ProSnippets 2.0 Migration Samples
Language:      c#
Subject:       Framework
Contributor:   ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization:  esri, https://www.esri.com
Date:          9/28/2021
ArcGIS Pro:    2.9
Visual Studio: 2017, 2019
The upgrade from ArcGIS Pro SDK 1.4 to ArcGIS Pro SDK 2.0 is a 'code breaking' change. This means that you have to change, recompile, rebuild, and redistribute any 1.x (SDK 1.4 and earlier) add-ins and configurations so that they work with ArcGIS Pro 2.0.
This document lists all 1.4 ProSnippets that required modification in order to work with ArcGIS Pro 2.0. The 1.4 code snippet is shown as the before code snippet and the equivalent 2.0 code snippet is shown as the now: code snippet.
With 2.0 the ItemFactory pattern changed notably as documented in ProConcepts Content and Items.
The following ProSnippet Migrations samples are available:
ProSnippet Migration by topic
Content
New project with specified name
    before:
//Settings used to create a new project
CreateProjectSettings projectSettings = new CreateProjectSettings();
//Sets the name of the project that will be created
projectSettings.Name = @"C:\Data\MyProject1\MyProject1.aprx";
//Create the new project
await Project.CreateAsync(projectSettings);
    now:
New project using a particular template
    before:
//Sets the project template that will be used to create the new project
projectSettings.TemplatePath = @"C:\Data\MyProject1\CustomTemplate.aptx";
    now:
Adds item to the current project
    before:
//Adding a folder connection
string folderPath = "@C:\\myDataFolder";
var folder = await Project.Current.AddAsync(ItemFactory.Create(folderPath));
//Adding a Geodatabase:
string gdbPath = "@C:\\myDataFolder\\myData.gdb";
var newlyAddedGDB = await Project.Current.AddAsync(ItemFactory.Create(gdbPath));
    now:
var folder = await QueuedTask.Run(() => {
  //Create the folder connection project item
  var item = ItemFactory.Instance.Create(folderPath) as IProjectItem;
  //If it is succesfully added to the project, return it otherwise null
  return Project.Current.AddItem(item) ? item as FolderConnectionProjectItem : null;
var newlyAddedGDB = await QueuedTask.Run(() => {
  //Create the File GDB project item
  var item = ItemFactory.Instance.Create(gdbPath) as IProjectItem;
  return Project.Current.AddItem(item) ? item as GDBProjectItem : null;
How to add a new map to a project
    before:
    var map = MapFactory.CreateMap("New Map", ArcGIS.Core.CIM.MapType.Map, ArcGIS.Core.CIM.MapViewingMode.Map, Basemap.Oceans);
    ProApp.Panes.CreateMapPaneAsync(map);
    now:
  //Note: see also MapFactory in ArcGIS.Desktop.Mapping
  var map = MapFactory.Instance.CreateMap("New Map", MapType.Map, MapViewingMode.Map, Basemap.Oceans);
Get all the project items
    before:
IEnumerable<ProjectItem> allProjectItems = Project.Current.GetItems<ProjectItem>();
foreach (var pi in allProjectItems)
    //Do Something
    now:
IEnumerable<Item> allProjectItems = Project.Current.GetItems<Item>();
  //Do Something
Gets a specific folder connection
    before:
//Gets a specific folder connection in the current project
ProjectItem myProjectFolder = Project.Current.GetItems<FolderConnectionProjectItem>().FirstOrDefault(folderPI => folderPI.Name.Equals("myDataFolder"));
    now:
FolderConnectionProjectItem myProjectFolder = Project.Current.GetItems<FolderConnectionProjectItem>().FirstOrDefault(folderPI => folderPI.Name.Equals("myDataFolder"));
Remove a specific folder connection
    before:
// Remove a folder connection from a project; the folder stored on the local disk or the network is not deleted
FolderConnectionProjectItem folderToRemove = Project.Current.GetItems<FolderConnectionProjectItem>().FirstOrDefault(myfolder => myfolder.Name.Equals("PlantSpecies"));
if (folderToRemove != null)
    await Project.Current.RemoveAsync(folderToRemove);
    now:
  Project.Current.RemoveItem(folderToRemove as IProjectItem);
Search project for a specific item
    before:
List<Item> _mxd = new List<Item>();
//Gets all the folder connections in the current project
var allFoldersItem = Project.Current.GetItems<FolderConnectionProjectItem>();
if (allFoldersItem != null)
    //iterate through all the FolderConnectionProjectItems found
    foreach (var folderItem in allFoldersItem)
        //Search for mxd files in that folder connection and add it to the List<T>
        //Note:ArcGIS Pro automatically creates and dynamically updates a searchable index as you build and work with projects.
        //Items are indexed when they are added to a project.
        //The first time a folder or database is indexed, indexing may take a while if it contains a large number of items.
        //While the index is being created, searches will not return any results.
        _mxd.AddRange(await folderItem.SearchAsync(".mxd"));
    now:
  var allFolderItems = Project.Current.GetItems<FolderConnectionProjectItem>();
  if (allFolderItems != null)
       _mxd = GetItemsFromFolderItem(allFolderItems, ".mxd");
  MessageBox.Show($@"Count: {_mxd.Count}");
private List<Item> GetItemsFromFolderItem (IEnumerable<FolderConnectionProjectItem> allFolderItems, string fileExtension)
  List<Item> foundItems = new List<Item>();
  List<FolderConnectionProjectItem> childFolders = new List<FolderConnectionProjectItem>();
  //iterate recursively through all the FolderConnectionProjectItems found
  foreach (var folderItem in allFolderItems)
    //Note:ArcGIS Pro automatically creates and dynamically updates a search-able index as you build and work with projects.
    childFolders.AddRange(folderItem.GetItems()
                          .Where(f => (f is FolderConnectionProjectItem))
                          .Select(f => f as FolderConnectionProjectItem));
    foundItems.AddRange(folderItem.GetItems()
                          .Where(f => f.Name.EndsWith(fileExtension, StringComparison.CurrentCultureIgnoreCase)));
  if (childFolders.Count > 0)
    foundItems.AddRange(GetItemsFromFolderItem(childFolders, fileExtension));
  return foundItems;
Get Item Categories
    before:
// Get the ItemCategories with which an item is associated
Item gdb = ItemFactory.Create(@"E:\CurrentProject\RegionalPolling\polldata.gdb");
List<ItemCategory> gdbItemCategories = gdb.ItemCategories;
    now:
Item gdb = ItemFactory.Instance.Create(@"E:\CurrentProject\RegionalPolling\polldata.gdb");
Using Item Categories
    before:
// Browse items using an ItemCategory as a filter
IEnumerable<Item> gdbContents = await gdb.GetItemsAsync();
IEnumerable<Item> filteredGDBContents1 = gdbContents.Where(item => item.ItemCategories.OfType<ItemCategoryDataSet>().Any());
IEnumerable<Item> filteredGDBContents2 = new ItemCategoryDataSet().Items(gdbContents);
    now:
IEnumerable<Item> gdbContents = gdb.GetItems();
Method to Return The Default Template Folder
    before:
public static string GetDefaultTemplateFolder() {
    string dir = System.IO.Path.GetDirectoryName(System.Reflection.Assembly.GetEntryAssembly().Location);
    string root = dir.Split(new string[] { @"\bin" }, StringSplitOptions.RemoveEmptyEntries)[0];
    return System.IO.Path.Combine(root, @"Resources\ProjectTemplates");
    now:
Get The List of Installed Templates
    before:
public static Task<List<string>> GetDefaultTemplatesAsync() {
    return Task.Run(() => {
        string templatesDir = GetDefaultTemplateFolder();
        return
            Directory.GetFiles(templatesDir, "*", SearchOption.TopDirectoryOnly)
                .Where(f => f.EndsWith(".ppkx") || f.EndsWith(".aptx")).ToList();
    now:
    return
Create Project With Template
    before:
var templates = await GetDefaultTemplatesAsync();
var projectFolder = System.IO.Path.Combine(
    System.Environment.GetFolderPath(
        Environment.SpecialFolder.MyDocuments),
    @"ArcGIS\Projects");
CreateProjectSettings ps = new CreateProjectSettings() {
    Name = "MyProject",
    LocationPath = projectFolder,
    TemplatePath = templates[2]//2D "Map" template
var project = await Project.CreateAsync(ps);
    now:
  Name = "MyProject",
Geodatabase
    before:
public async Task GetFeatureClassesInRelationshipClassAsync()
    await ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(@"C:\Data\LocalGovernment.gdb"))
            IReadOnlyList<RelationshipClassDefinition> relationshipClassDefinitions = geodatabase.GetDefinitions<RelationshipClassDefinition>();
            foreach (var relationshipClassDefintion in relationshipClassDefinitions)
                IReadOnlyList<Definition> definitions = geodatabase.GetRelatedDefinitions(relationshipClassDefintion,
                    DefinitionRelationshipType.DatasetsRelatedThrough);
                foreach (var definition in definitions)
                    MessageBox.Show($"Feature class in the RelationshipClass is:{definition.GetName()}");
    now:
        using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\Data\LocalGovernment.gdb"))))
Opening a File Geodatabase given the path
    before:
public async Task OpenFileGDB()
    try
      // Opens a file geodatabase. This will open the geodatabase if the folder exists and contains a valid geodatabase.
        // Use the geodatabase.
    catch (GeodatabaseNotFoundOrOpenedException exception)
      // Handle Exception.
    now:
  try {
    await ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() => {
      using (
          new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\Data\LocalGovernment.gdb")))) {
  catch (GeodatabaseNotFoundOrOpenedException exception) {
Opening an Enterprise Geodatabase using connection properties
    before:
public async Task OpenEnterpriseGeodatabase()
    // Opening a Non-Versioned SQL Server instance.
    DatabaseConnectionProperties connectionProperties = new DatabaseConnectionProperties(EnterpriseDatabaseType.SQLServer)
      AuthenticationMode = AuthenticationMode.DBMS,
      // Where testMachine is the machine where the instance is running and testInstance is the name of the SqlServer instance.
      Instance = @"testMachine\testInstance",
      // Provided that a database called LocalGovernment has been created on the testInstance and geodatabase has been enabled on the database.
      Database = "LocalGovernment",
      // Provided that a login called gdb has been created and corresponding schema has been created with the required permissions.
      User     = "gdb",
      Password = "password",
      Version  = "dbo.DEFAULT"
    using (Geodatabase geodatabase = new Geodatabase(connectionProperties))
    now:
    DatabaseConnectionProperties connectionProperties = new DatabaseConnectionProperties(EnterpriseDatabaseType.SQLServer) {
      User = "gdb",
    using (Geodatabase geodatabase = new Geodatabase(connectionProperties)) {
Opening an Enterprise Geodatabase using sde file path
    before:
public async Task OpenEnterpriseGeodatabaseUsingSDEFilePath()
    using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
    now:
    using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde")))) {
Obtaining Geodatabase from Project Item
    before:
public async Task ObtainingGeodatabaseFromProjectItem()
  IEnumerable<GDBProjectItem> gdbProjectItems = Project.Current.GetItems<GDBProjectItem>();
    foreach (GDBProjectItem gdbProjectItem in gdbProjectItems)
      using (Datastore datastore = gdbProjectItem.GetDatastore())
        //Unsupported datastores (non File GDB and non Enterprise GDB) will be of type UnknownDatastore
        if (datastore is UnknownDatastore)
          continue;
        Geodatabase geodatabase = datastore as Geodatabase;
    now:
    foreach (GDBProjectItem gdbProjectItem in gdbProjectItems) {
      using (Datastore datastore = gdbProjectItem.GetDatastore()) {
          continue;
Obtaining Geodatabase from FeatureLayer
    before:
public async Task ObtainingGeodatabaseFromFeatureLayer()
  IEnumerable<Layer> layers = MapView.Active.Map.Layers.Where(layer => layer is FeatureLayer);
    foreach (FeatureLayer featureLayer in layers)
      using (Table table = featureLayer.GetTable())
      using (Datastore datastore = table.GetDatastore())
          continue;
    now:
    foreach (FeatureLayer featureLayer in layers) {
      using (Datastore datastore = table.GetDatastore()) {
          continue;
Opening datasets from Geodatabase
    before:
public async Task OpeningDatasetsFromGeodatabase()
      using (Table table = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.EmployeeInfo"))
      // Open a featureClass (within a feature dataset or outside a feature dataset).
      using (FeatureClass featureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.AddressPoint"))
      // You can open a FeatureClass as a Table which will give you a Table Reference.
      using (Table featureClassAsTable = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.AddressPoint"))
        // But it is really a FeatureClass object.
        FeatureClass featureClassOpenedAsTable = featureClassAsTable as FeatureClass;
      // Open a FeatureDataset.
      using (FeatureDataset featureDataset = geodatabase.OpenDataset<FeatureDataset>("LocalGovernment.GDB.Address"))
      // Open a RelationsipClass.  Just as you can open a FeatureClass as a Table, you can also open an AttributedRelationshipClass as a RelationshipClass.
      using (RelationshipClass relationshipClass = geodatabase.OpenDataset<RelationshipClass>("LocalGovernment.GDB.AddressPointHasSiteAddresses"))
    now:
      using (Table table = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.EmployeeInfo")) {
      using (FeatureClass featureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.AddressPoint")) {
      using (Table featureClassAsTable = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.AddressPoint")) {
      using (FeatureDataset featureDataset = geodatabase.OpenDataset<FeatureDataset>("LocalGovernment.GDB.Address")) {
      using (RelationshipClass relationshipClass = geodatabase.OpenDataset<RelationshipClass>("LocalGovernment.GDB.AddressPointHasSiteAddresses")) {
Obtaining Definition from Geodatabase
    before:
public async Task ObtainingDefinitionFromGeodatabase()
      // Remember that for Enterprise databases you have to qualify your dataset names with the DatabaseName and UserName.
      TableDefinition enterpriseTableDefinition = geodatabase.GetDefinition<TableDefinition>("LocalGovernment.GDB.CitizenContactInfo");
      // It does not matter if the dataset is within a FeatureDataset or not.
      FeatureClassDefinition featureClassDefinition = geodatabase.GetDefinition<FeatureClassDefinition>("LocalGovernment.GDB.FireStation");
      // GetDefinition For a RelationshipClass.
      RelationshipClassDefinition relationshipClassDefinition = geodatabase.GetDefinition<RelationshipClassDefinition>("LocalGovernment.GDB.AddressPointHasSiteAddresses");
      // GetDefinition For a FeatureDataset.
      FeatureDatasetDefinition featureDatasetDefinition = geodatabase.GetDefinition<FeatureDatasetDefinition>("LocalGovernment.GDB.Address");
    now:
Obtaining List of Defintions from Geodatabase
    before:
public async Task ObtainingDefinitionsFromGeodatabase()
      IReadOnlyList<FeatureClassDefinition> enterpriseDefinitions = geodatabase.GetDefinitions<FeatureClassDefinition>();
      IEnumerable<Definition> featureClassesHavingGlobalID = enterpriseDefinitions.Where(definition => definition.HasGlobalID());
      IReadOnlyList<FeatureDatasetDefinition> featureDatasetDefinitions = geodatabase.GetDefinitions<FeatureDatasetDefinition>();
      bool electionRelatedFeatureDatasets = featureDatasetDefinitions.Any(definition => definition.GetName().Contains("Election"));
      IReadOnlyList<AttributedRelationshipClassDefinition> attributedRelationshipClassDefinitions = geodatabase.GetDefinitions<AttributedRelationshipClassDefinition>();
    now:
    before:
public async Task ObtainingRelatedDefinitionsFromGeodatabase()
      // Remember the qualification of DatabaseName. for the RelationshipClass.
      RelationshipClassDefinition enterpriseDefinition = geodatabase.GetDefinition<RelationshipClassDefinition>("LocalGovernment.GDB.AddressPointHasSiteAddresses");
      IReadOnlyList<Definition> enterpriseDefinitions = geodatabase.GetRelatedDefinitions(enterpriseDefinition, DefinitionRelationshipType.DatasetsRelatedThrough);
      FeatureClassDefinition enterpriseAddressPointDefinition = enterpriseDefinitions.First(
              defn => defn.GetName().Equals("LocalGovernment.GDB.AddressPoint")) as FeatureClassDefinition;
      IReadOnlyList<Definition> datasetsInAddressDataset = geodatabase.GetRelatedDefinitions(featureDatasetDefinition, DefinitionRelationshipType.DatasetInFeatureDataset);
      FeatureClassDefinition addressPointInAddressDataset = datasetsInAddressDataset.First(
      RelationshipClassDefinition addressPointHasSiteAddressInAddressDataset = datasetsInAddressDataset.First(
              defn => defn.GetName().Equals("LocalGovernment.GDB.AddressPointHasSiteAddresses")) as RelationshipClassDefinition;
    now:
Searching a Table using QueryFilter
    before:
public async Task SearchingATable()
    using (Table table             = geodatabase.OpenDataset<Table>("EmployeeInfo"))
      try
        QueryFilter queryFilter = new QueryFilter
          WhereClause   = "COSTCTRN = 'Information Technology'",
          SubFields     = "KNOWNAS, OFFICE, LOCATION",
          PostfixClause = "ORDER BY OFFICE"
        using (RowCursor rowCursor = table.Search(queryFilter, false))
          while (rowCursor.MoveNext())
            using (Row row = rowCursor.Current)
              string location = Convert.ToString(row["LOCATION"]);
              string knownAs = Convert.ToString(row["KNOWNAS"]);
      catch (GeodatabaseFieldException fieldException)
        // One of the fields in the where clause might not exist. There are multiple ways this can be handled:
        // Handle error appropriately
      catch (Exception exception)
        // logger.Error(exception.Message);
    now:
  try {
      using (Table table = geodatabase.OpenDataset<Table>("EmployeeInfo")) {
        QueryFilter queryFilter = new QueryFilter {
        using (RowCursor rowCursor = table.Search(queryFilter, false)) {
          while (rowCursor.MoveNext()) {
            using (Row row = rowCursor.Current) {
  catch (GeodatabaseFieldException fieldException) {
  catch (Exception exception) {
Searching a FeatureClass using SpatialQueryFilter
    before:
public async Task SearchingAFeatureClass()
    using (FeatureClass schoolBoundaryFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.SchoolBoundary"))
      // Using a spatial query filter to find all features which have a certain district name and lying within a given Polygon.
      SpatialQueryFilter spatialQueryFilter = new SpatialQueryFilter
        WhereClause    = "DISTRCTNAME = 'Indian Prairie School District 204'",
        FilterGeometry = new PolygonBuilder(new List<Coordinate>
          new Coordinate(1021880, 1867396),
          new Coordinate(1028223, 1870705),
          new Coordinate(1031165, 1866844),
          new Coordinate(1025373, 1860501),
          new Coordinate(1021788, 1863810)
        }).ToGeometry(),
        SpatialRelationship = SpatialRelationship.Within
      using (RowCursor indianPrairieCursor = schoolBoundaryFeatureClass.Search(spatialQueryFilter, false))
        while (indianPrairieCursor.MoveNext())
          using (Feature feature = (Feature)indianPrairieCursor.Current)
            // Process the feature. For example...
            Console.WriteLine(feature.GetObjectID());
    now:
    using (FeatureClass schoolBoundaryFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.SchoolBoundary")) {
      SpatialQueryFilter spatialQueryFilter = new SpatialQueryFilter {
        FilterGeometry = new PolygonBuilder(new List<Coordinate2D>
          new Coordinate2D(1021880, 1867396),
          new Coordinate2D(1028223, 1870705),
          new Coordinate2D(1031165, 1866844),
          new Coordinate2D(1025373, 1860501),
          new Coordinate2D(1021788, 1863810)
        }).ToGeometry(),
      using (RowCursor indianPrairieCursor = schoolBoundaryFeatureClass.Search(spatialQueryFilter, false)) {
        while (indianPrairieCursor.MoveNext()) {
          using (Feature feature = (Feature)indianPrairieCursor.Current) {
Selecting Rows from a Table
    before:
public async Task SelectingRowsFromATable()
    using (Table enterpriseTable   = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.piCIPCost"))
      QueryFilter anotherQueryFilter = new QueryFilter { WhereClause = "FLOOR = 1 AND WING = 'E'" };
      // For Selecting all matching entries.
      Selection anotherSelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.Normal);
      // This can be used to get one record which matches the criteria. No assumptions can be made about which record satisfying the criteria is selected.
      Selection onlyOneSelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.OnlyOne);
      // This can be used to obtain a empty selction which can be used as a container to combine results from different selections.
      Selection emptySelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.Empty);
      // If you want to select all the records in a table.
      Selection allRecordSelection = enterpriseTable.Select(null, SelectionType.ObjectID, SelectionOption.Normal);
    now:
    using (Table enterpriseTable = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.piCIPCost")) {
      using (Selection anotherSelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.Normal)) {
      using (Selection onlyOneSelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.OnlyOne)) {
      using (Selection emptySelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.Empty)) {
      using (Selection allRecordSelection = enterpriseTable.Select(null, SelectionType.ObjectID, SelectionOption.Normal)) {
Selecting Features from a FeatureClass
    before:
public async Task SelectingFeaturesFromAFeatureClass()
    using (FeatureClass enterpriseFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.FacilitySite"))
      List<Coordinate> newCoordinates = new List<Coordinate>
        new Coordinate(1021570, 1880583),
        new Coordinate(1028730, 1880994),
        new Coordinate(1029718, 1875644),
        new Coordinate(1021405, 1875397)
      SpatialQueryFilter spatialFilter = new SpatialQueryFilter
        WhereClause         = "FCODE = 'Park'",
        FilterGeometry      = new PolygonBuilder(newCoordinates).ToGeometry(),
        SpatialRelationship = SpatialRelationship.Crosses
      Selection anotherSelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.Normal);
      // criteria is selected.
      Selection onlyOneSelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.OnlyOne);
      Selection emptySelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.Empty);
      Selection allRecordSelection = enterpriseFeatureClass.Select(null, SelectionType.ObjectID, SelectionOption.Normal);
    now:
    using (FeatureClass enterpriseFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.FacilitySite")) {
      List<Coordinate2D> newCoordinates = new List<Coordinate2D>
        new Coordinate2D(1021570, 1880583),
        new Coordinate2D(1028730, 1880994),
        new Coordinate2D(1029718, 1875644),
        new Coordinate2D(1021405, 1875397)
      SpatialQueryFilter spatialFilter = new SpatialQueryFilter {
      using (Selection anotherSelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.Normal)) {
      using (Selection onlyOneSelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.OnlyOne)) {
      using (Selection emptySelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.Empty)) {
      using (Selection allRecordSelection = enterpriseFeatureClass.Select(null, SelectionType.ObjectID, SelectionOption.Normal)) {
Creating a Row
    before:
public async Task CreatingARow()
  string message      = String.Empty;
  bool creationResult = false;
      EditOperation editOperation = new EditOperation();
      editOperation.Callback(context =>
        try
          TableDefinition tableDefinition = enterpriseTable.GetDefinition();
          int assetNameIndex= tableDefinition.FindField("ASSETNA");
          using (RowBuffer rowBuffer = enterpriseTable.CreateRowBuffer())
            // Either the field index or the field name can be used in the indexer.
            rowBuffer[assetNameIndex] = "wMain";
            rowBuffer["COST"]         = 700;
            rowBuffer["ACTION"]       = "Open Cut";
            // subtype value for "Abandon".
            rowBuffer[tableDefinition.GetSubtypeField()] = 3;
            using (Row row = enterpriseTable.CreateRow(rowBuffer))
              // To Indicate that the attribute table has to be updated.
              context.Invalidate(row);
        catch (GeodatabaseException exObj)
          message = exObj.Message;
      }, enterpriseTable);
      var task = editOperation.ExecuteAsync();
      creationResult = task.Result;
      if (!creationResult)
        message = editOperation.ErrorMessage;
    MessageBox.Show(message);
    now:
      //var geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(uri)) for a File GDB
      //var shapeFileConnPath = new FileSystemConnectionPath(uri, FileSystemDatastoreType.Shapefile);
      //var shapefile = new FileSystemDatastore(shapeFileConnPath);
      //var table = shapefile.OpenDataset<Table>(strShapeFileName); for a Shape file
      //declare the callback here. We are not executing it ~yet~
      editOperation.Callback(context => {
        int assetNameIndex = tableDefinition.FindField("ASSETNA");
        using (RowBuffer rowBuffer = enterpriseTable.CreateRowBuffer()) {
          using (Row row = enterpriseTable.CreateRow(rowBuffer)) {
      try {
        creationResult = editOperation.Execute();
        if (!creationResult) message = editOperation.ErrorMessage;
      catch (GeodatabaseException exObj) {
  if (!string.IsNullOrEmpty(message))
Creating a Feature
    before:
public async Task CreatingAFeature()
        try
          FeatureClassDefinition facilitySiteDefinition = enterpriseFeatureClass.GetDefinition();
          int facilityIdIndex = facilitySiteDefinition.FindField("FACILITYID");
          using (RowBuffer rowBuffer = enterpriseFeatureClass.CreateRowBuffer())
            rowBuffer[facilityIdIndex] = "wMain";
            rowBuffer["NAME"]          = "Griffith Park";
            rowBuffer["OWNTYPE"]       = "Municipal";
            rowBuffer["FCODE"]         = "Park";
            // Add it to Public Attractions Subtype.
            rowBuffer[facilitySiteDefinition.GetSubtypeField()] = 820;
            rowBuffer[facilitySiteDefinition.GetShapeField()] = new PolygonBuilder(newCoordinates).ToGeometry();
            using (Feature feature = enterpriseFeatureClass.CreateRow(rowBuffer))
              //To Indicate that the attribute table has to be updated
              context.Invalidate(feature);
      }, enterpriseFeatureClass);
    now:
        using (RowBuffer rowBuffer = enterpriseFeatureClass.CreateRowBuffer()) {
          using (Feature feature = enterpriseFeatureClass.CreateRow(rowBuffer)) {
      try {
Modifying a Row
    before:
public async Task ModifyingARow()
  bool modificationResult = false;
        QueryFilter openCutFilter = new QueryFilter { WhereClause = "ACTION = 'Open Cut'" };
        using (RowCursor rowCursor = enterpriseTable.Search(openCutFilter, false))
          int subtypeFieldIndex = tableDefinition.FindField(tableDefinition.GetSubtypeField());
              // In order to update the Map and/or the attribute table.
              // Has to be called before any changes are made to the row.
              row["ASSETNA"] = "wMainOpenCut";
              if (Convert.ToDouble(row["COST"]) > 700)
                // Abandon asset if cost is higher than 700 (if that is what you want to do).
                row["ACTION"]          = "Open Cut Abandon";
                row[subtypeFieldIndex] = 3; //subtype value for "Abandon"
              //After all the changes are done, persist it.
              row.Store();
              // Has to be called after the store too.
      modificationResult = task.Result;
      if (!modificationResult)
    now:
        using (RowCursor rowCursor = enterpriseTable.Search(openCutFilter, false)) {
              if (Convert.ToDouble(row["COST"]) > 700) {
              row.Store();
      try {
        modificationResult = editOperation.Execute();
        if (!modificationResult) message = editOperation.ErrorMessage;
Modifying a Feature
    before:
public async Task ModifyingAFeature()
      int ownTypeIndex = facilitySiteDefinition.FindField("OWNTYPE");
      int areaIndex    = facilitySiteDefinition.FindField(facilitySiteDefinition.GetAreaField());
        QueryFilter queryFilter = new QueryFilter { WhereClause = "FCODE = 'Hazardous Materials Facility' AND OWNTYPE = 'Private'" };
        using (RowCursor rowCursor = enterpriseFeatureClass.Search(queryFilter, false))
            using (Feature feature = (Feature)rowCursor.Current)
              // Transfer all Hazardous Material Facilities to the City.
              feature[ownTypeIndex] = "Municipal";
              if (Convert.ToDouble(feature[areaIndex]) > 50000)
                // Set the Shape of the feature to whatever you need.
                feature.SetShape(new PolygonBuilder(newCoordinates).ToGeometry());
              feature.Store();
    now:
        using (RowCursor rowCursor = enterpriseFeatureClass.Search(queryFilter, false)) {
            using (Feature feature = (Feature)rowCursor.Current) {
              if (Convert.ToDouble(feature[areaIndex]) > 50000) {
              feature.Store();
      try {
Deleting a Row/Feature
    before:
public async Task DeletingARowOrFeature()
  bool deletionResult = false;
              // In order to update the Map and/or the attribute table. Has to be called before the delete.
              row.Delete();
      deletionResult = task.Result;
      if (!deletionResult)
    now:
              row.Delete();
      try {
        deletionResult = editOperation.Execute();
        if (!deletionResult) message = editOperation.ErrorMessage;
Obtaining a memory stream to modify or create Attachment data
    before:
private MemoryStream CreateMemoryStreamFromContentsOf(String fileNameWithPath)
  MemoryStream memoryStream = new MemoryStream();
  using (FileStream file = new FileStream(fileNameWithPath, FileMode.Open, FileAccess.Read))
    byte[] bytes = new byte[file.Length];
    file.Read(bytes, 0, (int)file.Length);
    memoryStream.Write(bytes, 0, (int)file.Length);
  return memoryStream;
    now:
  using (FileStream file = new FileStream(fileNameWithPath, FileMode.Open, FileAccess.Read)) {
Adding Attachments
    before:
public async Task AddingAttachments()
    using (FeatureClass parkFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.Park"))
      QueryFilter filter = new QueryFilter { WhereClause = "NUMPARKING > 0" };
      using (RowCursor parkingCursor = parkFeatureClass.Search(filter, false))
        while (parkingCursor.MoveNext())
          using (MemoryStream stream = CreateMemoryStreamFromContentsOf("Sample.xml"))
            Attachment attachment = new Attachment("Sample.xml", "text/xml", stream);
            using (Row row = parkingCursor.Current)
              long attachmentId = row.AddAttachment(attachment);
    now:
    using (FeatureClass parkFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.Park")) {
      using (RowCursor parkingCursor = parkFeatureClass.Search(filter, false)) {
        while (parkingCursor.MoveNext()) {
          using (MemoryStream stream = CreateMemoryStreamFromContentsOf("Sample.xml")) {
            using (Row row = parkingCursor.Current) {
Updating Attachments
    before:
public async Task UpdatingAttachments()
    using (FeatureClass landUseCaseFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.LandUseCase"))
      QueryFilter filter = new QueryFilter { WhereClause = "CASETYPE = 'Rezoning'" };
      using (RowCursor landUseCursor = landUseCaseFeatureClass.Search(filter, false))
        while (landUseCursor.MoveNext())
          Feature rezoningUseCase = (Feature)landUseCursor.Current;
          IReadOnlyList<Attachment> rezoningAttachments = rezoningUseCase.GetAttachments();
          IEnumerable<Attachment> filteredAttachments = rezoningAttachments.Where(attachment => !attachment.GetName().Contains("rezoning"));
          foreach (Attachment attachmentToUpdate in filteredAttachments)
            attachmentToUpdate.SetName(attachmentToUpdate.GetName().Replace(".pdf", "Rezoning.pdf"));
            rezoningUseCase.UpdateAttachment(attachmentToUpdate);
    now:
    using (FeatureClass landUseCaseFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.LandUseCase")) {
      using (RowCursor landUseCursor = landUseCaseFeatureClass.Search(filter, false)) {
        while (landUseCursor.MoveNext()) {
          foreach (Attachment attachmentToUpdate in filteredAttachments) {
Deleting Attachments
    before:
public async Task DeletingAttachments()
    using (Table inspectionTable   = geodatabase.OpenDataset<Table>("luCodeInspection"))
      QueryFilter queryFilter = new QueryFilter { WhereClause = "ACTION = '1st Notice'" };
      using (RowCursor cursor = inspectionTable.Search(queryFilter, false))
        while (cursor.MoveNext())
          using (Row currentRow = cursor.Current)
            IReadOnlyList<Attachment> rowAttachments = currentRow.GetAttachments(null, true);
            IEnumerable<Attachment> attachments      = rowAttachments.Where(attachment => attachment.GetContentType().Equals("application/pdf"));
            var attachmentIDs = attachments.Select(attachment => attachment.GetAttachmentID()) as IReadOnlyList<long>;
            IReadOnlyDictionary<long, Exception> failures = currentRow.DeleteAttachments(attachmentIDs);
            if (failures.Count > 0)
              //process errors
    now:
    using (Table inspectionTable = geodatabase.OpenDataset<Table>("luCodeInspection")) {
      using (RowCursor cursor = inspectionTable.Search(queryFilter, false)) {
        while (cursor.MoveNext()) {
          using (Row currentRow = cursor.Current) {
            if (failures.Count > 0) {
              //process errors
Working with Versions
    before:
public async Task WorkingWithVersions()
    using (Geodatabase geodatabase       = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file"))))
    using (VersionManager versionManager = geodatabase.GetVersionManager())
      IReadOnlyList<Version> versionList = versionManager.GetVersions();
      //The default version will have a null Parent
      Version defaultVersion = versionList.First(version => version.GetParent() == null);
      IEnumerable<Version> publicVersions = versionList.Where(version => version.GetAccessType() == VersionAccessType.Public);
      Version qaVersion = defaultVersion.GetChildren().First(version => version.GetName().Contains("QA"));
      Geodatabase qaVersionGeodatabase = qaVersion.Connect();
      FeatureClass currentFeatureClass = geodatabase.OpenDataset<FeatureClass>("featureClassName");
      FeatureClass qaFeatureClass = qaVersionGeodatabase.OpenDataset<FeatureClass>("featureClassName");
    now:
    using (VersionManager versionManager = geodatabase.GetVersionManager()) {
    before:
public async Task GettingRowsRelatedByRelationshipClass()
    using (RelationshipClass relationshipClass = geodatabase.OpenDataset<RelationshipClass>("LocalGovernment.GDB.luCodeViolationHasInspections"))
    using (FeatureClass violationsFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.luCodeViolation"))
    using (Table inspectionTable               = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.luCodeInspection"))
      List<Row> jeffersonAveViolations = new List<Row>();
      QueryFilter queryFilter = new QueryFilter { WhereClause = "LOCDESC LIKE '///%Jefferson///%'" };
      using (RowCursor rowCursor = violationsFeatureClass.Search(queryFilter, false))
          jeffersonAveViolations.Add(rowCursor.Current);
      IReadOnlyList<Row> relatedOriginRows = null;
      IReadOnlyList<Row> relatedDestinationRows = null;
      try
        QueryFilter filter = new QueryFilter { WhereClause = "ACTION = '1st Notice'" };
        Selection selection = inspectionTable.Select(filter, SelectionType.ObjectID, SelectionOption.Normal);
        relatedOriginRows = relationshipClass.GetRowsRelatedToDestinationRows(selection.GetObjectIDs());
        bool containsJeffersonAve = relatedOriginRows.Any(row => Convert.ToString(row["LOCDESC"]).Contains("Jefferson"));
        List<long> jeffersonAveViolationObjectIds = jeffersonAveViolations.Select(row => row.GetObjectID()).ToList();
        relatedDestinationRows = relationshipClass.GetRowsRelatedToOriginRows(jeffersonAveViolationObjectIds);
        bool hasFirstNoticeInspections = relatedDestinationRows.Any(row => Convert.ToString(row["ACTION"]).Contains("1st Notice"));
      finally
        Dispose(jeffersonAveViolations);
        Dispose(relatedOriginRows);
        Dispose(relatedDestinationRows);
private static void Dispose(IEnumerable<Row> rows)
  foreach (Row row in rows)
    row.Dispose();
    now:
    using (Table inspectionTable = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.luCodeInspection")) {
      using (RowCursor rowCursor = violationsFeatureClass.Search(queryFilter, false)) {
      try {
        using (Selection selection = inspectionTable.Select(filter, SelectionType.ObjectID, SelectionOption.Normal)) {
      finally {
    row.Dispose();
Creating a Relationship
    before:
public async Task CreatingARelationship()
    using (RelationshipClass relationshipClass = geodatabase.OpenDataset<RelationshipClass>("LocalGovernment.GDB.OverviewToProject"))
    using (FeatureClass projectsFeatureClass   = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.CIPProjects"))
    using (FeatureClass overviewFeatureClass   = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.CIPProjectsOverview"))
      // This will be PROJNAME. This can be used to get the field index or used directly as the field name.
      string originKeyField = relationshipClass.GetDefinition().GetOriginKeyField();
        // The rows are being added to illustrate adding relationships. If one has existing rows, those can be used to add a relationship.
        using (RowBuffer projectsRowBuffer = projectsFeatureClass.CreateRowBuffer())
        using (RowBuffer overviewRowBuffer = overviewFeatureClass.CreateRowBuffer())
          projectsRowBuffer["TOTCOST"] = 500000;
          overviewRowBuffer[originKeyField] = "LibraryConstruction";
          overviewRowBuffer["PROJECTMAN"]   = "John Doe";
          overviewRowBuffer["FUNDSOUR"]     = "Public";
          using (Row projectsRow = projectsFeatureClass.CreateRow(projectsRowBuffer))
          using (Row overviewRow = overviewFeatureClass.CreateRow(overviewRowBuffer))
            Relationship relationship = relationshipClass.CreateRelationship(overviewRow, projectsRow);
            //To Indicate that the Map has to draw this feature/row and/or the attribute table has to be updated
            context.Invalidate(projectsRow);
            context.Invalidate(overviewRow);
            context.Invalidate(relationshipClass);
      }, projectsFeatureClass, overviewFeatureClass);
      bool editResult = editOperation.Execute();
    now:
    using (FeatureClass overviewFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.CIPProjectsOverview")) {
        using (RowBuffer overviewRowBuffer = overviewFeatureClass.CreateRowBuffer()) {
          using (Row overviewRow = overviewFeatureClass.CreateRow(overviewRowBuffer)) {
Deleting a Relationship
    before:
public async Task DeletingARelationship()
        if (!rowCursor.MoveNext())
          return;
        using (Row jeffersonAveViolation = rowCursor.Current)
          IReadOnlyList<Row> relatedDestinationRows = relationshipClass.GetRowsRelatedToOriginRows(new List<long> { jeffersonAveViolation.GetObjectID() });
          try
              foreach (Row relatedDestinationRow in relatedDestinationRows)
                try
                  relationshipClass.DeleteRelationship(jeffersonAveViolation, relatedDestinationRow);
                catch (GeodatabaseRelationshipClassException exception)
                  Console.WriteLine(exception);
            }, relationshipClass);
          finally
            foreach (Row row in relatedDestinationRows)
              row.Dispose();
    now:
    using (FeatureClass violationsFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.luCodeViolation")) {
          return;
        using (Row jeffersonAveViolation = rowCursor.Current) {
          try {
              foreach (Row relatedDestinationRow in relatedDestinationRows) {
                try {
                catch (GeodatabaseRelationshipClassException exception) {
          finally {
              row.Dispose();
Evaluating a QueryDef on a single table
    before:
public async Task SimpleQueryDef()
      QueryDef adaCompilantParksQueryDef = new QueryDef
        Tables      = "Park",
        WhereClause = "ADACOMPLY = 'Yes'",
      using (RowCursor rowCursor = geodatabase.Evaluate(adaCompilantParksQueryDef, false))
            Feature feature = row as Feature;
            Geometry shape = feature.GetShape();
            String type = Convert.ToString(row["ADACOMPLY"]); // will be "Yes" for each row.
            try
              Table table = row.GetTable(); // Will always throw exception.
            catch (NotSupportedException exception)
              // Handle not supported exception.
    now:
    using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file")))) {
      QueryDef adaCompilantParksQueryDef = new QueryDef {
        Tables = "Park",
      using (RowCursor rowCursor = geodatabase.Evaluate(adaCompilantParksQueryDef, false)) {
            try {
            catch (NotSupportedException exception) {
Evaluating a QueryDef on a Join using WHERE Clause
    before:
public async Task JoiningWithWhereQueryDef()
      QueryDef municipalEmergencyFacilitiesQueryDef = new QueryDef
        SubFields   = "EmergencyFacility.OBJECTID, EmergencyFacility.Shape, EmergencyFacility.FACILITYID, FacilitySite.FACILITYID, FacilitySite.FCODE",
        Tables      = "EmergencyFacility, FacilitySite",
        WhereClause = "EmergencyFacility.FACNAME = FacilitySite.NAME AND EmergencyFacility.JURISDICT = 'Municipal'",
      using (RowCursor rowCursor = geodatabase.Evaluate(municipalEmergencyFacilitiesQueryDef, false))
            long objectID = Convert.ToInt64(row["EmergencyFacility.OBJECTID"]);
            String featureCode = Convert.ToString(row["FacilitySite.FCODE"]);
            IReadOnlyList<Field> fields = feature.GetFields(); //Contains one ArcGIS.Core.Data.Field objects for every subfield
    now:
      QueryDef municipalEmergencyFacilitiesQueryDef = new QueryDef {
      using (RowCursor rowCursor = geodatabase.Evaluate(municipalEmergencyFacilitiesQueryDef, false)) {
Evaluating a QueryDef on a OUTER JOIN
    before:
public async Task EvaluatingQueryDefWithOuterJoin()
      QueryDef queryDefWithLeftOuterJoin = new QueryDef
        Tables    = "CommunityAddress LEFT OUTER JOIN MunicipalBoundary on CommunityAddress.Municipality = MunicipalBoundary.Name",
        SubFields = "CommunityAddress.OBJECTID, CommunityAddress.Shape, CommunityAddress.SITEADDID, CommunityAddress.ADDRNUM, CommunityAddress.FULLNAME, CommunityAddress.FULLADDR, CommunityAddress.MUNICIPALITY, MunicipalBoundary.Name, MunicipalBoundary.MUNITYP, MunicipalBoundary.LOCALFIPS",
      using (RowCursor rowCursor = geodatabase.Evaluate(queryDefWithLeftOuterJoin, false))
            int siteAddressId = Convert.ToInt32(row["CommunityAddress.SITEADDID"]);
            String stateName = Convert.ToString(row["MunicipalBoundary.name"]);
    now:
      QueryDef queryDefWithLeftOuterJoin = new QueryDef {
      using (RowCursor rowCursor = geodatabase.Evaluate(queryDefWithLeftOuterJoin, false)) {
Opening a FeatureClass from a ShapeFile Datastore
    before:
public async Task OpenShapefileFeatureClass()
    using (Shapefile shapefile = new Shapefile(new ShapefileConnectionPath(new Uri("path\\to\\folder\\containing\\shapefiles"))))
      FeatureClass taxLotsFeatureClass      = shapefile.OpenTable("TaxLots") as FeatureClass;
      FeatureClass manHolesFeatureClass     = shapefile.OpenTable("ManHoles.shp") as FeatureClass; // Can use the .shp extension, but its not needed.
      Table taxDetailsTableWithoutExtension = shapefile.OpenTable("TaxDetails");
      Table taxDetailsTable                 = shapefile.OpenTable("TaxDetails.dbf");
    now:
    var fileConnection = new FileSystemConnectionPath(new Uri("path\\to\\folder\\containing\\shapefiles"), FileSystemDatastoreType.Shapefile);
    using (FileSystemDatastore shapefile = new FileSystemDatastore(fileConnection)) {
      FeatureClass taxLotsFeatureClass = shapefile.OpenDataset<FeatureClass>("TaxLots");
      FeatureClass manHolesFeatureClass = shapefile.OpenDataset<FeatureClass>("ManHoles.shp"); // Can use the .shp extension, but its not needed.
      Table taxDetailsTableWithoutExtension = shapefile.OpenDataset<Table>("TaxDetails");
      Table taxDetailsTable = shapefile.OpenDataset<Table>("TaxDetails.dbf");
Create Default QueryDescription for a Database table and obtain the ArcGIS.Core.Data.Table for the QueryDescription
    before:
public async Task DefaultQueryDescription()
    DatabaseConnectionProperties databaseConnectionProperties = new DatabaseConnectionProperties(EnterpriseDatabaseType.SQLServer)
      Instance           = "instance",
      Database           = "database",
      User               = "user",
    using (Database database = new Database(databaseConnectionProperties))
      QueryDescription queryDescription = database.GetQueryDescription("CUSTOMERS");
      using (Table table = database.OpenTable(queryDescription))
        //use table
    now:
    DatabaseConnectionProperties databaseConnectionProperties = new DatabaseConnectionProperties(EnterpriseDatabaseType.SQLServer) {
      User = "user",
    using (Database database = new Database(databaseConnectionProperties)) {
      using (Table table = database.OpenTable(queryDescription)) {
        //use table
Create QueryDescription from a custom query for a Database table
    before:
public async Task CustomQueryDescription()
      User               = "user",
      QueryDescription queryDescription = database.GetQueryDescription("SELECT OBJECTID, Shape, FACILITYID FROM EmergencyFacility WHERE JURISDICT = 'Municipal'", "MunicipalEmergencyFacilities");
        // Use the table.
    now:
      User = "user",
        // Use the table.
Create QueryDescription from a join query where there is no non-nullable unique id column
    before:
public async Task JoinQueryDescription()
      User               = "user",
      QueryDescription queryDescription = database.GetQueryDescription("SELECT BUSLINES.ID as BUSLINESID, BUSSTOPS.ID as BUSSTOPSID, BUSLINES.RTE_DESC, BUSLINES.DIR, BUSSTOPS.JURISDIC, BUSSTOPS.LOCATION, BUSSTOPS.ROUTE,BUSSTOPS.SHAPE from demosql.dbo.BUSSTOPS JOIN demosql.dbo.BUSLINES ON BUSSTOPS.ROUTE = BUSLINES.ROUTE", "BusInfo");
      queryDescription.SetObjectIDFields("BUSLINESID,BUSSTOPSID");
        // Use the table.
    now:
      User = "user",
        // Use the table.
Create QueryDescription from a query for a Database table which has more than one shape type
    before:
public async Task MultiGeometryQueryDescription()
      User               = "user",
      QueryDescription pointQueryDescription = database.GetQueryDescription("select Description, SHAPE, UniqueID from MULTIGEOMETRYTEST", "MultiGeometryPoint");
      pointQueryDescription.SetShapeType(GeometryType.Point);
      using (Table pointTable = database.OpenTable(pointQueryDescription))
        //use pointTable
      QueryDescription polygonQueryDescription = database.GetQueryDescription("select Description, SHAPE, UniqueID from MULTIGEOMETRYTEST", "MultiGeometryPolygon");
      polygonQueryDescription.SetShapeType(GeometryType.Polygon);
      using (Table polygonTable = database.OpenTable(polygonQueryDescription))
        //use polygonTable
    now:
      User = "user",
      using (Table pointTable = database.OpenTable(pointQueryDescription)) {
        //use pointTable
      using (Table polygonTable = database.OpenTable(polygonQueryDescription)) {
        //use polygonTable
Create QueryDescription from a query for a SQLite Database table
    before:
public async Task SqliteQueryDescription()
    using (Database database = new Database(new SQLiteConnectionPath(new Uri("Path\\To\\Sqlite\\Database\\USA.sqlite"))))
      QueryDescription washingtonCitiesQueryDescription = database.GetQueryDescription("select OBJECTID, Shape, CITY_FIPS, CITY_NAME, STATE_FIPS, STATE_CITY, TYPE, CAPITAL from main.cities where STATE_NAME='Washington'", "WashingtonCities");
      using (Table washingtonTable = database.OpenTable(washingtonCitiesQueryDescription))
        // Use washingtonTable.
    now:
    using (Database database = new Database(new SQLiteConnectionPath(new Uri("Path\\To\\Sqlite\\Database\\USA.sqlite")))) {
      using (Table washingtonTable = database.OpenTable(washingtonCitiesQueryDescription)) {
Using SQLSyntax to form platform agnostic queries
    before:
public async Task UsingSqlSyntaxToFormPlatformAgnosticQueries()
    using (Geodatabase geodatabase   = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri("C:\\Data\\LocalGovernment.gdb"))))
    using (FeatureClass featureClass = geodatabase.OpenDataset<FeatureClass>("FacilitySite"))
      SQLSyntax sqlSyntax          = geodatabase.GetSQLSyntax();
      string substringFunctionName = sqlSyntax.GetFunctionName(SQLFunction.Substring);
      string upperFunctionName     = sqlSyntax.GetFunctionName(SQLFunction.Upper);
      string substringfunction     = string.Format("{0}({1}(FCODE, 1, 6)) = 'SCHOOL'", upperFunctionName, substringFunctionName);
        WhereClause = substringfunction
      using (Selection selection = featureClass.Select(queryFilter, SelectionType.ObjectID, SelectionOption.Normal))
        // work with the selection.
    now:
    using (FeatureClass featureClass = geodatabase.OpenDataset<FeatureClass>("FacilitySite")) {
      using (Selection selection = featureClass.Select(queryFilter, SelectionType.ObjectID, SelectionOption.Normal)) {
Joining a file geodatabase feature class to an Oracle database query layer feature class with a virtual relationship class
    before:
public async Task JoiningFileGeodatabaseFeatureClassToOracleQueryLayer()
    using (Database database       = new Database(new DatabaseConnectionProperties(EnterpriseDatabaseType.Oracle)
      User               = "user",
    using (FeatureClass leftFeatureClass = geodatabase.OpenDataset<FeatureClass>("Hospital"))
    using (Table rightTable              = database.OpenTable(database.GetQueryDescription("FacilitySite")))
      Field originPrimaryKey      = leftFeatureClass.GetDefinition().GetFields().FirstOrDefault(field => field.Name.Equals("facilityId"));
      Field destinationForeignKey = rightTable.GetDefinition().GetFields().FirstOrDefault(field => field.Name.Equals("hospitalID"));
      VirtualRelationshipClassDescription description = new VirtualRelationshipClassDescription(originPrimaryKey, destinationForeignKey, RelationshipCardinality.OneToOne);
      using (RelationshipClass relationshipClass = leftFeatureClass.RelateTo(rightTable, description))
        JoinDescription joinDescription = new JoinDescription(relationshipClass)
          JoinDirection = JoinDirection.Forward,
          JoinType      = JoinType.LeftOuterJoin
        Join join = new Join(joinDescription);
        using (Table joinedTable = join.GetJoinedTable())
          // Perform operation on joined table.
    now:
    using (Database database = new Database(new DatabaseConnectionProperties(EnterpriseDatabaseType.Oracle) {
      User = "user",
    using (Table rightTable = database.OpenTable(database.GetQueryDescription("FacilitySite"))) {
      using (RelationshipClass relationshipClass = leftFeatureClass.RelateTo(rightTable, description)) {
        JoinDescription joinDescription = new JoinDescription(relationshipClass) {
        using (Table joinedTable = join.GetJoinedTable()) {
Creating a QueryTable using a query which joins two versioned tables in a geodatabase
    before:
public async Task QueryTableJoinWithVersionedData()
    QueryDef queryDef = new QueryDef
      Tables    = "CommunityAddress JOIN MunicipalBoundary on CommunityAddress.Municipality = MunicipalBoundary.Name",
    using (Geodatabase testVersion1Geodatabase = new Geodatabase(new DatabaseConnectionProperties(EnterpriseDatabaseType.Oracle)
      User               = "user",
      Version            = "user.testVersion1"
      QueryTableDescription queryTableDescription = new QueryTableDescription(queryDef)
        Name        = "CommunityAddrJounMunicipalBoundr",
        PrimaryKeys = testVersion1Geodatabase.GetSQLSyntax().QualifyColumnName("CommunityAddress", "OBJECTID")
      // Will be based on testVersion1.
      using (Table queryTable = testVersion1Geodatabase.OpenQueryTable(queryTableDescription))
        // Use queryTable.
    using (Geodatabase testVersion2Geodatabase = new Geodatabase(new DatabaseConnectionProperties(EnterpriseDatabaseType.Oracle)
      User               = "user",
      Version            = "user.testVersion2"
        PrimaryKeys = testVersion2Geodatabase.GetSQLSyntax().QualifyColumnName("CommunityAddress", "OBJECTID")
      // Will be based on testVersion2.
      using (Table queryTable = testVersion2Geodatabase.OpenQueryTable(queryTableDescription))
        // Use queryTable.
    now:
    QueryDef queryDef = new QueryDef {
    using (Geodatabase testVersion1Geodatabase = new Geodatabase(new DatabaseConnectionProperties(EnterpriseDatabaseType.Oracle) {
      User = "user",
      QueryTableDescription queryTableDescription = new QueryTableDescription(queryDef) {
      using (Table queryTable = testVersion1Geodatabase.OpenQueryTable(queryTableDescription)) {
        // Use queryTable.
    using (Geodatabase testVersion2Geodatabase = new Geodatabase(new DatabaseConnectionProperties(EnterpriseDatabaseType.Oracle) {
      User = "user",
      using (Table queryTable = testVersion2Geodatabase.OpenQueryTable(queryTableDescription)) {
        // Use queryTable.
Geometry
Construct a SpatialReference - from a Well Known ID
    before:
// methods need to run on the MCT
  // use the builder constructor
  SpatialReferenceBuilder srBuilder = new SpatialReferenceBuilder(3857);
  SpatialReference sr3857 = srBuilder.ToSpatialReference();
  // or use the convenience method
  SpatialReference sr_3857 = SpatialReferenceBuilder.CreateSpatialReference(3857);
    now:
  SpatialReference sr3857 = null;
  using (SpatialReferenceBuilder srBuilder = new SpatialReferenceBuilder(3857))
Construct a SpatialReference - from a string
    before:
  string wkt = "GEOGCS[\"MyGCS84\",DATUM[\"D_WGS_1984\",SPHEROID[\"WGS_1984\",6378137.0,298.257223563]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Radian\",1.0]]";
  SpatialReferenceBuilder builder = new SpatialReferenceBuilder(wkt);
  SpatialReference sr = builder.ToSpatialReference();
  SpatialReference anotherSR = SpatialReferenceBuilder.CreateSpatialReference(wkt);
    now:
  using (SpatialReferenceBuilder builder = new SpatialReferenceBuilder(wkt))
Construct a SpatialReference with a vertical coordinate system - from Well Known IDs
    before:
// see a list of vertical coordinate systems at http://resources.arcgis.com/en/help/arcgis-rest-api/index.html#/Vertical_coordinate_systems/02r3000000rn000000/
  // 4326 = GCS_WGS_1984
  // 115700 = vertical WGS_1984
  SpatialReferenceBuilder sb = new SpatialReferenceBuilder(4326, 115700);
  SpatialReference sr = sb.ToSpatialReference();
  SpatialReference sr_4326 = SpatialReferenceBuilder.CreateSpatialReference(4326, 115700);
// test creation with wkid, vwkid
    now:
  using (SpatialReferenceBuilder sb = new SpatialReferenceBuilder(4326, 115700))
    // spatialReferenceBuilder properties
    int wkid = sb.Wkid;
    string wkt = sb.Wkt;
    string name = sb.Name;
    int vcsWkid = sb.VcsWkid;
    string vcsWkt = sb.VcsWkt;
Construct a SpatialReference with a verical coordinate system - from a string
    before:
  // custom VCS - use vertical shift of -1.23 instead of 0
  string custom_vWkt = @"VERTCS[""SHD_height"",VDATUM[""Singapore_Height_Datum""],PARAMETER[""Vertical_Shift"",-1.23],PARAMETER[""Direction"",-1.0],UNIT[""Meter"",1.0]]";
  SpatialReferenceBuilder sb = new SpatialReferenceBuilder(4326, custom_vWkt);
  int wkid = sr.Wkid;             // wkid = 4326
  int vert_wkid = sr.VcsWkid;     // vert_wkid = 0
  string vert_wkt = sr.VcsWkt;    // vert_wkt = custom_vWkt
  SpatialReference sr_4326 = SpatialReferenceBuilder.CreateSpatialReference(4326, custom_vWkt);
    now:
  using (SpatialReferenceBuilder sb = new SpatialReferenceBuilder(4326, custom_vWkt))
    bool hasVcs = sr.HasVcs;
SpatialReference Properties
    before:
  int wkid = srBuilder.Wkid;
  string wkt = srBuilder.Wkt;
  string name = srBuilder.Name;
  double xyScale = srBuilder.XYScale;
  double xyTolerance = srBuilder.XYTolerance;
  double xyResolution = srBuilder.XYResolution;
  Unit unit = srBuilder.Unit;
  double zScale = srBuilder.ZScale;
  double zTolerance = srBuilder.ZTolerance;
  Unit zUnit = srBuilder.ZUnit;
  double mScale = srBuilder.MScale;
  double mTolerance = srBuilder.MTolerance;
  double falseX = srBuilder.FalseX;
  double falseY = srBuilder.FalseY;
  double falseZ = srBuilder.FalseZ;
  double falseM = srBuilder.FalseM;
  // get the spatial reference
  // spatial reference properties
  wkid = sr3857.Wkid;
  wkt = sr3857.Wkt;
  name = sr3857.Name;
  xyScale = sr3857.XYScale;
  xyTolerance = sr3857.XYTolerance;
  xyResolution = sr3857.XYResolution;
  unit = sr3857.Unit;
  zScale = sr3857.ZScale;
  zTolerance = sr3857.ZTolerance;
  zUnit = sr3857.ZUnit;
  mScale = sr3857.MScale;
  mTolerance = sr3857.MTolerance;
  falseX = sr3857.FalseX;
  falseY = sr3857.FalseY;
  falseZ = sr3857.FalseZ;
  falseM = sr3857.FalseM;
    now:
    wkid = sr3857.Wkid;
    wkt = sr3857.Wkt;
    name = sr3857.Name;
    unit = sr3857.Unit;
    bool hasVcs = sr3857.HasVcs;
Builder Properties
    before:
  // list of points
  List<MapPoint> points = new List<MapPoint>
    MapPointBuilder.CreateMapPoint(0, 0, 2, 3, 1),
    MapPointBuilder.CreateMapPoint(1, 1, 5, 6),
    MapPointBuilder.CreateMapPoint(2, 1, 6),
    MapPointBuilder.CreateMapPoint(0, 0)
  // will have attributes because it is created with convenience method
  Polyline polylineWithAttrs = PolylineBuilder.CreatePolyline(points);
  bool hasZ = polylineWithAttrs.HasZ;          // hasZ = true
  bool hasM = polylineWithAttrs.HasM;          // hasM = true
  bool hasID = polylineWithAttrs.HasID;        // hasID = true
  // will not have attributes because it is passed something other than an attributed polyline
  PolylineBuilder polylineB = new PolylineBuilder(points);
  hasZ = polylineB.HasZ;                      // hasZ = false
  hasM = polylineB.HasM;                      // hasM = false
  hasID = polylineB.HasID;                    // hasID = false
  // will have attributes because it is passed an attributed polyline
  polylineB = new PolylineBuilder(polylineWithAttrs);
  hasZ = polylineB.HasZ;                      // hasZ = true
  hasM = polylineB.HasM;                      // hasM = true
  hasID = polylineB.HasID;                    // hasID = true
  Polygon polygonWithAttrs = PolygonBuilder.CreatePolygon(points);
  hasZ = polygonWithAttrs.HasZ;               // hasZ = true
  hasM = polygonWithAttrs.HasM;               // hasM = true
  hasID = polygonWithAttrs.HasID;             // hasID = true
  // will not have attributes because it is passed something other than an attributed polygon
  PolygonBuilder polygonB = new PolygonBuilder(points);
  hasZ = polygonB.HasZ;                       // hasZ = false
  hasM = polygonB.HasM;                       // hasM = false
  hasID = polygonB.HasID;                     // hasID = false
  // will have attributes because it is passed an attributed polygon
  polygonB = new PolygonBuilder(polygonWithAttrs);
  hasZ = polygonB.HasZ;                       // hasZ = true
  hasM = polygonB.HasM;                       // hasM = true
  hasID = polygonB.HasID;                     // hasID = true
    now:
  // list of points
  using (PolylineBuilder polylineB = new PolylineBuilder(points))
  using (PolylineBuilder polylineB = new PolylineBuilder(polylineWithAttrs))
  using (PolygonBuilder polygonB = new PolygonBuilder(points))
  using (PolygonBuilder polygonB = new PolygonBuilder(polygonWithAttrs))
Construct a MapPoint
    before:
  // create a 3d point with M
  MapPointBuilder mb = new MapPointBuilder(1.0, 2.0, 3.0, 4.0);
  MapPoint ptWithM = mb.ToGeometry();
  MapPoint clone = ptWithM.Clone() as MapPoint;
  // or use the convenience methods
  MapPoint anotherPt = MapPointBuilder.CreateMapPoint(1.0, 2.0, 3.0, 4.0);
  MapPoint anotherM = MapPointBuilder.CreateMapPoint(ptWithM);
    now:
  using (MapPointBuilder mb = new MapPointBuilder(1.0, 2.0, 3.0, 4.0))
MapPoint Builder Properties
    before:
  MapPointBuilder mb = new MapPointBuilder(1.0, 2.0, 3.0);
  bool hasZ = mb.HasZ;          // hasZ = true
  bool hasM = mb.HasM;          // hasM = false
  bool hasID = mb.HasID;        // hasID = false
  MapPoint pt = mb.ToGeometry();
  double x = pt.X;                  // x = 1.0
  double y = pt.Y;                  // y = 2.0
  double z = pt.Z;                  // z = 3.0
  double m = pt.M;                  // m = Nan
  int ID = pt.ID;                   // ID = 0
  hasZ = pt.HasZ;                   // hasZ = true
  hasM = pt.HasM;                   // hasM = false
  hasID = pt.HasID;                 // hasID = false
  bool isEmpty = pt.IsEmpty;        // isEmpty = false
  MapPoint pt2 = MapPointBuilder.CreateMapPoint(pt);
  hasZ = pt2.HasZ;            // hasZ = true
  hasM = pt2.HasM;            // hasM = false
  hasID = pt2.HasID;          // hasID = false
    now:
  using (MapPointBuilder mb = new MapPointBuilder(1.0, 2.0, 3.0))
Construct a Polyline - from an enumeration of MapPoints
    before:
// methods need to run on MCT
  MapPoint startPt = MapPointBuilder.CreateMapPoint(1.0, 1.0);
  MapPoint endPt = MapPointBuilder.CreateMapPoint(2.0, 1.0);
  List<MapPoint> list = new List<MapPoint>();
  list.Add(startPt);
  list.Add(endPt);
  PolylineBuilder pb = new PolylineBuilder(list);
  pb.SpatialReference = SpatialReferences.WGS84;
  Polyline polyline1 = pb.ToGeometry();
  Polyline polyline2 = PolylineBuilder.CreatePolyline(list, SpatialReferences.WGS84);
    now:
  list.Add(startPt);
  list.Add(endPt);
  using (PolylineBuilder pb = new PolylineBuilder(list))
Get the points of a Polyline
    before:
// get the points as a readonly Collection
ReadOnlyPointCollection pts = polyline.Points;
int numPts = polyline.PointCount;
// get an enumeration of the points
IEnumerator<MapPoint> enumPts = polyline.Points.GetEnumerator();
// get the point coordinates as a readonly list
IReadOnlyList<Coordinate> coordinates = polyline.CopyCoordinatesToList();
    now:
IReadOnlyList<Coordinate2D> coordinates = polyline.Copy2DCoordinatesToList();
Reverse the order of points in a Polyline
    before:
  PolylineBuilder polylineBuilder = new PolylineBuilder(polyline);
  polylineBuilder.ReverseOrientation();
  Polyline reversedPolyline = polylineBuilder.ToGeometry();
    now:
  using (PolylineBuilder polylineBuilder = new PolylineBuilder(polyline))
Build a multi-part Polyline
    before:
  List<MapPoint> firstPoints = new List<MapPoint>();
  firstPoints.Add(MapPointBuilder.CreateMapPoint(1.0, 1.0));
  firstPoints.Add(MapPointBuilder.CreateMapPoint(1.0, 2.0));
  firstPoints.Add(MapPointBuilder.CreateMapPoint(2.0, 2.0));
  firstPoints.Add(MapPointBuilder.CreateMapPoint(2.0, 1.0));
  List<MapPoint> nextPoints = new List<MapPoint>();
  nextPoints.Add(MapPointBuilder.CreateMapPoint(11.0, 1.0));
  nextPoints.Add(MapPointBuilder.CreateMapPoint(11.0, 2.0));
  nextPoints.Add(MapPointBuilder.CreateMapPoint(12.0, 2.0));
  nextPoints.Add(MapPointBuilder.CreateMapPoint(12.0, 1.0));
  PolylineBuilder pBuilder = new PolylineBuilder(firstPoints);
  pBuilder.AddPart(nextPoints);
  Polyline p = pBuilder.ToGeometry();
  // polyline p has 2 parts
  pBuilder.RemovePart(0);
  // polyline p has 1 part
    now:
  using (PolylineBuilder pBuilder = new PolylineBuilder(firstPoints))
Split Polyline at distance
    before:
  // create list of points
  list.Add(startPt);
  list.Add(endPt);
  // use the PolylineBuilder as we wish to manipulate the geometry
  PolylineBuilder polylineBuilder = new PolylineBuilder(list);
  // split at a distance 0.75
  polylineBuilder.SplitAtDistance(0.75, false);
  // get the polyline
  Polyline p = polylineBuilder.ToGeometry();
  // polyline p should have 3 points  (1,1), (1.75, 1), (2,1)
  // add another path
  MapPoint p1 = MapPointBuilder.CreateMapPoint(4.0, 1.0);
  MapPoint p2 = MapPointBuilder.CreateMapPoint(6.0, 1.0);
  MapPoint p3 = MapPointBuilder.CreateMapPoint(7.0, 1.0);
  List<MapPoint> pts = new List<MapPoint>();
  pts.Add(p1);
  pts.Add(p2);
  pts.Add(p3);
  polylineBuilder.AddPart(pts);
  // polyline p has 2 parts.  Each part has 3 points
  // split the 2nd path half way - dont create a new path
  polylineBuilder.SplitPartAtDistance(1, 0.5, true, false);
  // polyline p still has 2 parts; but now has 7 points
    now:
  list.Add(startPt);
  list.Add(endPt);
  using (PolylineBuilder polylineBuilder = new PolylineBuilder(list))
    // get the polyline
    // add another path
    pts.Add(p1);
    pts.Add(p2);
    pts.Add(p3);
Construct a Polygon - from an enumeration of MapPoints
    before:
  MapPoint pt1 = MapPointBuilder.CreateMapPoint(1.0, 1.0);
  MapPoint pt2 = MapPointBuilder.CreateMapPoint(1.0, 2.0);
  MapPoint pt3 = MapPointBuilder.CreateMapPoint(2.0, 2.0);
  MapPoint pt4 = MapPointBuilder.CreateMapPoint(2.0, 1.0);
  list.Add(pt1);
  list.Add(pt2);
  list.Add(pt3);
  list.Add(pt4);
  PolygonBuilder pb = new PolygonBuilder(list);
  Polygon polygon = pb.ToGeometry();
  Polygon anotherPolygon = PolygonBuilder.CreatePolygon(list, SpatialReferences.WGS84);
    now:
  list.Add(pt1);
  list.Add(pt2);
  list.Add(pt3);
  list.Add(pt4);
  using (PolygonBuilder pb = new PolygonBuilder(list))
Get the points of a Polygon
    before:
ReadOnlyPointCollection pts = poly.Points;
IEnumerator<MapPoint> enumPts = poly.Points.GetEnumerator();
IReadOnlyList<Coordinate> coordinates = poly.CopyCoordinatesToList();
    now:
IReadOnlyList<Coordinate3D> coordinates = poly.Copy3DCoordinatesToList();
Build a donut polygon
    before:
  List<Coordinate2D> outerCoordinates = new List<Coordinate2D>();
  outerCoordinates.Add(new Coordinate2D(10.0, 10.0));
  outerCoordinates.Add(new Coordinate2D(10.0, 20.0));
  outerCoordinates.Add(new Coordinate2D(20.0, 20.0));
  outerCoordinates.Add(new Coordinate2D(20.0, 10.0));
  // use the PolygonBuilder as we wish to manipulate the parts
  PolygonBuilder pb = new PolygonBuilder(outerCoordinates);
  Polygon donut = pb.ToGeometry();
  double area = donut.Area;       // area = 100
  // define the inner polygon as anti-clockwise
  List<Coordinate2D> innerCoordinates = new List<Coordinate2D>();
  innerCoordinates.Add(new Coordinate2D(13.0, 13.0));
  innerCoordinates.Add(new Coordinate2D(17.0, 13.0));
  innerCoordinates.Add(new Coordinate2D(17.0, 17.0));
  innerCoordinates.Add(new Coordinate2D(13.0, 17.0));
  pb.AddPart(innerCoordinates);
  area = donut.Area;    // area = 84.0
  area = GeometryEngine.Area(donut);    // area = 84.0
    now:
  using (PolygonBuilder pb = new PolygonBuilder(outerCoordinates))
    area = GeometryEngine.Instance.Area(donut);    // area = 84.0
Construct an Envelope
    before:
  MapPoint minPt = MapPointBuilder.CreateMapPoint(1.0, 1.0);
  MapPoint maxPt = MapPointBuilder.CreateMapPoint(2.0, 2.0);
  EnvelopeBuilder ev = new EnvelopeBuilder(minPt, maxPt);
  Envelope env = ev.ToGeometry();
    now:
  using (EnvelopeBuilder ev = new EnvelopeBuilder(minPt, maxPt))
Expand an Envelope
    before:
  Envelope envelope = EnvelopeBuilder.CreateEnvelope(100.0, 100.0, 500.0, 500.0);
  // shrink the envelope by 50%
  Envelope result = envelope.Expand(0.5, 0.5, true);
    now:
  // or use the builder
  using (EnvelopeBuilder eBuilder = new EnvelopeBuilder(100.0, 100.0, 500.0, 500.0))
    // shrink by 50%
    eBuilder.Expand(0.5, 0.5, true);
    result = eBuilder.ToGeometry();
Construct a Multipoint - from an enumeration of MapPoints
    before:
  list.Add(MapPointBuilder.CreateMapPoint(1.0, 1.0));
  list.Add(MapPointBuilder.CreateMapPoint(1.0, 2.0));
  list.Add(MapPointBuilder.CreateMapPoint(2.0, 2.0));
  list.Add(MapPointBuilder.CreateMapPoint(2.0, 1.0));
  MultipointBuilder mpb = new MultipointBuilder(list);
  Multipoint mPt = mpb.ToGeometry();
  Multipoint multiPoint = MultipointBuilder.CreateMultipoint(list);
    now:
  using (MultipointBuilder mpb = new MultipointBuilder(list))
Modify the points of a Multipoint
    before:
  // assume a multiPoint has been built from 4 points
  // the modified multiPoint will have the first point removed and the last point moved
  MultipointBuilder mpb = new MultipointBuilder(multiPt);
  // remove the first point
  mpb.RemovePoint(0);
  // modify the coordinates of the last point
  MapPoint pt = mpb.GetMapPoint(mpb.PointCount-1);
  mpb.RemovePoint(mpb.PointCount - 1);
  MapPoint newPt = MapPointBuilder.CreateMapPoint(pt.X + 1.0, pt.Y + 2.0);
  mpb.Add(newPt);
  Multipoint modifiedMultiPoint = mpb.ToGeometry();
    now:
  using (MultipointBuilder mpb = new MultipointBuilder(multiPt))
    mpb.RemovePoint(0);
    MapPoint pt = mpb.GetMapPoint(mpb.PointCount - 1);
    mpb.Add(newPt);
Construct a LineSegment using two MapPoints
    before:
  LineBuilder lb = new LineBuilder(startPt, endPt);
  LineSegment line = lb.ToSegment();
  LineSegment anotherLine = LineBuilder.CreateLineSegment(startPt, endPt);
    now:
  using (LineBuilder lb = new LineBuilder(startPt, endPt))
Construct a Cubic Bezier - from Coordinates
    before:
// builders need to run on the MCT
  Coordinate startPt = new Coordinate(1.0, 1.0, 3.0);
  Coordinate endPt = new Coordinate(2.0, 2.0, 3.0);
  Coordinate2D ctrl1Pt = new Coordinate2D(1.0, 2.0);
  Coordinate2D ctrl2Pt = new Coordinate2D(2.0, 1.0);
  CubicBezierBuilder cbb = new CubicBezierBuilder(startPt, ctrl1Pt, ctrl2Pt, endPt, SpatialReferences.WGS84);
  CubicBezierSegment bezier = cbb.ToSegment();
  CubicBezierSegment anotherBezier = CubicBezierBuilder.CreateCubicBezierSegment(startPt, ctrl1Pt, ctrl2Pt, endPt, SpatialReferences.WGS84);
    now:
  MapPoint startPt = MapPointBuilder.CreateMapPoint(1.0, 1.0, 3.0);
  MapPoint endPt = MapPointBuilder.CreateMapPoint(2.0, 2.0, 3.0);
  using (CubicBezierBuilder cbb = new CubicBezierBuilder(startPt, ctrl1Pt, ctrl2Pt, endPt))
Construct a Cubic Bezier - from MapPoints
    before:
  MapPoint startPt = MapPointBuilder.CreateMapPoint(1.0, 1.0, SpatialReferences.WGS84);
  MapPoint endPt = MapPointBuilder.CreateMapPoint(2.0, 2.0, SpatialReferences.WGS84);
  MapPoint ctrl1Pt = MapPointBuilder.CreateMapPoint(1.0, 2.0, SpatialReferences.WGS84);
  MapPoint ctrl2Pt = MapPointBuilder.CreateMapPoint(2.0, 1.0, SpatialReferences.WGS84);
  CubicBezierBuilder cbb = new CubicBezierBuilder(startPt, ctrl1Pt, ctrl2Pt, endPt);
  CubicBezierSegment anotherBezier = CubicBezierBuilder.CreateCubicBezierSegment(startPt, ctrl1Pt, ctrl2Pt, endPt);
    now:
Construct a Cubic Bezier - from an enumeration of MapPoints
    before:
  List<MapPoint> listMapPoints = new List<MapPoint>();
  listMapPoints.Add(startPt);
  listMapPoints.Add(ctrl1Pt);
  listMapPoints.Add(ctrl2Pt);
  listMapPoints.Add(endPt);
  CubicBezierBuilder cbb = new CubicBezierBuilder(listMapPoints);
  CubicBezierSegment anotherBezier = CubicBezierBuilder.CreateCubicBezierSegment(listMapPoints);
    now:
  using (CubicBezierBuilder cbb = new CubicBezierBuilder(listMapPoints))
Cubic Bezier Builder Properties
    before:
  // retrieve the bezier curve's control points
  CubicBezierBuilder cbb = new CubicBezierBuilder(bezierSegment);
  MapPoint startPt = cbb.StartPoint;
  Coordinate2D ctrlPt1 = cbb.ControlPoint1;
  Coordinate2D ctrlPt2 = cbb.ControlPoint2;
  MapPoint endPt = cbb.EndPoint;
  // or use the QueryCoords method
  cbb.QueryCoords(out startPt, out ctrlPt1, out ctrlPt2, out endPt);
    now:
  using (CubicBezierBuilder cbb = new CubicBezierBuilder(bezierSegment))
Construct a Circular Arc - using an interior point
    before:
  // Construct a circular arc from (2, 1) to (1, 2) with interior pt (1 + sqrt(2)/2, 1 + sqrt(2)/2).
  Coordinate fromPt = new Coordinate(2, 1);
  Coordinate toPt = new Coordinate(1, 2);
  Coordinate2D interiorPt = new Coordinate2D(1 + Math.Sqrt(2) / 2, 1 + Math.Sqrt(2) / 2);
  EllipticArcBuilder cab = new EllipticArcBuilder(fromPt.ToMapPoint(), toPt.ToMapPoint(), interiorPt);
  EllipticArcSegment circularArc = cab.ToSegment();
  EllipticArcSegment anotherCircularArc = EllipticArcBuilder.CreateEllipticArcSegment(fromPt.ToMapPoint(), toPt.ToMapPoint(), interiorPt);
    now:
  MapPoint fromPt = MapPointBuilder.CreateMapPoint(2, 1);
  MapPoint toPt = MapPointBuilder.CreateMapPoint(1, 2);
  using (EllipticArcBuilder cab = new EllipticArcBuilder(fromPt, toPt, interiorPt))
  EllipticArcSegment anotherCircularArc = EllipticArcBuilder.CreateEllipticArcSegment(fromPt, toPt, interiorPt);
Construct a Circular Arc - using a chord length and bearing
    before:
  // Construct a circular arc counterclockwise from (2, 1) to (1, 2) such that the embedded
  // circle has center point at (1, 1) and radius = 1
  MapPoint fromPt = MapPointBuilder.CreateMapPoint(2, 1, SpatialReferences.WGS84);
  double chordLength = Math.Sqrt(2);
  double chordBearing = 3 * Math.PI / 4;
  double radius = 1;
  esriArcOrientation orientation = esriArcOrientation.esriArcCounterClockwise;
  MinorOrMajor minorOrMajor = MinorOrMajor.Minor;
  EllipticArcBuilder cab = new EllipticArcBuilder(fromPt, chordLength, chordBearing, radius, orientation, minorOrMajor);
  EllipticArcSegment anotherCircularArc = EllipticArcBuilder.CreateEllipticArcSegment(fromPt, chordLength, chordBearing, radius, orientation, minorOrMajor);
    now:
  double radius = 1;
  using (EllipticArcBuilder cab = new EllipticArcBuilder(fromPt, chordLength, chordBearing, radius, orientation, minorOrMajor))
Construct a Circular Arc - using a center point and orientation
    before:
  // with center point at (1, 1) and orientation counterclockwise.
  Coordinate2D centerPtCoord = new Coordinate2D(1, 1);
  EllipticArcBuilder cab = new EllipticArcBuilder(fromPt.ToMapPoint(), toPt.ToMapPoint(), centerPtCoord, esriArcOrientation.esriArcCounterClockwise);
  EllipticArcSegment anotherCircularArc = EllipticArcBuilder.CreateEllipticArcSegment(fromPt.ToMapPoint(), toPt.ToMapPoint(), centerPtCoord, esriArcOrientation.esriArcCounterClockwise);
    now:
ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() =>
    using (EllipticArcBuilder cab = new EllipticArcBuilder(fromPt, toPt, centerPtCoord, esriArcOrientation.esriArcCounterClockwise))
    EllipticArcSegment anotherCircularArc = EllipticArcBuilder.CreateEllipticArcSegment(fromPt, toPt, centerPtCoord, esriArcOrientation.esriArcCounterClockwise);
Construct a Circle
    before:
  // Construct a circle with center at (-1,-1), radius = 2, and oriented clockwise.
  Coordinate2D centerPtCoord = new Coordinate2D(-1, -1);
  EllipticArcBuilder builder = new EllipticArcBuilder(centerPtCoord, 2, esriArcOrientation.esriArcClockwise);
  EllipticArcSegment circle = builder.ToSegment();
  EllipticArcSegment anotherCircle = EllipticArcBuilder.CreateEllipticArcSegment(centerPtCoord, 2, esriArcOrientation.esriArcClockwise);
    now:
  using (EllipticArcBuilder builder = new EllipticArcBuilder(centerPtCoord, 2, esriArcOrientation.esriArcClockwise))
    // circle.IsCircular = true
    // circle.IsCounterClockwise = false
    // circle.IsMinor = false
    double startAngle, centralAngle, rotationAngle;
    double semiMajor, semiMinor;
    Coordinate2D actualCenterPt;
    circle.QueryCoords(out actualCenterPt, out startAngle, out centralAngle, out rotationAngle, out semiMajor, out semiMinor);
    // semiMajor = 2.0
    // semiMinor = 2.0
    // startAngle = PI/2
    // centralAngle = -2*PI
    // rotationAngle = 0
    // endAngle = PI/2
Construct an Ellipse
    before:
  // Construct an ellipse centered at (1, 2) with rotationAngle = -pi/6,
  // semiMajorAxis = 5, minorMajorRatio = 0.2, oriented clockwise
  Coordinate2D centerPt = new Coordinate2D(1, 2);
  EllipticArcBuilder builder = new EllipticArcBuilder(centerPt, -1 * Math.PI / 6, 5, 0.2, esriArcOrientation.esriArcClockwise);
  EllipticArcSegment ellipse = builder.ToSegment();
  EllipticArcSegment anotherEllipse = EllipticArcBuilder.CreateEllipticArcSegment(centerPt, -1 * Math.PI / 6, 5, 0.2, esriArcOrientation.esriArcClockwise);
    now:
  using (EllipticArcBuilder builder = new EllipticArcBuilder(centerPt, -1 * Math.PI / 6, 5, 0.2, esriArcOrientation.esriArcClockwise))
Elliptic Arc Builder Properties
    before:
  // retrieve the curve's control points
  EllipticArcBuilder builder = new EllipticArcBuilder(arcSegment);
  MapPoint startPt = builder.StartPoint;
  MapPoint endPt = builder.EndPoint;
  Coordinate2D centerPt = builder.CenterPoint;
  bool isCircular = builder.IsCircular;
  bool isMinor = builder.IsMinor;
    now:
  using (EllipticArcBuilder builder = new EllipticArcBuilder(arcSegment))
    double startAngle = builder.StartAngle;
    double endAngle = builder.EndAngle;
    double centralAngle = builder.CentralAngle;
    double rotationAngle = builder.RotationAngle;
Get the outermost rings of a polygon
    before:
public Polygon GetOutermostRings(Polygon inputPolygon)
  if (inputPolygon == null || inputPolygon.IsEmpty)
    return null;
  PolygonBuilder outerRings = new PolygonBuilder();
  List<Polygon> internalRings = new List<Polygon>();
  // explode the parts of the polygon into a list of individual geometries
  // see the "Get the individual parts of a multipart feature" snippet for MultipartToSinglePart method defintion
  var parts = MultipartToSinglePart(inputPolygon);
  // get an enumeration of clockwise geometries (area > 0) ordered by the area
  var clockwiseParts = parts.Where(geom => ((Polygon)geom).Area > 0).OrderByDescending(geom => ((Polygon)geom).Area);
  // for each of the exterior rings
  foreach (var part in clockwiseParts)
    // add the first (the largest) ring into the internal collection
    if (internalRings.Count == 0)
      internalRings.Add(part as Polygon);
    // use flag to indicate if current part is within the already selection polygons
    bool isWithin = false;
    foreach (var item in internalRings)
      if (GeometryEngine.Within(part, item))
        isWithin = true;
    // if the current polygon is not within any polygon of the internal collection
    // then it is disjoint and needs to be added to
    if (isWithin == false)
  // now assemble a new polygon geometry based on the internal polygon collection
  foreach (var ring in internalRings)
    outerRings.AddParts(ring.Parts);
  // return the final geometry of the outer rings
  return outerRings.ToGeometry();
    now:
    return null;
      if (GeometryEngine.Instance.Within(part, item))
        isWithin = true;
  using (PolygonBuilder outerRings = new PolygonBuilder())
Retrieve Geometry from Geodatabase
    before:
  try
    // open a gdb
    ArcGIS.Core.Data.Geodatabase gdb = new ArcGIS.Core.Data.Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"c:\Temp\MyDatabase.gdb")));
    //Open a featureClass
    ArcGIS.Core.Data.FeatureClass featureClass = gdb.OpenDataset<ArcGIS.Core.Data.FeatureClass>("Polygon");
    // find a field
    ArcGIS.Core.Data.FeatureClassDefinition featureClassDefinition = featureClass.GetDefinition();
    int fldIndex = featureClassDefinition.FindField("SomeField");
    if (fldIndex == -1)
      return;
    ArcGIS.Core.Data.QueryFilter filter = new ArcGIS.Core.Data.QueryFilter
      WhereClause = "OBJECTID = 6"
    // get the row
    ArcGIS.Core.Data.RowCursor rowCursor = featureClass.Search(filter, false);
      long oid = rowCursor.Current.GetObjectID();
      // get the shape from the row
      ArcGIS.Core.Data.Feature feature = rowCursor.Current as ArcGIS.Core.Data.Feature;
      Polygon polygon = feature.GetShape() as Polygon;
      // get the attribute from the row (assume it's a double field)
      double value = (double)rowCursor.Current.GetOriginalValue(fldIndex);
      // do something here
  catch (Exception ex)
    // error - handle appropriately
    now:
  try
    // open a gdb
    using (ArcGIS.Core.Data.Geodatabase gdb = new ArcGIS.Core.Data.Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"c:\Temp\MyDatabase.gdb"))))
      using (ArcGIS.Core.Data.FeatureClass featureClass = gdb.OpenDataset<ArcGIS.Core.Data.FeatureClass>("Polygon"))
        // find a field
        if (fldIndex == -1)
          return;
        // get the row
        using (ArcGIS.Core.Data.RowCursor rowCursor = featureClass.Search(filter, false))
Import and Export Geometries to Well Known Text
    before:
  // create a point with z, m
  MapPoint point = MapPointBuilder.CreateMapPoint(100, 200, 300, 400, SpatialReferences.WebMercator);
  // set the flags
  WKTExportFlags exportFlags = WKTExportFlags.wktExportDefaults;
  WKTImportFlags importFlags = WKTImportFlags.wktImportDefaults;
  // export and import
  string wktString = GeometryEngine.ExportToWKT(exportFlags, point);
  MapPoint importPoint = GeometryEngine.ImportFromWKT(importFlags, wktString, SpatialReferences.WebMercator) as MapPoint;
  double x = importPoint.X;       // x = 100
  double y = importPoint.Y;       // y = 200
  bool hasZ = importPoint.HasZ;   // hasZ = true
  double z = importPoint.Z;       // z = 300
  bool hasM = importPoint.HasM;   // hasM = true
  double m = importPoint.M;       // m = 400
  // export without z
  WKTExportFlags exportFlagsNoZ = WKTExportFlags.wktExportStripZs;
  hasZ = importPoint.HasZ;  // hasZ = false
  z = importPoint.Z;        // z = Nan
  // export without m
  WKTExportFlags exportFlagsNoM = WKTExportFlags.wktExportStripMs;
  hasM = importPoint.HasM;  // hasM = false
  m = importPoint.M;        // m = Nan
  // export without z, m
  wktString = GeometryEngine.ExportToWKT(exportFlagsNoZ | exportFlagsNoM, point);
    now:
  // set the flags
  string wktString = GeometryEngine.Instance.ExportToWKT(exportFlags, point);
  MapPoint importPoint = GeometryEngine.Instance.ImportFromWKT(importFlags, wktString, SpatialReferences.WebMercator) as MapPoint;
  // export without z
  wktString = GeometryEngine.Instance.ExportToWKT(exportFlagsNoZ, point);
  z = importPoint.Z;        // z = 0
  // export without m
  wktString = GeometryEngine.Instance.ExportToWKT(exportFlagsNoM, point);
  wktString = GeometryEngine.Instance.ExportToWKT(exportFlagsNoZ | exportFlagsNoM, point);
Import and Export Geometries to Well Known Binary
    before:
  // create a polyline
  List<Coordinate2D> coords = new List<Coordinate2D>
    new Coordinate2D(0, 0),
    new Coordinate2D(0, 1),
    new Coordinate2D(1, 1),
    new Coordinate2D(1, 0)
  Polyline polyline = PolylineBuilder.CreatePolyline(coords, SpatialReferences.WGS84);
  WKBExportFlags exportFlags = WKBExportFlags.wkbExportDefaults;
  WKBImportFlags importFlags = WKBImportFlags.wkbImportDefaults;
  byte[] buffer = GeometryEngine.ExportToWKB(exportFlags, polyline);
  Geometry geometry = GeometryEngine.ImportFromWKB(importFlags, buffer, SpatialReferences.WGS84);
  Polyline importPolyline = geometry as Polyline;
  // alternatively, determine the size for the buffer
  int bufferSize = GeometryEngine.GetWKBSize(exportFlags, polyline);
  buffer = new byte[bufferSize];
  // export
  bufferSize = GeometryEngine.ExportToWKB(exportFlags, polyline, ref buffer);
  // import
  importPolyline = GeometryEngine.ImportFromWKB(importFlags, buffer, SpatialReferences.WGS84) as Polyline;
    now:
  byte[] buffer = GeometryEngine.Instance.ExportToWKB(exportFlags, polyline);
  Geometry geometry = GeometryEngine.Instance.ImportFromWKB(importFlags, buffer, SpatialReferences.WGS84);
  int bufferSize = GeometryEngine.Instance.GetWKBSize(exportFlags, polyline);
  // export
  bufferSize = GeometryEngine.Instance.ExportToWKB(exportFlags, polyline, ref buffer);
  // import
  importPolyline = GeometryEngine.Instance.ImportFromWKB(importFlags, buffer, SpatialReferences.WGS84) as Polyline;
Import and Export Geometries to EsriShape
    before:
  // create an envelope
  List<Coordinate> coordsZM = new List<Coordinate>
    new Coordinate(1001, 1002, 1003, 1004),
    new Coordinate(2001, 2002, Double.NaN, 2004),
    new Coordinate(3001, -3002, 3003, 3004),
    new Coordinate(1001, -4002, 4003, 4004)
  Envelope envelope = EnvelopeBuilder.CreateEnvelope(coordsZM[0], coordsZM[2], SpatialReferences.WGS84);
  EsriShapeExportFlags exportFlags = EsriShapeExportFlags.esriShapeExportDefaults;
  EsriShapeImportFlags importFlags = EsriShapeImportFlags.esriShapeImportDefaults;
  byte[] buffer = GeometryEngine.ExportToEsriShape(exportFlags, envelope);
  Polygon importedPolygon = GeometryEngine.ImportFromEsriShape(importFlags, buffer, envelope.SpatialReference) as Polygon;
  Envelope importedEnvelope = importedPolygon.Extent;
  // export without z,m
  buffer = GeometryEngine.ExportToEsriShape(EsriShapeExportFlags.esriShapeExportStripZs | EsriShapeExportFlags.esriShapeExportStripMs, envelope);
  importedPolygon = GeometryEngine.ImportFromEsriShape(importFlags, buffer, SpatialReferences.WGS84) as Polygon;
  bool hasZ = importedEnvelope.HasZ;      // hasZ = false
  bool hasM = importedEnvelope.HasM;      // hasM = false
  // export with shapeSize
  int bufferSize = GeometryEngine.GetEsriShapeSize(exportFlags, envelope);
  bufferSize = GeometryEngine.ExportToEsriShape(exportFlags, envelope, ref buffer);
    now:
  List<MapPoint> coordsZM = new List<MapPoint>
    MapPointBuilder.CreateMapPoint(1001, 1002, 1003, 1004),
    MapPointBuilder.CreateMapPoint(2001, 2002, Double.NaN, 2004),
    MapPointBuilder.CreateMapPoint(3001, -3002, 3003, 3004),
    MapPointBuilder.CreateMapPoint(1001, -4002, 4003, 4004)
  byte[] buffer = GeometryEngine.Instance.ExportToEsriShape(exportFlags, envelope);
  Polygon importedPolygon = GeometryEngine.Instance.ImportFromEsriShape(importFlags, buffer, envelope.SpatialReference) as Polygon;
  buffer = GeometryEngine.Instance.ExportToEsriShape(EsriShapeExportFlags.esriShapeExportStripZs | EsriShapeExportFlags.esriShapeExportStripMs, envelope);
  importedPolygon = GeometryEngine.Instance.ImportFromEsriShape(importFlags, buffer, SpatialReferences.WGS84) as Polygon;
  int bufferSize = GeometryEngine.Instance.GetEsriShapeSize(exportFlags, envelope);
  bufferSize = GeometryEngine.Instance.ExportToEsriShape(exportFlags, envelope, ref buffer);
  // or use the envelope and envelopeBuilder classes
  buffer = envelope.ToEsriShape();
  // buffer represents a polygon as there is not an envelope Esri shape buffer
  // EnvelopeBuilder.FromEsriShape takes a polygon Esri shape buffer and returns the extent of the polygon.
  importedEnvelope = EnvelopeBuilder.FromEsriShape(buffer);
Import and Export Geometries to JSON
    before:
  // MapPoint
  MapPoint point = MapPointBuilder.CreateMapPoint(1, 2, SpatialReferences.WGS84);
  string inputString = "{\"x\":1,\"y\":2,\"spatialReference\":{\"wkid\":4326,\"latestWkid\":4326}}";
  Geometry geometry = GeometryEngine.ImportFromJSON(JSONImportFlags.jsonImportDefaults, inputString);
  MapPoint importPoint = geometry as MapPoint;
  // importPoint = 1, 2
  // importPoint.SpatialReference.WKid = 4326
  string outputString = GeometryEngine.ExportToJSON(JSONExportFlags.jsonExportDefaults, point);
  // outputString =  "{\"x\":1,\"y\":2,\"spatialReference\":{\"wkid\":4326,\"latestWkid\":4326}}"
  inputString = "{\"spatialReference\":{\"wkid\":4326},\"z\":3,\"m\":4,\"x\":1,\"y\":2}";
  point = GeometryEngine.ImportFromJSON(JSONImportFlags.jsonImportDefaults, inputString) as MapPoint;
  // point.HasM = true
  // point.HasZ = true
  // point.M = 4
  // point.Z = 3
  // skip spatial reference
  outputString = GeometryEngine.ExportToJSON(JSONExportFlags.jsonExportSkipCRS, point);
  // outputString = "{\"x\":1,\"y\":2,\"z\":3,\"m\":4}"
  // Multipoint
    new Coordinate2D(100, 200),
    new Coordinate2D(201, 300),
    new Coordinate2D(301, 400),
    new Coordinate2D(401, 500)
  Multipoint multipoint = MultipointBuilder.CreateMultipoint(coords, SpatialReferences.WebMercator);
  inputString = "{\"points\":[[100,200],[201,300],[301,400],[401,500]],\"spatialReference\":{\"wkid\":3857}}";
  Multipoint importMultipoint = GeometryEngine.ImportFromJSON(JSONImportFlags.jsonImportDefaults, inputString) as Multipoint;
  // importMultipoint.IsEqual(multipoint) = true
  outputString = GeometryEngine.ExportToJSON(JSONExportFlags.jsonExportDefaults, multipoint);
  // outputString = inputString
  ReadOnlyPointCollection points = importMultipoint.Points;
  // points.Count = 4
  // points[0] = 100, 200
  // points[1] = 201, 300
  // points[2] = 301, 400
  // points[3] = 401, 500
  // Polyline
  Polyline polyline = PolylineBuilder.CreatePolyline(coords, SpatialReferences.WebMercator);
  outputString = GeometryEngine.ExportToJSON(JSONExportFlags.jsonExportSkipCRS, polyline);
  geometry = GeometryEngine.ImportFromJSON(JSONImportFlags.jsonImportDefaults, outputString);
  // importPolyline.SpatialReference = null
  points = importPolyline.Points;
  // points.Count = 4
  // Polygon
  Polygon polygon = PolygonBuilder.CreatePolygon(coords, SpatialReferences.WebMercator);
  outputString = GeometryEngine.ExportToJSON(JSONExportFlags.jsonExportSkipCRS, polygon);
  Polygon importPolygon = geometry as Polygon;
  points = importPolygon.Points;
  // points.Count = 5
  // Empty polygon
  polygon = PolygonBuilder.CreatePolygon(SpatialReferences.WebMercator);
  outputString = GeometryEngine.ExportToJSON(JSONExportFlags.jsonExportDefaults, polygon);
  importPolygon = GeometryEngine.ImportFromJSON(JSONImportFlags.jsonImportDefaults, outputString) as Polygon;
  // importPolygon.IsEmpty = true
  // importPolygon.SpatialReference.Wkid = 3857
    now:
  // MapPoint
  Geometry geometry = GeometryEngine.Instance.ImportFromJSON(JSONImportFlags.jsonImportDefaults, inputString);
  // use the MapPointBuilder convenience method
  MapPoint importPoint2 = MapPointBuilder.FromJson(inputString);
  // importPoint2 = 1, 2
  // impointPoint2.SpatialReference.Wkid = 4326
  string outputString = GeometryEngine.Instance.ExportToJSON(JSONExportFlags.jsonExportDefaults, importPoint);
  string outputString2 = importPoint.ToJson();
  importPoint = GeometryEngine.Instance.ImportFromJSON(JSONImportFlags.jsonImportDefaults, inputString) as MapPoint;
  // importPoint.HasM = true
  // importPoint.HasZ = true
  // importPoint.X = 1
  // importPoint.Y = 2
  // importPoint.M = 4
  // importPoint.Z = 3
  // export to json - skip spatial reference
  outputString = GeometryEngine.Instance.ExportToJSON(JSONExportFlags.jsonExportSkipCRS, importPoint);
  // export from mappoint, skipping the sr - same as GeometryEngine.Instance.ExportToJSON w JSONExportFlags.jsonExportSkipCRS
  outputString2 = importPoint.ToJson(true);
  // Multipoint
  Multipoint importMultipoint = GeometryEngine.Instance.ImportFromJSON(JSONImportFlags.jsonImportDefaults, inputString) as Multipoint;
  // points.Count = 4
  // use the Multipointbuilder convenience method
  Multipoint importMultipoint2 = MultipointBuilder.FromJson(inputString);
  // importMultipoint2.IsEqual(multipoint) = true
  // export to json
  outputString = GeometryEngine.Instance.ExportToJSON(JSONExportFlags.jsonExportDefaults, multipoint);
  // or use the multipoint itself
  outputString2 = multipoint.ToJson();
  // Polyline
  // export without the spatial reference
  outputString = GeometryEngine.Instance.ExportToJSON(JSONExportFlags.jsonExportSkipCRS, polyline);
  // import
  geometry = GeometryEngine.Instance.ImportFromJSON(JSONImportFlags.jsonImportDefaults, outputString);
  // points.Count = 4
  // use the polylineBuilder convenience method
  Polyline importPolyline2 = PolylineBuilder.FromJson(outputString);
  // importPolyline2 = importPolyline
  outputString2 = importPolyline2.ToJson();
  // outputString2 = outputString
  // Polygon
  outputString = GeometryEngine.Instance.ExportToJSON(JSONExportFlags.jsonExportSkipCRS, polygon);
  // import
  // importPolygon.SpatialReference = null
  // points.Count = 5
  // polygonBuilder convenience method
  Polygon importPolyon2 = PolygonBuilder.FromJson(outputString);
  // importPolygon2 = importPolygon
  // export from the polygon
  outputString2 = importPolyon2.ToJson(true);
  // Empty polygon
  outputString = GeometryEngine.Instance.ExportToJSON(JSONExportFlags.jsonExportDefaults, polygon);
  importPolygon = GeometryEngine.Instance.ImportFromJSON(JSONImportFlags.jsonImportDefaults, outputString) as Polygon;
Determine area of a polygon
    before:
  var g1 = PolygonBuilder.FromJson("{\"rings\": [ [ [0, 0], [10, 0], [10, 10], [0, 10] ] ] }");
  double d = GeometryEngine.Area(g1);
  // d = -100.0         //negative due to wrong ring orientation
  d = GeometryEngine.Area(GeometryEngine.SimplifyAsFeature(g1));
  // d = 100.0        // feature has been simplifed; ring orientation is correct
    now:
  double d = GeometryEngine.Instance.Area(g1);
  d = GeometryEngine.Instance.Area(GeometryEngine.Instance.SimplifyAsFeature(g1));
Determine the boundary of a multi-part Polygon
    before:
  // create a donut polygon.  Must use the PolygonBuilder object
  List<Coordinate2D> outerPts = new List<Coordinate2D>();
  outerPts.Add(new Coordinate2D(10.0, 10.0));
  outerPts.Add(new Coordinate2D(10.0, 20.0));
  outerPts.Add(new Coordinate2D(20.0, 20.0));
  outerPts.Add(new Coordinate2D(20.0, 10.0));
  List<Coordinate2D> innerPts = new List<Coordinate2D>();
  innerPts.Add(new Coordinate2D(13.0, 13.0));
  innerPts.Add(new Coordinate2D(17.0, 13.0));
  innerPts.Add(new Coordinate2D(17.0, 17.0));
  innerPts.Add(new Coordinate2D(13.0, 17.0));
  // add the outer points
  PolygonBuilder pb = new PolygonBuilder(outerPts);
  // add the inner points (note they are defined anticlockwise)
  pb.AddPart(innerPts);
  // get the polygon
  // get the boundary
  Geometry g = GeometryEngine.Boundary(donut);
  Polyline boundary = g as Polyline;
    now:
  using (PolygonBuilder pb = new PolygonBuilder(outerPts))
    // get the polygon
    // get the boundary
    Geometry g = GeometryEngine.Instance.Boundary(donut);
Buffer a MapPoint
    before:
  // buffer a point
  MapPoint pt = MapPointBuilder.CreateMapPoint(1.0, 1.0, SpatialReferences.WGS84);
  Geometry ptBuffer = GeometryEngine.Buffer(pt, 5.0);
  Polygon buffer = ptBuffer as Polygon;
    now:
  // buffer a point
  Geometry ptBuffer = GeometryEngine.Instance.Buffer(pt, 5.0);
Buffer a Circular Arc
    before:
  // create the circular arc
  EllipticArcSegment circularArc = EllipticArcBuilder.CreateEllipticArcSegment(fromPt.ToMapPoint(), toPt.ToMapPoint(), interiorPt);
  // buffer the arc
  Polyline polyline = PolylineBuilder.CreatePolyline(circularArc);
  Geometry lineBuffer = GeometryEngine.Buffer(polyline, 10);
    now:
  EllipticArcSegment circularArc = EllipticArcBuilder.CreateEllipticArcSegment(fromPt, toPt, interiorPt);
  // buffer the arc
  Geometry lineBuffer = GeometryEngine.Instance.Buffer(polyline, 10);
Buffer multiple MapPoints
    before:
  // creates a buffer around each MapPoint
  pts.Add(MapPointBuilder.CreateMapPoint(1.0, 1.0));
  pts.Add(MapPointBuilder.CreateMapPoint(1.0, 2.0));
  pts.Add(MapPointBuilder.CreateMapPoint(2.0, 2.0));
  pts.Add(MapPointBuilder.CreateMapPoint(2.0, 1.0));
  Geometry ptsBuffer = GeometryEngine.Buffer(pts, 0.25);
  Polygon bufferResult = ptsBuffer as Polygon;      // bufferResult will have 4 parts
    now:
  Geometry ptsBuffer = GeometryEngine.Instance.Buffer(pts, 0.25);
Buffer many different Geometry Types
    before:
  List<Coordinate2D> coords = new List<Coordinate2D>()
    new Coordinate2D(1, 2), new Coordinate2D(3, 4), new Coordinate2D(4, 2),
    new Coordinate2D(5, 6), new Coordinate2D(7, 8), new Coordinate2D(8, 4),
    new Coordinate2D(9, 10), new Coordinate2D(11, 12), new Coordinate2D(12, 8),
    new Coordinate2D(10, 8), new Coordinate2D(12, 12), new Coordinate2D(14, 10)
  List<Geometry> manyGeometries = new List<Geometry>
    MapPointBuilder.CreateMapPoint(coords[9]),
    PolylineBuilder.CreatePolyline(new List<Coordinate2D>(){coords[0], coords[1], coords[2]}, SpatialReferences.WGS84),
    PolylineBuilder.CreatePolyline(new List<Coordinate2D>(){coords[3], coords[4], coords[5]}),
    PolygonBuilder.CreatePolygon(new List<Coordinate2D>(){coords[6], coords[7], coords[8]})
  Geometry manyGeomBuffer = GeometryEngine.Buffer(manyGeometries, 0.25);
    now:
  Geometry manyGeomBuffer = GeometryEngine.Instance.Buffer(manyGeometries, 0.25);
Interpolate Z values on a polyline
    before:
  List<Coordinate> coords2 = new List<Coordinate>()
    new Coordinate(0, 0, 0),
    new Coordinate(0, 1000),
    new Coordinate(1000, 1000, 50),
    new Coordinate(1000, 1000, 76),
  SpatialReference sr = SpatialReferences.WebMercator;
  Polyline polyline = PolylineBuilder.CreatePolyline(coords2, sr);
  // polyline.HasZ = true
  // polyline.Points[1].HasZ = true
  // polyline.Points[1].Z  = NaN
  // polyline.Points[4].HasZ = true
  // polyline.Points[4].Z  = NaN
  Polyline polylineNoNaNZs = GeometryEngine.CalculateNonSimpleZs(polyline, 0) as Polyline;
  // polylineNoNaNZs.Points[1].HasZ = true
  // polylineNoNaNZs.Points[1].Z = 25  (halfway between 0 and 50)
  // polylineNoNaNZs.Points[4].HasZ = true
  // polylineNoNaNZs.Points[4].Z = 38  (halfway between 76 and 0)
    now:
  List<Coordinate3D> coords2 = new List<Coordinate3D>()
    new Coordinate3D(0, 0, 0),
    new Coordinate3D(0, 1000, double.NaN),
    new Coordinate3D(1000, 1000, 50),
    new Coordinate3D(1000, 1000, 76),
  Polyline polylineNoNaNZs = GeometryEngine.Instance.CalculateNonSimpleZs(polyline, 0) as Polyline;
Interpolate M values on a polygon
    before:
  List<Coordinate> coords = new List<Coordinate>()
    new Coordinate(0, 0, 0, 0),
    new Coordinate(1000, 1000, 10, 50)
  SpatialReference sr2 = SpatialReferences.WebMercator;
  Polygon polygon = PolygonBuilder.CreatePolygon(coords, sr2);
  // polygon.HasM = true
  // polygon.Points[1].HasM = true
  // polygon.Points[1].M = NaN
  Polygon polygonNoNaNMs = GeometryEngine.CalculateNonSimpleMs(polygon, 0) as Polygon;
  // polygonNoNaNMs.Points[1].HasM = true
  // polygonNoNaNMs.Points[1].M = 25  (halfway between 0 and 50)
    now:
  List<MapPoint> coords = new List<MapPoint>()
    MapPointBuilder.CreateMapPoint(0, 0, 0, 0),
    MapPointBuilder.CreateMapPoint(0, 1000),
    MapPointBuilder.CreateMapPoint(1000, 1000, 10, 50)
  Polygon polygonNoNaNMs = GeometryEngine.Instance.CalculateNonSimpleMs(polygon, 0) as Polygon;
Center an envelope around X,Y
    before:
  Envelope env = EnvelopeBuilder.CreateEnvelope(1.0, 1.0, 5.0, 5.0);
  Envelope centered = GeometryEngine.CenterAt(env, 2.0, 2.0);
  // centered.Center.X = 2.0
  // centered.Center.Y = 2.0
  // centered.XMin = 0
  // centered.YMin = 0
  // centered.XMax = 4
  // centered.YMax = 4
  centered = env.CenterAt(4.0, 3.0);
  // centered.Center.X == 4.0
  // centered.Center.Y == 3.0
  // centered.XMin == 2.0
  // centered.YMin == 1.0
  // centered.XMax == 6.0
  // centered.YMax == 5.0
    now:
  Envelope centered = GeometryEngine.Instance.CenterAt(env, 2.0, 2.0);
Find the centroid of geometries
    before:
  // simple polygon
  List<Coordinate2D> list2D = new List<Coordinate2D>();
  list2D.Add(new Coordinate2D(0, 0));
  list2D.Add(new Coordinate2D(0, 2));
  list2D.Add(new Coordinate2D(2, 2));
  list2D.Add(new Coordinate2D(2, 0));
  Polygon polygon = PolygonBuilder.CreatePolygon(list2D, SpatialReferences.WGS84);
  // verify it is simple
  bool isSimple = GeometryEngine.IsSimpleAsFeature(polygon);
  // find the centroid
  MapPoint centroid = GeometryEngine.Centroid(polygon);
  // centroid.X = 1
  // centroid.Y = 1
  // map Point
  MapPoint pt1 = MapPointBuilder.CreateMapPoint(1, 2, 3, 4, SpatialReferences.WGS84);
  MapPoint pt2 = MapPointBuilder.CreateMapPoint(5, 2, double.NaN, 7);
  // pt1.HasZ = true
  // pt1.HasM = true
  centroid = GeometryEngine.Centroid(pt1);
  // centroid.HasZ = true
  // centroid.HasM = true
  // pt1.IsEqual(centroid) = true
  // multipoint
  List<MapPoint> list = new List<MapPoint>() { pt1, pt2 };
  Multipoint multipoint = MultipointBuilder.CreateMultipoint(list);
  // multipoint.HasZ = true
  // multipoint.HasM = true
  centroid = GeometryEngine.Centroid(multipoint);
  // centroid.X = 3
  // centroid.Y = 2
  // centroid.HasZ = false
  // centroid.HasM = false
    now:
  // simple polygon
  bool isSimple = GeometryEngine.Instance.IsSimpleAsFeature(polygon);
  MapPoint centroid = GeometryEngine.Instance.Centroid(polygon);
  // centroid.X = 1
  // centroid.Y = 1
  // map Point
  // pt1.HasZ = true
  // pt1.HasM = true
  centroid = GeometryEngine.Instance.Centroid(pt1);
  // multipoint
  centroid = GeometryEngine.Instance.Centroid(multipoint);
  // centroid.X = 3
  // centroid.Y = 2
Clip a Polyline
    before:
  // clip a polyline by an envelope
  Envelope env = EnvelopeBuilder.CreateEnvelope(2.0, 2.0, 4.0, 4.0);
  LineSegment line = LineBuilder.CreateLineSegment(new Coordinate(0, 3), new Coordinate(5.0, 3.0));
  Polyline polyline = PolylineBuilder.CreatePolyline(line);
  Geometry clipGeom = GeometryEngine.Clip(polyline, env);
    now:
  LineSegment line = LineBuilder.CreateLineSegment(new Coordinate2D(0, 3), new Coordinate2D(5.0, 3.0));
  Geometry clipGeom = GeometryEngine.Instance.Clip(polyline, env);
Clip a Polyline by a Polygon
    before:
  // clip a polyline by a polygon
  List<Coordinate2D> list = new List<Coordinate2D>();
  list.Add(new Coordinate2D(1.0, 1.0));
  list.Add(new Coordinate2D(1.0, 4.0));
  list.Add(new Coordinate2D(4.0, 4.0));
  list.Add(new Coordinate2D(4.0, 1.0));
  Polygon polygon = PolygonBuilder.CreatePolygon(list, SpatialReferences.WGS84);
  LineSegment crossingLine = LineBuilder.CreateLineSegment(MapPointBuilder.CreateMapPoint(0, 3), MapPointBuilder.CreateMapPoint(5.0, 3.0));
  Polyline p = PolylineBuilder.CreatePolyline(crossingLine);
  Geometry geometry = GeometryEngine.Clip(p, polygon.Extent);
    now:
  Geometry geometry = GeometryEngine.Instance.Clip(p, polygon.Extent);
Polygon contains MapPoints, Polylines, Polygons
    before:
  // build a polygon
  Polygon poly = PolygonBuilder.CreatePolygon(pts);
  // test if an inner point is contained
  MapPoint innerPt = MapPointBuilder.CreateMapPoint(1.5, 1.5);
  bool contains = GeometryEngine.Contains(poly, innerPt);   // contains = true
  // test a point on a boundary
  contains = GeometryEngine.Contains(poly, poly.Points[0]);     // contains = false
  // test an interior line
  MapPoint innerPt2 = MapPointBuilder.CreateMapPoint(1.25, 1.75);
  List<MapPoint> innerLinePts = new List<MapPoint>();
  innerLinePts.Add(innerPt);
  innerLinePts.Add(innerPt2);
  // test an inner polyline
  Polyline polyline = PolylineBuilder.CreatePolyline(innerLinePts);
  contains = GeometryEngine.Contains(poly, polyline);   // contains = true
  // test a line that crosses the boundary
  MapPoint outerPt = MapPointBuilder.CreateMapPoint(3, 1.5);
  List<MapPoint> crossingLinePts = new List<MapPoint>();
  crossingLinePts.Add(innerPt);
  crossingLinePts.Add(outerPt);
  polyline = PolylineBuilder.CreatePolyline(crossingLinePts);
  contains = GeometryEngine.Contains(poly, polyline);     // contains = false
  // test a polygon in polygon
  Envelope env = EnvelopeBuilder.CreateEnvelope(innerPt, innerPt2);
  contains = GeometryEngine.Contains(poly, env);      // contains = true
    now:
  // build a polygon
  bool contains = GeometryEngine.Instance.Contains(poly, innerPt);   // contains = true
  contains = GeometryEngine.Instance.Contains(poly, poly.Points[0]);     // contains = false
  contains = GeometryEngine.Instance.Contains(poly, polyline);   // contains = true
  contains = GeometryEngine.Instance.Contains(poly, polyline);     // contains = false
  contains = GeometryEngine.Instance.Contains(poly, env);      // contains = true
Determine convex hull
    before:
  // convex hull around a point - returns a point
  MapPoint pt = MapPointBuilder.CreateMapPoint(2.0, 2.0);
  Geometry hull = GeometryEngine.ConvexHull(pt);
  MapPoint hullPt = hull as MapPoint;
  // nullPt.X = 2
  // hullPt.Y = 2
  // convex hull around a multipoint - returns a polygon
  // build a multiPoint
  hull = GeometryEngine.ConvexHull(multiPoint);
  Polygon hullPoly = hull as Polygon;
  // hullPoly.Area = 1
  // hullPoly.PointCount = 5
  // convex hull around a line - returns a polyline or polygon
  List<MapPoint> polylineList = new List<MapPoint>();
  polylineList.Add(MapPointBuilder.CreateMapPoint(1.0, 1.0));
  polylineList.Add(MapPointBuilder.CreateMapPoint(2.0, 2.0));
  // 2 point straight line
  Polyline polyline = PolylineBuilder.CreatePolyline(polylineList);
  hull = GeometryEngine.ConvexHull(polyline);
  Polyline hullPolyline = hull as Polyline;
  // hullPolyline.Length = Math.Sqrt(2)
  // hullPolyline.PointCount = 2
  // 3 point angular line
  polylineList.Add(MapPointBuilder.CreateMapPoint(2.0, 1.0));
  // hullPoly.Length = 2 + Math.Sqrt(2)
  // hullPoly.Area = 0.5
  // hullPoly.PointCount = 4
  // convex hull around a polygon - returns a polygon
  // simple polygon
  Polygon poly = PolygonBuilder.CreatePolygon(list);
  hull = GeometryEngine.ConvexHull(poly);
  // hullPoly.Length = 4.0
  // hullPoly.Area = 1.0
  // polygon with concave angles
  List<MapPoint> funkyList = new List<MapPoint>();
  funkyList.Add(MapPointBuilder.CreateMapPoint(1.0, 1.0));
  funkyList.Add(MapPointBuilder.CreateMapPoint(1.5, 1.5));
  funkyList.Add(MapPointBuilder.CreateMapPoint(1.0, 2.0));
  funkyList.Add(MapPointBuilder.CreateMapPoint(2.0, 2.0));
  funkyList.Add(MapPointBuilder.CreateMapPoint(2.0, 1.0));
  Polygon funkyPoly = PolygonBuilder.CreatePolygon(funkyList);
  hull = GeometryEngine.ConvexHull(funkyPoly);
  // hullPoly.Points[0] = 1.0, 1.0
  // hullPoly.Points[1] = 1.0, 2.0
  // hullPoly.Points[2] = 2.0, 2.0
  // hullPoly.Points[3] = 2.0, 1.0
  // hullPoly.Points[4] = 1.0, 1.0
    now:
  Geometry hull = GeometryEngine.Instance.ConvexHull(pt);
  // nullPt.X = 2
  // hullPt.Y = 2
  hull = GeometryEngine.Instance.ConvexHull(multiPoint);
  hull = GeometryEngine.Instance.ConvexHull(polyline);
  // simple polygon
  hull = GeometryEngine.Instance.ConvexHull(poly);
  hull = GeometryEngine.Instance.ConvexHull(funkyPoly);
Determine if two geometries cross
    before:
  // pt on pt
  MapPoint pt = MapPointBuilder.CreateMapPoint(1.0, 1.0);
  MapPoint pt2 = MapPointBuilder.CreateMapPoint(2.0, 2.0);
  bool crosses = GeometryEngine.Crosses(pt, pt2);         // crosses = false
  crosses = GeometryEngine.Crosses(pt, pt);               // crosses = false
  // pt and line
  list.Add(MapPointBuilder.CreateMapPoint(3.0, 3.0));
  list.Add(MapPointBuilder.CreateMapPoint(5.0, 1.0));
  Polyline line1 = PolylineBuilder.CreatePolyline(list);
  crosses = GeometryEngine.Crosses(line1, pt2);           // crosses = false
  crosses = GeometryEngine.Crosses(pt2, line1);           // crosses = false
  // end pt of line
  crosses = GeometryEngine.Crosses(line1, pt);            // crosses = false
  // pt and polygon
  List<MapPoint> polyPts = new List<MapPoint>();
  polyPts.Add(MapPointBuilder.CreateMapPoint(3.0, 2.0));
  polyPts.Add(MapPointBuilder.CreateMapPoint(3.0, 6.0));
  polyPts.Add(MapPointBuilder.CreateMapPoint(6.0, 6.0));
  polyPts.Add(MapPointBuilder.CreateMapPoint(6.0, 2.0));
  Polygon poly1 = PolygonBuilder.CreatePolygon(polyPts);
  crosses = GeometryEngine.Crosses(poly1, pt);              // crosses = false
  crosses = GeometryEngine.Crosses(pt, poly1);              // crosses = false
  // line and line
  List<MapPoint> list2 = new List<MapPoint>();
  list2.Add(MapPointBuilder.CreateMapPoint(1.0, 3.0));
  list2.Add(MapPointBuilder.CreateMapPoint(3.0, 1.0));
  list2.Add(MapPointBuilder.CreateMapPoint(5.0, 3.0));
  Polyline line2 = PolylineBuilder.CreatePolyline(list2);
  crosses = GeometryEngine.Crosses(line1, line2);           // crosses = true
  // line and polygon
  crosses = GeometryEngine.Crosses(poly1, line1);           // crosses = true
  // polygon and polygon
  Envelope env = EnvelopeBuilder.CreateEnvelope(MapPointBuilder.CreateMapPoint(1.0, 1.0), MapPointBuilder.CreateMapPoint(4, 4));
  Polygon poly2 = PolygonBuilder.CreatePolygon(env);
  crosses = GeometryEngine.Crosses(poly1, poly2);           // crosses = false
    now:
  // pt on pt
  bool crosses = GeometryEngine.Instance.Crosses(pt, pt2);         // crosses = false
  crosses = GeometryEngine.Instance.Crosses(pt, pt);               // crosses = false
  // pt and line
  crosses = GeometryEngine.Instance.Crosses(line1, pt2);           // crosses = false
  crosses = GeometryEngine.Instance.Crosses(pt2, line1);           // crosses = false
  // end pt of line
  crosses = GeometryEngine.Instance.Crosses(line1, pt);            // crosses = false
  // pt and polygon
  crosses = GeometryEngine.Instance.Crosses(poly1, pt);              // crosses = false
  crosses = GeometryEngine.Instance.Crosses(pt, poly1);              // crosses = false
  // line and line
  crosses = GeometryEngine.Instance.Crosses(line1, line2);           // crosses = true
  // line and polygon
  crosses = GeometryEngine.Instance.Crosses(poly1, line1);           // crosses = true
  crosses = GeometryEngine.Instance.Crosses(poly1, poly2);           // crosses = false
Cut a geometry with a polyline
    before:
  SpatialReference sr = SpatialReferences.WGS84;
  list.Add(MapPointBuilder.CreateMapPoint(1.0, 1.0, sr));
  list.Add(MapPointBuilder.CreateMapPoint(1.0, 4.0, sr));
  list.Add(MapPointBuilder.CreateMapPoint(4.0, 4.0, sr));
  list.Add(MapPointBuilder.CreateMapPoint(4.0, 1.0, sr));
  List<Geometry> cutGeometries;
  LineSegment line = LineBuilder.CreateLineSegment(MapPointBuilder.CreateMapPoint(0, 0, sr), MapPointBuilder.CreateMapPoint(3, 6, sr));
  Polyline cutter = PolylineBuilder.CreatePolyline(line);
  // polyline
  Polyline polyline = PolylineBuilder.CreatePolyline(list);
  bool isSimple = GeometryEngine.IsSimpleAsFeature(polyline);
  cutGeometries = GeometryEngine.Cut(polyline, cutter) as List<Geometry>;
  Polyline leftPolyline = cutGeometries[0] as Polyline;
  Polyline rightPolyline = cutGeometries[1] as Polyline;
  // leftPolyline.Points[0] = 1, 2
  // leftPolyline.Points[1] = 1, 4
  // leftPolyline.Points[2] = 2, 4
  // rightPolyline.Points.Count = 5
  // rightPolyline.Parts.Count = 2
  ReadOnlySegmentCollection segments0 = rightPolyline.Parts[0];
  // segments0[0].StartCoordinate = 1, 1
  // segments0[0].EndCoordinate = 1, 2
  ReadOnlySegmentCollection segments1 = rightPolyline.Parts[1];
  // segments1.Count = 2
  // segments1[0].StartCoordinate = 2, 4
  // segments1[0].EndCoordinate = 4, 4
  // segments1[1].StartCoordinate = 4, 4
  // segments1[1].EndCoordinate = 4, 1
  // polygon
  Polygon polygon = PolygonBuilder.CreatePolygon(list);
  cutGeometries = GeometryEngine.Cut(polygon, cutter) as List<Geometry>;
    now:
  // polyline
  bool isSimple = GeometryEngine.Instance.IsSimpleAsFeature(polyline);
  cutGeometries = GeometryEngine.Instance.Cut(polyline, cutter) as List<Geometry>;
  // polygon
  cutGeometries = GeometryEngine.Instance.Cut(polygon, cutter) as List<Geometry>;
Densify By Length
    before:
  // densify a line segment
  MapPoint endPt = MapPointBuilder.CreateMapPoint(1, 21);
  LineSegment line = LineBuilder.CreateLineSegment(startPt, endPt);
  Geometry geom = GeometryEngine.DensifyByLength(polyline, 2);
  Polyline result = geom as Polyline;
  // densify a circular arc
    now:
  Geometry geom = GeometryEngine.Instance.DensifyByLength(polyline, 2);
Difference between two Polygons
    before:
  Geometry result = GeometryEngine.Difference(poly1, poly2);
  Polygon polyResult = result as Polygon;
  // polyResult.Area = 10.0
  result = GeometryEngine.Difference(poly2, poly1);
  // polyResult.Area = 7.0
    now:
  Geometry result = GeometryEngine.Instance.Difference(poly1, poly2);
  result = GeometryEngine.Instance.Difference(poly2, poly1);
Determine if two Geometries are disjoint
    before:
  // pt on pt
  MapPoint pt2 = MapPointBuilder.CreateMapPoint(2.0, 2.5);
  bool disjoint = GeometryEngine.Disjoint(pt, pt2);       // result is true
  MultipointBuilder mpb = new MultipointBuilder();
  mpb.Add(pt);
  mpb.Add(pt2);
  Multipoint multiPoint = mpb.ToGeometry();
  disjoint = GeometryEngine.Disjoint(multiPoint, pt);     // result is false
  // pt and line
  disjoint = GeometryEngine.Disjoint(line1, pt2);       // result is true
  disjoint = GeometryEngine.Disjoint(pt2, line1);       // result is true
  // end pt of line
  disjoint = GeometryEngine.Disjoint(line1, pt);        // result is false
  // pt and polygon
  disjoint = GeometryEngine.Disjoint(poly1, pt);          // result is true
  disjoint = GeometryEngine.Disjoint(pt, poly1);          // result is true
  // line and line
  disjoint = GeometryEngine.Disjoint(line1, line2);         // result is false
  // line and polygon
  disjoint = GeometryEngine.Disjoint(poly1, line1);         // result is false
  disjoint = GeometryEngine.Disjoint(line1, poly1);         // result is false
  disjoint = GeometryEngine.Disjoint(poly1, poly2);         // result is false
  // disjoint3D
  MapPoint pt3D_1 = MapPointBuilder.CreateMapPoint(1, 1, 1, sr);
  MapPoint pt3D_2 = MapPointBuilder.CreateMapPoint(2, 2, 2, sr);
  MapPoint pt3D_3 = MapPointBuilder.CreateMapPoint(1, 1, 2, sr);
  mpb.Add(pt3D_1);
  mpb.Add(pt3D_2);
  mpb.HasZ = true;
  disjoint = GeometryEngine.Disjoint3D(multiPoint, pt3D_2);     // disjoint = false
  disjoint = GeometryEngine.Disjoint3D(multiPoint, pt3D_3);     // disjoint = true
    now:
  // pt on pt
  bool disjoint = GeometryEngine.Instance.Disjoint(pt, pt2);       // result is true
  using (MultipointBuilder mpb = new MultipointBuilder())
    mpb.Add(pt);
    mpb.Add(pt2);
    disjoint = GeometryEngine.Instance.Disjoint(multiPoint, pt);     // result is false
  // pt and line
  disjoint = GeometryEngine.Instance.Disjoint(line1, pt2);       // result is true
  disjoint = GeometryEngine.Instance.Disjoint(pt2, line1);       // result is true
  // end pt of line
  disjoint = GeometryEngine.Instance.Disjoint(line1, pt);        // result is false
  // pt and polygon
  disjoint = GeometryEngine.Instance.Disjoint(poly1, pt);          // result is true
  disjoint = GeometryEngine.Instance.Disjoint(pt, poly1);          // result is true
  // line and line
  disjoint = GeometryEngine.Instance.Disjoint(line1, line2);         // result is false
  // line and polygon
  disjoint = GeometryEngine.Instance.Disjoint(poly1, line1);         // result is false
  disjoint = GeometryEngine.Instance.Disjoint(line1, poly1);         // result is false
  disjoint = GeometryEngine.Instance.Disjoint(poly1, poly2);         // result is false
  // disjoint3D
    mpb.Add(pt3D_1);
    mpb.Add(pt3D_2);
    mpb.HasZ = true;
    disjoint = GeometryEngine.Instance.Disjoint3D(multiPoint, pt3D_2);     // disjoint = false
    disjoint = GeometryEngine.Instance.Disjoint3D(multiPoint, pt3D_3);     // disjoint = true
Determine distance between two Geometries
    before:
  MapPoint pt3 = MapPointBuilder.CreateMapPoint(4.0, 2.0);
  // pt and pt
  double d = GeometryEngine.Distance(pt1, pt2);         // d = Math.Sqrt(2)
  // pt and multipoint
  List<MapPoint> multiPts = new List<MapPoint>();
  multiPts.Add(pt2);
  multiPts.Add(pt3);
  Multipoint multiPoint = MultipointBuilder.CreateMultipoint(multiPts);
  d = GeometryEngine.Distance(pt1, multiPoint);         // d = Math.Sqrt(2)
  // pt and envelope
  Envelope env = EnvelopeBuilder.CreateEnvelope(pt1, pt2);
  d = GeometryEngine.Distance(pt1, env);                // d = 0
  // pt and polyline
  List<MapPoint> polylinePts = new List<MapPoint>();
  polylinePts.Add(MapPointBuilder.CreateMapPoint(2.0, 1.0));
  polylinePts.Add(pt2);
  Polyline polyline = PolylineBuilder.CreatePolyline(polylinePts);
  d = GeometryEngine.Distance(pt1, polyline);             // d = 1.0
  // pt and polygon
  Envelope env2 = EnvelopeBuilder.CreateEnvelope(MapPointBuilder.CreateMapPoint(3.0, 3.0), MapPointBuilder.CreateMapPoint(5.0, 5.0));
  Polygon poly = PolygonBuilder.CreatePolygon(env2);
  d = GeometryEngine.Distance(pt1, poly);                 // d = Math.Sqrt(8)
  // envelope and polyline
  d = GeometryEngine.Distance(env, polyline);             // d = 0
  // polyline and polyline
  polylineList.Add(MapPointBuilder.CreateMapPoint(4, 3));
  polylineList.Add(MapPointBuilder.CreateMapPoint(4, 4));
  Polyline polyline2 = PolylineBuilder.CreatePolyline(polylineList);
  d = GeometryEngine.Distance(polyline, polyline2);           // d = Math.Sqrt(5)
  d = GeometryEngine.Distance(poly, poly2);                 // d = Math.Sqrt(2)
    now:
  // pt and pt
  double d = GeometryEngine.Instance.Distance(pt1, pt2);         // d = Math.Sqrt(2)
  multiPts.Add(pt2);
  multiPts.Add(pt3);
  d = GeometryEngine.Instance.Distance(pt1, multiPoint);         // d = Math.Sqrt(2)
  // pt and envelope
  d = GeometryEngine.Instance.Distance(pt1, env);                // d = 0
  // pt and polyline
  d = GeometryEngine.Instance.Distance(pt1, polyline);             // d = 1.0
  // pt and polygon
  d = GeometryEngine.Instance.Distance(pt1, poly);                 // d = Math.Sqrt(8)
  d = GeometryEngine.Instance.Distance(env, polyline);             // d = 0
  d = GeometryEngine.Instance.Distance(polyline, polyline2);           // d = Math.Sqrt(5)
  d = GeometryEngine.Instance.Distance(poly, poly2);                 // d = Math.Sqrt(2)
Determine 3D distance between two Geometries
    before:
  // between points
  MapPoint pt1 = MapPointBuilder.CreateMapPoint(1, 1, 1);
  MapPoint pt2 = MapPointBuilder.CreateMapPoint(2, 2, 2);
  MapPoint pt3 = MapPointBuilder.CreateMapPoint(10, 2, 1);
  // pt1 to pt2
  double d = GeometryEngine.Distance3D(pt1, pt2);        // d = Math.Sqrt(3)
  // pt1 to pt3
  d = GeometryEngine.Distance3D(pt1, pt3);        // d = Math.Sqrt(82)
  // pt2 to pt3
  d = GeometryEngine.Distance3D(pt2, pt3);        // d = Math.Sqrt(65)
  // intersecting lines
  list.Add(MapPointBuilder.CreateMapPoint(1.0, 1.0, 1.0));
  list.Add(MapPointBuilder.CreateMapPoint(3.0, 3.0, 1.0));
  list.Add(MapPointBuilder.CreateMapPoint(5.0, 1.0, 1.0));
  list2.Add(MapPointBuilder.CreateMapPoint(1.0, 3.0, 1.0));
  list2.Add(MapPointBuilder.CreateMapPoint(3.0, 1.0, 1.0));
  list2.Add(MapPointBuilder.CreateMapPoint(5.0, 3.0, 1.0));
  bool intersects = GeometryEngine.Intersects(line1, line2);    // intersects = true
  d = GeometryEngine.Distance3D(line1, line2);                  // d = 0   (distance is 0 when geomtries intersect)
    now:
// methods need to run on the MCT
  // between points
  // pt1 to pt2
  double d = GeometryEngine.Instance.Distance3D(pt1, pt2);        // d = Math.Sqrt(3)
  // pt1 to pt3
  d = GeometryEngine.Instance.Distance3D(pt1, pt3);        // d = Math.Sqrt(82)
  // pt2 to pt3
  d = GeometryEngine.Instance.Distance3D(pt2, pt3);        // d = Math.Sqrt(65)
  bool intersects = GeometryEngine.Instance.Intersects(line1, line2);    // intersects = true
  d = GeometryEngine.Instance.Distance3D(line1, line2);                  // d = 0   (distance is 0 when geomtries intersect)
Expand envelopes
    before:
  Envelope env = EnvelopeBuilder.CreateEnvelope(100.0, 100.0, 500.0, 500.0);
  // env.HasZ = false
  Envelope result = GeometryEngine.Expand(env, 0.5, 0.5, true);
  // result.Center = 300, 300
  // result.XMin = 200
  // result.YMin = 200
  // result.XMax = 400
  // result.YMax = 400
  result = GeometryEngine.Expand(env, 100, 200, false);
  // result.XMin = 0
  // result.YMin = -100
  // result.XMax = 600
  // result.YMax = 700
  try
    // expand in 3 dimensions
    result = GeometryEngine.Expand(env, 0.5, 0.5, 0.5, true);
  catch (InvalidOperationException e)
    // the geometry is not Z-Aware
  // expand a 3d envelope
  MapPoint pt1 = MapPointBuilder.CreateMapPoint(100, 100, 100);
  MapPoint pt2 = MapPointBuilder.CreateMapPoint(200, 200, 200);
  EnvelopeBuilder eb = new EnvelopeBuilder(pt1, pt2);
  eb.HasZ = true;
  env = eb.ToGeometry();
  // result.Center = 150, 150, 150
  // result.XMin = 125
  // result.YMin = 125
  // result.ZMin = 125
  // result.XMax = 175
  // result.YMax = 175
  // result.ZMax = 175
    now:
  // env.HasZ = false
  Envelope result = GeometryEngine.Instance.Expand(env, 0.5, 0.5, true);
  result = GeometryEngine.Instance.Expand(env, 100, 200, false);
  // result.XMin = 0
  try
    result = GeometryEngine.Instance.Expand(env, 0.5, 0.5, 0.5, true);
  using (EnvelopeBuilder eb = new EnvelopeBuilder(pt1, pt2))
    eb.HasZ = true;
Extend a polyline
    before:
  // build a polyline
  var polyline = PolylineBuilder.CreatePolyline(new[]
      MapPointBuilder.CreateMapPoint( 1,  1, 10, 20),
      MapPointBuilder.CreateMapPoint( 0,  0, 10, 20),
      MapPointBuilder.CreateMapPoint( 1, -1, 10, 20)
  // build the extender line
  var extender = PolylineBuilder.CreatePolyline(new[]
      MapPointBuilder.CreateMapPoint( 2, 2),
      MapPointBuilder.CreateMapPoint( 2,-2),
  // extend
  var result = GeometryEngine.Extend(polyline, extender, ExtendFlags.KeepEndAttributes);
  Polyline extendedLine = result as Polyline;
  // result.Parts[0].Points[0] = 2, 2, 10, 20
  // result.parts[0].Points[1] = 1, 1, 10, 20
  // result.Parts[0].Points[2] = 0, 0, 10, 20
  // result.Parts[0].Points[3] = 1, -1, 10, 20
  // result.Parts[0].Points[4] = 2, -2, 10, 20
  // change the flags
  result = GeometryEngine.Extend(polyline, extender, ExtendFlags.NoEndAttributes);
  // result.Parts[0].Points[0] = 2, 2, 0
  // result.Parts[0].Points[4] = 2, -2, 0
  // extend
  result = GeometryEngine.Extend(polyline, extender, ExtendFlags.KeepEndAttributes | ExtendFlags.NoExtendAtTo);
  // extend with no intersection
      MapPointBuilder.CreateMapPoint( 1,  1),
      MapPointBuilder.CreateMapPoint( 3,  1),
      MapPointBuilder.CreateMapPoint( 1, 4),
      MapPointBuilder.CreateMapPoint( 3, 4),
  result = GeometryEngine.Extend(polyline, extender, ExtendFlags.Default);
  // result = null
    now:
  // build a polyline
  // extend
  var result = GeometryEngine.Instance.Extend(polyline, extender, ExtendFlags.KeepEndAttributes);
  // change the flags
  result = GeometryEngine.Instance.Extend(polyline, extender, ExtendFlags.NoEndAttributes);
  // extend
  result = GeometryEngine.Instance.Extend(polyline, extender, ExtendFlags.KeepEndAttributes | ExtendFlags.NoExtendAtTo);
  result = GeometryEngine.Instance.Extend(polyline, extender, ExtendFlags.Default);
  // result = null
GeodesicBuffer
    before:
  // buffer a point
  Polygon outPolygon = GeometryEngine.GeodesicBuffer(pt, 5) as Polygon;
  double delta = SpatialReferences.WGS84.XYTolerance * 2 * Math.Sqrt(2);
  ReadOnlyPointCollection points = outPolygon.Points;
  foreach (MapPoint p in points)
    double d = GeometryEngine.GeodesicDistance(pt, p);
    // d = 5 (+- delta)
  // buffer of 0 distance produces an empty geometry
  Geometry g = GeometryEngine.GeodesicBuffer(pt, 0);
  // g.IsEmpty = true
  // buffer many points
  list.Add(MapPointBuilder.CreateMapPoint(1.0, 1.0, SpatialReferences.WGS84));
  list.Add(MapPointBuilder.CreateMapPoint(10.0, 20.0));
  list.Add(MapPointBuilder.CreateMapPoint(40.0, 40.0));
  list.Add(MapPointBuilder.CreateMapPoint(60.0, 60.0));
  outPolygon = GeometryEngine.GeodesicBuffer(list, 10000) as Polygon;
  // outPolygon.PartCount = 4
  // buffer different geometry types
    new Coordinate2D(1, 2), new Coordinate2D(10, 20), new Coordinate2D(20, 30),
    new Coordinate2D(50, 60), new Coordinate2D(70, 80), new Coordinate2D(80, 40),
    new Coordinate2D(90, 10), new Coordinate2D(110, 15), new Coordinate2D(120, 30),
    new Coordinate2D(10, 40), new Coordinate2D(-10, 40), new Coordinate2D(-10, 50)
    MapPointBuilder.CreateMapPoint(1.0, 1.0, SpatialReferences.WGS84),
    PolygonBuilder.CreatePolygon(new List<Coordinate2D>(){coords[9], coords[10], coords[11]})
  outPolygon = GeometryEngine.GeodesicBuffer(manyGeometries, 20000) as Polygon;
    now:
  // buffer a point
  Polygon outPolygon = GeometryEngine.Instance.GeodesicBuffer(pt, 5) as Polygon;
    double d = GeometryEngine.Instance.GeodesicDistance(pt, p);
    // d = 5 (+- delta)
  Geometry g = GeometryEngine.Instance.GeodesicBuffer(pt, 0);
  // g.IsEmpty = true
  outPolygon = GeometryEngine.Instance.GeodesicBuffer(list, 10000) as Polygon;
  outPolygon = GeometryEngine.Instance.GeodesicBuffer(manyGeometries, 20000) as Polygon;
GeodeticDensifyByDeviation - polyline
    before:
    new Coordinate(-80, 0),
    new Coordinate(-20, 60),
    new Coordinate(40, 20),
    new Coordinate(0, -20),
  Polyline polyline = PolylineBuilder.CreatePolyline(coords, sr);
  // densify in km
  Polyline geodesicPolyline = GeometryEngine.GeodeticDensifyByDeviation(polyline, 200, LinearUnit.Kilometers, CurveType.Geodesic) as Polyline;
  // densify in m
  geodesicPolyline = GeometryEngine.GeodeticDensifyByDeviation(polyline, 200, LinearUnit.Meters, CurveType.Geodesic) as Polyline;
  // Change curve type to Loxodrome
  Polyline loxodromePolyline = GeometryEngine.GeodeticDensifyByDeviation(polyline, 200, LinearUnit.Meters, CurveType.Loxodrome) as Polyline;
    now:
    new Coordinate2D(-80, 0),
    new Coordinate2D(-20, 60),
    new Coordinate2D(40, 20),
    new Coordinate2D(0, -20),
  // densify in km
  Polyline geodesicPolyline = GeometryEngine.Instance.GeodeticDensifyByDeviation(polyline, 200, LinearUnit.Kilometers, GeodeticCurveType.Geodesic) as Polyline;
  // densify in m
  geodesicPolyline = GeometryEngine.Instance.GeodeticDensifyByDeviation(polyline, 200, LinearUnit.Meters, GeodeticCurveType.Geodesic) as Polyline;
  Polyline loxodromePolyline = GeometryEngine.Instance.GeodeticDensifyByDeviation(polyline, 200, LinearUnit.Meters, GeodeticCurveType.Loxodrome) as Polyline;
GeodeticDensifyByLength - polygon
    before:
  // create a polygon
  Polygon polygon = PolygonBuilder.CreatePolygon(coords, sr);
  // get the geodesic lengths of the polygon segments
  ReadOnlySegmentCollection segments = polygon.Parts[0];
  List<Double> geoLengths = new List<Double>(segments.Count);
  foreach (Segment s in segments)
    Polyline line = PolylineBuilder.CreatePolyline(s, sr);
    double geoLen = GeometryEngine.GeodesicLength(line);
    geoLengths.Add(geoLen);
  // find the max length
  geoLengths.Sort();
  double maxLen = geoLengths[geoLengths.Count - 1];
  // densify the polygon (in meters)
  Polygon densifiedPoly = GeometryEngine.GeodeticDensifyByLength(polygon, maxLen, LinearUnit.Meters, CurveType.Geodesic) as Polygon;
  // densify the polygon (in km)
  double maxSegmentLength = maxLen / 10000;
  densifiedPoly = GeometryEngine.GeodeticDensifyByLength(polygon, maxSegmentLength, LinearUnit.Kilometers, CurveType.Geodesic) as Polygon;
    now:
  // create a polygon
    double geoLen = GeometryEngine.Instance.GeodesicLength(line);
  geoLengths.Sort();
  Polygon densifiedPoly = GeometryEngine.Instance.GeodeticDensifyByLength(polygon, maxLen, LinearUnit.Meters, GeodeticCurveType.Geodesic) as Polygon;
  densifiedPoly = GeometryEngine.Instance.GeodeticDensifyByLength(polygon, maxSegmentLength, LinearUnit.Kilometers, GeodeticCurveType.Geodesic) as Polygon;
GeodesicEllipse
    before:
  GeometryEngine.GeodesicEllipseParameter param = new GeometryEngine.GeodesicEllipseParameter();
  param.AxisDirection = 4 * Math.PI / 3;
  param.Center = new Coordinate(-120, 60);
  param.LinearUnit = LinearUnit.Meters;
  param.OutGeometryType = GeometryType.Polyline;
  param.SemiAxis1Length = 6500000;
  param.SemiAxis2Length = 1500000;
  param.VertexCount = 800;
  Geometry geometry = GeometryEngine.GeodesicEllipse(param, SpatialReferences.WGS84);
  // geometry.IsEmpty = false
  Polyline polyline = geometry as Polyline;
  // polyline.PointCount = 801
  // polyline.PartCount = 1
    now:
  GeodesicEllipseParameter param = new GeodesicEllipseParameter();
  param.Center = new Coordinate2D(-120, 60);
  Geometry geometry = GeometryEngine.Instance.GeodesicEllipse(param, SpatialReferences.WGS84);
Perform Geodetic Move on a set of MapPoints
    before:
  var points = new[] { MapPointBuilder.CreateMapPoint(0, 0, sr) };
  double distance = 10;
  double azimuth = Math.PI / 2;
  var resultPoints = GeometryEngine.GeodeticMove(points, sr, distance, LinearUnit.Meters, azimuth, CurveType.Geodesic);
  // resultPoints.First().X = 10
  // resultPoints.First().Y = 0
  // resultPoints.First().SpatialReference.Wkid = sr.Wkid
  // Change LinearUnit to Miles
  resultPoints = GeometryEngine.GeodeticMove(points, sr, distance, LinearUnit.Miles, azimuth, CurveType.Geodesic);
  // resultPoints.First().X = 16093.44
  resultPoints = GeometryEngine.GeodeticMove(points, sr, distance, LinearUnit.Miles, azimuth, CurveType.Loxodrome);
    now:
  var resultPoints = GeometryEngine.Instance.GeodeticMove(points, sr, distance, LinearUnit.Meters, azimuth, GeodeticCurveType.Geodesic);
  resultPoints = GeometryEngine.Instance.GeodeticMove(points, sr, distance, LinearUnit.Miles, azimuth, GeodeticCurveType.Geodesic);
  resultPoints = GeometryEngine.Instance.GeodeticMove(points, sr, distance, LinearUnit.Miles, azimuth, GeodeticCurveType.Loxodrome);
GeodesicSector
    before:
  GeometryEngine.GeodesicSectorParameter param = new GeometryEngine.GeodesicSectorParameter();
  param.ArcVertexCount = 50;
  param.AxisDirection = Math.PI / 4;
  param.Center = new Coordinate(0, 0);
  param.OutGeometryType = GeometryType.Polygon;
  param.RadiusVertexCount = 10;
  param.SectorAngle = 5 * Math.PI / 3;
  param.SemiAxis1Length = 100000;
  param.SemiAxis2Length = 20000;
  param.StartDirection = 11 * Math.PI / 6;
  Geometry geometry = GeometryEngine.GeodesicSector(param, SpatialReferences.WGS84);
  Polygon polygon = geometry as Polygon;
  // polygon.PointCount = 68
  // polygon.PartCount = 1
    now:
  GeodesicSectorParameter param = new GeodesicSectorParameter();
  param.Center = new Coordinate2D(0, 0);
  Geometry geometry = GeometryEngine.Instance.GeodesicSector(param, SpatialReferences.WGS84);
Retrieve coordinate systems
    before:
// get all the geographic coordinate systems
IReadOnlyList<CoordinateSystemListEntry> gcs_list = GeometryEngine.GetPredefinedCoordinateSystemList(CoordinateSystemFilter.GeographicCoordinateSystem);
// get the projected coordinate systems
IReadOnlyList<CoordinateSystemListEntry> proj_list = GeometryEngine.GetPredefinedCoordinateSystemList(CoordinateSystemFilter.ProjectedCoordinateSystem);
// get the vertical coordinate systems
IReadOnlyList<CoordinateSystemListEntry> vert_list = GeometryEngine.GetPredefinedCoordinateSystemList(CoordinateSystemFilter.VerticalCoordinateSystem);
// get geographic and projected coordinate systems
IReadOnlyList<CoordinateSystemListEntry> combined_list = GeometryEngine.GetPredefinedCoordinateSystemList(CoordinateSystemFilter.GeographicCoordinateSystem | CoordinateSystemFilter.ProjectedCoordinateSystem);
    now:
IReadOnlyList<CoordinateSystemListEntry> gcs_list = GeometryEngine.Instance.GetPredefinedCoordinateSystemList(CoordinateSystemFilter.GeographicCoordinateSystem);
IReadOnlyList<CoordinateSystemListEntry> proj_list = GeometryEngine.Instance.GetPredefinedCoordinateSystemList(CoordinateSystemFilter.ProjectedCoordinateSystem);
IReadOnlyList<CoordinateSystemListEntry> vert_list = GeometryEngine.Instance.GetPredefinedCoordinateSystemList(CoordinateSystemFilter.VerticalCoordinateSystem);
IReadOnlyList<CoordinateSystemListEntry> combined_list = GeometryEngine.Instance.GetPredefinedCoordinateSystemList(CoordinateSystemFilter.GeographicCoordinateSystem | CoordinateSystemFilter.ProjectedCoordinateSystem);
Get Sub-curve of a polyline or polygon
    before:
    new Coordinate(-111, 72),
    new Coordinate(-108, 68),
    new Coordinate(-114, 68)
  Polyline subCurve = GeometryEngine.GetSubCurve(polyline, 0, 5, GeometryEngine.AsRatioOrLength.AsLength);
  // subCurve.PartCount = 1
  // subCurve.PointCount = 2
  ReadOnlyPointCollection points = subCurve.Points;
  // points[0] = -111, 72
  // points[1] = -108, 68
  subCurve = GeometryEngine.GetSubCurve(polyline, 0, 0.5, GeometryEngine.AsRatioOrLength.AsRatio);
  // subCurve.PointCount = 3
  // points[2] = -108.5, 68
  List<Coordinate> coords3D = new List<Coordinate>()
    new Coordinate(0, 1, 1),
    new Coordinate(1, 1, 2),
    new Coordinate(1, 0, 3)
  Polygon polygon = PolygonBuilder.CreatePolygon(coords3D, sr);
  subCurve = GeometryEngine.GetSubCurve3D(polygon, 0, 1, GeometryEngine.AsRatioOrLength.AsLength);
  // subCurve.HasZ = true
  // points.Count = 2
  // points[0] = 0, 0, 0
  // points[1] = 0, 0.70710678118654746, 0.70710678118654746
    now:
    new Coordinate2D(-111, 72),
    new Coordinate2D(-108, 68),
    new Coordinate2D(-114, 68)
  Polyline subCurve = GeometryEngine.Instance.GetSubCurve(polyline, 0, 5, AsRatioOrLength.AsLength);
  subCurve = GeometryEngine.Instance.GetSubCurve(polyline, 0, 0.5, AsRatioOrLength.AsRatio);
  List<Coordinate3D> coords3D = new List<Coordinate3D>()
    new Coordinate3D(0, 1, 1),
    new Coordinate3D(1, 1, 2),
    new Coordinate3D(1, 0, 3)
  subCurve = GeometryEngine.Instance.GetSubCurve3D(polygon, 0, 1, AsRatioOrLength.AsLength);
  // points.Count = 2
Intersection between two Polylines
    before:
  // determine intersection between two polylines
  List<MapPoint> pts = new List<MapPoint>();
  pts.Add(MapPointBuilder.CreateMapPoint(3.0, 3.0));
  pts.Add(MapPointBuilder.CreateMapPoint(5.0, 1.0));
  Polyline line1 = PolylineBuilder.CreatePolyline(pts);
  List<MapPoint> pts2 = new List<MapPoint>();
  pts2.Add(MapPointBuilder.CreateMapPoint(1.0, 3.0));
  pts2.Add(MapPointBuilder.CreateMapPoint(3.0, 1.0));
  pts2.Add(MapPointBuilder.CreateMapPoint(5.0, 3.0));
  Polyline line2 = PolylineBuilder.CreatePolyline(pts2);
  Geometry g = GeometryEngine.Intersection(line1, line2, GeometryDimension.esriGeometry0Dimension);
  Multipoint resultMultipoint = g as Multipoint;
  // result is a multiPoint that intersects at (2,2) and (4,2)
    now:
  Geometry g = GeometryEngine.Instance.Intersection(line1, line2, GeometryDimension.esriGeometry0Dimension);
Intersection between two Polygons
    before:
  // determine intersection between two polygons
  Envelope env1 = EnvelopeBuilder.CreateEnvelope(new Coordinate2D(3.0, 2.0), new Coordinate2D(6.0, 6.0));
  Polygon poly1 = PolygonBuilder.CreatePolygon(env1);
  Envelope env2 = EnvelopeBuilder.CreateEnvelope(new Coordinate2D(1.0, 1.0), new Coordinate2D(4.0, 4.0));
  Polygon poly2 = PolygonBuilder.CreatePolygon(env2);
  Polygon polyResult = GeometryEngine.Intersection(poly1, poly2) as Polygon;
    now:
  Polygon polyResult = GeometryEngine.Instance.Intersection(poly1, poly2) as Polygon;
Determine label point for a Polygon
    before:
  // create a polygon
  list2D.Add(new Coordinate2D(1.0, 1.0));
  list2D.Add(new Coordinate2D(1.0, 2.0));
  list2D.Add(new Coordinate2D(2.0, 2.0));
  list2D.Add(new Coordinate2D(2.0, 1.0));
  Polygon polygon = PolygonBuilder.CreatePolygon(list2D);
  MapPoint pt = GeometryEngine.LabelPoint(polygon);
    now:
  // create a polygon
  MapPoint pt = GeometryEngine.Instance.LabelPoint(polygon);
Move a MapPoint
    before:
  MapPoint pt = MapPointBuilder.CreateMapPoint(1.0, 3.0);
  MapPoint ptResult = GeometryEngine.Move(pt, -3.5, 2.5) as MapPoint;
  // ptResult is (-2.5, 5.5)
    now:
  MapPoint ptResult = GeometryEngine.Instance.Move(pt, -3.5, 2.5) as MapPoint;
Move a z-aware MapPoint
    before:
  MapPoint zPt = MapPointBuilder.CreateMapPoint(1.0, 3.0, 2.0);
  MapPoint zPtResult = GeometryEngine.Move(zPt, 4, 0.25, 0.5) as MapPoint;
  // zPtResult is (5.0, 3.25, 2.5);
    now:
  MapPoint zPtResult = GeometryEngine.Instance.Move(zPt, 4, 0.25, 0.5) as MapPoint;
Move a Polyline
    before:
  pts.Add(MapPointBuilder.CreateMapPoint(1.0, 1.0, 3.0));
  pts.Add(MapPointBuilder.CreateMapPoint(3.0, 3.0, 3.0));
  pts.Add(MapPointBuilder.CreateMapPoint(3, 2, 3.0));
  pts.Add(MapPointBuilder.CreateMapPoint(4.0, 2.0, 3.0));
  Polyline polyline = PolylineBuilder.CreatePolyline(pts);
  Geometry g = GeometryEngine.Move(polyline, 3, 2);
  Polyline polylineResult = g as Polyline;
  // polylineResult.Points[0] = 4.0, 3.0, 3.0
  // polylineResult.Points[1] = 6.0, 5.0, 3.0
  // polylineResult.Points[2] = 6.0, 4.0, 3.0
  // polylineResult.Points[3] = 7.0, 4.0, 3.0
    now:
  Geometry g = GeometryEngine.Instance.Move(polyline, 3, 2);
MovePointAlongLine
    before:
  LineSegment line = LineBuilder.CreateLineSegment(MapPointBuilder.CreateMapPoint(0, 3), MapPointBuilder.CreateMapPoint(5.0, 3.0));
  bool simple = GeometryEngine.IsSimpleAsFeature(polyline);
  // ratio = false
  MapPoint pt = GeometryEngine.MovePointAlongLine(polyline, 1.0, false, 0.0, GeometryEngine.SegmentExtension.NoExtension);
  // pt = 1.0, 3.0
  pt = GeometryEngine.MovePointAlongLine(polyline, 1.0, false, -1.0, GeometryEngine.SegmentExtension.NoExtension);
  // pt = 1.0, 4.0
  pt = GeometryEngine.MovePointAlongLine(polyline, 1.0, false, 2.0, GeometryEngine.SegmentExtension.NoExtension);
  // pt = 1.0, 1.0
  // ratio = true
  pt = GeometryEngine.MovePointAlongLine(polyline, 0.5, true, 0, GeometryEngine.SegmentExtension.NoExtension);
  // pt = 2.5, 3.0
  // move past the line
  pt = GeometryEngine.MovePointAlongLine(polyline, 7, false, 0, GeometryEngine.SegmentExtension.NoExtension);
  // pt = 5.0, 3.0
  // move past the line with extension at "to" point
  pt = GeometryEngine.MovePointAlongLine(polyline, 7, false, 0, GeometryEngine.SegmentExtension.ExtendEmbeddedAtTo);
  // pt = 7.0, 3.0
  // negative distance with extension at "from" point
  pt = GeometryEngine.MovePointAlongLine(polyline, -2, false, 0, GeometryEngine.SegmentExtension.ExtendEmbeddedAtFrom);
  // pt = -2.0, 3.0
  // ratio = true
  // pt = 2.5, 3.0
  // line with Z
  List<Coordinate> coords3D = new List<Coordinate> { new Coordinate(0, 0, 0), new Coordinate(1113195, 1118890, 5000) };
  Polyline polylineZ = PolylineBuilder.CreatePolyline(coords3D, SpatialReferences.WebMercator);
  // polylineZ.HasZ = true
  // ratio = true, no offset
  pt = GeometryEngine.MovePointAlongLine(polylineZ, 0.5, true, 0, GeometryEngine.SegmentExtension.NoExtension);
  // pt.X = 556597.5
  // pt.Y = 559445
  // pt.Z = 2500
  // ratio = true, past the line with "to" extension, no offset
  pt = GeometryEngine.MovePointAlongLine(polylineZ, 1.5, true, 0, GeometryEngine.SegmentExtension.ExtendEmbeddedAtTo);
  // pt.X = 1669792.5
  // pt.Y = 1678335
  // pt.Z = 7500
  // ratio = true, negative distance past the line with no extension, no offset
  pt = GeometryEngine.MovePointAlongLine(polylineZ, -1.5, true, 0, GeometryEngine.SegmentExtension.NoExtension);
  // pt.X = 0
  // pt.Y = 0
  // pt.Z = -7500
  // polyline with Z but 2d distance = 0
  MapPoint pt3 = MapPointBuilder.CreateMapPoint(5, 5, 0);
  MapPoint pt4 = MapPointBuilder.CreateMapPoint(5, 5, 10);
  List<MapPoint> pts = new List<MapPoint>() { pt3, pt4 };
  PolylineBuilder pb = new PolylineBuilder();
  pb.SetEmpty();
  pb.AddPart(pts);
  pb.HasZ = true;
  polyline = pb.ToGeometry();
  // polyline.Length3D = 10
  // polyline.Length = 0
  MapPoint result = GeometryEngine.MovePointAlongLine(polyline, 2, false, 0, GeometryEngine.SegmentExtension.NoExtension);
  // result = 5, 5, 2
  // polyline with length2d = 0 and length3d = 0
  MapPoint pt5 = MapPointBuilder.CreateMapPoint(5, 5, 10);
  MapPoint pt6 = MapPointBuilder.CreateMapPoint(5, 5, 10);
  pts.Clear();
  pts.Add(pt5);
  pts.Add(pt6);
  pb.SetEmpty();
  pb.AddPart(pts);
  pb.HasZ = true;
  // polyline.Length3D = 0
  result = GeometryEngine.MovePointAlongLine(polyline, 3, true, 0, GeometryEngine.SegmentExtension.NoExtension);
  // result = 5, 5, 10
  result = GeometryEngine.MovePointAlongLine(polyline, 3, true, 0, GeometryEngine.SegmentExtension.ExtendEmbeddedAtFrom);
  // polyline with Z and M
  List<MapPoint> inputPoints = new List<MapPoint>()
    MapPointBuilder.CreateMapPoint(1, 2, 3, 4),
    MapPointBuilder.CreateMapPoint(1, 2, 33, 44),
  Polyline polylineZM = PolylineBuilder.CreatePolyline(inputPoints, SpatialReferences.WGS84);
  // polylineZM.HasZ = true
  // polylineZM.HasM = true
  MapPoint pointAlong = GeometryEngine.MovePointAlongLine(polylineZM, 0.5, true, 0, GeometryEngine.SegmentExtension.NoExtension);
  // pointAlong = 1, 2, 18, 24
  // ratio = true with offset
  pointAlong = GeometryEngine.MovePointAlongLine(polylineZM, 0.2, true, 2.23606797749979, GeometryEngine.SegmentExtension.NoExtension);
  // pointAlong = 1, 2, 9, 12
    now:
ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() =>
  bool simple = GeometryEngine.Instance.IsSimpleAsFeature(polyline);
  // ratio = false
  MapPoint pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 1.0, false, 0.0, SegmentExtension.NoExtension);
  // pt = 1.0, 3.0
  pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 1.0, false, -1.0, SegmentExtension.NoExtension);
  // pt = 1.0, 4.0
  pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 1.0, false, 2.0, SegmentExtension.NoExtension);
  // pt = 1.0, 1.0
  // ratio = true
  pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 0.5, true, 0, SegmentExtension.NoExtension);
  // pt = 2.5, 3.0
  pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 7, false, 0, SegmentExtension.NoExtension);
  // pt = 5.0, 3.0
  pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 7, false, 0, SegmentExtension.ExtendEmbeddedAtTo);
  // pt = 7.0, 3.0
  pt = GeometryEngine.Instance.MovePointAlongLine(polyline, -2, false, 0, SegmentExtension.ExtendEmbeddedAtFrom);
  // pt = -2.0, 3.0
  // ratio = true
  // pt = 2.5, 3.0
  // line with Z
  List<Coordinate3D> coords3D = new List<Coordinate3D> { new Coordinate3D(0, 0, 0), new Coordinate3D(1113195, 1118890, 5000) };
  pt = GeometryEngine.Instance.MovePointAlongLine(polylineZ, 0.5, true, 0, SegmentExtension.NoExtension);
  // pt.X = 556597.5
  // pt.Y = 559445
  // pt.Z = 2500
  pt = GeometryEngine.Instance.MovePointAlongLine(polylineZ, 1.5, true, 0, SegmentExtension.ExtendEmbeddedAtTo);
  // pt.X = 1669792.5
  // pt.Y = 1678335
  // pt.Z = 7500
  pt = GeometryEngine.Instance.MovePointAlongLine(polylineZ, -1.5, true, 0, SegmentExtension.NoExtension);
  // pt.X = 0
  // pt.Y = 0
  // pt.Z = -7500
  using (PolylineBuilder pb = new PolylineBuilder())
    pb.SetEmpty();
    pb.AddPart(pts);
    pb.HasZ = true;
    MapPoint result = GeometryEngine.Instance.MovePointAlongLine(polyline, 2, false, 0, SegmentExtension.NoExtension);
    // result = 5, 5, 2
    pts.Clear();
    pts.Add(pt5);
    pts.Add(pt6);
    pb.SetEmpty();
    pb.AddPart(pts);
    pb.HasZ = true;
    result = GeometryEngine.Instance.MovePointAlongLine(polyline, 3, true, 0, SegmentExtension.NoExtension);
    result = GeometryEngine.Instance.MovePointAlongLine(polyline, 3, true, 0, SegmentExtension.ExtendEmbeddedAtFrom);
  MapPoint pointAlong = GeometryEngine.Instance.MovePointAlongLine(polylineZM, 0.5, true, 0, SegmentExtension.NoExtension);
  pointAlong = GeometryEngine.Instance.MovePointAlongLine(polylineZM, 0.2, true, 2.23606797749979, SegmentExtension.NoExtension);
Nearest Point versus Nearest Vertex
    before:
  MapPoint pt = MapPointBuilder.CreateMapPoint(5, 5, sr);
    new Coordinate(10, 1),
    new Coordinate(10, -4),
    new Coordinate(0, -4),
    new Coordinate(0, 1),
  Polygon polygon = PolygonBuilder.CreatePolygon(coords);
  // find the nearest point in the polygon geomtry to the pt
  GeometryEngine.ProximityResult result = GeometryEngine.NearestPoint(polygon, pt);
  // result.Point = 5, 1
  // result.SegmentIndex = 3
  // result.PartIndex = 0
  // result.PointIndex = null
  //result.Distance = 4
  //result.RightSide = false
  // find the nearest vertex in the polgyon geometry to the pt
  result = GeometryEngine.NearestVertex(polygon, pt);
  // result.Point = 10, 1
  // result.PointIndex = 0
  // result.SegmentIndex = null
  // result.Distance = Math.Sqrt(41)
  // result.RightSide = false
    now:
    new Coordinate2D(10, 1),
    new Coordinate2D(10, -4),
    new Coordinate2D(0, -4),
  ProximityResult result = GeometryEngine.Instance.NearestPoint(polygon, pt);
  result = GeometryEngine.Instance.NearestVertex(polygon, pt);
Determine Nearest Point in 3D
    before:
  // test pt1 to pt2
  GeometryEngine.ProximityResult result = GeometryEngine.NearestPoint3D(pt1, pt2);
  // result.Point = 1,1,1
  // result.Distance = Math.Sqrt(3)
  // multipoint built from pt1, pt2.   should be closer to pt2
  MultipointBuilder mpb = new MultipointBuilder(pt1);
  mpb.Add(pt2);
  mpb.HasZ = true;
  Multipoint multipoint = mpb.ToGeometry();
  result = GeometryEngine.NearestPoint3D(multipoint, pt3);
  // result.Point = 2, 2, 2
  // result.Distance = Math.Sqrt(65)
  // result.PartIndex = 1
  // result.PointIndex = 1
    now:
  // test pt1 to pt2
  ProximityResult result = GeometryEngine.Instance.NearestPoint3D(pt1, pt2);
  using (MultipointBuilder mpb = new MultipointBuilder(pt1))
    mpb.Add(pt2);
    mpb.HasZ = true;
    result = GeometryEngine.Instance.NearestPoint3D(multipoint, pt3);
Determine if geometries overlap
    before:
  MapPoint pt1 = MapPointBuilder.CreateMapPoint(1.5, 1.5);
  MapPoint pt2 = MapPointBuilder.CreateMapPoint(1.25, 1.75);
  MapPoint pt3 = MapPointBuilder.CreateMapPoint(3, 1.5);
  MapPoint pt4 = MapPointBuilder.CreateMapPoint(1.5, 2);
  // point and point overlap
  bool overlaps = GeometryEngine.Overlaps(pt1, pt2);        // overlaps = false
  overlaps = GeometryEngine.Overlaps(pt1, pt1);             // overlaps = false
  // Two geometries overlap if the region of their intersection is of the same dimension as the geometries involved and
  // is not equivalent to either of the geometries.
  pts.Add(pt1);
  pts.Add(pt2);
  pts.Add(pt3);
  pts2.Add(pt2);
  pts2.Add(pt3);
  pts2.Add(pt4);
  // pt and line overlap
  bool isSimple = GeometryEngine.IsSimpleAsFeature(polyline);         // isSimple = true
  overlaps = GeometryEngine.Overlaps(polyline, pt1);                  // overlaps = false
  // line and line
  Polyline polyline2 = PolylineBuilder.CreatePolyline(pts2);
  isSimple = GeometryEngine.IsSimpleAsFeature(polyline2);             // isSimple = true
  overlaps = GeometryEngine.Overlaps(polyline, polyline2);            // overlaps = true
    now:
  bool overlaps = GeometryEngine.Instance.Overlaps(pt1, pt2);        // overlaps = false
  overlaps = GeometryEngine.Instance.Overlaps(pt1, pt1);             // overlaps = false
  pts.Add(pt1);
  pts.Add(pt2);
  pts.Add(pt3);
  pts2.Add(pt2);
  pts2.Add(pt3);
  pts2.Add(pt4);
  bool isSimple = GeometryEngine.Instance.IsSimpleAsFeature(polyline);         // isSimple = true
  overlaps = GeometryEngine.Instance.Overlaps(polyline, pt1);                  // overlaps = false
  // line and line
  isSimple = GeometryEngine.Instance.IsSimpleAsFeature(polyline2);             // isSimple = true
  overlaps = GeometryEngine.Instance.Overlaps(polyline, polyline2);            // overlaps = true
Project from WGS84 to WebMercator
    before:
  MapPoint pt = MapPointBuilder.CreateMapPoint(1.0, 3.0, SpatialReferences.WGS84);
  Geometry result = GeometryEngine.Project(pt, SpatialReferences.WebMercator);
  MapPoint projectedPt = result as MapPoint;
    now:
  Geometry result = GeometryEngine.Instance.Project(pt, SpatialReferences.WebMercator);
Project from WGS84
    before:
  // create the polygon
  pts.Add(MapPointBuilder.CreateMapPoint(1.0, 1.0, SpatialReferences.WGS84));
  pts.Add(MapPointBuilder.CreateMapPoint(1.0, 2.0, SpatialReferences.WGS84));
  pts.Add(MapPointBuilder.CreateMapPoint(2.0, 2.0, SpatialReferences.WGS84));
  pts.Add(MapPointBuilder.CreateMapPoint(2.0, 1.0, SpatialReferences.WGS84));
  Polygon polygon = PolygonBuilder.CreatePolygon(pts);
  // ensure it is simple
  // create the spatial reference to project to
  SpatialReference northPole = SpatialReferenceBuilder.CreateSpatialReference(102018);   // north pole stereographic
  // project
  Geometry g = GeometryEngine.Project(polygon, northPole);
    now:
  // project
  Geometry g = GeometryEngine.Instance.Project(polygon, northPole);
QueryPointAndDistance
    before:
  // Horizontal line segment
  List<MapPoint> linePts = new List<MapPoint>();
  linePts.Add(MapPointBuilder.CreateMapPoint(1.0, 1.0, SpatialReferences.WGS84));
  linePts.Add(MapPointBuilder.CreateMapPoint(11.0, 1.0, SpatialReferences.WGS84));
  Polyline polyline = PolylineBuilder.CreatePolyline(linePts);
  // Don't extent the segment
  GeometryEngine.SegmentExtension extension = GeometryEngine.SegmentExtension.NoExtension;
  // A point on the line segment
  MapPoint inPoint = MapPointBuilder.CreateMapPoint(2, 1, SpatialReferences.WGS84);
  double distanceAlongCurve, distanceFromCurve;
  GeometryEngine.LeftOrRightSide whichSide;
  GeometryEngine.AsRatioOrLength asRatioOrLength = GeometryEngine.AsRatioOrLength.AsLength;
  MapPoint outPoint = GeometryEngine.QueryPointAndDistance(polyline, extension, inPoint, asRatioOrLength, out distanceAlongCurve, out distanceFromCurve, out whichSide);
  // outPoint = 2, 1
  // distanceAlongCurve = 1
  // distanceFromCurve = 0
  // whichSide = GeometryEngine.LeftOrRightSide.LeftSide
  // Extend infinitely in both directions
  extension = GeometryEngine.SegmentExtension.ExtendTangents;
  // A point on the left side
  inPoint = MapPointBuilder.CreateMapPoint(16, 6, SpatialReferences.WGS84);
  asRatioOrLength = GeometryEngine.AsRatioOrLength.AsRatio;
  // outPoint = 16, 1
  // distanceAlongCurve = 1.5
  // distanceFromCurve = 5
    now:
  SegmentExtension extension = SegmentExtension.NoExtension;
  AsRatioOrLength asRatioOrLength = AsRatioOrLength.AsLength;
  MapPoint outPoint = GeometryEngine.Instance.QueryPointAndDistance(polyline, extension, inPoint, asRatioOrLength, out distanceAlongCurve, out distanceFromCurve, out whichSide);
  // outPoint = 2, 1
  // whichSide = GeometryEngine.Instance.LeftOrRightSide.LeftSide
  extension = SegmentExtension.ExtendTangents;
  asRatioOrLength = AsRatioOrLength.AsRatio;
  // outPoint = 16, 1
Determine relationship between two geometries
    before:
  // set up some geometries
  // points
  MapPoint point0 = MapPointBuilder.CreateMapPoint(0, 0, SpatialReferences.WGS84);
  MapPoint point1 = MapPointBuilder.CreateMapPoint(1, 1, SpatialReferences.WGS84);
  MapPoint point2 = MapPointBuilder.CreateMapPoint(-5, 5, SpatialReferences.WGS84);
  // multipoint
  List<MapPoint> points = new List<MapPoint>() { point0, point1, point2 };
  Multipoint multipoint = MultipointBuilder.CreateMultipoint(points, SpatialReferences.WGS84);
  // polygon
  List<Coordinate2D> polygonCoords = new List<Coordinate2D>()
    new Coordinate2D(-10, 0),
    new Coordinate2D(0, 10),
    new Coordinate2D(10, 0),
  Polygon polygon = PolygonBuilder.CreatePolygon(polygonCoords, SpatialReferences.WGS84);
  // polylines
  Polyline polyline1 = PolylineBuilder.CreatePolyline(LineBuilder.CreateLineSegment(new Coordinate(-9.1, 0.1), new Coordinate(0, 9)), SpatialReferences.WGS84);
  Polyline polyline2 = PolylineBuilder.CreatePolyline(LineBuilder.CreateLineSegment(new Coordinate(-5, 5), new Coordinate(0, 5)), SpatialReferences.WGS84);
  Polyline polyline3 = PolylineBuilder.CreatePolyline(LineBuilder.CreateLineSegment(new Coordinate(2.09, -2.04), new Coordinate(5, 10)), SpatialReferences.WGS84);
  Polyline polyline4 = PolylineBuilder.CreatePolyline(LineBuilder.CreateLineSegment(new Coordinate(10, -5), new Coordinate(10, 5)), SpatialReferences.WGS84);
  List<Segment> segments = new List<Segment>()
    LineBuilder.CreateLineSegment(new Coordinate(5.05, -2.87), new Coordinate(6.35, 1.57)),
    LineBuilder.CreateLineSegment(new Coordinate(6.35, 1.57), new Coordinate(4.13, 2.59)),
    LineBuilder.CreateLineSegment(new Coordinate(4.13, 2.59), new Coordinate(5, 5))
  Polyline polyline5 = PolylineBuilder.CreatePolyline(segments, SpatialReferences.WGS84);
  segments.Add(LineBuilder.CreateLineSegment(new Coordinate(5, 5), new Coordinate(10, 10)));
  Polyline polyline6 = PolylineBuilder.CreatePolyline(segments, SpatialReferences.WGS84);
  Polyline polyline7 = PolylineBuilder.CreatePolyline(polyline5);
  Polyline polyline8 = PolylineBuilder.CreatePolyline(LineBuilder.CreateLineSegment(new Coordinate(5, 5), new Coordinate(10, 10)), SpatialReferences.WGS84);
  segments.Clear();
  segments.Add(LineBuilder.CreateLineSegment(new Coordinate(0.6, 3.5), new Coordinate(0.7, 7)));
  segments.Add(LineBuilder.CreateLineSegment(new Coordinate(0.7, 7), new Coordinate(3, 9)));
  Polyline polyline9 = PolylineBuilder.CreatePolyline(segments, SpatialReferences.WGS84);
  // now do the Related tests
  // Interior/Interior Intersects
  string scl = "T********";
  bool related = GeometryEngine.Relate(polygon, polyline1, scl);     // related = true
  related = GeometryEngine.Relate(point0, point1, scl);              // related = false
  related = GeometryEngine.Relate(point0, multipoint, scl);          // related = true
  related = GeometryEngine.Relate(multipoint, polygon, scl);         // related = true
  related = GeometryEngine.Relate(multipoint, polyline1, scl);       // related = false
  related = GeometryEngine.Relate(polyline2, point2, scl);           // related = false
  related = GeometryEngine.Relate(point1, polygon, scl);             // related = true
  // Interior/Boundary Intersects
  scl = "*T*******";
  related = GeometryEngine.Relate(polygon, polyline2, scl);          // related = true
  related = GeometryEngine.Relate(polygon, polyline3, scl);          // related = false
  related = GeometryEngine.Relate(point1, polygon, scl);             // related = false
  // Boundary/Boundary Interior intersects
  scl = "***T*****";
  related = GeometryEngine.Relate(polygon, polyline4, scl);          // related = true
  // Overlaps Dim1
  scl = "1*T***T**";
  related = GeometryEngine.Relate(polygon, polyline5, scl);          // related = true
  // Crosses Area/Line (LineB crosses PolygonA)
  scl = "1020F1102";
  related = GeometryEngine.Relate(polygon, polyline6, scl);          // related = false
  related = GeometryEngine.Relate(polygon, polyline9, scl);          // related = true
  // Boundary/Boundary Touches
  scl = "F***T****";
  related = GeometryEngine.Relate(polygon, polyline7, scl);          // related = false
  related = GeometryEngine.Relate(polygon, polyline8, scl);          // related = true
    now:
  // points
  // multipoint
  // polygon
  // polylines
  Polyline polyline1 = PolylineBuilder.CreatePolyline(LineBuilder.CreateLineSegment(new Coordinate2D(-9.1, 0.1), new Coordinate2D(0, 9)), SpatialReferences.WGS84);
  Polyline polyline2 = PolylineBuilder.CreatePolyline(LineBuilder.CreateLineSegment(new Coordinate2D(-5, 5), new Coordinate2D(0, 5)), SpatialReferences.WGS84);
  Polyline polyline3 = PolylineBuilder.CreatePolyline(LineBuilder.CreateLineSegment(new Coordinate2D(2.09, -2.04), new Coordinate2D(5, 10)), SpatialReferences.WGS84);
  Polyline polyline4 = PolylineBuilder.CreatePolyline(LineBuilder.CreateLineSegment(new Coordinate2D(10, -5), new Coordinate2D(10, 5)), SpatialReferences.WGS84);
    LineBuilder.CreateLineSegment(new Coordinate2D(5.05, -2.87), new Coordinate2D(6.35, 1.57)),
    LineBuilder.CreateLineSegment(new Coordinate2D(6.35, 1.57), new Coordinate2D(4.13, 2.59)),
    LineBuilder.CreateLineSegment(new Coordinate2D(4.13, 2.59), new Coordinate2D(5, 5))
  segments.Add(LineBuilder.CreateLineSegment(new Coordinate2D(5, 5), new Coordinate2D(10, 10)));
  Polyline polyline8 = PolylineBuilder.CreatePolyline(LineBuilder.CreateLineSegment(new Coordinate2D(5, 5), new Coordinate2D(10, 10)), SpatialReferences.WGS84);
  segments.Clear();
  segments.Add(LineBuilder.CreateLineSegment(new Coordinate2D(0.6, 3.5), new Coordinate2D(0.7, 7)));
  segments.Add(LineBuilder.CreateLineSegment(new Coordinate2D(0.7, 7), new Coordinate2D(3, 9)));
  bool related = GeometryEngine.Instance.Relate(polygon, polyline1, scl);     // related = true
  related = GeometryEngine.Instance.Relate(point0, point1, scl);              // related = false
  related = GeometryEngine.Instance.Relate(point0, multipoint, scl);          // related = true
  related = GeometryEngine.Instance.Relate(multipoint, polygon, scl);         // related = true
  related = GeometryEngine.Instance.Relate(multipoint, polyline1, scl);       // related = false
  related = GeometryEngine.Instance.Relate(polyline2, point2, scl);           // related = false
  related = GeometryEngine.Instance.Relate(point1, polygon, scl);             // related = true
  scl = "*T*******";
  related = GeometryEngine.Instance.Relate(polygon, polyline2, scl);          // related = true
  related = GeometryEngine.Instance.Relate(polygon, polyline3, scl);          // related = false
  related = GeometryEngine.Instance.Relate(point1, polygon, scl);             // related = false
  scl = "***T*****";
  related = GeometryEngine.Instance.Relate(polygon, polyline4, scl);          // related = true
  // Overlaps Dim1
  scl = "1*T***T**";
  related = GeometryEngine.Instance.Relate(polygon, polyline5, scl);          // related = true
  scl = "1020F1102";
  related = GeometryEngine.Instance.Relate(polygon, polyline6, scl);          // related = false
  related = GeometryEngine.Instance.Relate(polygon, polyline9, scl);          // related = true
  scl = "F***T****";
  related = GeometryEngine.Instance.Relate(polygon, polyline7, scl);          // related = false
  related = GeometryEngine.Instance.Relate(polygon, polyline8, scl);          // related = true
Replace NaN Zs in a polygon
    before:
  List<Coordinate> coordsZ = new List<Coordinate>()
    new Coordinate(1, 2, double.NaN),
    new Coordinate(4, 5, 3),
    new Coordinate(7, 8, double.NaN)
  Polygon polygon = PolygonBuilder.CreatePolygon(coordsZ);
  // polygon.HasZ = true
  Polygon polygonZReplaced = GeometryEngine.ReplaceNaNZs(polygon, -1) as Polygon;
  // polygonZReplaced.Points[0].Z = -1
  // polygonZReplaced.Points[1].Z = 3
  // polygonZReplaced.Points[2].Z = -1
    now:
  List<Coordinate3D> coordsZ = new List<Coordinate3D>()
    new Coordinate3D(1, 2, double.NaN),
    new Coordinate3D(4, 5, 3),
    new Coordinate3D(7, 8, double.NaN)
  Polygon polygonZReplaced = GeometryEngine.Instance.ReplaceNaNZs(polygon, -1) as Polygon;
Reverse the order of points in a Polygon
    before:
  Geometry g = GeometryEngine.ReverseOrientation(polygon);
  Polygon gPolygon = g as Polygon;
  // gPolygon.Points[0] = 1.0, 1.0
  // gPolygon.Points[1] = 2.0, 1.0
  // gPolygon.Points[2] = 2.0, 2.0
  // gPolygon.Points[3] = 1.0, 2.0
  // gPolygon.Points[4] = 1.0, 1.0
  // gPolygon.Area = -1 * polygon.Area
    now:
  Geometry g = GeometryEngine.Instance.ReverseOrientation(polygon);
Rotate a MapPoint
    before:
  MapPoint rotatePt = MapPointBuilder.CreateMapPoint(3.0, 3.0);
  Geometry result = GeometryEngine.Rotate(pt, rotatePt, Math.PI / 2);
  // result point is (3, 1)
    now:
  Geometry result = GeometryEngine.Instance.Rotate(pt, rotatePt, Math.PI / 2);
Rotate a Polyline
    before:
  // rotate a polyline
  MapPoint fixedPt = MapPointBuilder.CreateMapPoint(3.0, 3.0);
  pts.Add(MapPointBuilder.CreateMapPoint(1.0, 5.0));
  pts.Add(MapPointBuilder.CreateMapPoint(5, 5));
  Polyline rotated = GeometryEngine.Rotate(polyline, fixedPt, Math.PI / 4) as Polyline;  // rotate 45 deg
    now:
  Polyline rotated = GeometryEngine.Instance.Rotate(polyline, fixedPt, Math.PI / 4) as Polyline;  // rotate 45 deg
Set all Zs in a polyline
    before:
    new Coordinate(1, 2, 3),
    new Coordinate(4, 5, 6),
  Polyline polyline = PolylineBuilder.CreatePolyline(coordsZ);
  Polyline polylineSetZ = GeometryEngine.SetConstantZ(polyline, -1) as Polyline;
  // polylineSetZ.Points[0].Z = -1
  // polylineSetZ.Points[1].Z = -1
  // polylineSetZ.Points[2].Z = -1
  polylineSetZ = GeometryEngine.SetConstantZ(polyline, double.NaN) as Polyline;
  // polylineSetZ.Points[0].HasZ = true
  // polylineSetZ.Points[0].Z = NaN
  // polylineSetZ.Points[1].HasZ = true
  // polylineSetZ.Points[1].Z = NaN
  // polylineSetZ.Points[2].HasZ = true
  // polylineSetZ.Points[2].Z = NaN
  polylineSetZ = GeometryEngine.SetConstantZ(polyline, double.PositiveInfinity) as Polyline;
  // polylineSetZ.Points[0].Z = double.PositiveInfinity
  // polylineSetZ.Points[1].Z = double.PositiveInfinity
  // polylineSetZ.Points[2].Z = double.PositiveInfinity
    now:
    new Coordinate3D(1, 2, 3),
    new Coordinate3D(4, 5, 6),
  Polyline polylineSetZ = GeometryEngine.Instance.SetConstantZ(polyline, -1) as Polyline;
  polylineSetZ = GeometryEngine.Instance.SetConstantZ(polyline, double.NaN) as Polyline;
  polylineSetZ = GeometryEngine.Instance.SetConstantZ(polyline, double.PositiveInfinity) as Polyline;
Calculate area of geometry on surface of Earth's ellipsoid - ShapePreservingArea
    before:
  // pt
  MapPoint pt = MapPointBuilder.CreateMapPoint(1.0, 3.0, SpatialReferences.WebMercator);
  double area = GeometryEngine.ShapePreservingArea(pt);         // area = 0
  pts.Add(MapPointBuilder.CreateMapPoint(1.0, 3.0, 3.0));
  pts.Add(MapPointBuilder.CreateMapPoint(3, 3, 3.0));
  pts.Add(MapPointBuilder.CreateMapPoint(3.0, 1.0, 3.0));
  // multipoint
  Multipoint mPt = MultipointBuilder.CreateMultipoint(pts);
  area = GeometryEngine.ShapePreservingArea(mPt);               // area = 0
  // polyline
  area = GeometryEngine.ShapePreservingArea(polyline);          // area = 0
  // polygon
  Polygon polygon = PolygonBuilder.CreatePolygon(pts, SpatialReferences.WGS84);
  area = GeometryEngine.ShapePreservingArea(polygon);
  polygon = PolygonBuilder.CreatePolygon(pts, SpatialReferences.WebMercator);
    now:
  // pt
  double area = GeometryEngine.Instance.ShapePreservingArea(pt);         // area = 0
  // multipoint
  area = GeometryEngine.Instance.ShapePreservingArea(mPt);               // area = 0
  // polyline
  area = GeometryEngine.Instance.ShapePreservingArea(polyline);          // area = 0
  // polygon
  area = GeometryEngine.Instance.ShapePreservingArea(polygon);
Calculate length of geometry on surface of Earth's ellipsoid - ShapePreservingLength
    before:
  // pt
  double len = GeometryEngine.ShapePreservingLength(pt);          // len = 0
  // multipoint
  len = GeometryEngine.ShapePreservingLength(mPt);                // len = 0
  // polyline
  Polyline polyline = PolylineBuilder.CreatePolyline(pts, SpatialReferences.WGS84);
  len = GeometryEngine.ShapePreservingLength(polyline);
  // polygon
  len = GeometryEngine.ShapePreservingLength(polygon);
    now:
  // pt
  double len = GeometryEngine.Instance.ShapePreservingLength(pt);          // len = 0
  // multipoint
  len = GeometryEngine.Instance.ShapePreservingLength(mPt);                // len = 0
  // polyline
  len = GeometryEngine.Instance.ShapePreservingLength(polyline);
  // polygon
  len = GeometryEngine.Instance.ShapePreservingLength(polygon);
Scale a geometry
    before:
  MapPoint midPt = MapPointBuilder.CreateMapPoint(1.5, 1.5);
  // polyline
  // polyline.Length = 6
  Geometry g = GeometryEngine.Scale(polyline, midPt, 0.5, 0.5);
  Polyline resultPolyline = g as Polyline;
  // resultPolyline.length  = 3
  // resultPolyline.Points[0] = 1.25, 1.25, 3
  // resultPolyline.Points[1] = 1.25, 2.25, 3
  // resultPolyline.Points[2] = 2.25, 2.25, 3
  // resultPolyline.Points[3] = 2.25, 1.25, 3
  // 3D point - scale in 3d
  MapPoint midPtZ = MapPointBuilder.CreateMapPoint(1.5, 1.5, 1);
  g = GeometryEngine.Scale(polyline, midPtZ, 0.5, 0.5, 0.25);
  // resultPolyline.Points[0] = 1.25, 1.25, 1.5
  // resultPolyline.Points[1] = 1.25, 2.25, 1.5
  // resultPolyline.Points[2] = 2.25, 2.25, 1.5
  // resultPolyline.Points[3] = 2.25, 1.25, 1.5
    now:
  // polyline
  Geometry g = GeometryEngine.Instance.Scale(polyline, midPt, 0.5, 0.5);
  g = GeometryEngine.Instance.Scale(polyline, midPtZ, 0.5, 0.5, 0.25);
Simplify a polyline with intersections, overlaps
    before:
  List<Coordinate> coords = new List<Coordinate>()
    new Coordinate(8, 0),
    new Coordinate(8, 4),
    new Coordinate(6, 4),
    new Coordinate(10, 4),
  // build a line that has segments that cross over each other
  ReadOnlyPartCollection parts = polyline.Parts;
  ReadOnlySegmentCollection segments = parts[0];
  // segments.Count = 5
  //  note there is a difference between SimpleAsFeature (doesn't detect intersections and overlaps, determines if it's simple enough for gdb storage)
  //  and SimplifyPolyline  (does detect intersections etc)
  bool isSimple = GeometryEngine.IsSimpleAsFeature(polyline, false);
  // isSimple = true
  // simplify it (with force = false)
  // because it has already been deemed 'simple' (previous IsSimpleAsFeature call) no detection of intersections, overlaps occur
  Polyline simplePolyline = GeometryEngine.SimplifyPolyline(polyline, SimplifyType.Planar, false);
  // simplePolyline.PartCount = 1
  ReadOnlyPartCollection simpleParts = simplePolyline.Parts;
  ReadOnlySegmentCollection simpleSegments = simpleParts[0];
  // simpleSegments.Count = 5
  // simplify it (with force = true)
  // detection of intersections, overlaps occur
  simplePolyline = GeometryEngine.SimplifyPolyline(polyline, SimplifyType.Planar, true);
  // simplePolyline.PartCount = 3
  // simpleSegments.Count = 1
    now:
  List<Coordinate2D> coords = new List<Coordinate2D>()
    new Coordinate2D(8, 0),
    new Coordinate2D(8, 4),
    new Coordinate2D(6, 4),
    new Coordinate2D(10, 4),
  bool isSimple = GeometryEngine.Instance.IsSimpleAsFeature(polyline, false);
  // isSimple = true
  Polyline simplePolyline = GeometryEngine.Instance.SimplifyPolyline(polyline, SimplifyType.Planar, false);
  simplePolyline = GeometryEngine.Instance.SimplifyPolyline(polyline, SimplifyType.Planar, true);
Polygon touches another Polygon
    before:
  // two disjoint polygons
  Envelope env = EnvelopeBuilder.CreateEnvelope(MapPointBuilder.CreateMapPoint(4.0, 4.0), MapPointBuilder.CreateMapPoint(8, 8));
  Polygon poly1 = PolygonBuilder.CreatePolygon(env);
  Envelope env2 = EnvelopeBuilder.CreateEnvelope(MapPointBuilder.CreateMapPoint(1.0, 1.0), MapPointBuilder.CreateMapPoint(5, 5));
  bool touches = GeometryEngine.Touches(poly1, poly2);    // touches = false
  // another polygon that touches the first
  Envelope env3 = EnvelopeBuilder.CreateEnvelope(MapPointBuilder.CreateMapPoint(1.0, 1.0), MapPointBuilder.CreateMapPoint(4, 4));
  Polygon poly3 = PolygonBuilder.CreatePolygon(env3);
  touches = GeometryEngine.Touches(poly1, poly3);         // touches = true
    now:
  bool touches = GeometryEngine.Instance.Touches(poly1, poly2);    // touches = false
  touches = GeometryEngine.Instance.Touches(poly1, poly3);         // touches = true
Union two MapPoints - creates a Multipoint
    before:
  MapPoint pt1 = MapPointBuilder.CreateMapPoint(1.0, 1.0);
  Geometry geometry = GeometryEngine.Union(pt1, pt2);
  Multipoint multipoint = geometry as Multipoint;   // multipoint has point count of 2
    now:
  Geometry geometry = GeometryEngine.Instance.Union(pt1, pt2);
Union two Polygons
    before:
  // union two polygons
  bool isSimple = GeometryEngine.IsSimpleAsFeature(poly1);
  isSimple = GeometryEngine.IsSimpleAsFeature(poly2);
  Geometry g = GeometryEngine.Union(poly1, poly2);
  Polygon polyResult = g as Polygon;
    now:
  bool isSimple = GeometryEngine.Instance.IsSimpleAsFeature(poly1);
  isSimple = GeometryEngine.Instance.IsSimpleAsFeature(poly2);
  Geometry g = GeometryEngine.Instance.Union(poly1, poly2);
Union many Polylines
    before:
  // union many polylines
    new Coordinate2D(1, 2), new Coordinate2D(3, 4), new Coordinate2D(4, 2),
    new Coordinate2D(5, 6), new Coordinate2D(7, 8), new Coordinate2D(8, 4),
    new Coordinate2D(9, 10), new Coordinate2D(11, 12), new Coordinate2D(12, 8),
    new Coordinate2D(10, 8), new Coordinate2D(12, 12), new Coordinate2D(14, 10)
  // create Disjoint lines
  List<Polyline> manyLines = new List<Polyline>
    PolylineBuilder.CreatePolyline(new List<Coordinate2D>(){coords[0], coords[1], coords[2]}, SpatialReferences.WGS84),
    PolylineBuilder.CreatePolyline(new List<Coordinate2D>(){coords[3], coords[4], coords[5]}),
    PolylineBuilder.CreatePolyline(new List<Coordinate2D>(){coords[6], coords[7], coords[8]})
  Polyline polyline = GeometryEngine.Union(manyLines) as Polyline;
    now:
  Polyline polyline = GeometryEngine.Instance.Union(manyLines) as Polyline;
Union many Polygons
    before:
  // union many polygons
    new Coordinate(1, 2, 0), new Coordinate(3, 4, 1), new Coordinate(4, 2, 2),
    new Coordinate(5, 6, 3), new Coordinate(7, 8, 4), new Coordinate(8, 4, 5),
    new Coordinate(9, 10, 6), new Coordinate(11, 12, 7), new Coordinate(12, 8, 8),
    new Coordinate(10, 8, 9), new Coordinate(12, 12, 10), new Coordinate(14, 10, 11)
  // create polygons
  List<Polygon> manyPolygonsZ = new List<Polygon>
    PolygonBuilder.CreatePolygon(new List<Coordinate>(){coordsZ[0], coordsZ[1], coordsZ[2]}, SpatialReferences.WGS84),
    PolygonBuilder.CreatePolygon(new List<Coordinate>(){coordsZ[3], coordsZ[4], coordsZ[5]}),
    PolygonBuilder.CreatePolygon(new List<Coordinate>(){coordsZ[6], coordsZ[7], coordsZ[8]})
  Polygon polygon = GeometryEngine.Union(manyPolygonsZ) as Polygon;
    now:
    new Coordinate3D(1, 2, 0), new Coordinate3D(3, 4, 1), new Coordinate3D(4, 2, 2),
    new Coordinate3D(5, 6, 3), new Coordinate3D(7, 8, 4), new Coordinate3D(8, 4, 5),
    new Coordinate3D(9, 10, 6), new Coordinate3D(11, 12, 7), new Coordinate3D(12, 8, 8),
    new Coordinate3D(10, 8, 9), new Coordinate3D(12, 12, 10), new Coordinate3D(14, 10, 11)
  // create polygons
    PolygonBuilder.CreatePolygon(new List<Coordinate3D>(){coordsZ[0], coordsZ[1], coordsZ[2]}, SpatialReferences.WGS84),
    PolygonBuilder.CreatePolygon(new List<Coordinate3D>(){coordsZ[3], coordsZ[4], coordsZ[5]}),
    PolygonBuilder.CreatePolygon(new List<Coordinate3D>(){coordsZ[6], coordsZ[7], coordsZ[8]})
  Polygon polygon = GeometryEngine.Instance.Union(manyPolygonsZ) as Polygon;
MapPoints, Polylines, Polygons within Polygon
    before:
  // build a polygon
  pts.Add(MapPointBuilder.CreateMapPoint(1.0, 1.0));
  pts.Add(MapPointBuilder.CreateMapPoint(1.0, 2.0));
  pts.Add(MapPointBuilder.CreateMapPoint(2.0, 2.0));
  pts.Add(MapPointBuilder.CreateMapPoint(2.0, 1.0));
  Polygon poly = PolygonBuilder.CreatePolygon(pts);
  // an inner point
  MapPoint innerPt = MapPointBuilder.CreateMapPoint(1.5, 1.5);
  bool within = GeometryEngine.Within(innerPt, poly);   // within = true
  // point on a boundary
  within = GeometryEngine.Within(pts[0], poly);     // within = false
  // an interior line
  MapPoint innerPt2 = MapPointBuilder.CreateMapPoint(1.25, 1.75);
  List<MapPoint> innerLinePts = new List<MapPoint>();
  innerLinePts.Add(innerPt);
  innerLinePts.Add(innerPt2);
  Polyline polyline = PolylineBuilder.CreatePolyline(innerLinePts);
  within = GeometryEngine.Within(polyline, poly);   // within = true
  // a line that crosses the boundary
  MapPoint outerPt = MapPointBuilder.CreateMapPoint(3, 1.5);
  List<MapPoint> crossingLinePts = new List<MapPoint>();
  crossingLinePts.Add(innerPt);
  crossingLinePts.Add(outerPt);
  polyline = PolylineBuilder.CreatePolyline(crossingLinePts);
  within = GeometryEngine.Within(polyline, poly);     // within = false
  // polygon in polygon
  Envelope env = EnvelopeBuilder.CreateEnvelope(innerPt, innerPt2);
  within = GeometryEngine.Within(env, poly);      // within = true
    now:
  // build a polygon
  // an inner point
  bool within = GeometryEngine.Instance.Within(innerPt, poly);   // within = true
  within = GeometryEngine.Instance.Within(pts[0], poly);     // within = false
  // an interior line
  within = GeometryEngine.Instance.Within(polyline, poly);   // within = true
  within = GeometryEngine.Instance.Within(polyline, poly);     // within = false
  within = GeometryEngine.Instance.Within(env, poly);      // within = true
Create Projection Transformation
    before:
// methods need to be on the MCT
  SpatialReference sr4267 = SpatialReferenceBuilder.CreateSpatialReference(4267);
  SpatialReference sr4326 = SpatialReferences.WGS84;
  SpatialReference sr3857 = SpatialReferences.WebMercator;
  // Create transformation from  4267 -> 3857
  ProjectionTransformation projTransFromSRs = ArcGIS.Core.Geometry.ProjectionTransformation.Create(sr4267, sr3857);
  // create an envelope
  Envelope env = EnvelopeBuilder.CreateEnvelope(new Coordinate2D(2, 2), new Coordinate2D(3, 3), sr4267);
  // Project with one geo transform 4267 -> 3857
  Envelope projectedEnvEx = GeometryEngine.ProjectEx(env, projTransFromSRs) as Envelope;
  // Create inverse transformation, 3857 -> 4267
  ProjectionTransformation projTransFromSRsInverse = ArcGIS.Core.Geometry.ProjectionTransformation.Create(sr3857, sr4267);
  // Project the projected envelope back using the inverse transformation
  Envelope projectedEnvBack = GeometryEngine.ProjectEx(projectedEnvEx, projTransFromSRsInverse) as Envelope;
  bool isEqual = env.IsEqual(projectedEnvBack);
    now:
  Envelope projectedEnvEx = GeometryEngine.Instance.ProjectEx(env, projTransFromSRs) as Envelope;
  Envelope projectedEnvBack = GeometryEngine.Instance.ProjectEx(projectedEnvEx, projTransFromSRsInverse) as Envelope;
MapPoint - GeoCoordinateString Conversion
    before:
  SpatialReference sr2 = SpatialReferences.WebMercator;
  // create some points
  MapPoint point0 = MapPointBuilder.CreateMapPoint(0, 0, sr);
  MapPoint point1 = MapPointBuilder.CreateMapPoint(10, 20, sr);
  MapPoint point2 = GeometryEngine.Project(point1, sr2) as MapPoint;
  MapPoint pointEmpty = MapPointBuilder.CreateMapPoint(sr);
  MapPoint pointwithNoSR = MapPointBuilder.CreateMapPoint(1, 1);
  MapPoint pointZM = MapPointBuilder.CreateMapPoint(1, 2, 3, 4, sr);
  // convert to MGRS
  ToGeoCoordinateParameter mgrsParam = new ToGeoCoordinateParameter(GeoCoordinateType.MGRS);
  string geoCoordString = point0.ToGeoCoordinateString(mgrsParam);        // 31NAA6602100000
  // use the builder to create a new point from the string.  Coordinates are the same
  MapPoint outPoint = MapPointBuilder.FromGeoCoordinateString(geoCoordString, sr, GeoCoordinateType.MGRS);    // outPoint.x = 0; outPoint.Y = 0
  geoCoordString = point1.ToGeoCoordinateString(mgrsParam);             // 32QPH0460911794
  outPoint = MapPointBuilder.FromGeoCoordinateString(geoCoordString, sr, GeoCoordinateType.MGRS);       // outPoint.X = 10; outPoint.Y = 20
  // z, m are not transformed
  geoCoordString = pointZM.ToGeoCoordinateString(mgrsParam);
  outPoint = MapPointBuilder.FromGeoCoordinateString(geoCoordString, sr, GeoCoordinateType.MGRS);     // outPoint.X = 1; outPoint.Y = 2; outPoint.Z = Nan; outPoint.M = Nan;
  // set the number of digits to 2 and convert
  mgrsParam.NumDigits = 2;
  geoCoordString = point1.ToGeoCoordinateString(mgrsParam);             // 32QPH0512
  // convert to UTM
  ToGeoCoordinateParameter utmParam = new ToGeoCoordinateParameter(GeoCoordinateType.UTM);
  geoCoordString = point0.ToGeoCoordinateString(utmParam);        // 31N 166021 0000000
  geoCoordString = point1.ToGeoCoordinateString(utmParam);        // 32Q 604609 2211793
  // convert to DMS
  ToGeoCoordinateParameter dmsParam = new ToGeoCoordinateParameter(GeoCoordinateType.DMS);
  geoCoordString = point0.ToGeoCoordinateString(dmsParam);        // 00 00 00.00N 000 00 00.00E
  geoCoordString = point1.ToGeoCoordinateString(dmsParam);        // 20 00 00.00N 010 00 00.00E
  // convert to DDM
  ToGeoCoordinateParameter ddmParam = new ToGeoCoordinateParameter(GeoCoordinateType.DDM);
  geoCoordString = point0.ToGeoCoordinateString(ddmParam);        // 00 00.0000N 000 00.0000E
  geoCoordString = point1.ToGeoCoordinateString(ddmParam);        // 20 00.0000N 010 00.0000E
  // convert to DD
  ToGeoCoordinateParameter ddParam = new ToGeoCoordinateParameter(GeoCoordinateType.DD);
  geoCoordString = point0.ToGeoCoordinateString(ddParam);       // 00.000000N 000.000000E
  geoCoordString = point1.ToGeoCoordinateString(ddParam);       // 20.000000N 010.000000E
    now:
  SpatialReference sr = SpatialReferences.WGS84;
  MapPoint point2 = GeometryEngine.Instance.Project(point1, sr2) as MapPoint;
  // convert to MGRS
  // convert to UTM
  // convert to DMS
  // convert to DDM
  // convert to DD
Geoprocessing
Get Geoprocessing project items
    before:
var gpItems = CoreModule.CurrentProject.Items.OfType<GeoprocessingProjectItem>();
// go through all the available toolboxes
foreach (var gpItem in gpItems)
    var itemsInsideToolBox = await gpItem.GetItemsAsync();
    // then for each toolbox list the tools inside
    foreach (var toolItem in itemsInsideToolBox)
        string newTool = String.Join(";", new string[] { toolItem.Path, toolItem.Name });
        // do something with the newTool
        // for example, add to a list to track or use them later
    now:
  var itemsInsideToolBox = gpItem.GetItems();
Layouts
Retrieve layout project items
    before:
// get all the layouts
IEnumerable<LayoutProjectItem> layouts = Project.Current.GetItems<LayoutProjectItem>();
// or get a specific layout (by name)
LayoutProjectItem layoutItem = Project.Current.GetItems<LayoutProjectItem>().FirstOrDefault(item => item.Name.Equals("MyLayout"));
if (layoutItem != null)
  // Delete the layout from the project
  Project.Current.RemoveAsync(layoutItem);
    now:
  Project.Current.RemoveItem(layoutItem);
Update Text Element properties
    before:
// Reference a layoutitem in a project by name
    // Reference and load the layout associated with the layout item
    Layout layout = layoutItem.GetLayout();
    if (layout != null)
      // Reference a text element by name
      TextElement txtElm = layout.FindElement("MyTextElement") as TextElement;
      if (txtElm != null)
        // Change placement properties
        PlacementProperties txtPlacement = txtElm.GetPlacement();
        txtPlacement.Anchor = ArcGIS.Core.CIM.Anchor.CenterPoint;
        txtPlacement.X = x;
        txtPlacement.Y = y;
        txtElm.SetPlacement(txtPlacement);
        // Change TextProperties
        TextProperties txtProperties = new TextProperties("Hello world", "Times New Roman", 48);
        txtElm.SetTextProperties(txtProperties);
    now:
    if (layout != null)
      if (txtElm != null)
        txtElm.SetAnchor(ArcGIS.Core.CIM.Anchor.CenterPoint);
        txtElm.SetX(x);
        txtElm.SetY(y);
        TextProperties txtProperties = new TextProperties("Hello world", "Times New Roman", 48, "Regular");
Update a picture element
    before:
    if (layout != null)
      // Reference a picture element by name
      PictureElement picElm = layout.FindElement("MyPicture") as PictureElement;
      // Change the path to a new source
      if (picElm != null)
        picElm.SetSourcePath(@"D:\MyData\Pics\LakeHuron.jpg");
    now:
  if (layout != null)
    if (picElm != null)
      picElm.SetSourcePath(@"D:\MyData\Pics\somePic.jpg");
Lock an element
    before:
// The Locked property is displayed in the TOC as a lock symbol next to each element.
// If locked the element can't be selected in the layout using the graphic
// selection tools.
    if (layout != null)
      //Reference an element by name
      Element element = layout.FindElement("MyElement");
      if (element != null)
        // Modify the Locked property via the CIM
        ArcGIS.Core.CIM.CIMElement CIMElement = element.Definition as ArcGIS.Core.CIM.CIMElement;
        CIMElement.Locked = true;
        element.SetDefinition(CIMElement);
    now:
// selection tools.
  if (layout != null)
      ArcGIS.Core.CIM.CIMElement CIMElement = element.GetDefinition() as ArcGIS.Core.CIM.CIMElement;
Clone an element
    before:
  if (layout != null)
    // Reference a element by name
    GraphicElement graphicElement = layout.FindElement("MyElement") as GraphicElement;
    if (graphicElement != null)
      // get the placement properties
      PlacementProperties graPlace = graphicElement.GetPlacement();
      // clone and set the new x,y
      var cloneElement = graphicElement.Clone("Clone");
      graPlace.X = graPlace.X + xOffset;
      graPlace.Y = graPlace.Y - yOffset;
      cloneElement.SetPlacement(graPlace);
    now:
  if (layout != null)
      GraphicElement cloneElement = graphicElement.Clone("Clone");
      cloneElement.SetX(cloneElement.GetX() + xOffset);
      cloneElement.SetY(cloneElement.GetY() + yOffset);
Access map frame and map bookmarks from Layout
    before:
    if (layout == null)
      return;
    // Reference a mapframe by name
    MapFrame mf = layout.Elements.FirstOrDefault(item => item.Name.Equals("MapFrame")) as MapFrame;
    if (mf == null)
      return;
    // get the mapframe's MapView
    ArcGIS.Desktop.Mapping.MapView mv = mf.MapView;
    if (mv == null)
      return;
    // get the map and the bookmarks
    ArcGIS.Desktop.Mapping.Map map = mf.Map;
    var bookmarks = map.GetBookmarks();
    if (bookmarks == null)
      return;
    // Loop through each bookmark
    foreach (var bookmark in bookmarks)
      // Set up a PDF format and set its properties
      ArcGIS.Desktop.Mapping.PDFFormat PDF = new ArcGIS.Desktop.Mapping.PDFFormat();
      String path = String.Format(@"C:\Temp\{0}.pdf", bookmark.Name);
      PDF.OutputFileName = path;
      // Zoom to the bookmark - use 0 just in case the app backstage Navigation Transition Time is > 0
      mv.ZoomTo(bookmark, TimeSpan.FromSeconds(0));
      // Export to PDF
      if (PDF.ValidateOutputFilePath())
        mf.Export(PDF);
    now:
    if (layout == null)
      return;
    if (mf == null)
      return;
    Bookmark bookmark = mf.Map.GetBookmarks().FirstOrDefault(b => b.Name == "Great Lakes");
    if (bookmark == null)
      return;
    mf.SetCamera(bookmark);
    // Export to PDF
        mf.Export(PDF);
Export a layout
    before:
    if (layout == null)
      return;
    // Create BMP format with appropriate settings
    ArcGIS.Desktop.Mapping.BMPFormat BMP = new ArcGIS.Desktop.Mapping.BMPFormat();
    BMP.Resolution = 300;
    BMP.OutputFileName = @"C:\temp\Layout.bmp";
    if (BMP.ValidateOutputFilePath())
      layout.Export(BMP);
    // Create EMF format with appropriate settings
    ArcGIS.Desktop.Mapping.EMFFormat EMF = new ArcGIS.Desktop.Mapping.EMFFormat();
    EMF.Resolution = 300;
    EMF.OutputFileName = @"C:\temp\Layout.emf";
    if (EMF.ValidateOutputFilePath())
      layout.Export(EMF);
    // create eps format with appropriate settings
    ArcGIS.Desktop.Mapping.EPSFormat EPS = new ArcGIS.Desktop.Mapping.EPSFormat();
    EPS.Resolution = 300;
    EPS.OutputFileName = @"C:\temp\Layout.eps";
    if (EPS.ValidateOutputFilePath())
      layout.Export(EPS);
    // Create GIF format with appropriate settings
    ArcGIS.Desktop.Mapping.GIFFormat GIF = new ArcGIS.Desktop.Mapping.GIFFormat();
    GIF.Resolution = 300;
    GIF.OutputFileName = @"C:\temp\Layout.gif";
    if (GIF.ValidateOutputFilePath())
      layout.Export(GIF);
    // Create JPEG format with appropriate settings
    ArcGIS.Desktop.Mapping.JPEGFormat JPEG = new ArcGIS.Desktop.Mapping.JPEGFormat();
    JPEG.Resolution = 300;
    JPEG.OutputFileName = @"C:\temp\Layout.jpg";
    if (JPEG.ValidateOutputFilePath())
      layout.Export(JPEG);
    // Create PDF format with appropriate settings
    PDF.Resolution = 300;
    PDF.OutputFileName = @"C:\temp\Layout.pdf";
      layout.Export(PDF);
    // Create PNG format with appropriate settings
    ArcGIS.Desktop.Mapping.PNGFormat PNG = new ArcGIS.Desktop.Mapping.PNGFormat();
    PNG.Resolution = 300;
    PNG.OutputFileName = @"C:\temp\Layout.png";
    if (PNG.ValidateOutputFilePath())
      layout.Export(PNG);
    // Create SVG format with appropriate settings
    ArcGIS.Desktop.Mapping.SVGFormat SVG = new ArcGIS.Desktop.Mapping.SVGFormat();
    SVG.Resolution = 300;
    SVG.OutputFileName = @"C:\temp\Layout.svg";
    if (SVG.ValidateOutputFilePath())
      layout.Export(SVG);
    // Create TGA format with appropriate settings
    ArcGIS.Desktop.Mapping.TGAFormat TGA = new ArcGIS.Desktop.Mapping.TGAFormat();
    TGA.Resolution = 300;
    TGA.OutputFileName = @"C:\temp\Layout.tga";
    if (TGA.ValidateOutputFilePath())
      layout.Export(TGA);
    // Create TIFF format with appropriate settings
    ArcGIS.Desktop.Mapping.TIFFFormat TIFF = new ArcGIS.Desktop.Mapping.TIFFFormat();
    TIFF.Resolution = 300;
    TIFF.OutputFileName = @"C:\temp\Layout.tif";
    if (TIFF.ValidateOutputFilePath())
      layout.Export(TIFF);
    now:
    if (layout == null)
      return;
      Resolution = 300,
      layout.Export(BMP);
      Resolution = 300,
      layout.Export(EMF);
      Resolution = 300,
      layout.Export(EPS);
      Resolution = 300,
      layout.Export(GIF);
      Resolution = 300,
      Resolution = 300,
      layout.Export(PDF);
      Resolution = 300,
      layout.Export(PNG);
      Resolution = 300,
      layout.Export(SVG);
      Resolution = 300,
      layout.Export(TGA);
      Resolution = 300,
Export a map frame
    before:
    // get the layout
    if (layout == null)
      return;
    // get the map frame
    MapFrame mf = layout.FindElement("MyMapFrame") as MapFrame;
    if (mf != null)
      BMP.HasWorldFile = true;
      BMP.OutputFileName = @"C:\temp\MapFrame.bmp";
        mf.Export(BMP);
      // emf, eps, gif, jpeg, pdf, png, svg, tga, tiff formats are also available for export
    now:
    // get the layout
    if (layout == null)
      return;
    if (mf != null)
        HasWorldFile = true,
        Resolution = 300,
        mf.Export(BMP);
Export the active Mapview
    before:
  if (MapView.Active != null)
    //Create BMP format with appropriate settings
    ArcGIS.Desktop.Mapping.BMPFormat bmp = new ArcGIS.Desktop.Mapping.BMPFormat();
    bmp.Resolution = 300;
    bmp.Height = 500;
    bmp.Width = 800;
    bmp.HasWorldFile = true;
    bmp.OutputFileName = @"C:\temp\MapView.bmp";
    //Export active map view
    if (bmp.ValidateOutputFilePath())
      MapView.Active.Export(bmp);
    // emf, eps, gif, jpeg, pdf, png, svg, tga, tiff formats also available for export
    now:
      Resolution = 300,
      Height = 500,
      Width = 800,
MapAuthoring
How to create a new style
    before:
//Full path for the new style file (.stylx) to be created
string styleToCreate = @"C:\Temp\NewStyle.stylx";
await Project.Current.CreateStyleAsync(styleToCreate);
    now:
await QueuedTask.Run(() => StyleHelper.CreateStyle(Project.Current, styleToCreate));
How to add a style to project
    before:
//For ArcGIS Pro system styles, just pass in the name of the style to add to the project
await Project.Current.AddStyleAsync("3D Vehicles");
//For custom styles, pass in the full path to the style file on disk
string customStyleToAdd = @"C:\Temp\CustomStyle.stylx";
await Project.Current.AddStyleAsync(customStyleToAdd);
    now:
await QueuedTask.Run(() => StyleHelper.AddStyle(Project.Current, "3D Vehicles"));
await QueuedTask.Run(() => StyleHelper.AddStyle(Project.Current, customStyleToAdd));
How to remove a style from project
    before:
//For ArcGIS Pro system styles,, just pass in the name of the style to remove from the project
await Project.Current.RemoveStyleAsync("3D Vehicles");
string customStyleToRemove = @"C:\Temp\CustomStyle.stylx";
await Project.Current.RemoveStyleAsync(customStyleToRemove);
    now:
//For ArcGIS Pro system styles, just pass in the name of the style to remove from the project
await QueuedTask.Run(() => StyleHelper.RemoveStyle(Project.Current, "3D Vehicles"));
await QueuedTask.Run(() => StyleHelper.RemoveStyle(Project.Current, customStyleToAdd));
How to determine if a style can be upgraded
    before:
//Pass in the full path to the style file on disk
public async Task<bool> CanUpgradeStyleAsync(string stylePath)
  //Add the style to the current project
  await Project.Current.AddStyleAsync(stylePath);
  StyleProjectItem style = Project.Current.GetItems<StyleProjectItem>().First(x => x.Path == stylePath);
  //returns true if style can be upgraded
  return style.CanBeUpgraded();
    now:
  await QueuedTask.Run(() => StyleHelper.AddStyle(Project.Current, stylePath));
How to determine if a style is read-only
    before:
public async Task<bool> IsReadOnly(string stylePath)
  //returns true if style is read-only
  return style.IsReadOnly();
    now:
How to determine if a style is current
    before:
public async Task<bool> IsCurrent(string stylePath)
  //returns true if style matches the current Pro version
  return style.IsCurrent();
    now:
How to upgrade a style
    before:
public async Task<bool> UpgradeStyleAsync(string stylePath)
  bool success = false;
  //Verify that style can be upgraded
  if (style.CanBeUpgraded())
    success = await StyleHelper.UpgradeStyleAsync(style);
  //return true if style was upgraded
  return success;
    now:
    success = await QueuedTask.Run(() => StyleHelper.UpgradeStyle(style));
  return success;
How to construct a point symbol of a specific color and size
    before:
  CIMPointSymbol pointSymbol = SymbolFactory.ConstructPointSymbol(ColorFactory.RedRGB, 10.0);
    now:
  CIMPointSymbol pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB, 10.0);
How to construct a point symbol of a specific color, size and shape
    before:
  CIMPointSymbol starPointSymbol = SymbolFactory.ConstructPointSymbol(ColorFactory.RedRGB, 10.0, SimpleMarkerStyle.Star);
    now:
  CIMPointSymbol starPointSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB, 10.0, SimpleMarkerStyle.Star);
How to construct a point symbol from a marker
    before:
  CIMMarker marker = SymbolFactory.ConstructMarker(ColorFactory.GreenRGB, 8.0, SimpleMarkerStyle.Pushpin);
  CIMPointSymbol pointSymbolFromMarker = SymbolFactory.ConstructPointSymbol(marker);
    now:
  CIMMarker marker = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.GreenRGB, 8.0, SimpleMarkerStyle.Pushpin);
  CIMPointSymbol pointSymbolFromMarker = SymbolFactory.Instance.ConstructPointSymbol(marker);
How to construct a point symbol from a file on disk
    before:
//The following file formats can be used to create the marker: DAE, 3DS, FLT, EMF, JPG, PNG, BMP, GIF
CIMMarker markerFromFile = await SymbolFactory.ConstructMarkerFromFileAsync(@"C:\Temp\fileName.dae");
CIMPointSymbol pointSymbolFromFile = SymbolFactory.ConstructPointSymbol(markerFromFile);
    now:
CIMMarker markerFromFile = await QueuedTask.Run(() => SymbolFactory.Instance.ConstructMarkerFromFile(@"C:\Temp\fileName.dae"));
CIMPointSymbol pointSymbolFromFile = SymbolFactory.Instance.ConstructPointSymbol(markerFromFile);
How to construct a polygon symbol of specific color and fill style
    before:
CIMPolygonSymbol polygonSymbol = SymbolFactory.ConstructPolygonSymbol(ColorFactory.RedRGB, SimpleFillStyle.Solid);
    now:
CIMPolygonSymbol polygonSymbol = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.RedRGB, SimpleFillStyle.Solid);
How to construct a polygon symbol of specific color, fill style and outline
    before:
CIMStroke outline = SymbolFactory.ConstructStroke(ColorFactory.BlueRGB, 2.0, SimpleLineStyle.Solid);
CIMPolygonSymbol fillWithOutline = SymbolFactory.ConstructPolygonSymbol(ColorFactory.RedRGB, SimpleFillStyle.Solid, outline);
    now:
CIMStroke outline = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlueRGB, 2.0, SimpleLineStyle.Solid);
CIMPolygonSymbol fillWithOutline = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.RedRGB, SimpleFillStyle.Solid, outline);
How to construct a polygon symbol without an outline
    before:
CIMPolygonSymbol fillWithoutOutline = SymbolFactory.ConstructPolygonSymbol(ColorFactory.RedRGB, SimpleFillStyle.Solid, null);
    now:
CIMPolygonSymbol fillWithoutOutline = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.RedRGB, SimpleFillStyle.Solid, null);
How to construct a line symbol of specific color, size and line style
    before:
CIMLineSymbol lineSymbol = SymbolFactory.ConstructLineSymbol(ColorFactory.BlueRGB, 4.0, SimpleLineStyle.Solid);
    now:
CIMLineSymbol lineSymbol = SymbolFactory.Instance.ConstructLineSymbol(ColorFactory.Instance.BlueRGB, 4.0, SimpleLineStyle.Solid);
How to construct a line symbol from a stroke
    before:
CIMStroke stroke = SymbolFactory.ConstructStroke(ColorFactory.BlackRGB, 2.0);
CIMLineSymbol lineSymbolFromStroke = SymbolFactory.ConstructLineSymbol(stroke);
    now:
CIMStroke stroke = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlackRGB, 2.0);
CIMLineSymbol lineSymbolFromStroke = SymbolFactory.Instance.ConstructLineSymbol(stroke);
How to construct a multilayer line symbol with circle markers on the line ends
    before:
//These methods must be called within the lambda passed to QueuedTask.Run
var lineStrokeRed = SymbolFactory.ConstructStroke(ColorFactory.RedRGB, 4.0);
var markerCircle = SymbolFactory.ConstructMarker(ColorFactory.RedRGB, 12, SimpleMarkerStyle.Circle);
markerCircle.MarkerPlacement = new CIMMarkerPlacementOnVertices()
  AngleToLine = true,
  PlaceOnEndPoints = true,
  Offset = 0
var lineSymbolWithCircles = new CIMLineSymbol()
  SymbolLayers = new CIMSymbolLayer[2] { markerCircle, lineStrokeRed }
    now:
var lineStrokeRed = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.RedRGB, 4.0);
var markerCircle = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.RedRGB, 12, SimpleMarkerStyle.Circle);
  AngleToLine = true,
  Offset = 0
How to construct a multilayer line symbol with an arrow head on the end
    before:
var markerTriangle = SymbolFactory.ConstructMarker(ColorFactory.RedRGB, 12, SimpleMarkerStyle.Triangle);
markerTriangle.Rotation = -90; // or -90
markerTriangle.MarkerPlacement = new CIMMarkerPlacementOnLine() { AngleToLine = true, RelativeTo = PlacementOnLineRelativeTo.LineEnd };
var lineSymbolWithArrow = new CIMLineSymbol()
  SymbolLayers = new CIMSymbolLayer[2] { markerTriangle,
              SymbolFactory.ConstructStroke(ColorFactory.RedRGB, 2)
    now:
var markerTriangle = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.RedRGB, 12, SimpleMarkerStyle.Triangle);
              SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.RedRGB, 2)
How to get symbol reference from a symbol
    before:
CIMPolygonSymbol symbol = SymbolFactory.ConstructPolygonSymbol(ColorFactory.RedRGB);
//Get symbol reference from the symbol
CIMSymbolReference symbolReference = symbol.MakeSymbolReference();
    now:
CIMPolygonSymbol symbol = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.RedRGB);
How to search for point symbols in a style
    before:
public Task<IList<SymbolStyleItem>> GetPointSymbolsFromStyleAsync(StyleProjectItem style, string searchString)
  if (style == null)
    throw new System.ArgumentNullException();
  //Search for point symbols
  return style.SearchSymbolsAsync(StyleItemType.PointSymbol, searchString);
    now:
  if (style == null)
  return QueuedTask.Run(() => style.SearchSymbols(StyleItemType.PointSymbol, searchString));
How to search for line symbols in a style
    before:
public Task<IList<SymbolStyleItem>> GetLineSymbolsFromStyleAsync(StyleProjectItem style, string searchString)
  if (style == null)
  //Search for line symbols
  return style.SearchSymbolsAsync(StyleItemType.LineSymbol, searchString);
    now:
  if (style == null)
  return QueuedTask.Run(() => style.SearchSymbols(StyleItemType.LineSymbol, searchString));
How to search for polygon symbols in a style
    before:
public Task<IList<SymbolStyleItem>> GetPolygonSymbolsFromStyleAsync(StyleProjectItem style, string searchString)
  if (style == null)
  //Search for polygon symbols
  return style.SearchSymbolsAsync(StyleItemType.PolygonSymbol, searchString);
    now:
public async Task<IList<SymbolStyleItem>> GetPolygonSymbolsFromStyleAsync(StyleProjectItem style, string searchString)
  if (style == null)
  return await QueuedTask.Run(() => style.SearchSymbols(StyleItemType.PolygonSymbol, searchString));
How to search for colors in a style
    before:
public Task<IList<ColorStyleItem>> GetColorsFromStyleAsync(StyleProjectItem style, string searchString)
  if (style == null)
  //Search for colors
  return style.SearchColorsAsync(searchString);
    now:
public async Task<IList<ColorStyleItem>> GetColorsFromStyleAsync(StyleProjectItem style, string searchString)
  if (style == null)
  //Search for colors
  return await QueuedTask.Run(() => style.SearchColors(searchString));
How to search for color ramps in a style
    before:
public Task<IList<ColorRampStyleItem>> GetColorRampsFromStyleAsync(StyleProjectItem style, string searchString)
  //StyleProjectItem can be "ColorBrewer Schemes (RGB)", "ArcGIS 2D"...
  if (style == null)
  //Search for color ramps
  //Color Ramp searchString can be "Spectral (7 Classes)", "Pastel 1 (3 Classes)", "Red-Gray (10 Classes)"..
  return style.SearchColorRampsAsync(searchString);
    now:
public async Task<IList<ColorRampStyleItem>> GetColorRampsFromStyleAsync(StyleProjectItem style, string searchString)
  if (style == null)
  return await QueuedTask.Run(() => style.SearchColorRamps(searchString));
How to search for north arrows in a style
    before:
public Task<IList<NorthArrowStyleItem>> GetNorthArrowsFromStyleAsync(StyleProjectItem style, string searchString)
  if (style == null)
  //Search for north arrows
  return style.SearchNorthArrowsAsync(searchString);
    now:
  if (style == null)
  return QueuedTask.Run(() => style.SearchNorthArrows(searchString));
How to search for scale bars in a style
    before:
public Task<IList<ScaleBarStyleItem>> GetScaleBarsFromStyleAsync(StyleProjectItem style, string searchString)
  if (style == null)
  //Search for scale bars
  return style.SearchScaleBarsAsync(searchString);
    now:
  if (style == null)
  return QueuedTask.Run(() => style.SearchScaleBars(searchString));
How to search for label placements in a style
    before:
public Task<IList<LabelPlacementStyleItem>> GetLabelPlacementsFromStyleAsync(StyleProjectItem style, string searchString)
  if (style == null)
  //Search for standard label placement
  return style.SearchLabelPlacementsAsync(StyleItemType.StandardLabelPlacement, searchString);
    now:
  if (style == null)
  return QueuedTask.Run(() => style.SearchLabelPlacements(StyleItemType.StandardLabelPlacement, searchString));
How to apply a point symbol from a style to a feature layer
    before:
// var map = MapView.Active.Map;
// if (map == null)
//        return;
// var pointFeatureLayer =
//       map.GetLayersAsFlattenedList()
//          .OfType<FeatureLayer>()
//         .Where(fl => fl.ShapeType == esriGeometryType.esriGeometryPoint);
//   await ApplySymbolToFeatureLayerAsync(pointFeatureLayer.FirstOrDefault(), "Fire Station");
    public Task ApplySymbolToFeatureLayerAsync(FeatureLayer featureLayer, string symbolName)
        return QueuedTask.Run(async () =>
            //Get the ArcGIS 2D System style from the Project
            var arcGIS2DStyle = Project.Current.GetItems<StyleProjectItem>().FirstOrDefault(s => s.Name == "ArcGIS 2D");
            //Search for the symbolName style items within the ArcGIS 2D style project item.
            var items = await arcGIS2DStyle.SearchSymbolsAsync(StyleItemType.PointSymbol, symbolName);
            //Gets the CIMSymbol
            CIMSymbol symbol = items.FirstOrDefault().Symbol;
            //Get the renderer of the point feature layer
            CIMSimpleRenderer renderer = featureLayer.GetRenderer() as CIMSimpleRenderer;
            //Set symbol's real world setting to be the same as that of the feature layer
            symbol.SetRealWorldUnits(featureLayer.UsesRealWorldSymbolSizes);
            //Apply the symbol to the feature layer's current renderer
            renderer.Symbol = symbol.MakeSymbolReference();
            //Appy the renderer to the feature layer
            featureLayer.SetRenderer(renderer);
    now:
// if (map == null)
//        return;
          var items = await QueuedTask.Run(() => arcGIS2DStyle.SearchSymbols(StyleItemType.PointSymbol, symbolName));
How to apply a color ramp from a style to a feature layer
    before:
public async Task ApplyColorRampAsync(FeatureLayer featureLayer, string[] fields)
      Project.Current.GetItems<StyleProjectItem>().FirstOrDefault(s => s.Name == "ColorBrewer Schemes (RGB)");
    if (style == null) return;
    var colorRampList = await style.SearchColorRampsAsync("Red-Gray (10 Classes)");
    if (colorRampList == null || colorRampList.Count == 0) return;
    CIMColorRamp cimColorRamp = null;
    CIMRenderer renderer = null;
        cimColorRamp = colorRampList[0].ColorRamp;
        var rendererDef = new UniqueValueRendererDefinition(fields, null, cimColorRamp);
        renderer = featureLayer?.CreateRenderer(rendererDef);
        featureLayer?.SetRenderer(renderer);
    now:
    var colorRampList = await QueuedTask.Run(() => style.SearchColorRamps("Red-Gray (10 Classes)"));
Create a new map with a default basemap layer
    before:
var map = MapFactory.CreateMap(mapName, basemap: Basemap.ProjectDefault);
//TODO: use the map...
    now:
var map = MapFactory.Instance.CreateMap(mapName, basemap: Basemap.ProjectDefault);
Open a webmap
    before:
Map map = null;
//Assume we get the selected webmap from the Project pane's Portal tab
if (Project.Current.SelectedItems.Count > 0)
  if (MapFactory.CanCreateMapFrom(Project.Current.SelectedItems[0]))
    map = await MapFactory.CreateMapAsync(Project.Current.SelectedItems[0]);
    await ProApp.Panes.CreateMapPaneAsync(map);
    now:
Map map = null;
  if (MapFactory.Instance.CanCreateMapFrom(Project.Current.SelectedItems[0]))
    map = MapFactory.Instance.CreateMapFromItem(Project.Current.SelectedItems[0]);
Get Map Panes
    before:
public static IEnumerable<IMapPane> GetMapPanes() {
    //Sorted by Map Uri
    return ProApp.Panes.OfType<IMapPane>().OrderBy((mp) => mp.MapView.Map.URI ?? mp.MapView.Map.Name);
    now:
  //Sorted by Map Uri
Create and add a layer to the active map
    before:
* string url = @"c:\data\project.gdb\DEM";  //Raster dataset from a FileGeodatabase
* string url = @"c:\connections\mySDEConnection.sde\roads";  //FeatureClass of a SDE
* string url = @"c:\connections\mySDEConnection.sde\States\roads";  //FeatureClass within a FeatureDataset from a SDE
* string url = @"c:\data\roads.shp";  //Shapefile
* string url = @"c:\data\imagery.tif";  //Image from a folder
* string url = @"c:\data\mySDEConnection.sde\roads";  //.lyrx or .lpkx file
* string url = @"http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer";  //map service
* string url = @"http://sampleserver6.arcgisonline.com/arcgis/rest/services/NapervilleShelters/FeatureServer/0";  //FeatureLayer off a map service or feature service
string url = @"c:\data\project.gdb\roads";  //FeatureClass of a FileGeodatabase
Uri uri = new Uri(url);
await QueuedTask.Run(() => LayerFactory.CreateLayer(uri, MapView.Active.Map));
    now:
await QueuedTask.Run(() => LayerFactory.Instance.CreateLayer(uri, MapView.Active.Map));
Create a feature layer with class breaks renderer with defaults
    before:
  LayerFactory.CreateFeatureLayer(
    new Uri(@"c:\data\countydata.gdb\counties"),
    MapView.Active.Map,
    layerName: "Population Density (sq mi) Year 2010",
    rendererDefinition: new GraduatedColorsRendererDefinition("POP10_SQMI")
    now:
  LayerFactory.Instance.CreateFeatureLayer(
    MapView.Active.Map,
    before:
string colorBrewerSchemesName = "ColorBrewer Schemes (RGB)";
StyleProjectItem style = Project.Current.GetItems<StyleProjectItem>().First(s => s.Name == colorBrewerSchemesName);
string colorRampName = "Greens (Continuous)";
IList<ColorRampStyleItem> colorRampList = await style.SearchColorRampsAsync(colorRampName);
ColorRampStyleItem colorRamp = colorRampList[0];
  GraduatedColorsRendererDefinition gcDef = new GraduatedColorsRendererDefinition()
    ClassificationField = "CROP_ACR07",
    ClassificationMethod = ArcGIS.Core.CIM.ClassificationMethod.NaturalBreaks,
    BreakCount = 6,
    ColorRamp = colorRamp.ColorRamp,
    SymbolTemplate = SymbolFactory.ConstructPolygonSymbol(
                      ColorFactory.Green, SimpleFillStyle.Solid, null).MakeSymbolReference(),
    ExclusionClause = "CROP_ACR07 = -99",
    ExclusionSymbol = SymbolFactory.ConstructPolygonSymbol(
                      ColorFactory.Red, SimpleFillStyle.Solid, null).MakeSymbolReference(),
    ExclusionLabel = "No yield",
  LayerFactory.CreateFeatureLayer(new Uri(@"c:\Data\CountyData.gdb\Counties"),
      MapView.Active.Map, layerName: "Crop", rendererDefinition: gcDef);
    now:
IList<ColorRampStyleItem> colorRampList = await QueuedTask.Run(() =>
  return style.SearchColorRamps(colorRampName);
    BreakCount = 6,
    SymbolTemplate = SymbolFactory.Instance.ConstructPolygonSymbol(
                      ColorFactory.Instance.GreenRGB, SimpleFillStyle.Solid, null).MakeSymbolReference(),
    ExclusionSymbol = SymbolFactory.Instance.ConstructPolygonSymbol(
                      ColorFactory.Instance.RedRGB, SimpleFillStyle.Solid, null).MakeSymbolReference(),
  LayerFactory.Instance.CreateFeatureLayer(new Uri(@"c:\Data\CountyData.gdb\Counties"),
Set unique value renderer to the selected feature layer of the active map
    before:
  String[] fields = new string[] { "Type" }; //field to be used to retrieve unique values
  CIMPointSymbol pointSym = SymbolFactory.ConstructPointSymbol(
            ColorFactory.Green, 16.0, SimpleMarkerStyle.Pushpin);  //construting a point symbol as a template symbol
  CIMSymbolReference symbolPointTemplate = pointSym.MakeSymbolReference();
  //constructing rederer definition for unique value renderer
  UniqueValueRendererDefinition uniqueValueRendererDef = new UniqueValueRendererDefinition(fields, symbolPointTemplate);
  //creating a unique value renderer
  var flyr = MapView.Active.GetSelectedLayers()[0] as FeatureLayer;
  CIMUniqueValueRenderer uniqueValueRenderer = (CIMUniqueValueRenderer)flyr.CreateRenderer(uniqueValueRendererDef);
  //setting the renderer to the feature layer
  flyr.SetRenderer(uniqueValueRenderer);
    now:
  CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(
            ColorFactory.Instance.GreenRGB, 16.0, SimpleMarkerStyle.Pushpin);  //constructing a point symbol as a template symbol
  //constructing renderer definition for unique value renderer
Create a query layer
    before:
  Map map = MapView.Active.Map;
  Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri(@"C:\Connections\mySDE.sde")));
  CIMSqlQueryDataConnection sqldc = new CIMSqlQueryDataConnection()
    WorkspaceConnectionString = geodatabase.GetConnectionString(),
    GeometryType = esriGeometryType.esriGeometryPolygon,
    OIDFields = "OBJECTID",
    Srid = "102008",
    SqlQuery = "select * from MySDE.dbo.STATES"
  FeatureLayer flyr = (FeatureLayer)LayerFactory.CreateLayer(sqldc, map, layerName: "States");
    now:
    Srid = "102008",
  FeatureLayer flyr = (FeatureLayer)LayerFactory.Instance.CreateLayer(sqldc, map, layerName: "States");
Create a raster layer
    before:
string url = @"C:\Images\Italy.tif";
RasterLayer rasterLayer = (RasterLayer)LayerFactory.CreateLayer(new Uri(url), aMap);
    now:
  // Create a raster layer using a path to an image.
  // Note: You can create a raster layer from a url, project item, or data connection.
  rasterLayer = (RasterLayer)LayerFactory.Instance.CreateLayer(new Uri(url), aMap);
Update the raster colorizer on a raster layer
    before:
// Get the colorizer from the raster layer
CIMRasterColorizer rasterColorizer = rasterLayer.GetColorizer();
// Update raster colorizer properties
rasterColorizer.Brightness = 10;
rasterColorizer.Contrast = -5;
rasterColorizer.ResamplingType = RasterResamplingType.NearestNeighbor;
// Update the raster layer with the changed colorizer
rasterLayer.SetColorizer(rasterColorizer);
    now:
  // Get the colorizer from the raster layer.
  // Update raster colorizer properties.
  // Update the raster layer with the changed colorizer.
Update the RGB colorizer on a raster layer
    before:
CIMRasterColorizer rColorizer = rasterLayer.GetColorizer();
// Check if the colorizer is an RGB colorizer
if (rColorizer is CIMRasterRGBColorizer)
    CIMRasterRGBColorizer rasterRGBColorizer = (CIMRasterRGBColorizer)rColorizer;
    // Update RGB colorizer properties
    rasterRGBColorizer.StretchType = RasterStretchType.ESRI;
    rasterLayer.SetColorizer((CIMRasterColorizer)rasterRGBColorizer);
    now:
  // Check if the colorizer is an RGB colorizer.
    // Update RGB colorizer properties.
Create a mosaic layer
    before:
string url = @"C:\Images\countries.gdb\Italy";
MosaicLayer mosaicLayer = (MosaicLayer)LayerFactory.CreateLayer(new Uri(url), aMap);
    now:
MosaicLayer mosaicLayer = null;
  // Create a mosaic layer using a path to a mosaic dataset.
  // Note: You can create a mosaic layer from a url, project item, or data connection.
  mosaicLayer = (MosaicLayer)LayerFactory.Instance.CreateLayer(new Uri(url), aMap);
Update the sort order (mosaic method) on a mosaic layer
    before:
// Get the Image sub-layer of the mosaic
ImageServiceLayer mosaicImageSubLayer = (ImageServiceLayer)mosaicLayer.GetImageLayer();
// Get the mosaic rule
CIMMosaicRule mosaicingRule = mosaicImageSubLayer.GetMosaicRule();
// Set the Mosaic Method to Center
mosaicingRule.MosaicMethod = RasterMosaicMethod.Center;
// Update the mosaic with the changed mosaic rule
mosaicImageSubLayer.SetMosaicRule(mosaicingRule);
    now:
  // Get the image sub-layer from the mosaic layer.
  // Get the mosaic rule.
  // Set the Mosaic Method to Center.
  // Update the mosaic with the changed mosaic rule.
Update the resolve overlap (mosaic operator) on a mosaic layer
    before:
ImageServiceLayer mosaicImageSublayer = (ImageServiceLayer)mosaicLayer.GetImageLayer();
CIMMosaicRule mosaicRule = mosaicImageSublayer.GetMosaicRule();
// Set the Mosaic Operator to Mean
mosaicRule.MosaicOperatorType = RasterMosaicOperatorType.Mean;
mosaicImageSublayer.SetMosaicRule(mosaicRule);
    now:
  // Set the Mosaic Operator to Mean.
Create an image service layer
    before:
string url = @"http://imagery.arcgisonline.com/arcgis/services/LandsatGLS/GLS2010_Enhanced/ImageServer";
ImageServiceLayer isLayer = (ImageServiceLayer)LayerFactory.CreateLayer(new Uri(url), aMap);
    now:
ImageServiceLayer isLayer = null;
string url =
  // Create an image service layer using the url for an image service.
  isLayer = (ImageServiceLayer)LayerFactory.Instance.CreateLayer(new Uri(url), aMap);
Update the raster colorizer on an image service layer
    before:
// Get the colorizer from the image service layer
CIMRasterColorizer rasterColorizer = isLayer.GetColorizer();
// Update the colorizer properties
// Update the image service layer with the changed colorizer
isLayer.SetColorizer(rasterColorizer);
    now:
  // Get the colorizer from the image service layer.
  // Update the colorizer properties.
  // Update the image service layer with the changed colorizer.
Update the RGB colorizer on an image service layer
    before:
CIMRasterColorizer rColorizer = isLayer.GetColorizer();
    CIMRasterRGBColorizer rasterRGBColorizer = (CIMRasterRGBColorizer)isLayer.GetColorizer();
    isLayer.SetColorizer((CIMRasterColorizer)rasterRGBColorizer);
    now:
    // Cast colorizer type from CIMRasterColorizer to CIMRasterRGBColorizer.
Update the sort order (mosaic method) on an image service layer
    before:
// Get the mosaic rule of the image service
CIMMosaicRule mosaicRule = isLayer.GetMosaicRule();
mosaicRule.MosaicMethod = RasterMosaicMethod.Center;
// Update the image service with the changed mosaic rule
isLayer.SetMosaicRule(mosaicRule);
    now:
  // Get the mosaic rule of the image service.
  // Update the image service with the changed mosaic rule.
Update the resolve overlap (mosaic operator) on an image service layer
    before:
CIMMosaicRule mosaicingRule = isLayer.GetMosaicRule();
mosaicingRule.MosaicOperatorType = RasterMosaicOperatorType.Mean;
isLayer.SetMosaicRule(mosaicingRule);
    now:
Create a Heatmap Renderer
    before:
string colorBrewerSchemesName = "ArcGIS Colors";
string colorRampName = "Heat Map 4 - Semitransparent";
  //defining a heatmap renderer that uses values from Population field as the weights
  HeatMapRendererDefinition heatMapDef = new HeatMapRendererDefinition()
    Radius = 20,
    WeightField = "Population",
    RendereringQuality = 8,
    UpperLabel = "High Density",
    LowerLabel = "Low Density"
  FeatureLayer flyr = MapView.Active.Map.Layers[0] as FeatureLayer;
  CIMHeatMapRenderer heatMapRndr = (CIMHeatMapRenderer)flyr.CreateRenderer(heatMapDef);
  flyr.SetRenderer(heatMapRndr);
    now:
    Radius = 20,
Create an Unclassed Renderer
    before:
  CIMPointSymbol pointSym = SymbolFactory.ConstructPointSymbol(ColorFactory.GreenRGB, 16.0, SimpleMarkerStyle.Diamond);
  //defining an unclassed renderer with custom upper and lower stops
  //all features with value >= 5,000,000 will be drawn with the upper color from the color ramp
  //all features with value <= 50,000 will be drawn with the lower color from the color ramp
  UnclassedColorsRendererDefinition unclassRndrDef = new UnclassedColorsRendererDefinition
                        ("Population", symbolPointTemplate, colorRamp.ColorRamp, "Highest", "Lowest", 5000000, 50000);
  //drawing features with null values with a different symbol
  unclassRndrDef.ShowNullValues = true;
  unclassRndrDef.NullValueLabel = "Unknown";
  CIMPointSymbol nullSym = SymbolFactory.ConstructPointSymbol(ColorFactory.RedRGB, 16.0, SimpleMarkerStyle.Circle);
  unclassRndrDef.NullValueSymbol = nullSym.MakeSymbolReference();
  CIMClassBreaksRenderer cbRndr = (CIMClassBreaksRenderer)flyr.CreateRenderer(unclassRndrDef);
  flyr.SetRenderer(cbRndr);
    now:
  CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreenRGB, 16.0, SimpleMarkerStyle.Diamond);
    ShowNullValues = true,
  CIMPointSymbol nullSym = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB, 16.0, SimpleMarkerStyle.Circle);
Create a Proportion Renderer with max and min symbol size capped
    before:
  CIMPointSymbol pointSym = SymbolFactory.ConstructPointSymbol(ColorFactory.GreenRGB, 1.0, SimpleMarkerStyle.Circle);
  //minimum symbol size is capped to 4 point while the maximum symbol size is set to 50 point
  ProportionalRendererDefinition prDef = new ProportionalRendererDefinition("POPULATION", symbolPointTemplate, 4, 50, true);
  //setting upper and lower size stops to stop symbols growing or shrinking beyond those thresholds
  prDef.UpperSizeStop = 5000000;  //features with values >= 5,000,000 will be drawn with maximum symbol size
  prDef.LowerSizeStop = 50000;    //features with values <= 50,000 will be drawn with minimum symbol size
  CIMProportionalRenderer propRndr = (CIMProportionalRenderer)flyr.CreateRenderer(prDef);
  flyr.SetRenderer(propRndr);
    now:
  CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreenRGB, 1.0, SimpleMarkerStyle.Circle);
    UpperSizeStop = 5000000,  //features with values >= 5,000,000 will be drawn with maximum symbol size
    LowerSizeStop = 50000    //features with values <= 50,000 will be drawn with minimum symbol size
Create a True Proportion Renderer
    before:
  //Defining proportional renderer where size of symbol will be same as its value in field used in the renderer.
  ProportionalRendererDefinition prDef = new ProportionalRendererDefinition("POPULATION", esriUnits.esriMeters, symbolPointTemplate, SymbolShapes.Square, ValueRepresentations.Radius);
    now:
Enable labeling on a layer
    before:
var featureLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault();
ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() => {
    // toggle the label visibility
    featureLayer.SetLabelVisibility(!featureLayer.IsLabelVisible);
    now:
Access the display field for a layer
    before:
    // get the CIM definition from the layer
    var cimFeatureDefinition = featureLayer.GetDefinition() as ArcGIS.Core.CIM.CIMBasicFeatureLayer;
    // get the view of the source table underlying the layer
    var cimDisplayTable = cimFeatureDefinition.FeatureTable;
    // this field is used as the 'label' to represent the row
    var displayField = cimDisplayTable.DisplayField;
    now:
Find connected attribute field for rotation
    before:
    // get the CIM renderer from the layer
    var cimRenderer = featureLayer.GetRenderer() as ArcGIS.Core.CIM.CIMSimpleRenderer;
    // get the collection of connected attributes for rotation
    var cimRotationVariable = cimRenderer.VisualVariables.OfType<ArcGIS.Core.CIM.CIMRotationVisualVariable>().FirstOrDefault();
    // the z direction is describing the heading rotation
    var rotationInfoZ = cimRotationVariable.VisualVariableInfoZ;
    var rotationExpression = rotationInfoZ.Expression; // this expression stores the field name
    now:
Toggle "Scale layer symbols when reference scale is set"
    before:
    // get the CIM layer definition
    var cimFeatureLayer = featureLayer.GetDefinition() as ArcGIS.Core.CIM.CIMFeatureLayer;
    // turn on the option to scale the symbols in this layer based in the map's reference scale
    cimFeatureLayer.ScaleSymbols = true;
    now:
Set the layer cache
    before:
    // change the layer cache type to maximum age
    featureLayer.SetDisplayCacheType(ArcGIS.Core.CIM.DisplayCacheType.MaxAge);
    // change from the default 5 min to 2 min
    featureLayer.SetDisplayCacheMaxAge(TimeSpan.FromMinutes(2));
    now:
Change the layer selection color
    before:
    // get the CIM definition of the layer
    var layerDef = featureLayer.GetDefinition() as ArcGIS.Core.CIM.CIMBasicFeatureLayer;
    // disable the default symbol
    layerDef.UseSelectionSymbol = false;
    // assign a new color
    layerDef.SelectionColor = ColorFactory.RedRGB;
    // apply the definition to the layer
    featureLayer.SetDefinition(layerDef);
    if (!featureLayer.IsVisible) featureLayer.SetVisibility(true);
    //Do a selection
    MapView.Active.SelectFeatures(MapView.Active.Extent);
    now:
  layerDef.SelectionColor = ColorFactory.Instance.RedRGB;
  //Do a selection
MapExploration
Flash selected features
    before:
public Task FlashSelectedFeaturesAsync()
        //Get the active map view.
        var mapView = MapView.Active;
        if (mapView == null)
            return;
        //Get the selected features from the map and filter out the standalone table selection.
        var selectedFeatures = mapView.Map.GetSelection()
            .Where(kvp => kvp.Key is BasicFeatureLayer)
            .ToDictionary(kvp => (BasicFeatureLayer) kvp.Key, kvp => kvp.Value);
        //Flash the collection of features.
        mapView.FlashFeature(selectedFeatures);
    now:
      return;
              .ToDictionary(kvp => (BasicFeatureLayer)kvp.Key, kvp => kvp.Value);
Show a custom pop-up
    before:
public void ShowCustomPopup()
        return;
    //Create custom popup content
    var popups = new List<PopupContent>();
    popups.Add(new PopupContent("<b>This text is bold.</b>", "Custom tooltip from HTML string"));
    popups.Add(new PopupContent(new Uri("https://www.esri.com/"), "Custom tooltip from Uri"));
    mapView.ShowCustomPopup(popups);
    now:
    return;
            new PopupContent("<b>This text is bold.</b>", "Custom tooltip from HTML string"),
Project camera into a new spatial reference
    before:
public Task<Camera> ProjectCamera(Camera camera, ArcGIS.Core.Geometry.SpatialReference spatialReference)
        var mapPoint = MapPointBuilder.CreateMapPoint(camera.X, camera.Y, camera.Z, camera.SpatialReference);
        var newPoint = GeometryEngine.Project(mapPoint, spatialReference) as MapPoint;
        var newCamera = new Camera()
            X = newPoint.X,
            Y = newPoint.Y,
            Z = newPoint.Z,
            Scale = camera.Scale,
            Pitch = camera.Pitch,
            Heading = camera.Heading,
            Roll = camera.Roll,
            Viewpoint = camera.Viewpoint,
            SpatialReference = spatialReference
        return newCamera;
    now:
    var newPoint = GeometryEngine.Instance.Project(mapPoint, spatialReference) as MapPoint;
      X = newPoint.X,
      Y = newPoint.Y,
      Z = newPoint.Z,
      Roll = camera.Roll,
    return newCamera;
Graphic Overlay
    before:
public async void GraphicOverlaySnippetTest()
    // get the current mapview and point
        return;
    var myextent = mapView.Extent;
    var point = myextent.Center;
    // add point graphic to the overlay at the center of the mapView
    var disposable = await QueuedTask.Run(() =>
        //add these to the overlay
        return mapView.AddOverlay(point,
                      ColorFactory.RedRGB, 30.0, SimpleMarkerStyle.Star).MakeSymbolReference());
    // update the overlay with new point graphic symbol
    MessageBox.Show("Now to update the overlay...");
        mapView.UpdateOverlay(disposable, point, SymbolFactory.ConstructPointSymbol(
                          ColorFactory.BlueRGB, 20.0, SimpleMarkerStyle.Circle).MakeSymbolReference());
    // clear the overlay display by disposing of the graphic
    MessageBox.Show("Now to clear the overlay...");
    disposable.Dispose();
    now:
    return;
                      ColorFactory.Instance.RedRGB, 30.0, SimpleMarkerStyle.Star).MakeSymbolReference());
    mapView.UpdateOverlay(disposable, point, SymbolFactory.Instance.ConstructPointSymbol(
                                  ColorFactory.Instance.BlueRGB, 20.0, SimpleMarkerStyle.Circle).MakeSymbolReference());
Change symbol for a sketch tool
    before:
internal class SketchTool_WithSymbol : MapTool
    public SketchTool_WithSymbol()
        IsSketchTool = true;
        SketchOutputMode = SketchOutputMode.Map; //Changing the Sketch Symbol is only supported with map sketches.
        SketchType = SketchGeometryType.Rectangle;
    protected override Task OnToolActivateAsync(bool hasMapViewChanged)
            //Set the Sketch Symbol if it hasn't already been set.
            if (SketchSymbol != null)
                return;
            var polygonSymbol = SymbolFactory.ConstructPolygonSymbol(ColorFactory.CreateRGBColor(24, 69, 59),
                SymbolFactory.ConstructStroke(ColorFactory.BlackRGB, 1.0, SimpleLineStyle.Dash));
            SketchSymbol = SymbolFactory.MakeSymbolReference(polygonSymbol);
    now:
        return;
      var polygonSymbol = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.CreateRGBColor(24, 69, 59),
                      SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlackRGB, 1.0, SimpleLineStyle.Dash));
      SketchSymbol = polygonSymbol.MakeSymbolReference();
Tasks
Retrieve all the Task Items in a Project
    before:
IEnumerable<TaskProjectItem> tasks = Project.Current.GetItems<TaskProjectItem>();
foreach (var task in tasks)
  // do something
    now:
IEnumerable<TaskProjectItem> taskItems = Project.Current.GetItems<TaskProjectItem>();
foreach (var item in taskItems)
  // do something
Open a Project Task Item
    before:
// get the first project task item
var taskItem = Project.Current.GetItems<TaskProjectItem>().FirstOrDefault();
// if there isn't a project task item, return
if (taskItem == null)
  return;
try
  // Open it
  System.Guid guid = await TaskAssistantModule.OpenTaskItemAsync(taskItem.TaskGuid);
  // TODO - retain the guid returned for use with CloseTaskAsync
catch (OpenTaskException e)
  ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(e.Message);
    now:
  return;
try
  // Open it
  System.Guid guid = await TaskAssistantModule.OpenTaskItemAsync(taskItem.TaskItemGuid);
Close a Task Item
    before:
// find the first project task item which is open
var taskItem = Project.Current.GetItems<TaskProjectItem>().FirstOrDefault(t => t.IsOpen == true);
  return;
// close it
// NOTE : The task item will also be removed from the project
TaskAssistantModule.CloseTaskAsync(taskItem.TaskGuid);
    now:
  return;
// close it
TaskAssistantModule.CloseTaskAsync(taskItem.TaskItemGuid);
Export a Task Item
    before:
  return;
try
  // export the task item to the c:\Temp folder
  string fileName = await TaskAssistantModule.ExportTaskAsync(taskItem.TaskGuid, @"c:\temp");
  ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show("Task saved to " + fileName);
catch (ExportTaskException e)
  ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show("Error saving task " + e.Message);
    now:
  return;
try
  string fileName = await TaskAssistantModule.ExportTaskAsync(taskItem.TaskItemGuid, @"c:\temp");
Sharing
ArcGISPortalManager: Get a portal and Sign In, Set it Active
    before:
//Find the portal to sign in with using its Uri...
var portal = ArcGISPortalManager.Current.GetPortal(new Uri(uri, UriKind.Absolute));
if (!portal.IsSignedOn()) {
    //Calling "SignIn" will trigger the OAuth popup if your credentials are
    //not cached (eg from a previous sign in in the session)
    if (portal.SignIn().success) {
        //Set this portal as my active portal
        ArcGISPortalManager.Current.SetActivePortal(portal);
    now:
EsriHttpClient: Get the Current signed on User
    before:
//Reference Newtonsoft - Json.Net
  //Reference System.Net.Http
UriBuilder selfURL = new UriBuilder(PortalManager.GetActivePortal());
selfURL.Path = "sharing/rest/portals/self";
selfURL.Query = "f=json";
EsriHttpResponseMessage response = new EsriHttpClient().Get(selfURL.Uri.ToString());
dynamic portalSelf = JObject.Parse(await response.Content.ReadAsStringAsync());
// if the response doesn't contain the user information then it is essentially
// an anonymous request against the portal
if (portalSelf.user == null)
    return;
string userName = portalSelf.user.username;
    now:
UriBuilder selfURL = new UriBuilder(ArcGISPortalManager.Current.GetActivePortal().PortalUri)
  Path = "sharing/rest/portals/self",
  Query = "f=json"
    return;
Get the Groups for the Current Signed on User
    before:
//Assume that you have executed the "Get the Current signed on User" snippet and have 'userName'
UriBuilder groupsURL = new UriBuilder(PortalManager.GetActivePortal());
groupsURL.Path = String.Format("sharing/rest/community/users/{0}", userName);
groupsURL.Query = "f=json";
var groupResponse = new EsriHttpClient().Get(groupsURL.Uri.ToString());
dynamic portalGroups = JObject.Parse(await groupResponse.Content.ReadAsStringAsync());
string groups = portalGroups.groups.ToString();
    now:
UriBuilder groupsURL = new UriBuilder(ArcGISPortalManager.Current.GetActivePortal().PortalUri)
  Path = String.Format("sharing/rest/community/users/{0}", userName),
  Query = "f=json"
EsriHttpClient: Query for esri content on the active Portal
    before:
//http://www.arcgis.com/sharing/search?q=owner:esri&f=json
UriBuilder searchURL = new UriBuilder(PortalManager.GetActivePortal());
searchURL.Path = "sharing/rest/search";
searchURL.Query = "q=owner:esri&f=json";
EsriHttpClient httpClient = new EsriHttpClient();
var searchResponse = httpClient.Get(searchURL.Uri.ToString());
dynamic resultItems = JObject.Parse(await searchResponse.Content.ReadAsStringAsync());
long numberOfTotalItems = resultItems.total.Value;
long currentCount = 0;
List<dynamic> resultItemList = new List<dynamic>();
// store the first results in the list
resultItemList.AddRange(resultItems.results);
currentCount = currentCount + resultItems.num.Value;
//Up to 50
while (currentCount < numberOfTotalItems && currentCount <= 50) {
    searchURL.Query = String.Format("q=owner:esri&start={0}&f=json", resultItems.nextStart.Value);
    now:
UriBuilder searchURL = new UriBuilder(ArcGISPortalManager.Current.GetActivePortal().PortalUri)
  Path = "sharing/rest/search",
//Up to 50
EsriHttpClient: Get a Web Map for the Current User and Add it to Pro
    before:
searchURL.Path = "sharing/rest/portals/self";
searchURL.Query = "f=json";
EsriHttpResponseMessage response = httpClient.Get(searchURL.Uri.ToString());
    return;
string webMaps = "(type:\"Web Map\" OR type:\"Explorer Map\" OR type:\"Web Mapping Application\" OR type:\"Online Map\")";
searchURL.Query = string.Format("q=owner:{0} {1}&f=json", userName, webMaps);
if (numberOfTotalItems == 0)
    return;
//get the first result
dynamic item = resultItemList[0];
string itemID = item.id;
Item currentItem = ItemFactory.Create(itemID, ItemFactory.ItemType.PortalItem);
if (MapFactory.CanCreateMapFrom(currentItem)) {
    Map newMap = await MapFactory.CreateMapAsync(currentItem);
    await ProApp.Panes.CreateMapPaneAsync(newMap);
    now:
  Query = "f=json"
    return;
    return;
Item currentItem = ItemFactory.Instance.Create(itemID, ItemFactory.ItemType.PortalItem);
if (MapFactory.Instance.CanCreateMapFrom(currentItem)) {
    Map newMap = MapFactory.Instance.CreateMapFromItem(currentItem);
EsriHttpClient: Get a Service Layer and Add it to Pro
    before:
string layers = "(type:\"Map Service\" OR type:\"Image Service\" OR type:\"Feature Service\" OR type:\"WMS\" OR type:\"KML\")";
//any public layer content
searchURL.Query = string.Format("q={0}&f=json", layers);
    return;
await QueuedTask.Run(async () => {
    // if we have an item that can be turned into a layer
    // add it to the map
    if (LayerFactory.CanCreateLayerFrom(currentItem))
        LayerFactory.CreateLayer(currentItem, MapView.Active.Map);
    now:
    return;
  if (LayerFactory.Instance.CanCreateLayerFrom(currentItem))
    LayerFactory.Instance.CreateLayer(currentItem, MapView.Active.Map);
