID: esri_mapping_subtypeValueLayerAndStreamServiceNotSelectedCondition |
| Name: No subtype value layer is selected ID: esri_mapping_SubtypeValueLayerNotSelectedCondition |
| Name: Subtype value tables selected. ID: esri_mapping_subtypeValueTableSelectedCondition |
| Name: Parcel Fabric version supports parcel topology rules. ID: esri_mapping_SupportParcelTopologyRulesCondition |
| Name: Time is not supported ID: esri_mapping_SupportsTimePageCondition |
| Name: Show the symbology pane ID: esri_mapping_SymbologyPaneVisibleCondition |
| Name: Tangent Snapping ID: esri_mapping_TangentSnapping |
| Name: Tile layer is selected ID: esri_mapping_TiledServiceLayerSelectedCondition |
| Name: The active map view has time enabled. ID: esri_mapping_timeEnabledCondition |
| Name: The active map view has time enabled and time shortcuts are available. ID: esri_mapping_timeShortcutsEnabledCondition |
| Name: A feature layer or a standalone table is selected ID: esri_mapping_tocTableCondition |
| Name: A standalone table is selected but not a sub-table of a layer ID: esri_mapping_topLevelOnlyStandaloneTableSelectedCondition |
| Name: A trace network layer is selected ID: esri_mapping_traceNetworkCondition |
| Name: A utility network layer is selected ID: esri_mapping_utilityNetworkCondition |
| Name: Create a new version. ID: esri_mapping_versionsView_canAddNewCondition |
| Name: License is standard, Branch, and versions view has edits ID: esri_mapping_versionsView_canCommitEditsCondition |
| Name: Version(s) have been selected in the versions view. ID: esri_mapping_versionsView_canDeleteCondition |
| Name: License is standard or has advanced editing license. ID: esri_mapping_versionsView_canReconcileAndPostCondition |
| Name: Version(s) have been selected in the versions view. ID: esri_mapping_versionsView_canRestoreCondition |
| Name: Versions have been modified or deleted in the versions view ID: esri_mapping_versionsView_hasEditsCondition |
| Name: Version(s) have been selected in the versions view ID: esri_mapping_versionsView_hasSelectionCondition |
| Name: Versions view has been set to read only. ID: esri_mapping_versionsView_readOnlyCondition |
| Name: Vertex Snapping ID: esri_mapping_VertexSnapping |
| Name: 3D Scene or Globe ID: esri_mapping_ViewingMode3DCondition |
| Name: 3D Scene or Globe or Stereo ID: esri_mapping_ViewingMode3DOrStereoCondition |
| Name: A WCS Layer is not selected ID: esri_mapping_WCSLayerNotSelectedCondition |
| Name: A WFS Layer is selected ID: esri_mapping_WfsLayerSelectedCondition |
| Name: WMS Service layer is selected ID: esri_mapping_WMSServiceLayerSelectedCondition |
| Name: WMS sub layer is selected ID: esri_mapping_WMSSubLayerSelectedCondition |
| Name: WMTS Service layer is selected ID: esri_mapping_WMTSServiceLayerSelectedCondition |
| Name: The subtypes view is not read only and has at least one integer field. ID: esri_subtypes_canManageCondition |
dockPanes
![]() | Name: Export Movie ID: esri_mapping_animationDockPane Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Animation Properties ID: esri_mapping_animationEditorDockPane Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Preview Frame ID: esri_mapping_animationPreviewDockPane Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Animation Timeline ID: esri_mapping_animationTimelineDockPane Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Bookmarks ID: esri_mapping_bookmarksManagerDockPane Condition: esri_mapping_mapProjectItemCondition |
![]() | Name: Building Filter ID: esri_mapping_buildingSceneLayerObject3DRenderingFilterDockPane Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Device Location ID: esri_mapping_deviceLocationInfoDockPane Condition: esri_mapping_showLocationInfoEnabledCondition |
![]() | Name: Domain Usage ID: esri_mapping_domainsinuseDockPane |
![]() | Name: Export to 3D File ID: esri_mapping_exportSceneDockPane Condition: esri_mapping_mapViewingMode3DPerspectiveCondition |
![]() | Name: Feature Class Properties ID: esri_mapping_featureClassDockPane Condition: esri_mapping_openProjectCondition |
![]() | Name: Find Routes ID: esri_mapping_findRoutesDockPane |
![]() | Name: Find Similar ID: esri_mapping_findSimilarDockPane |
![]() | Name: Configure Simulation ID: esri_mapping_floodSimulationConfigureDockPane Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Geocode Table ID: esri_mapping_geocodeTableDockPane Condition: esri_mapping_onlyTableLayersSelectedCondition |
![]() | Name: Pop-up ID: esri_mapping_infoDockPane |
![]() | Name: Exploratory Analysis ID: esri_mapping_interactiveAnalysisDockPane |
![]() | Name: Label Class ID: esri_mapping_labelClassDockPane Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Locate ID: esri_mapping_locateDockPane Condition: esri_mapping_locateProvidersReadyToUseWithMap |
![]() | Name: Oriented Imagery Viewer ID: esri_mapping_orientedImageryViewerDockPane |
![]() | Name: Configure Pop-ups ID: esri_mapping_popupsDockPane Condition: esri_mapping_mapPane |
![]() | Name: Configure Simulation ID: esri_mapping_simulationConfigureDockPane Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Export Simulation ID: esri_mapping_simulationExportDockPane Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Symbology ID: esri_mapping_symbologyDockPane Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: History ID: esri_mapping_temporalViewerDockPane Condition: esri_mapping_mapPane |
![]() | Name: Voxel Exploration ID: esri_mapping_voxelLayerExploreDockPane Condition: esri_mapping_mapPaneOrLayoutPane |
galleries
![]() | Name: Ready to Use Rules ID: esri_attributeRulesView_AddAttributeCompositeRuleGallery Condition: esri_mapping_attributeRulesView_compositeShowRibbon |
![]() | Name: Add Data ID: esri_mapping_addDataGallery Condition: esri_mapping_mapPaneOrLinkChart |
![]() | Name: Simulation ID: esri_mapping_addSimulationGallery Condition: esri_mapping_simulationEnabledCondition |
![]() | Name: Aggregation ID: esri_mapping_aggregationTypeGallery Condition: esri_mapping_CanAggregateSelectedLayersCondition |
![]() | Name: Add Overlay ID: esri_mapping_animationOverlayGallery |
![]() | Name: Add Rule ID: esri_mapping_attributeRules_addRuleGallery Condition: esri_mapping_attributeRulesView_editable |
![]() | Name: Ready to Use Rules ID: esri_mapping_attributeRules_datareviewerRuleGallery Condition: esri_mapping_attributeRulesView_reviewer |
![]() | Name: Basemap ID: esri_mapping_basemapGallery Condition: esri_mapping_BasemapGalleryCondition |
![]() | Name: Bookmarks ID: esri_mapping_bookmarksNavigateGallery Condition: esri_mapping_mapPaneOrLayoutPane |
![]() | Name: Update ID: esri_mapping_bookmarksUpdateGallery Condition: esri_mapping_mapPane |
![]() | Name: Camera Effect ID: esri_mapping_cameraEffectGallery Condition: esri_mapping_CameraEffectCondition |
![]() | Name: Color Vision Deficiency Type ID: esri_mapping_colorVisionDeficiencyGallery |
| Name: Group Type ID: esri_mapping_groupLayerTypeGallery Condition: esri_mapping_singleGroupLayerSelectedCondition | |
![]() | Name: Import ID: esri_mapping_importToKeyframeGallery |
![]() | Name: Exploratory Analysis ID: esri_mapping_interactiveAnalysisGallery Condition: esri_mapping_mapPaneOrLayoutPaneNotLinkChart |
![]() | Name: Label Placement Style ID: esri_mapping_labelPlacementStyleGallery Condition: esri_mapping_labeledLayer2DCondition |
![]() | Name: Text Symbol Style ID: esri_mapping_labelTextSymbolStylesGallery Condition: esri_mapping_labeledLayerSelectedCondition |
| Name: Face Culling ID: esri_mapping_layer3DFaceCullingGallery Condition: esri_mapping_FaceCullingCondition | |
| Name: Lighting ID: esri_mapping_layer3DLightingGallery Condition: esri_mapping_LightingCondition | |
![]() | Name: Symbology ID: esri_mapping_layerBinsSymbologyGallery Condition: esri_mapping_EnableSymbologyCondition |
![]() | Name: Symbology ID: esri_mapping_layerClustersSymbologyGallery Condition: esri_mapping_EnableSymbologyCondition |
| Name: Type ID: esri_mapping_layerExtrusionTypeGallery Condition: esri_mapping_onlyFeatureLayersSelectedOn3DViewCondition | |
![]() | Name: Building Filter ID: esri_mapping_layerObject3DRenderingFilterGallery |
![]() | Name: Symbology ID: esri_mapping_layerSymbologyGallery Condition: esri_mapping_EnableSymbologyCondition |
| ID: esri_mapping_locateGallery Condition: esri_mapping_locateProvidersReadyToUseWithMap | |
| ID: esri_mapping_orientedImageryLayerMeasureInOIGallery Condition: esri_mapping_imageLoadedInOrientedImageryViewerCondition | |
| Name: Feature Layer overlay ID: esri_mapping_orientedImageryLayerOverlaysFeatureLayerGallery Condition: esri_mapping_imageLoadedInOrientedImageryViewerCondition | |
![]() | Name: Symbology ID: esri_mapping_pointCloudLayerSymbologyGallery Condition: esri_mapping_singlePointCloudLayerSelectedCondition |
![]() | Name: Postprocessing Effects ID: esri_mapping_postprocessingEffectGallery Condition: esri_mapping_EffectCondition |
![]() | Name: Basemap ID: esri_mapping_previewBasemapGallery Condition: esri_mapping_PreviewBasemapGalleryCondition |
![]() | Name: Band Combination ID: esri_mapping_rasterBandCombinationGallery Condition: esri_mapping_rasterLayerBandCombinationApplicableCondition |
![]() | Name: Symbology ID: esri_mapping_rasterLayerSymbologyGallery Condition: esri_mapping_allRasterLayersSelectedCondition |
![]() | Name: Sort ID: esri_mapping_rasterMosaicMethodsGallery Condition: esri_mapping_dynamicImageServiceLayerWithTableSelectedCondition |
![]() | Name: Resolve Overlap ID: esri_mapping_rasterMosaicOperatorsGallery Condition: esri_mapping_dynamicImageServiceLayerWithTableSelectedCondition |
![]() | Name: Processing Templates ID: esri_mapping_rasterRenderingRulesGallery Condition: esri_mapping_renderingRulesSupportedCondition |
![]() | Name: Resampling Type ID: esri_mapping_rasterResamplingTypeGallery Condition: esri_mapping_allRasterLayersSelectedCondition |
![]() | Name: Rotation Type ID: esri_mapping_rasterRotationTypeGallery Condition: esri_mapping_allRasterLayersSelectedCondition |
![]() | Name: SAR Indices ID: esri_mapping_rasterSARIndicesGallery Condition: esri_mapping_rasterSARLayerIndicesApplicableCondition |
![]() | Name: Polarizations ID: esri_mapping_rasterSARPolsGallery |
![]() | Name: Stretch Type ID: esri_mapping_rasterStretchTypeGallery Condition: esri_mapping_rasterLayerStretchTypeApplicableCondition |
![]() | Name: Template ID: esri_mapping_rasterTemplateGallery Condition: esri_mapping_mapPane |
| Name: Drawing Mode ID: esri_mapping_sceneViewModeGallery Condition: esri_mapping_ViewingMode3DCondition | |
![]() | Name: Add Element ID: esri_mapping_simulationInsertGallery Condition: esri_mapping_simulationLayerActiveCondition |
![]() | Name: Related Data ID: esri_mapping_tableRelatesGallery |
| Name: Filter ID: esri_mapping_tocFilterGallery | |
![]() | Name: Visual Effect ID: esri_mapping_visualEffectGallery Condition: esri_mapping_EffectCondition |
![]() | Name: Symbology ID: esri_mapping_voxelLayerSymbologyGallery Condition: esri_mapping_singleVoxelLayerSelectedInLocalSceneConditionEx |
![]() | Name: Symbology ID: esri_mapping_wmsSubLayerSymbologyGallery Condition: esri_mapping_WMSSubLayerSelectedCondition |
![]() | Name: Bookmarks ID: esri_motionimagery_bookmarksNavigateGallery Condition: esri_motionimagery_videoPaneActive |
groups
![]() | Name: Data Design ID: esri_contingentvalues_designViewGroup |
![]() | Name: Edits ID: esri_contingentvalues_EditsGroup |
![]() | Name: Import/Export ID: esri_contingentvalues_ImportExportGroup |
![]() | Name: Manage Edits ID: esri_contingentvalues_ManageEditsGroup |
![]() | Name: Changes ID: esri_domainview_changesGroup |
![]() | Name: Edits ID: esri_domainview_editsGroup |
![]() | Name: Filter ID: esri_domainview_filterGroup |
![]() | Name: Changes ID: esri_fieldview_changesGroup |
![]() | Name: Data Engineering ID: esri_fieldview_dataEngineeringGroup |
![]() | Name: Data Design ID: esri_fieldview_designGroup |
![]() | Name: Edits ID: esri_fieldview_editsGroup |
![]() | Name: Filter ID: esri_fieldview_filterGroup |
![]() | Name: Field Order ID: esri_fieldview_sortGroup |
![]() | Name: Effects ID: esri_mapping__pointCloudLayerEffectsGroup |
![]() | Name: Accessibility ID: esri_mapping_accessibilityGroup Condition: esri_mapping_ColorVisionCondition |
![]() | Name: Active Range ID: esri_mapping_activeRange |
| Name: New Check ID: esri_mapping_AddAttributeCompositeRuleButtonGroup | |
![]() | Name: Add Rules ID: esri_mapping_AddAttributeRulesButtonGroup |
![]() | Name: Animation ID: esri_mapping_animation Condition: esri_mapping_mapOrDesignViewOrConflictsPanes |
![]() | Name: Create ID: esri_mapping_animationAppend |
![]() | Name: Export ID: esri_mapping_animationExport |
![]() | Name: Edit ID: esri_mapping_animationKeyframe |
![]() | Name: Manage ID: esri_mapping_animationList |
![]() | Name: Overlay ID: esri_mapping_animationOverlay |
![]() | Name: Playback ID: esri_mapping_animationPlayback |
![]() | Name: Display ID: esri_mapping_animationVisualization |
![]() | Name: Reference Scale ID: esri_mapping_annotationLayerReferenceScaleGroup Condition: esri_mapping_AnnotationLayerReferenceScaleCondition |
![]() | Name: Drawing ID: esri_mapping_annotationLayerSymbology |
![]() | Name: Archiving ID: esri_mapping_archiveGroup |
![]() | Name: Data Design ID: esri_mapping_AttributeRulesDesignViewGroup |
![]() | Name: Edits ID: esri_mapping_AttributeRulesEditsGroup |
![]() | Name: Import/Export ID: esri_mapping_AttributeRulesImportExportGroup |
![]() | Name: Manage Edits ID: esri_mapping_attributeRulesView_manageEditsGroup |
| Name: BIM Cloud ID: esri_mapping_bimCloudControlsGroup | |
![]() | Name: Appearance ID: esri_mapping_binningAppearanceGroup |
![]() | Name: Configuration ID: esri_mapping_binningConfigurationGroup |
| Name: Drawing ID: esri_mapping_binningDrawingGroup | |
![]() | Name: Drawing ID: esri_mapping_binningLayerDrawingGroup |
![]() | Name: Layer ID: esri_mapping_binningLayerGroup |
![]() | Name: Size ID: esri_mapping_binningSizeGroup |
![]() | Name: Summary ID: esri_mapping_binningSummaryGroup |
![]() | Name: Binning Threshold ID: esri_mapping_binningThresholdGroup |
| Name: Conversion ID: esri_mapping_buildingLayerConversionGroup | |
| Name: Filter ID: esri_mapping_buildingLayerObject3DRenderingFilterGroup | |
![]() | Name: Configuration ID: esri_mapping_catalogLayerConfigurationGroup |
![]() | Name: Drawing ID: esri_mapping_catalogLayerSymbology |
![]() | Name: Drawing ID: esri_mapping_clusteringLayerDrawingGroup |
| Name: Distance ID: esri_mapping_clusteringRadiusGroup | |
![]() | Name: Summary ID: esri_mapping_clusteringSummaryGroup |
| Name: Visibility ID: esri_mapping_clusteringVisibilityGroup | |
![]() | Name: Current Range ID: esri_mapping_currentRange |
![]() | Name: Current Time ID: esri_mapping_currentTime |
| Name: Clipboard ID: esri_mapping_dataSources_ClipboardGroup | |
![]() | Name: Close ID: esri_mapping_dataSources_CloseGroup |
![]() | Name: Manage Changes ID: esri_mapping_dataSources_ManageChangesGroup |
![]() | Name: Tools ID: esri_mapping_dataSources_ReplaceToolsGroup |
![]() | Name: View ID: esri_mapping_dataSources_ViewGroup |
| Name: Clipboard ID: esri_mapping_DeleteAttributeRulesCompositeRulesButtonGroup | |
![]() | Name: Clipboard ID: esri_mapping_designView_clipboardGroup |
![]() | Name: Data Design ID: esri_mapping_designViewGroup |
![]() | Name: Data Design ID: esri_mapping_designViewGroupOnlyFieldsView |
![]() | Name: Device Location ID: esri_mapping_deviceLocationGroup |
| Name: Windows ID: esri_mapping_dockWindows | |
![]() | Name: Manage Edits ID: esri_mapping_domains_manageEditsGroup |
![]() | Name: Effects ID: esri_mapping_effectsGroup Condition: esri_mapping_showEffectsGroupCondition |
![]() | Name: Drawing ID: esri_mapping_elevationLayerDrawingGroup |
![]() | Name: Effects ID: esri_mapping_elevationLayerEffectsGroup |
![]() | Name: Surface ID: esri_mapping_elevationSurfaceLayerGroup |
![]() | Name: Drawing ID: esri_mapping_ENCLayerSymbology |
![]() | Name: Feature Cache ID: esri_mapping_featureCacheGroup Condition: esri_mapping_featureCachingEnabledCondition |
![]() | Name: Table ID: esri_mapping_featureLayerAttributeGroup |
![]() | Name: Manage Edits ID: esri_mapping_fieldsview_manageEditsGroup |
![]() | Name: Filter Versions ID: esri_mapping_filterVersionsGroup |
![]() | Name: Selection ID: esri_mapping_footprintlayer_SelectionGroup |
![]() | Name: Full Extent ID: esri_mapping_fullRange |
![]() | Name: Full Extent ID: esri_mapping_fullTime |
![]() | Name: Compare ID: esri_mapping_gaussianSplatLayerCompareGroup |
![]() | Name: Geocoding ID: esri_mapping_geocodeToolsGroup |
| Name: Close ID: esri_mapping_georeference_CloseGroup Condition: esri_mapping_SceneGeoreferenceCondition | |
| Name: Alignment ID: esri_mapping_georeference_GeoreferenceGroup Condition: esri_mapping_SceneMapCondition | |
![]() | Name: Prepare ID: esri_mapping_georeference_PrepareGroup Condition: esri_mapping_SceneGeoreferenceCondition |
| Name: Alignment ID: esri_mapping_georeference_RasterGeoreferenceGroup Condition: esri_mapping_MapCondition | |
| Name: Save ID: esri_mapping_georeference_SaveGroup Condition: esri_mapping_SceneGeoreferenceCondition | |
![]() | Name: Arrange ID: esri_mapping_graphicsLayerArrangeGroup |
![]() | Name: Edit ID: esri_mapping_graphicsLayerEditGroup |
![]() | Name: Insert ID: esri_mapping_graphicsLayerInsertGroup |
![]() | Name: Reference Scale ID: esri_mapping_graphicsLayerReferenceScaleGroup |
![]() | Name: Drawing ID: esri_mapping_graphicsLayerSymbology |
![]() | Name: Options ID: esri_mapping_groupLayerOptions |
![]() | Name: Tools ID: esri_mapping_imageServiceLayerToolsGroup |
![]() | Name: Inquiry ID: esri_mapping_inquiryGroup |
![]() | Name: Analyze ID: esri_mapping_integratedMeshLayerAnalyzeGroup |
| Name: Exclusion ID: esri_mapping_integratedMeshLayerDataExclusionGroup | |
![]() | Name: Manage ID: esri_mapping_integratedMeshLayerManageGroup |
![]() | Name: Modification ID: esri_mapping_integratedMeshLayerModificationGroup |
![]() | Name: Operation ID: esri_mapping_integratedMeshLayerOperationGroup |
![]() | Name: Text Symbol ID: esri_mapping_kmlLayerLabelingTextSymbolGroup |
![]() | Name: Labeling ID: esri_mapping_labelingGroup |
![]() | Name: Label Class ID: esri_mapping_labelingLabelClassGroup |
![]() | Name: Layer ID: esri_mapping_labelingLayerGroup |
![]() | Name: Map ID: esri_mapping_labelingMapGroup |
![]() | Name: Label Placement ID: esri_mapping_labelingPlacementStyleGroup |
![]() | Name: Visibility Range ID: esri_mapping_labelingScalesGroup2D Condition: esri_mapping_mapViewingMode2DCondition |
![]() | Name: Visibility Range ID: esri_mapping_labelingScalesGroup3D Condition: esri_mapping_ViewingMode3DCondition |
![]() | Name: Text Symbol ID: esri_mapping_labelingTextSymbolGroup |
![]() | Name: Faces ID: esri_mapping_layer3DGroup |
![]() | Name: Archiving ID: esri_mapping_layerArchivingGroup |
![]() | Name: Compare ID: esri_mapping_layerCompareGroup |
![]() | Name: Definition Query ID: esri_mapping_layerDefQueryGroup |
![]() | Name: Effects ID: esri_mapping_layerEffectsGroup |
![]() | Name: Extrusion ID: esri_mapping_layerExtrusion |
![]() | Name: Layer ID: esri_mapping_layerGroup |
| Name: Filter ID: esri_mapping_layerObject3DRenderingFilterGroup | |
![]() | Name: Relationship ID: esri_mapping_layerRelationshipsGroup |
![]() | Name: Visibility Range ID: esri_mapping_layerScaleVisibilityGroup |
![]() | Name: Selection ID: esri_mapping_layerSelectionGroup |
![]() | Name: Drawing ID: esri_mapping_layerSymbology |
![]() | Name: Drawing ID: esri_mapping_layerSymbologyMixedLayers |
![]() | Name: Drawing ID: esri_mapping_layerSymbologyWMSSubLayers |
![]() | Name: Export ID: esri_mapping_layerToolsGroup |
![]() | Name: Versioning ID: esri_mapping_layerVersioningGroup |
![]() | Name: Manage Edits ID: esri_mapping_layerVersioningManageEditsGroup |
![]() | Name: Light and Shadow ID: esri_mapping_lightingAndShading_LAS_PCL Condition: esri_mapping_3DLightingAndShading |
![]() | Name: Light and Shadow ID: esri_mapping_lightingAndShadingGroup Condition: esri_mapping_3DLightingAndShading |
![]() | Name: Display ID: esri_mapping_linearReferencing_displayGroup |
![]() | Name: Navigate ID: esri_mapping_linearReferencing_NavigationGroup |
![]() | Name: Route Identifier ID: esri_mapping_linearReferencing_routeIdentifier |
![]() | Name: Selection ID: esri_mapping_linearReferencing_selectionGroup |
![]() | Name: Display ID: esri_mapping_location_displayGroup |
![]() | Name: Navigation ID: esri_mapping_location_locationNavigationGroup |
![]() | Name: Effects ID: esri_mapping_mapImageLayerSubLayerEffectsGroup |
![]() | Name: Labeling ID: esri_mapping_mapImageLayerSubLayerLabelingGroup |
![]() | Name: Drawing ID: esri_mapping_mapImageLayerSubLayerSymbology Condition: esri_mapping_mapServiceSubLayerDynamicSymbologyAllowedState |
![]() | Name: Analysis ID: esri_mapping_mdimRasterLayerAnalysisGroup |
![]() | Name: Selection ID: esri_mapping_mosaicLayerSelectionGroup |
![]() | Name: Navigate ID: esri_mapping_navigateGroup |
![]() | Name: Navigation ID: esri_mapping_navigation Condition: esri_mapping_mapOrDesignViewOrConflictsPanes |
![]() | Name: Offline ID: esri_mapping_offlineGroup |
![]() | Name: Organize ID: esri_mapping_organizeStyles |
![]() | Name: Show ID: esri_mapping_OrientedImageryLayerShowGroup |
![]() | Name: Tools ID: esri_mapping_OrientedImageryLayerToolsGroup |
| Name: Image Inquiry ID: esri_mapping_OrientedImageryLayerVisuGroup | |
![]() | Name: Overprint ID: esri_mapping_overprint |
![]() | Name: Analyze ID: esri_mapping_pointCloudLayerAnalyzeGroup |
![]() | Name: Drawing ID: esri_mapping_pointCloudLayerAppearanceDrawingGroup |
![]() | Name: Point Display ID: esri_mapping_pointCloudLayerAppearancePointThinningGroup |
![]() | Name: Manage ID: esri_mapping_pointCloudLayerManageGroup |
![]() | Name: Profile Viewing ID: esri_mapping_profileViewGroup Condition: esri_mapping_SceneMapCondition |
![]() | Name: Project ID: esri_mapping_projectFile |
![]() | Name: View ID: esri_mapping_range |
![]() | Name: Playback ID: esri_mapping_rangePlayback |
![]() | Name: Step ID: esri_mapping_rangeStep |
![]() | Name: Compression ID: esri_mapping_rasterLayerCompressionGroup |
![]() | Name: Enhancement ID: esri_mapping_rasterLayerEnhancementGroup |
![]() | Name: Image Display Order ID: esri_mapping_rasterLayerImageDisplayOrderGroup |
![]() | Name: Multidimensional Filter ID: esri_mapping_rasterLayerMultidimensionalGroup |
![]() | Name: Processing ID: esri_mapping_rasterLayerProcessingTemplatesGroup |
![]() | Name: Rendering ID: esri_mapping_rasterLayerRenderingGroup |
![]() | Name: Rotation ID: esri_mapping_rasterLayerRotateGroup |
![]() | Name: Tools ID: esri_mapping_rasterLayerToolsGroup |
![]() | Name: Analysis ID: esri_mapping_SARLayerAnalysisGroup |
![]() | Name: Visualization ID: esri_mapping_SARLayerVisualizationGroup |
![]() | Name: Scene ID: esri_mapping_sceneGroup Condition: esri_mapping_mapOrDesignViewOrConflictsPanes |
![]() | Name: Exclusion ID: esri_mapping_sceneLayerDataExclusionGroup |
![]() | Name: Selection ID: esri_mapping_sceneLayerSelectionGroup |
![]() | Name: Drawing ID: esri_mapping_sceneLayerSymbology |
![]() | Name: Selection ID: esri_mapping_selectionGroup |
![]() | Name: Active ID: esri_mapping_simulationActive |
![]() | Name: Configuration ID: esri_mapping_simulationConfiguration |
![]() | Name: Export ID: esri_mapping_simulationExport |
![]() | Name: Insert ID: esri_mapping_simulationInsert |
![]() | Name: Playback ID: esri_mapping_simulationPlayback Condition: esri_mapping_playableSimulationCondition |
![]() | Name: Resolution ID: esri_mapping_simulationResolution |
![]() | Name: Build ID: esri_mapping_simulationRun Condition: esri_mapping_notPlayableSimulationCondition |
![]() | Name: Build ID: esri_mapping_simulationRunClear Condition: esri_mapping_playableSimulationCondition |
![]() | Name: Relationship ID: esri_mapping_standaloneRelationshipsGroup |
![]() | Name: Selection ID: esri_mapping_standaloneSelectionGroup |
![]() | Name: Streaming Data ID: esri_mapping_streamingDataGroup |
![]() | Name: Previous Observations ID: esri_mapping_streamLayerPreviousObservations Condition: esri_mapping_streamLayerWithTrackIdSelectedCondition |
![]() | Name: Drawing ID: esri_mapping_streamLayerSymbology |
![]() | Name: Drawing ID: esri_mapping_subtypeGroupLayerSymbology |
![]() | Name: Export ID: esri_mapping_subtypeGroupTableToolsGroup |
![]() | Name: Link ID: esri_mapping_syncViewGroup Condition: esri_mapping_mapOrDesignViewOrConflictsPanes |
| Name: Thumbnail ID: esri_mapping_thumbnailGroup Condition: esri_mapping_mapOrDesignViewOrConflictsPanes | |
![]() | Name: View ID: esri_mapping_time |
![]() | Name: Playback ID: esri_mapping_timePlayback |
![]() | Name: Snapping ID: esri_mapping_timeSnapping |
![]() | Name: Step ID: esri_mapping_timeStep |
![]() | Name: Time Zone ID: esri_mapping_timeZoneGroup |
![]() | Name: Export ID: esri_mapping_trajectoryLayerExportGroup |
![]() | Name: Version Administration ID: esri_mapping_VersionAdministrationGroup |
![]() | Name: Manage Versions ID: esri_mapping_VersionChangesGroup |
![]() | Name: Data Source ID: esri_mapping_versionDataSourceGroup |
![]() | Name: Map View ID: esri_mapping_versionMapViewGroup |
![]() | Name: View Clipping ID: esri_mapping_viewClippingGroup Condition: esri_mapping_mapOrDesignViewOrConflictsPanes |
![]() | Name: View ID: esri_mapping_viewGroup Condition: esri_mapping_mapOrDesignViewOrConflictsPanes |
| Name: Explore ID: esri_mapping_voxelLayerDataExploreGroup | |
![]() | Name: Drawing ID: esri_mapping_voxelLayerDrawingGroup |
![]() | Name: Elevation ID: esri_mapping_voxelLayerElevationGroup |
![]() | Name: Export ID: esri_mapping_voxelLayerExportGroup |
| Name: Isosurface ID: esri_mapping_voxelLayerIsosurfaceGroup | |
![]() | Name: Lighting ID: esri_mapping_voxelLayerLightingGroup |
![]() | Name: Variable ID: esri_mapping_voxelLayerVariableGroup |
![]() | Name: Project ID: esri_project_mapping_home |
![]() | Name: Styles ID: esri_project_styles |
![]() | Name: Create ID: esri_project_styles_create |
![]() | Name: Manage ID: esri_project_styles_manage |
![]() | Name: Project ID: esri_project_styles_project |
![]() | Name: Edits ID: esri_subtypeview_changesGroup |
![]() | Name: Data Design ID: esri_subtypeview_designViewGroup |
![]() | Name: Manage Edits ID: esri_subtypeview_managementGroup |
insertSheet
| Name: Feature Layers ID: esri_catalog_parcelFeatureLayersPropertyPage |
| Name: Annotation Class ID: esri_mapping_annotationSubLayerAnnotationClassPage |
| Name: General ID: esri_mapping_annotationSubLayerGeneralPage |
| Name: Computation ID: esri_mapping_binningComputationSettingsPage |
| Name: Summary Statistics ID: esri_mapping_binningSummaryStatisticsPage |
| Name: Category Definition ID: esri_mapping_categoryDefinitionTimelineSwimlanePropertyPage |
| Name: Clip Layers ID: esri_mapping_clipLayersPropertyPage Condition: esri_mapping_mapNotBaseMapCondition |
| Name: Summary Statistics ID: esri_mapping_clusteringSummaryStatisticsPage |
| Name: Color Management ID: esri_mapping_colorManagementPropertyPage |
| Name: About the locator ID: esri_mapping_CompositeLocatorGeneralPropertyPage |
| Name: Input fields ID: esri_mapping_CompositeLocatorInputAddressFieldsPropertyPage |
| Name: Participating locators ID: esri_mapping_CompositeLocatorInputMappingPropertyPage |
| Name: Performance ID: esri_mapping_CompositeLocatorPerformancePropertyPage |
| Name: Result order ID: esri_mapping_CompositeLocatorResultOrder |
| Name: Coordinate Systems ID: esri_mapping_coordinateSystemPropertyPage |
| Name: Extent ID: esri_mapping_customFullExtentMapPropertyPage |
| Name: Custom Parameters ID: esri_mapping_customParametersPropertyPage Condition: esri_mapping_customParameterLayerSelectedCondition |
| Name: Custom Parameters ID: esri_mapping_customParametersPropertyPage Condition: esri_mapping_customParameterStandaloneTableSelectedCondition |
| Name: Metadata ID: esri_mapping_descriptionPropertyPage |
| Name: Display ID: esri_mapping_dynamicServiceLayerDisplayPropertyPage Condition: esri_mapping_compositeSublayerNotSelectedCondition |
| Name: General ID: esri_mapping_generalGroupLayerPropertyPage |
| Name: General ID: esri_mapping_generalLayerPropertyPage |
| Name: General ID: esri_mapping_generalLinkChartLinkSetPropertyPage |
| Name: General ID: esri_mapping_generalLinkChartNodeSetPropertyPage |
| Name: General ID: esri_mapping_generalLinkChartPropertyPage |
| Name: General ID: esri_mapping_generalMapPropertyPage |
| Name: General ID: esri_mapping_generalMultiMapPropertyPage |
| Name: General ID: esri_mapping_generalStandaloneTablePropertyPage |
| Name: General ID: esri_mapping_generalStandaloneVideoPropertyPage |
| Name: General ID: esri_mapping_generalTimelineLayerPropertyPage |
| Name: General ID: esri_mapping_generalTimelinePropertyPage |
| Name: General ID: esri_mapping_generalTimelineSwimlanePropertyPage |
| Name: Standard Heights ID: esri_mapping_heightListPropertyPage |
| Name: Illumination ID: esri_mapping_illuminationPropertyPage |
| Name: Indoor Layers ID: esri_mapping_indoorMapPropertyPage Condition: esri_mapping_indoorLicenseCondition |
| Name: Indoor Positioning ID: esri_mapping_ipsMapPropertyPage Condition: esri_mapping_ipsLicenseCondition |
| Name: Joins ID: esri_mapping_joinsPropertyPage Condition: esri_mapping_subtypeValueLayerAndStreamServiceNotSelectedCondition |
| Name: Joins ID: esri_mapping_joinsPropertyPage Condition: esri_mapping_WCSLayerNotSelectedCondition |
| Name: Labels ID: esri_mapping_labelGeneralMultiMapPropertyPage Condition: esri_mapping_notStereoMapViewPane |
| Name: Labels ID: esri_mapping_labelGeneralPropertyPage Condition: esri_mapping_notStereoMapViewPane |
| Name: Cache ID: esri_mapping_layerCachePropertyPage Condition: esri_mapping_compositeSublayerAndStreamServiceNotSelectedCondition |
| Name: Cache ID: esri_mapping_layerCachePropertyPage Condition: esri_mapping_compositeSublayerNotSelectedCondition |
| Name: Cache ID: esri_mapping_layerCachePropertyPage |
| Name: Definition Query ID: esri_mapping_layerDefintionQueryPage Condition: esri_mapping_SubtypeValueLayerNotSelectedCondition |
| Name: Definition Query ID: esri_mapping_layerDefintionQueryPage |
| Name: Definition Query ID: esri_mapping_layerDefintionQueryPage Condition: esri_mapping_mapServiceSubLayerFeatureSourceSelectedCondition |
| Name: Definition Query ID: esri_mapping_layerDefintionQueryPage Condition: esri_mapping_imageServiceLayerWithTableSelectedCondition |
| Name: Display ID: esri_mapping_layerDisplayPropertyPage |
| Name: Display ID: esri_mapping_layerDisplayPropertyPage Condition: esri_mapping_2DSceneLayerSelectedState |
| Name: Display ID: esri_mapping_layerDisplayPropertyPage Condition: esri_mapping_displayPageOnlyCompressTexturesCondition |
| Name: Display ID: esri_mapping_layerDisplayPropertyPage Condition: esri_mapping_ViewingMode3DCondition |
| Name: Display ID: esri_mapping_layerDisplayPropertyPage Condition: esri_mapping_showVoxelLayerDisplayPropertyPageCondition |
| Name: Elevation ID: esri_mapping_layerElevationPropertyPage Condition: esri_mapping_showLayerElevationCondition |
| Name: Elevation ID: esri_mapping_layerElevationPropertyPage Condition: esri_mapping_compositeSublayerNotSelectedCondition |
| Name: Floors ID: esri_mapping_layerFloorsPage Condition: esri_mapping_isSelectedLayerValidForFloorCondition |
| Name: Indexes ID: esri_mapping_layerIndexesPropertyPage Condition: esri_mapping_isSelectedFeatureLayerValidForIndexesCondition |
| Name: Indexes ID: esri_mapping_layerIndexesPropertyPage |
| Name: Display ID: esri_mapping_layerISDisplayPage Condition: esri_mapping_imageServiceLayerWithTableSelectedCondition |
| Name: Display ID: esri_mapping_layerMosaicDisplayPage |
| Name: Mosaic ID: esri_mapping_layerMosaicRulePage Condition: esri_mapping_dynamicImageServiceLayerWithTableSelectedCondition |
| Name: Diagram Properties ID: esri_mapping_layerNetworkDiagramPropertiesPage |
| Name: Network Properties ID: esri_mapping_layerNetworkPropertiesPage |
| Name: Processing Templates ID: esri_mapping_layerProcessingTemplatePage Condition: esri_mapping_imageServiceAndMosaicLayerSelectedCondition |
| Name: Processing Templates ID: esri_mapping_layerProcessingTemplatePage Condition: esri_mapping_renderingRulesSupportedCondition |
| Name: Range ID: esri_mapping_layerRangePage Condition: esri_mapping_SubtypeValueLayerNotSelectedCondition |
| Name: Range ID: esri_mapping_layerRangePage |
| Name: Range ID: esri_mapping_layerRangePage Condition: esri_mapping_netcdfOrMdimRasterDataSourceSelectedCondition |
| Name: Range ID: esri_mapping_layerRangePage Condition: esri_mapping_dynamicImageServiceLayerWithTableSelectedCondition |
| Name: Range ID: esri_mapping_layerRangePage Condition: esri_mapping_notBuildingSceneLayersSelectedCondition |
| Name: Display ID: esri_mapping_layerRasterDisplayPage |
| Name: Selection ID: esri_mapping_layerSelectionPropertyPage |
| Name: Selection ID: esri_mapping_layerSelectionPropertyPage Condition: esri_mapping_imageServiceLayerWithTableSelectedCondition |
| Name: Source ID: esri_mapping_layerSourcePropertyPage Condition: esri_mapping_dataLayerSelectedCondition |
| Name: Source ID: esri_mapping_layerSourcePropertyPage |
| Name: Time ID: esri_mapping_layerTimePage |
| Name: Time ID: esri_mapping_layerTimePage Condition: esri_mapping_SupportsTimePageCondition |
| Name: Alternate Name Tables ID: esri_mapping_locatorEagleAlternateDataPropertyPage |
| Name: About the locator ID: esri_mapping_locatorEagleGeneralPropertyPage |
| Name: Geocoding options ID: esri_mapping_locatorEagleGeocodingOptionsPropertyPage |
| Name: Input fields ID: esri_mapping_locatorEagleInputFieldsPropertyPage |
| Name: Output fields ID: esri_mapping_locatorEagleOutputsPropertyPage |
| Name: Performance ID: esri_mapping_locatorEaglePerformancePropertyPage |
| Name: Reference Data Tables ID: esri_mapping_locatorEagleReferenceDataPropertyPage |
| Name: About the locator ID: esri_mapping_locatorViewAboutPropertyPage |
| Name: Geocoding options ID: esri_mapping_locatorViewGeocodingOptionsPropertyPage |
| Name: General ID: esri_mapping_multiGeneralLinkChartLinkSetPropertyPage |
| Name: General ID: esri_mapping_multiGeneralLinkChartNodeSetPropertyPage |
| Name: General ID: esri_mapping_multiGeneralLinkChartPropertyPage |
| Name: General ID: esri_mapping_multiGeneralStandaloneTablePropertyPage |
| Name: General ID: esri_mapping_multiGeneralStandaloneVideoPropertyPage |
| Name: General ID: esri_mapping_multiGeneralTimelineLayerPropertyPage |
| Name: General ID: esri_mapping_multiGeneralTimelinePropertyPage |
| Name: General ID: esri_mapping_multiGeneralTimelineSwimlanePropertyPage |
| Name: General ID: esri_mapping_multiLayerPropertySheet |
| Name: Locations ID: esri_mapping_naLayerLocationSettingsPropertyPage |
| Name: Travel Mode ID: esri_mapping_naLayerTravelModePropertyPage |
| Name: OGC Features ID: esri_mapping_ogcapiPropertyPage Condition: esri_mapping_OgcAPILayerSelectedCondition |
| Name: OGCAPI Maptiles ID: esri_mapping_ogcapiPropertyPage Condition: esri_mapping_OgcAPILayerSelectedCondition |
| Name: Oriented Imagery ID: esri_mapping_orientedImageryPropertyPage |
| Name: Cache ID: esri_mapping_pointCloudLayerCachePropertyPage |
| Name: Elevation ID: esri_mapping_pointCloudLayerElevationPropertyPage |
| Name: Point Cloud Layer Filter ID: esri_mapping_pointCloudLayerFilterPropertyPage |
| Name: General ID: esri_mapping_pointCloudLayerGeneralPropertyPage |
| Name: Source ID: esri_mapping_pointCloudLayerSourcePropertyPage Condition: esri_mapping_dataLayerSelectedCondition |
| Name: Query Parameters ID: esri_mapping_queryParametersPropertyPage Condition: esri_mapping_queryDataSourceSelectedCondition |
| Name: Relates ID: esri_mapping_relatesPropertyPage Condition: esri_mapping_LinkChartCompositeSubLayerStreamServiceNotSelectedCondition |
| Name: Relates ID: esri_mapping_relatesPropertyPage Condition: esri_mapping_WCSLayerNotSelectedCondition |
| Name: Relates ID: esri_mapping_relatesPropertyPage Condition: esri_mapping_NoIntegratedMeshLayersSelectedCondition |
| Name: Scale Format ID: esri_mapping_scaleFormatPropertyPage |
| Name: Standard Scales ID: esri_mapping_scaleListPropertyPage |
| Name: Cache ID: esri_mapping_simulationLayerPropertyPage |
| Name: Selection ID: esri_mapping_standaloneSelectionPropertyPage |
| Name: Definition Query ID: esri_mapping_standaloneTableDefinitionQueryPropertyPage |
| Name: Display ID: esri_mapping_standaloneTableDisplayPropertyPage |
| Name: Indexes ID: esri_mapping_StandaloneTableIndexesPropertyPage Condition: esri_mapping_isSelectedTableValidForIndexesCondition |
| Name: Joins ID: esri_mapping_standaloneTableJoinsPropertyPage |
| Name: Range ID: esri_mapping_standaloneTableRangePage |
| Name: Relates ID: esri_mapping_standaloneTableRelatesPropertyPage |
| Name: Source ID: esri_mapping_standaloneTableSourcePropertyPage |
| Name: Time ID: esri_mapping_standaloneTableTimePage |
| Name: Source ID: esri_mapping_standaloneVideoSourcePropertyPage |
| Name: Stereo ID: esri_mapping_stereoScopicPropertyPage Condition: esri_mapping_stereoMapViewPane |
| Name: Subtype ID: esri_mapping_subtypeLayersPropertyPage |
| Name: WMTS ID: esri_mapping_tiledServiceLayerConfigurationPropertyPage Condition: esri_mapping_WMTSServiceLayerSelectedCondition |
| Name: Time ID: esri_mapping_timePropertyPage |
| Name: Errors ID: esri_mapping_topologyErrorsPropertyPage |
| Name: Feature Layers ID: esri_mapping_topologyFeatureLayersPropertyPage |
| Name: Rules ID: esri_mapping_topologyRulesPropertyPage |
| Name: Network Attributes ID: esri_mapping_traceNetworkAttributesPropertyPage |
| Name: Network Diagrams ID: esri_mapping_traceNetworkDiagramsPropertyPage |
| Name: Trace Network ID: esri_mapping_traceNetworkPropertyPage |
| Name: Network Topology ID: esri_mapping_traceNetworkTopologyPropertyPage |
| Name: Transformation ID: esri_mapping_transformationPropertyPage |
| Name: Network Diagrams ID: esri_mapping_utilityNetworkDiagramsPropertyPage |
| Name: WFS ID: esri_mapping_wfsPropertyPage Condition: esri_mapping_WfsLayerSelectedCondition |
| Name: Layers ID: esri_mapping_WMSLayersPropertyPage Condition: esri_mapping_WMSServiceLayerSelectedCondition |
menus
| Name: Open 2D Layers context menu ID: esri_mapping_2DCategoryContextMenu | |
| Name: Open scene context menu ID: esri_mapping_3d_mapContextMenu | |
| Name: Open 3D Layers context menu ID: esri_mapping_3DCategoryContextMenu | |
![]() | Name: Add To New ID: esri_mapping_addDataMenu |
![]() | Name: Add ID: esri_mapping_addStyleMenu |
| Name: Control Points ID: esri_mapping_animationControlPointMenu | |
| Name: Look At ID: esri_mapping_animationLookAtMenu | |
| Name: Edit Animation ID: esri_mapping_animationMoveHandle2DMenu | |
| Name: Edit Animation ID: esri_mapping_animationMoveHandle3DMenu | |
| Name: Edit Animation ID: esri_mapping_animationMoveHandleCP_2DMenu | |
| Name: Edit Animation ID: esri_mapping_animationMoveHandleCP_3DMenu | |
| Name: Annotation sublayer properties ID: esri_mapping_annotationSubLayerContextMenu | |
| Name: Band Combinations ID: esri_mapping_bandCombinationMenu | |
| Name: View ID: esri_mapping_basemapContextMenu | |
![]() | Name: Convert ID: esri_mapping_basemapConvertMenu |
| Name: Open binning layer context menu ID: esri_mapping_binningLayerContextMenu | |
| Name: Bookmark Options ID: esri_mapping_bookmarkOptionsMenu | |
| Name: Open layer context menu ID: esri_mapping_buildingDisciplineLayerContextMenu | |
| Name: Open layer context menu ID: esri_mapping_buildingDisciplineSceneLayerContextMenu | |
| Name: Open layer context menu ID: esri_mapping_buildingLayerContextMenu | |
| Name: Open layer context menu ID: esri_mapping_buildingSceneLayerContextMenu | |
| Name: Open footprint layer context menu ID: esri_mapping_catalogLayer_FootprintLayerContextMenu | |
| Name: Open Layers in view context menu ID: esri_mapping_catalogLayer_LayersInViewContextMenu | |
| Name: Open layer context menu ID: esri_mapping_catalogLayerContextMenu | |
| Name: Context menu for the transient sublayers of catalog layers. ID: esri_mapping_catalogTransientSublayerContextMenu | |
| Name: Open clustering layer context menu ID: esri_mapping_clusteringLayerContextMenu | |
![]() | Name: Color Vision Simulator ID: esri_mapping_ColorVisionDeficiencyMenu |
| Name: View ID: esri_mapping_containmentMapContextMenu | |
| Name: Convert Coordinates ID: esri_mapping_ConvertCoordinatesMenu | |
| Name: Data Source ID: esri_mapping_dataSourceContextMenu | |
| Name: Data Design ID: esri_mapping_designViewMenu | |
| Name: Data Design ID: esri_mapping_designViewUnregisteredMenu | |
| Name: Elevation ID: esri_mapping_ElevationMenu | |
| Name: Open elevation source layer context menu ID: esri_mapping_ElevationSourceLayerContextMenu | |
| Name: Open elevation surface layer category context menu ID: esri_mapping_ElevationSurfaceLayerCategoryContextMenu | |
| Name: Open elevation surface layer context menu ID: esri_mapping_ElevationSurfaceLayerContextMenu | |
| Name: Open ENC layer context menu ID: esri_mapping_ENCLayerContextMenu | |
| Name: Open ENC sublayer context menu ID: esri_mapping_ENCSubLayerContextMenu | |
| Name: Open ENC subtable context menu ID: esri_mapping_ENCSubTableContextMenu | |
| Name: Cut and Fill ID: esri_mapping_exploratoryCutFillMenu | |
| Name: Line of Sight ID: esri_mapping_exploratoryLOSMenu | |
| Name: Slice ID: esri_mapping_exploratorySliceBoxMenu | |
| Name: Slice ID: esri_mapping_exploratorySliceCylinderMenu | |
| Name: Slice ID: esri_mapping_exploratorySliceRectMenu | |
| Name: Slice ID: esri_mapping_exploratorySliceSphereMenu | |
| Name: View Dome ID: esri_mapping_exploratoryViewDomeMenu | |
| Name: Viewshed ID: esri_mapping_exploratoryViewshedMenu | |
| Name: Data Source ID: esri_mapping_featureDatasetContextMenu | |
| Name: Mask ID: esri_mapping_featureSceneLayerMaskMenu | |
| Name: View ID: esri_mapping_FileStyleContextMenu | |
| Name: View ID: esri_mapping_FileStylxContextMenu | |
| Name: Open simulation barrier group context menu ID: esri_mapping_floodSimulationBarrierGroupContextMenu | |
| Name: Open simulation drainage group context menu ID: esri_mapping_floodSimulationDrainageGroupContextMenu | |
| Name: Open layer context menu ID: esri_mapping_floodSimulationLayerContextMenu | |
| Name: Open simulation water source group context menu ID: esri_mapping_floodSimulationWaterSourceGroupContextMenu | |
| Name: Open layer context menu ID: esri_mapping_gaussianSplatLayerContextMenu | |
| Name: Open elevation source layer context menu ID: esri_mapping_GoogleBasemapContextMenu | |
| Name: Open graphics Layer layer context menu ID: esri_mapping_graphicsLayerContextMenu | |
| Name: Open group layer context menu ID: esri_mapping_groupLayerContextMenu | |
| Name: Group Type ID: esri_mapping_groupTypeMenu | |
| Name: Open image service context menu ID: esri_mapping_imageServiceLayerContextMenu | |
![]() | Name: Import ID: esri_mapping_importStyleMenu |
| Name: Open layer context menu ID: esri_mapping_integratedMeshContextMenu | |
| Name: Selection ID: esri_mapping_integratedMeshsceneLayer_selectionSubMenu | |
| Name: Open layer context menu ID: esri_mapping_integratedMeshTiles3DLayerContextMenu | |
| ID: esri_mapping_kmlFeatureContextMenu | |
| Name: Open KML layer context menu ID: esri_mapping_kmlLayerContextMenu | |
| ID: esri_mapping_kmlNonGeographicFeatureContextMenu | |
| Name: Open label class context menu ID: esri_mapping_labelClassMenu | |
| Name: Paste ID: esri_mapping_labelClassPasteMenu | |
| Name: Convert Labels ID: esri_mapping_labelConvertLabelsSubMenu | |
| Name: Convert Labels ID: esri_mapping_labelConvertLayerLabelsSubMenu | |
![]() | Name: More ID: esri_mapping_labelingOptionsMenu |
![]() | Name: Labeling ID: esri_mapping_labelingOptionsSubMenu |
| Name: Open LAS context menu ID: esri_mapping_lasDatasetLayerContextMenu | |
| Name: Selection ID: esri_mapping_layer_selectionSubMenu | |
![]() | Name: Locate Candidate ID: esri_mapping_layercandidate_menu |
![]() | Name: Layer Multiselect Candidate ID: esri_mapping_layercandidate_multiselection_menu |
| Name: Open layer context menu ID: esri_mapping_layerContextMenu | |
| Name: Depth Priority ID: esri_mapping_layerDepthPrioritySubMenu | |
| Name: Open link chart context menu ID: esri_mapping_linkChartContextMenu | |
| Name: Open link chart relationship context menu ID: esri_mapping_linkChartLinkSetContextMenu | |
| Name: Open link chart entity context menu ID: esri_mapping_linkChartNodeSetContextMenu | |
| ID: esri_mapping_locate_layerSearchOptionsMenu | |
![]() | Name: Locate Candidate ID: esri_mapping_locatecandidate_menu |
![]() | Name: Locate Multiselect Candidate ID: esri_mapping_locatecandidate_multiselection_menu |
| Name: View ID: esri_mapping_map2DContextMenu | |
![]() | Name: Convert ID: esri_mapping_map2DConvertMenu |
| Name: View ID: esri_mapping_map3DContextMenu | |
![]() | Name: Convert ID: esri_mapping_map3DConvertMenu |
| Name: View ID: esri_mapping_mapContainerContextMenu | |
| Name: Open map context menu ID: esri_mapping_mapContextMenu | |
![]() | Name: Convert ID: esri_mapping_mapStereoConvertMenu |
| Name: General ID: esri_mapping_measurement_default Condition: esri_mapping_imageLoadedInOrientedImageryViewerCondition | |
| Name: Triangulated ID: esri_mapping_measurement_triangulated Condition: esri_mapping_imageLoadedInOrientedImageryViewerCondition | |
| Name: Modification ID: esri_mapping_meshLayerModificationMenu | |
| Name: Open raster mosaic boundary context menu ID: esri_mapping_mosaicBoundarySubLayerContextMenu | |
| Name: Open raster mosaic footprint context menu ID: esri_mapping_mosaicFootprintSubLayerContextMenu | |
| Name: Open raster mosaic image context menu ID: esri_mapping_mosaicImageSubLayerContextMenu | |
| Name: Open raster mosaic context menu ID: esri_mapping_mosaicLayerContextMenu | |
| Name: Open raster mosaic seamline context menu ID: esri_mapping_mosaicSeamlineSubLayerContextMenu | |
| Name: Open network analysis layer context menu ID: esri_mapping_naLayerContextMenu | |
| Name: Open network dataset layer context menu ID: esri_mapping_networkDatasetLayerContextMenu | |
| Name: View ID: esri_mapping_networkDiagramContextMenu | |
| Name: Open diagram layer context menu ID: esri_mapping_networkDiagramLayerContextMenu | |
![]() | Name: New ID: esri_mapping_newStyleMenu |
| Name: Open NITF layer context menu ID: esri_mapping_nitfLayerContextMenu | |
| Name: Data Source ID: esri_mapping_nonVersionableDataSourceContextMenu | |
| Name: Open service sub layer context menu ID: esri_mapping_ogcServiceSubLayerContextMenu | |
| Name: Open layer context menu ID: esri_mapping_plumeSimulationLayerContextMenu | |
| Name: Open simulation plume source group context menu ID: esri_mapping_plumeSimulationSourceGroupContextMenu | |
| Name: Open point cloud layer context menu ID: esri_mapping_pointCloudLayerContextMenu | |
![]() | Name: Points From Table ID: esri_mapping_pointsFromTableMenu |
| Name: Pop-up Feature ID: esri_mapping_popupFeatureContextMenu | |
| Name: Pop-up Layer ID: esri_mapping_popupLayerContextMenu | |
| Name: Pop-up Link Chart Feature ID: esri_mapping_popupLinkChartFeatureContextMenu | |
| Name: Mark Location ID: esri_mapping_popupMarkLocationMenu | |
| Name: Pop-up Relate ID: esri_mapping_popupRelateContextMenu | |
| Name: Selection ID: esri_mapping_popupToolContextMenu | |
| Name: View ID: esri_mapping_PortalStylxContextMenu | |
| Name: Open raster layer context menu ID: esri_mapping_rasterLayerContextMenu | |
| Name: Selection ID: esri_mapping_rasterSelectionSubMenu | |
| Name: Reorder Layers ID: esri_mapping_reorderLayersMenu | |
| Name: Selection ID: esri_mapping_sceneLayer_selectionSubMenu | |
| Name: Open layer context menu ID: esri_mapping_scenelayerContextMenu | |
| Name: Selection ID: esri_mapping_selection2DContextMenu | |
| Name: Selection ID: esri_mapping_selection3DContextMenu | |
| Name: Selection ID: esri_mapping_selectionSubMenu | |
| Name: Selection ID: esri_mapping_selectionSubMenu_CatalogFootprintLayer | |
| Name: Open service composite sub layer context menu ID: esri_mapping_serviceCompositeSubLayerContextMenu | |
| Name: Open service layer context menu ID: esri_mapping_serviceLayerContextMenu | |
| Name: Open service sub layer context menu ID: esri_mapping_serviceSubLayerContextMenu | |
| Name: Open service sub table context menu ID: esri_mapping_serviceSubTableContextMenu | |
| Name: Sharing ID: esri_mapping_shareElevationMenu | |
| Name: Open simulation area of interest context menu ID: esri_mapping_SimulationAreaOfInterestContextMenu | |
| Name: Open simulation layers context menu ID: esri_mapping_SimulationCategoryContextMenu | |
| Name: Open simulation object context menu ID: esri_mapping_simulationObjectContextMenu | |
| Name: Open layer context menu ID: esri_mapping_smartIntegratedMeshContextMenu | |
| Name: Selection ID: esri_mapping_standaloneTable_selectionSubMenu | |
| Name: Open standalone table context menu ID: esri_mapping_standaloneTableContextMenu | |
| Name: Open standalone tables context menu ID: esri_mapping_standaloneTablesCategoryContextMenu | |
| Name: Open standalone video context menu ID: esri_mapping_standaloneVideoContextMenu | |
| Name: Open standalone video context menu ID: esri_mapping_standaloneVideosCategoryContextMenu | |
| Name: View ID: esri_mapping_stereoMapContextMenu | |
| Name: View ID: esri_mapping_styleContainerContextMenu | |
| Name: View ID: esri_mapping_StyleContentContextMenu | |
| Name: View ID: esri_mapping_StyleContextMenu | |
| Name: Item ID: esri_mapping_StyleItemContextMenu | |
| Name: Item ID: esri_mapping_StyleItemProjectItemContextMenu | |
| Name: Open subtype layer context menu ID: esri_mapping_subtypeGroupLayerContextMenu | |
| Name: Open subtype group table context menu ID: esri_mapping_subtypeGroupTableContextMenu | |
| Name: Open subtype value layer context menu ID: esri_mapping_subtypeValueLayerContextMenu | |
| Name: Selection ID: esri_mapping_subtypeValueTable_selectionSubMenu | |
| Name: Open subtype table context menu ID: esri_mapping_subtypeValueTableContextMenu | |
| Name: Swipe ID: esri_mapping_swipeToolContextMenu | |
![]() | Name: Link Views ID: esri_mapping_syncViewExtentMenu |
![]() | Name: Locate Candidate ID: esri_mapping_tablecandidate_menu |
![]() | Name: Layer Multiselect Candidate ID: esri_mapping_tablecandidate_multiselection_menu |
| Name: Templates ID: esri_mapping_TemplatedRulesMenu Condition: esri_mapping_attributeRulesView_editable | |
| Name: Open Terrain layer context menu ID: esri_mapping_terrainLayerContextMenu | |
| Name: Open layer context menu ID: esri_mapping_tiles3DLayerContextMenu | |
| Name: Open timeline context menu ID: esri_mapping_timelineContextMenu | |
| Name: Open timeline layer context menu ID: esri_mapping_timelineLayerContextMenu | |
| Name: Open timeline layer context menu ID: esri_mapping_timelineLeftoverLaneContextMenu | |
| Name: Open timeline swimlane context menu ID: esri_mapping_timelineSwimlaneContextMenu | |
| Name: Open TIN layer context menu ID: esri_mapping_tinLayerContextMenu | |
| Name: Open Content Pane Context Menu ID: esri_mapping_tocContextMenu | |
| Name: Open content pane filter menu ID: esri_mapping_tocFilterMenu | |
| Name: Open trace network layer context menu ID: esri_mapping_traceNetworkLayerContextMenu | |
| Name: Open trajectory footprint sublayer context menu ID: esri_mapping_trajectoryFootprintSubLayerContextMenu | |
| Name: Open trajectory layer context menu ID: esri_mapping_trajectoryLayerContextMenu | |
| Name: Open trajectory point sublayer context menu ID: esri_mapping_trajectoryPointSubLayerContextMenu | |
| Name: Selection ID: esri_mapping_trajectorySubLayerSelectionSubMenu | |
| Name: Open layer context menu ID: esri_mapping_unregisteredLayerContextMenu | |
| Name: Open standalone table context menu ID: esri_mapping_unregisteredStandaloneTableContextMenu | |
| Name: Open utility network layer context menu ID: esri_mapping_utilityNetworkLayerContextMenu | |
| Name: Open VectorTiles layer context menu ID: esri_mapping_vectorTilesLayerContextMenu | |
| Name: Open section context menu ID: esri_mapping_voxelDynamicSectionContextMenu | |
| Name: Open isosurfaces container context menu ID: esri_mapping_voxelIsosurfaceContainerContextMenu | |
| Name: Open isosurface context menu ID: esri_mapping_voxelIsosurfaceContextMenu | |
| Name: Open layer context menu ID: esri_mapping_voxelLayerContextMenu | |
| Name: Open section container context menu ID: esri_mapping_voxelSectionsContainerContextMenu | |
| Name: Open slice context menu ID: esri_mapping_voxelSliceContextMenu | |
| Name: Open slices container context menu ID: esri_mapping_voxelSlicesContainerContextMenu | |
| Name: Open section context menu ID: esri_mapping_voxelStaticSectionContextMenu | |
| Name: Open section container context menu ID: esri_mapping_voxelStaticSectionsContainerContextMenu | |
| Name: View ID: esri_mapping_webStylxContextMenu |
miniToolbars
modules
| Name: Mapping ID: esri_mapping |
palettes
buttonPalette
| Name: Path ID: esri_mapping_animationFeedbackPalette |
| Name: Convert ID: esri_mapping_convertMapPalette |
| Name: Link Views ID: esri_mapping_syncViewExtentPalette |
toolPalette
| Name: Convert ID: esri_mapping_labelConvertLabelsToolPalette |
| Name: New Map ID: esri_mapping_newMapPalette |
| Name: New Item ID: esri_mapping_newStyleItem |
| Name: Measure ID: esri_mapping_oldMeasureToolPalette |
| Name: Explore Images ID: esri_mapping_orientedImageryLayerExploreImagesToolPalette |
| Name: Select ID: esri_mapping_rasterLayerSelectionMenu |
| Name: Operations ID: esri_mapping_rasterLayerSelectionOperationMenu |
| Name: Select ID: esri_mapping_selectToolPalette |
panes
![]() | Name: Attribute Rules ID: esri_mapping_attributeRulesPane |
![]() | Name: Contingent Values ID: esri_mapping_contingentValuesPane |
![]() | Name: Domains ID: esri_mapping_domainsPane |
![]() | Name: Fields ID: esri_mapping_fieldsPane |
![]() | Name: Map ID: esri_mapping_mapPane |
![]() | Name: Subtypes ID: esri_mapping_subtypesPane |
![]() | Name: Versions ID: esri_mapping_versionsPane |
propertySheets
| Name: Annotation SubLayer Properties ID: esri_mapping_annotationSubLayerPropertySheet |
| Name: Binning Properties ID: esri_mapping_binningLayerPropertySheet |
| Name: Layer Properties ID: esri_mapping_buildingDisciplineSceneLayerPropertySheet |
| Name: Layer Properties ID: esri_mapping_buildingSceneLayerPropertySheet |
| Name: Group Layer Properties ID: esri_mapping_catalogDynamicGroupLayerPropertySheet |
| Name: Catalog Layer Properties ID: esri_mapping_catalogLayer_footprintLayerPropertySheet |
| Name: Catalog Layer Properties ID: esri_mapping_catalogLayer_transientSublayerPropertySheet |
| Name: Catalog Layer Properties ID: esri_mapping_catalogLayerPropertySheet |
| Name: Clustering Properties ID: esri_mapping_clusteringLayerPropertySheet |
| Name: Layer Properties ID: esri_mapping_dynamicServiceLayerPropertySheet |
| Name: Layer Properties ID: esri_mapping_dynamicServiceSubLayerPropertySheet |
| Name: Elevation Source Layer Properties ID: esri_mapping_elevationSourceLayerPropertySheet |
| Name: Layer Properties ID: esri_mapping_ENCLayerPropertySheet |
| Name: Feature Layer Properties ID: esri_mapping_featureLayerPropertySheet |
| Name: Feature Layer Properties ID: esri_mapping_featureMosaicSubLayerPropertySheet |
| Name: Feature Layer Properties ID: esri_mapping_featureTrajectorySubLayerPropertySheet |
| Name: Flood Simulation Layer Properties ID: esri_mapping_floodSimulationLayerPropertySheet |
| Name: Layer Properties ID: esri_mapping_gaussianSplatLayerPropertySheet |
| Name: Group Layer Properties ID: esri_mapping_groupLayerPropertySheet |
| Name: Scale Properties ID: esri_mapping_heightSettingsPropertySheet |
| Name: Image Service Layer Properties ID: esri_mapping_imageMosaicSubLayerPropertySheet |
| Name: Image Service Layer Properties ID: esri_mapping_imageServiceLayerPropertySheet |
| Name: Layer Properties ID: esri_mapping_integratedMeshSceneServicelayerPropertySheet |
| Name: Link Chart Properties ID: esri_mapping_KG_linkChartPropertySheet |
| Name: Layer Properties ID: esri_mapping_kmlLayerPropertySheet |
| Name: Feature Layer Properties ID: esri_mapping_knowledgeGraphFeatureLayerPropertySheet |
| Name: Layer Properties ID: esri_mapping_layerPropertySheet |
| Name: Layer Properties ID: esri_mapping_linkChartKGLayerPropertySheet |
| Name: Feature Layer Properties ID: esri_mapping_linkChartLCGroupLayerPropertySheet |
| Name: Feature Layer Properties ID: esri_mapping_linkChartLCLayerPropertySheet |
| Name: Link Chart Relationship Properties ID: esri_mapping_linkChartLinkSetPropertySheet |
| Name: Link Chart Entity Properties ID: esri_mapping_linkChartNodeSetPropertySheet |
| Name: Link Chart Properties ID: esri_mapping_linkChartPropertySheet |
| Name: Locator Properties ID: esri_mapping_locatorCompositePropertySheet |
| Name: Locator Properties ID: esri_mapping_locatorEaglePropertySheet |
| Name: Configure View ID: esri_mapping_locatorViewPropertySheet |
| Name: Layer Properties ID: esri_mapping_mapKGLayerPropertySheet |
| Name: Map Properties ID: esri_mapping_mapPropertySheet |
| Name: Mosaic Layer Properties ID: esri_mapping_mosaicLayerPropertySheet |
| Name: Multiple Annotation Sublayer Properties ID: esri_mapping_multiAnnotationSubLayerPropertySheet |
| Name: Elevation Source Layer Properties ID: esri_mapping_multiElevationSourceLayerPropertySheet |
| Name: Feature Layer Properties ID: esri_mapping_multiFeatureLayerPropertySheet |
| Name: Layer Properties ID: esri_mapping_multiLayerPropertySheet |
| Name: Link Chart Relationship Properties ID: esri_mapping_multiLinkChartLinkSetPropertySheet |
| Name: Link Chart Entity Properties ID: esri_mapping_multiLinkChartNodeSetPropertySheet |
| Name: Link Chart Properties ID: esri_mapping_multiLinkChartPropertySheet |
| Name: Multiple Map Properties ID: esri_mapping_multiMapPropertySheet |
| Name: Raster Layer Properties ID: esri_mapping_multiRasterLayerPropertySheet |
| Name: Standalone Table Properties ID: esri_mapping_multiStandaloneTablePropertySheet |
| Name: Standalone Video Properties ID: esri_mapping_multiStandvideoVideoPropertySheet |
| Name: Timeline Layer Properties ID: esri_mapping_multiTimelineLayerPropertySheet |
| Name: Timeline Properties ID: esri_mapping_multiTimelinePropertySheet |
| Name: Timeline Layer Properties ID: esri_mapping_multiTimelineSwimlanePropertySheet |
| Name: Network Analysis Layer Properties ID: esri_mapping_naLayerPropertySheet |
| Name: Network Dataset Layer Properties ID: esri_mapping_ndsLayerPropertySheet |
| Name: Network Diagram Layer Properties ID: esri_mapping_networkDiagramLayerPropertySheet |
| Name: Layer Properties ID: esri_mapping_ogcServiceSubLayerPropertySheet |
| Name: Oriented Imagery Layer Properties ID: esri_mapping_orientedImageryLayerPropertySheet |
| Name: Parcel Fabric Layer Properties ID: esri_mapping_parcelLayerPropertySheet |
| Name: Plume Simulation Layer Properties ID: esri_mapping_plumeSimulationLayerPropertySheet |
| Name: Point Cloud Layer Properties ID: esri_mapping_pointCloudLayerPropertySheet |
| Name: Raster Layer Properties ID: esri_mapping_rasterLayerPropertySheet |
| Name: Scale Properties ID: esri_mapping_scaleSettingsPropertySheet |
| Name: Layer Properties ID: esri_mapping_sceneServicelayerPropertySheet |
| Name: Service Sub Table Properties ID: esri_mapping_serviceSubTablePropertySheet |
| Name: Layer Properties ID: esri_mapping_simpleLayerPropertySheet |
| Name: Standalone Table Properties ID: esri_mapping_standaloneTablePropertySheet |
| Name: Standalone Video Properties ID: esri_mapping_standaloneVideoPropertySheet |
| Name: Layer Properties ID: esri_mapping_subtypeGroupLayerPropertySheet |
| Name: Subtype Group Table Properties ID: esri_mapping_subtypeGroupTablePropertySheet |
| Name: Subtype Value Table Properties ID: esri_mapping_subtypeValueTablePropertySheet |
| Name: Layer Properties ID: esri_mapping_tiledServiceLayerPropertySheet |
| Name: Layer Properties ID: esri_mapping_tiles3DLayerPropertySheet |
| Name: Timeline Layer Properties ID: esri_mapping_timelineLayerPropertySheet |
| Name: Timeline Properties ID: esri_mapping_timelinePropertySheet |
| Name: Timeline Layer Properties ID: esri_mapping_timelineSwimlanePropertySheet |
| Name: Properties ID: esri_mapping_topologyLayerPropertySheet |
| Name: Trace Network Layer Properties ID: esri_mapping_traceNetworkLayerPropertySheet |
| Name: Trajectory Layer Properties ID: esri_mapping_trajectoryLayerPropertySheet |
| Name: Utility Network Layer Properties ID: esri_mapping_utilityNetworkLayerPropertySheet |
| Name: Layer Properties ID: esri_mapping_vectorTileLayerPropertySheet |
| Name: Layer Properties ID: esri_mapping_voxelLayerPropertySheet |
splitButtons
| Name: Import Rules ID: esri_attributeRulesView_importRuleSplitButton Condition: esri_mapping_attributeRulesView_editable |
| Name: Open new attribute rule gallery. ID: esri_attributeRulesView_newCalculationRuleSplitButton |
| Name: Open add data dialog ID: esri_mapping_addDataSplitButton |
| Name: Open append transition palette ID: esri_mapping_animationAppendTransitionSplitButton |
| Name: Camera Effect ID: esri_mapping_cameraEffectSplitButton |
| Name: Color Vision Simulator ID: esri_mapping_colorVisionSplitButton |
| Name: Enable Location ID: esri_mapping_deviceLocation_enableMyLocationSplitButton |
| Name: Open current explore tool ID: esri_mapping_exploreSplitButton |
| Name: Illumination ID: esri_mapping_illuminationTimeSplitButton |
| Name: Open current infographics ID: esri_mapping_infographicSplitButton |
| Name: Open exploratory analysis palette ID: esri_mapping_interactiveAnalysisSplitButton |
| Name: Open current layer symbology ID: esri_mapping_layerBinsSymbologySplitButton |
| Name: Clustering ID: esri_mapping_layerClustersSymbologySplitButton |
| Name: Open current layer symbology ID: esri_mapping_layerSymbologySplitButton |
| Name: WMS sublayer ID: esri_mapping_layerSymbologyWMSSubLayerSplitButton |
| Name: Search for addresses ID: esri_mapping_locateSplitButton |
| Name: Expand menu of Measure Tools ID: esri_mapping_measureSplitButton Condition: esri_mapping_mapPane |
| Name: Expand menu of Oriented Imagery Measure Tools ID: esri_mapping_orientedImageryLayerMeasureSplitButton |
| ID: esri_mapping_orientedImageryLayerOverlaysFeatureLayerSplitButton Condition: esri_mapping_imageLoadedInOrientedImageryViewerCondition |
| ID: esri_mapping_pastePropertiesSplitButton Condition: esri_mapping_singleTOCItemSelectedCondition |
| Name: Controls the display of point cloud points ID: esri_mapping_pointCloudLayerSymbologySplitButton |
| Name: Postprocessing Effects ID: esri_mapping_postprocessingEffectSplitButton |
| Name: Open profile tool ID: esri_mapping_profileViewSplitButton |
| Name: Choose a stretch type for the raster layer ID: esri_mapping_rasterLayerStretchTypeSplitButton |
| Name: Open current raster layer symbology ID: esri_mapping_rasterLayerSymbologySplitButton |
| Name: Expand Snapping to show Snap Modes ID: esri_mapping_snappingSplitButton Condition: esri_mapping_mapPane |
| Name: Visual Effect ID: esri_mapping_visualEffectSplitButton |
| Name: Open current layer symbology ID: esri_mapping_voxelLayerSymbologySplitButton |
| Name: Weather ID: esri_mapping_weatherEffectSplitButton |
subgroups
tabGroups
| Name: Annotation Layer ID: esri_mapping_annotationLayerTabGroup |
| Name: Composite ID: esri_mapping_AttributeCompositeRulesTabGroup |
| Name: Building ID: esri_mapping_bimLayerTabGroup |
| Name: Aggregation ID: esri_mapping_BinningTabGroup |
| Name: Building Scene Layer ID: esri_mapping_buildingSceneLayerTabGroup |
| Name: CAD Layer ID: esri_mapping_cadLayerTabGroup |
| Name: Aggregation ID: esri_mapping_ClusteringTabGroup |
| Name: Color Coded Group Layer ID: esri_mapping_colorCodedLayerTabGroup |
| Name: Manage ID: esri_mapping_DataSourcesTabGroup |
| Name: Data Source ID: esri_mapping_DataSourceTabGroup |
| Name: Dimension Layer ID: esri_mapping_dimensionLayerTabGroup |
| Name: Elevation Surface Layer ID: esri_mapping_elevationSurfaceLayersTabGroup |
| Name: Feature Layer ID: esri_mapping_featureLayerTabGroup |
| Name: Graphics Layer ID: esri_mapping_graphicsLayerTabGroup |
| Name: Group Layer ID: esri_mapping_groupLayerTabGroup |
| Name: Image Service Layer ID: esri_mapping_imageServiceLayerTabGroup |
| Name: Integrated Mesh Layer ID: esri_mapping_integratedMeshLayerTabGroup |
| Name: KML Layer ID: esri_mapping_kmlLayerTabGroup |
| Name: Knowledge Graph Feature Layer ID: esri_mapping_knowledgeGraphfeatureLayerTabGroup |
| Name: Knowledge Graph Table ID: esri_mapping_knowledgeGraphTableLayerTabGroup |
| Name: Legend Class ID: esri_mapping_legendClassTabGroup |
| Name: Linear Referencing ID: esri_mapping_linearReferencingTabGroup |
| Name: Link Chart Aggregation Layer ID: esri_mapping_linkChartAggregationLayerTabGroup |
| Name: Link Chart Layer ID: esri_mapping_linkChartLayerTabGroup |
| Name: Map Image Layer Sublayer ID: esri_mapping_mapImageLayerSubLayerTabGroup |
| Name: Map Image Layer ID: esri_mapping_mapImageLayerTabGroup |
| Name: Manage ID: esri_mapping_MappingTabGroup |
| Name: Map ID: esri_mapping_mapTabGroup |
| Name: Layer ID: esri_mapping_mixedLayerTabGroup |
| Name: Image Layer ID: esri_mapping_mosaicImageSubLayerTabGroup |
| Name: Mosaic Layer ID: esri_mapping_mosaicLayerTabGroup |
| Name: Point Cloud Layer ID: esri_mapping_pointCloudLayerTabGroup |
| Name: Raster Layer ID: esri_mapping_rasterLayerTabGroup |
| Name: Scene Layer ID: esri_mapping_sceneLayerTabGroup |
| Name: Stream Layer ID: esri_mapping_streamLayerTabGroup |
| Name: Manage ID: esri_mapping_StyleTabGroup |
| Name: Subtype Group Layer ID: esri_mapping_subtypeGroupLayerTabGroup |
| Name: Subtype Group Table ID: esri_mapping_subtypeGroupTableTabGroup |
| Name: Standalone Table ID: esri_mapping_subtypeValueTableTabGroup |
| Name: Standalone Table ID: esri_mapping_tableLayerTabGroup |
| Name: Table ID: esri_mapping_TableViewTabGroup |
| Name: Tile Layer ID: esri_mapping_tiledLayerTabGroup |
| Name: 3D Tiles Layer ID: esri_mapping_tiles3dLayerTabGroup |
| Name: Trajectory Layer ID: esri_mapping_trajectoryLayerTabGroup |
| Name: Vector Tile Layer ID: esri_mapping_vectorTileLayerTabGroup |
| Name: Voxel Layer ID: esri_mapping_voxelLayerTabGroup |
| Name: WMS Layer ID: esri_mapping_wmsLayerTabGroup |
| Name: WMS Sublayer ID: esri_mapping_wmsSubLayerTabGroup |
tabs
| Name: Animation ID: esri_mapping_animationTab Condition: esri_mapping_animationEnabledCondition |
| Name: Annotation Layer ID: esri_mapping_annotationLayerAppearanceTab Condition: esri_mapping_onlyAnnotationLayersSelectedCondition |
| Name: Data ID: esri_mapping_annotationLayerDataTab Condition: esri_mapping_onlyAnnotationLayersSelectedCondition |
| Name: BIM Data ID: esri_mapping_BimContextualTab Condition: esri_mapping_onlyBimLayerSelectedCondition |
| Name: Binning ID: esri_mapping_binContextualTab Condition: esri_mapping_singleBinningLayerSelectedCondition |
| Name: Building Scene Layer ID: esri_mapping_buildingSceneLayerDataTab Condition: esri_mapping_buildingSceneLayersSelectedCondition |
| Name: Data ID: esri_mapping_catalogLayerDataTab Condition: esri_mapping_onlyCatalogLayersSelectedCondition |
| Name: Catalog Layer ID: esri_mapping_catalogLayerTab Condition: esri_mapping_onlyCatalogLayersSelectedCondition |
| Name: Clustering ID: esri_mapping_clusteringContextualTab Condition: esri_mapping_singleClusteringLayerSelectedCondition |
| Name: Color Coded Group Layer ID: esri_mapping_colorCodedLayerAppearanceTab Condition: esri_mapping_colorCodedLayerSelectedCondition |
| Name: Standalone Table ID: esri_mapping_dataLayerDataTab Condition: esri_mapping_onlyTableLayersSelectedCondition |
| Name: Data Sources ID: esri_mapping_dataSourcesEditroTab Condition: esri_mapping_catalogViewEditingDataSourcesCondition |
| Name: Versioning ID: esri_mapping_datasourceVersionTab Condition: esri_mapping_mapSupportsVersioningCondition |
| Name: Subtype Group Table ID: esri_mapping_dataSubtypeGroupTableDataTab Condition: esri_mapping_subtypeGroupTableSelectedCondition |
| Name: Standalone Table ID: esri_mapping_dataSubtypeValueTableDataTab Condition: esri_mapping_subtypeValueTableSelectedCondition |
| Name: Dimension Layer ID: esri_mapping_dimensionLayerAppearanceTab Condition: esri_mapping_onlyDimensionLayersSelectedCondition |
| Name: Data ID: esri_mapping_dimensionLayerDataTab Condition: esri_mapping_onlyDimensionLayersSelectedCondition |
| Name: Elevation Surface Layer ID: esri_mapping_elevationSurfaceLayersAppearanceTab Condition: esri_mapping_ElevationSurfaceLayerSelectedCondition |
| Name: ENC Layer ID: esri_mapping_ENCLayerAppearanceTab Condition: esri_mapping_onlyENCLayersSelectedCondition |
| Name: Feature Layer ID: esri_mapping_featureLayerAppearanceTab Condition: esri_mapping_onlyFeatureLayersSelectedCondition |
| Name: CAD Data ID: esri_mapping_featureLayerCadTab Condition: esri_mapping_cadLayerSelectedCondition |
| Name: Data ID: esri_mapping_featureLayerDataTab Condition: esri_mapping_onlyFeatureLayersSelectedCondition |
| Name: Feature Layer ID: esri_mapping_footprintAppearanceTab Condition: esri_mapping_onlyCatalogLayerFootprintSelectedCondition |
| Name: Labeling ID: esri_mapping_footprintLabelingTab Condition: esri_mapping_onlyCatalogLayerFootprintSelectedCondition |
| Name: Data ID: esri_mapping_footprintLayerDataTab Condition: esri_mapping_onlyCatalogLayerFootprintSelectedCondition |
| Name: Gaussian Splat Layer ID: esri_mapping_gaussianSplatLayerAppearanceTab Condition: esri_mapping_gaussianSplatLayerSelectedCondition |
| Name: Georeference ID: esri_mapping_georeference_GeoreferenceTab Condition: esri_mapping_GeoreferenceCondition |
| Name: Graphics Layer ID: esri_mapping_graphicsLayerAppearanceTab Condition: esri_mapping_onlyGraphicsLayersSelectedCondition |
| Name: Graphics ID: esri_mapping_graphicsLayerGraphicsTab Condition: esri_mapping_graphicsLayersExistCondition |
| Name: Group Layer ID: esri_mapping_groupLayerAppearanceTab Condition: esri_mapping_groupLayerSelectedCondition |
| Name: Check Settings ID: esri_mapping_homeAttributeCompositeRulesViewTab Condition: esri_mapping_attributeRulesView_compositeShowRibbon |
| Name: Attribute Rules ID: esri_mapping_homeAttributeRulesViewTab Condition: esri_mapping_attributeRulesPane |
| Name: Contingent Values ID: esri_mapping_homeContingentValuesViewTab Condition: esri_mapping_contingentValuesPane |
| Name: Fields ID: esri_mapping_homeDesignViewTab Condition: esri_mapping_fieldsPane |
| Name: Domains ID: esri_mapping_homeDomainsViewTab Condition: esri_mapping_domainsPane |
| Name: Subtypes ID: esri_mapping_homeSubtypesViewTab Condition: esri_mapping_subtypesPane |
| Name: Map ID: esri_mapping_homeTab Condition: esri_mapping_pane_core |
| Name: Versions ID: esri_mapping_homeVersionManagerViewTab Condition: esri_mapping_versionsPane |
| Name: Image Service Layer ID: esri_mapping_imageServiceLayerAppearanceTab Condition: esri_mapping_onlyImageServiceLayersSelectedCondition |
| Name: Data ID: esri_mapping_imageServiceLayerDataTab Condition: esri_mapping_onlyImageServiceLayersSelectedCondition |
| Name: Multidimensional ID: esri_mapping_imageServiceLayerMdimTab Condition: esri_mapping_singleMdimISLayerSelectedCondition |
| Name: Integrated Mesh Layer ID: esri_mapping_integratedMeshLayerAppearanceTab Condition: esri_mapping_onlyIntegratedMeshLayersSelectedCondition |
| Name: Data ID: esri_mapping_integratedMeshLayerDataTab Condition: esri_mapping_onlyIntegratedMeshLayersSelectedCondition |
| Name: KML Layer ID: esri_mapping_kmlLayerAppearanceTab Condition: esri_mapping_kmlLayersSelectedCondition |
| Name: Labeling ID: esri_mapping_kmlLayerLabelingTab Condition: esri_mapping_kmlLayersSelectedCondition |
| Name: Knowledge Graph Table ID: esri_mapping_knowledgeGraphDataLayerDataTab Condition: esri_mapping_onlyKnowledgeGraphTableLayersSelectedCondition |
| Name: Knowledge Graph Feature Layer ID: esri_mapping_knowledgeGraphFeatureLayerAppearanceTab Condition: esri_mapping_onlyMapKnowledgeGraphFeatureLayersSelectedCondition |
| Name: Data ID: esri_mapping_knowledgeGraphFeatureLayerDataTab Condition: esri_mapping_onlyMapKnowledgeGraphFeatureLayersSelectedCondition |
| Name: Labeling ID: esri_mapping_knowledgeGraphLabelingTab Condition: esri_mapping_onlyMapKnowledgeGraphFeatureLayersSelectedCondition |
| Name: Labeling ID: esri_mapping_labelingTab Condition: esri_mapping_onlyFeatureLayersSelectedCondition |
| Name: Linear Referencing ID: esri_mapping_linearReferencingTab Condition: esri_mapping_LinearReferencingCondition |
| Name: Link Chart Aggregation Layer ID: esri_mapping_linkChartAggregationLayerAppearanceTab Condition: esri_mapping_onlyLinkChartAggregationLayersSelectedCondition |
| Name: Data ID: esri_mapping_linkChartAggregationLayerDataTab Condition: esri_mapping_onlyLinkChartAggregationLayersSelectedCondition |
| Name: Labeling ID: esri_mapping_linkChartAggregationLayerlabelingTab Condition: esri_mapping_onlyLinkChartAggregationLayersSelectedCondition |
| Name: Link Chart Layer ID: esri_mapping_linkChartLayerAppearanceTab Condition: esri_mapping_onlyLinkChartLayersSelectedCondition |
| Name: Data ID: esri_mapping_linkChartLayerDataTab Condition: esri_mapping_onlyLinkChartLayersSelectedCondition |
| Name: Labeling ID: esri_mapping_linkChartLayerLabelingTab Condition: esri_mapping_onlyLinkChartLayersSelectedCondition |
| Name: Device Location ID: esri_mapping_locationTab Condition: esri_mapping_locationTabGroupCondition |
| Name: Manage ID: esri_mapping_MapContainer Condition: esri_MappingContainer |
| Name: Map Image Layer ID: esri_mapping_mapImageLayerAppearanceTab Condition: esri_mapping_MapImageLayerSelectedCondition |
| Name: Map Image Sublayer ID: esri_mapping_mapImageLayerSubLayerAppearanceTab Condition: esri_mapping_mapServiceSubLayerCanAlterAppearanceCondition |
| Name: Data ID: esri_mapping_mapImageLayerSubLayerDataTab Condition: esri_mapping_mapServiceSubLayerFeatureSourceSelectedCondition |
| Name: Labeling ID: esri_mapping_mapImageLayerSubLayerLabelingTab Condition: esri_mapping_mapServiceSubLayerSelectedCondition |
| Name: Layer ID: esri_mapping_mixedLayerAppearanceTab Condition: esri_mapping_mixedLayersSelectedCondition |
| Name: Image Layer ID: esri_mapping_mosaicImageSubLayerAppearanceTab Condition: esri_mapping_onlyMosaicImageSubLayersSelectedCondition |
| Name: Data ID: esri_mapping_mosaicImageSubLayerDataTab Condition: esri_mapping_onlyMosaicImageSubLayersSelectedCondition |
| Name: Multidimensional ID: esri_mapping_mosaicImageSubLayerMdimTab Condition: esri_mapping_singleMdimMosaicImgSubLayerSelectedCondition |
| Name: Mosaic Layer ID: esri_mapping_mosaicLayerAppearanceTab Condition: esri_mapping_onlyMosaicLayersSelectedCondition |
| Name: Data ID: esri_mapping_mosaicLayerDataTab Condition: esri_mapping_onlyMosaicLayersSelectedCondition |
| Name: Multidimensional ID: esri_mapping_mosaicLayerMdimTab Condition: esri_mapping_singleMdimMosaicLayerSelectedCondition |
| Name: Labeling ID: esri_mapping_orientedImageryLabelingTab Condition: esri_mapping_orientedImageryLayersSelectedCondition |
| Name: Data ID: esri_mapping_orientedImageryLayerDataTab Condition: esri_mapping_orientedImageryLayersSelectedCondition |
| Name: Oriented Imagery Layer ID: esri_mapping_orientedImageryLayerTab Condition: esri_mapping_orientedImageryLayersSelectedCondition |
| Name: Point Cloud Layer ID: esri_mapping_pointCloudLayerAppearanceTab Condition: esri_mapping_onlyPointCloudLayersSelectedCondition |
| Name: Data ID: esri_mapping_pointCloudLayerDataTab Condition: esri_mapping_onlyPointCloudLayersSelectedCondition |
| Name: Range ID: esri_mapping_rangeTab Condition: esri_mapping_rangeEnabledCondition |
| Name: Raster Layer ID: esri_mapping_rasterLayerAppearanceTab Condition: esri_mapping_onlyRasterLayersSelectedCondition |
| Name: Data ID: esri_mapping_rasterLayerDataTab Condition: esri_mapping_onlyRasterLayersSelectedCondition |
| Name: Multidimensional ID: esri_mapping_rasterLayerMdimTab Condition: esri_mapping_singleMdimRasterLayerSelectedCondition |
| Name: SAR ID: esri_mapping_rasterLayerSARTab Condition: esri_mapping_singleSARRasterLayerSelectedCondition |
| Name: Scene Layer ID: esri_mapping_sceneLayerAppearanceTab Condition: esri_mapping_only3DObjectLayersOr3DPointLayersSelectedCondition |
| Name: Data ID: esri_mapping_sceneLayerDataTab Condition: esri_mapping_only3DObjectLayersOr3DPointLayersSelectedCondition |
| Name: Simulation ID: esri_mapping_simulationTab Condition: esri_mapping_simulationLayerExistsCondition |
| Name: Integrated Mesh Layer ID: esri_mapping_smartIntegratedMeshLayerAppearanceTab Condition: esri_mapping_onlySmartIntegratedMeshLayersSelectedCondition |
| Name: Data ID: esri_mapping_smartIntegratedMeshLayerDataTab Condition: esri_mapping_onlySmartIntegratedMeshLayersSelectedCondition |
| Name: Stream Layer ID: esri_mapping_streamLayerAppearanceTab Condition: esri_mapping_onlyStreamLayersSelectedCondition |
| Name: Data ID: esri_mapping_streamLayerDataTab Condition: esri_mapping_onlyStreamLayersSelectedCondition |
| Name: Labeling ID: esri_mapping_streamLayerLabelingTab Condition: esri_mapping_onlyStreamLayersSelectedCondition |
| Name: Manage ID: esri_mapping_StylesTab Condition: esri_StylesContainer |
| Name: Subtype Group Layer ID: esri_mapping_subtypeGroupLayerAppearanceTab Condition: esri_mapping_onlySubtypeGroupLayersSelectedCondition |
| Name: Data ID: esri_mapping_subtypeGroupLayerDataTab Condition: esri_mapping_onlySubtypeGroupLayersSelectedCondition |
| Name: Table ID: esri_mapping_tableTab Condition: esri_editing_tableOpenCondition |
| Name: Tile Layer ID: esri_mapping_tiledLayerAppearanceTab Condition: esri_mapping_TiledServiceLayerSelectedCondition |
| Name: 3D Tiles Layer ID: esri_mapping_tiles3dLayerAppearanceTab Condition: esri_mapping_tiles3DLayerSelectedCondition |
| Name: Data ID: esri_mapping_tiles3dLayerDataTab Condition: esri_mapping_integratedMeshTiles3DLayersSelectedCondition |
| Name: Time ID: esri_mapping_timeTab Condition: esri_mapping_timeEnabledCondition |
| Name: Trajectory Layer ID: esri_mapping_trajectoryLayerAppearanceTab Condition: esri_mapping_onlyTrajectoryLayersSelectedCondition |
| Name: Data ID: esri_mapping_trajectoryLayerDataTab Condition: esri_mapping_onlyTrajectoryLayersSelectedCondition |
| Name: Vector Tile Layer ID: esri_mapping_vectorTileLayerAppearanceTab Condition: esri_mapping_vectorTileLayersSelectedCondition |
| Name: Voxel Layer ID: esri_mapping_voxelLayerAppearanceTab Condition: esri_mapping_voxelLayersSelectedCondition |
| Name: Data ID: esri_mapping_voxelLayerDataTab Condition: esri_mapping_voxelLayersSelectedCondition |
| Name: WMS Layer ID: esri_mapping_wmsLayerAppearanceTab Condition: esri_mapping_WMSServiceLayerSelectedCondition |
| Name: WMS Sublayer ID: esri_mapping_wmsSubLayerAppearanceTab Condition: esri_mapping_WMSSubLayerSelectedCondition |
toolbars
Click this link to view ADMapping.daml.
